08-24-2020, 14:34 | #33 (permalink) |
No Life Poster Join Date: Dec 2012 Location: Khushab Punjab Pakistan
Member: 1857951 Status: Offline Sonork: 100.1638512 Thanks Meter: 261 | Jazz Digit 4G Flashing Error............. Operation : Write Flash [ v2.15 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :17 [FL] : Set : preloader_fise6731_kaie_s_e_k.bin [FL] : Set : recovery.img [FL] : Set : md1rom.img [FL] : Set : md1dsp.img [FL] : Set : spmfw.img [FL] : Set : mcupmfw.img [FL] : Set : lk.bin [FL] : Set : lk.bin [FL] : Set : loader_ext.img [FL] : Set : loader_ext.img [FL] : Set : boot.img [FL] : Set : logo.bin [FL] : Set : tz.img [FL] : Set : tz.img [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0x177DDEB8 [ 375.87 MB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM Port (COM6) MODE : PRELOADER PORT PORT : 6 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x02 BROM : PRELOADER PORT MODE : BQ : SEC_6739 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x20000000 [ 512.00 MB ] EMMC: 150100464A3235414202418EAAFF533F EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FJ25AB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0xE9000000 [ 3.64 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 8AC9529522FDFDD3F7EF1505F8769586 DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000002E88000 Erase : 0x0000000003688000 : 0x0000000004000000 Erase : 0x0000000008800000 : 0x0000000000A00000 Erase : 0x0000000009500000 : 0x0000000007200000 Erase : 0x0000000010C00000 : 0x0000000000200000 Erase : 0x0000000010E20000 : 0x00000000D79DBE00 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Update bootloader backup copy ... Update bootloader backup copy Ok! Write : RECOVERY FAIL : SEC : PUBK AUTH MISMATCH N ERR : 0xC002001B ERR : SEC : PUBK AUTH MISMATCH N ERR : 0x0088FE70|0x0088FE70 Error : Flashing failed! >>> Seems as something wrong with device! Check battery charge and device state! Reconnect Power/Cable! |
08-24-2020, 15:01 | #35 (permalink) |
Freak Poster Join Date: Nov 2016
Member: 2649950 Status: Offline Thanks Meter: 33 | Operation : Identify [ v2.15 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM34) MODE : BOOTROM PORT : 34 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT8163 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2028 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT8163 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 4D000115463847421515F64207CF3B4D DAInf: 4 : 2 : 161 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 1501004D4247384642F615154D3BCF07 NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 DRAM : 0x0178 EMI : DEV : MT6752 EMI : SRC : preloader_joyasz6580_we_n.bin EMI : CNT : 0001 INIT : 0xBC : DRAM [ 0x00000000 : [ 0 B ] ] DA : Failed to configure DA! ERROR : 00000BC4 : DEVICE NOT FOUND Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.15 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM42) MODE : PRELOADER PORT PORT : 42 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT8163 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT MODE : 0_base : BASE_v2028 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT8163 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00002001 : DA SEND ERROR! ERROR : SECURE BOOT : MISMATCH BOOT SIGNATURE! INFO : PRELOADER Level : Connect device in BROM mode! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
08-24-2020, 15:10 | #37 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. I not see reasons why it not should for models, which have preloader support ( not need brom-auth with xiaomi sign ) RM8 Pro require boot unlock and open loader flashing. I've posted in my thread about RMN 8 pro and ufs test update. Note 9, if not wrong, not require open preloader, since it work as it ( according users test ) and UltraFlashing may flash anything inside. But, here can be preloader anti roll-back. We will check that, if sample will be on hands. anyway - flashing try without pre-erase may help to check it without damage device, better not touch preloader too to avoid brick. |
The Following 6 Users Say Thank You to JayDi For This Useful Post: |
08-24-2020, 15:11 | #38 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
08-24-2020, 15:13 | #40 (permalink) | |
Right now use PRELOADER mode instead. | |
The Following 2 Users Say Thank You to JayDi For This Useful Post: |
08-24-2020, 15:16 | #42 (permalink) | |
Ultraflashing, introduced in our previous update - allow now flash them without any original da, signatures or whatever else. Just need select correct model in software or brand and do the work. If SW ask use bromv - use it, if sw ask other type - select it. Inside lot of pre-defined da and other, and they are NOT end in model list. Under Identify button exists special selector for MODE-SPECIFIED agents. | |
The Following 3 Users Say Thank You to JayDi For This Useful Post: |
08-24-2020, 15:19 | #43 (permalink) | |
About issue of not active ultraflash - yes, will be optimized for cheap phones, but very later. It made for anti-sniff protection. | |
08-24-2020, 15:21 | #44 (permalink) | |
BTW - you had selected as EMI preloader from MT6580. Will add checking for that too in next versions. | |
