01-27-2021, 09:26 | #436 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Algeria
Member: 56090 Status: Offline Thanks Meter: 162 | CPU Dual core 2.40ghz Ram 2go Multiple H.D System installed is XP 32bits pack 3 CM2MT2 launch normally just first untick read only and hiden this folder (MM) or creat batch file in desktop with following command: attrib -h -r /s /d F:\InfinityBox\CM2MT2\phdata\MM\*.* start F:\InfinityBox\CM2MT2\CM2MT2.exe Salam |
01-27-2021, 11:29 | #437 (permalink) |
Junior Member Join Date: Dec 2020 Location: pakistan
Member: 2974988 Status: Offline Thanks Meter: 0 | MT2 and SP2 , it's just blink and disappear, i did full scan, delete folder on c"\infinity and re-install again, but still no avail (i did all steps mentioned there forum dot gsmhosting dot com) i think its time to move some better box or dongle . |
01-27-2021, 12:52 | #440 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
Another good idea - configure your PC for WORK but not for minecraft. Now please follow this solution https://www.infinity-box.com/support/?r=100127 What is your results dear friend ? | |
01-27-2021, 13:01 | #441 (permalink) |
Junior Member Join Date: Jul 2020 Location: India
Member: 2963525 Status: Offline Thanks Meter: 4 | Redmi Note 8 Pro HW Report Code: Operation : HW Report [ v2.18 ] HWreport : Mode : UFS 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM35) MODE : BOOTROM PORT : 35 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Krug TYPE : MODERN RAPHAEL BROM : MEID : 82F57CC5AE37B9ADC91CC13CACA2347D BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2028 | Manual : Disabled BROM : SOCID : D322276958CD842B007940DCA6E96D885CB2F0AB7C16689F0B4790D282066166 BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6785 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x180000000 [ 6.00 GB ] UFS: CE014B4D324837303031434D2D423531 UFS: VEN : 0x01CE VID : KM2H7001CM-B51 IFW : 0600 LU0 : 0x00400000 [ 4.00 MB ] LU1 : 0x00400000 [ 4.00 MB ] LU2 : 0xEE5800000 [ 59.59 GB ] FSN : 00330061003800300035003400340030 REG : 0x101010000 CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 5DB73902A0F05845E018D3BD986386E9 DA : USB : HIGH-SPEED Boot done! Memory Info : CID : KM2H7001CM-B518 EXT_CSD Info : [UFS] Device Desc: [UFS] String Desc: Serial Number INDEX 2, LENGTH 24 [UFS] Serial Number: 003300610038003000350034003400300038006300310064 [UFS] life cycle check, pre_eol_info=1, life_time_est_a=1, life_time_est_b=1 [UFS] vendor id : 0x1ce [UFS] ufs id : KM2H7001CM-B518 [UFS] ufs fwver: 0600 [UFS] dev_quirk = 0x0 [UFS] Custom force provison=0, TW size=-1GB, TW no red=1, HPB size=-1GB [UFS] info: number of active LU: 3, check OK. [UFS] info: number of Boot LU: 2, check OK. [UFS] info: LU Configuration Check OK. Bootable UFS [UFS] info: Boot LU Configuration Check OK. Active Boot LU: LU0 [UFS] warn: Power on, reset, or bus device reset occupied [UFS] Sense Data: ASC=29, ASCQ=0 [UFS] warn: Power on, reset, or bus device reset occupied [UFS] Sense Data: ASC=29, ASCQ=0 [UFS] warn: Power on, reset, or bus device reset occupied [UFS] Sense Data: ASC=29, ASCQ=0 [UFS] warn: Power on, reset, or bus device reset occupied [UFS] Sense Data: ASC=29, ASCQ=0 [UFS] info: HS-G3-2 Overall status : MLC status : 0% - 10% used SLC status : 0% - 10% used EOL status : Normal ( Less than 80% reserved blocks used ) RPMB : RPMB KEY NOT set! [State : CLEAN : USABLE] Done! Elapsed: 00:00:29 |
The Following 2 Users Say Thank You to Thalamahes For This Useful Post: |
01-27-2021, 13:43 | #442 (permalink) |
No Life Poster Join Date: May 2007 Location: india
Member: 500302 Status: Offline Thanks Meter: 157 | realme c2 unlock done...............grate infinity wow............................................... ... Operation : Reset Settings/Format FS [ v2.18 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM15) MODE : BOOTROM PORT : 15 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : E397CA8E49C22A803BF9864958A09ADE BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 068D5DD91717530B6437142D85EADD750B925BA2B687BD103D E3867FFD363104 BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0002 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 90014A484147346132A51D6628044605 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HAG4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 61910C0698D9B10BF3D41FCF1A3D2C9 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x815757 Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:34 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to Wasim007 For This Useful Post: |
01-27-2021, 17:01 | #445 (permalink) |
Product Supporter Join Date: Jun 2010 Location: Infinity Team support
Member: 1330296 Status: Offline Thanks Meter: 1,137 | Dear Sirs, Latest important MTK drivers ! Support area -> /drivers/Drivers_MTK_v2.0.1.1.7z Do you forgot password for drivers ? Oh... No... Don't tell me you forgot password 12345678 Last edited by YellowBoss; 01-27-2021 at 17:15. |
The Following 4 Users Say Thank You to Infinity-BEST For This Useful Post: |
01-27-2021, 21:08 | #446 (permalink) |
No Life Poster Join Date: Jun 2003 Location: somewhere Age: 40
Member: 31028 Status: Offline Thanks Meter: 56 | Operation : Identify [ v2.18 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM291) MODE : PRELOADER PORT PORT : 291 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.18 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM291) MODE : PRELOADER PORT PORT : 291 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Huawei y5 2019 (amn-lx9) i am new to cm2mt2 what setting? how to connect, just insert usb cable or volume - and insert cable? best regards |
01-27-2021, 21:35 | #447 (permalink) | |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Quote:
The Following User Says Thank You to Yusuf Lawal For This Useful Post: |
01-27-2021, 22:08 | #450 (permalink) |
Member: 31028 Status: Offline Thanks Meter: 56 | progress Error : Fail to init protocol! >>> Internal EMI : Select other EMI number! External Preloader - make sure it correct for connected device! Reconnect Power/Cable! Operation : Identify [ v2.18 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM5) MODE : BOOTROM PORT : 5 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN RAPHAEL BROM : MEID : 72DCCE974F6A7F968E025BDB5640F48A BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Huawei : Y5_AMN-XXX | Manual : Disabled BROM : SOCID : 22DE1A305D1A7C4D8DB6A16F1F7B9247CD1AF90FC5AFCB5E71 23A0A8DA965A71 BROM : LOG : F0: 102B 0000 F3: 0000 0000 [0200] V0: 0000 0000 [0001] BROM : SLA : Sending Auth BROM : SLA : Auth accepted! BROM : SLA : CHALLENGE not used AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6765 EMI : SRC : preloader_k62v1_64_mexico.bin EMI : CNT : 000E EMI : [00] : eMMC : DDR3 : ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 3,00 GB ] EMI : [01] : eMMC : DDR3 : ID : 13014E53304A394237 : VEN : MICRON | DEV : S0J9B7 : RAM : [ 3,00 GB ] EMI : [02] : eMMC : DDR3 : ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 2,00 GB ] EMI : [03] : eMMC : DDR3 : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 3,00 GB ] EMI : [04] : eMMC : DDR3 : ID : 90014A484347386134 : VEN : HYNIX | DEV : HCG8a4 : RAM : [ 4,00 GB ] EMI : [05] : eMMC : DDR3 : ID : 150100514536334D42 : VEN : SAMSUNG | DEV : QE63MB : RAM : [ 2,00 GB ] EMI : [06] : eMMC : DDR3 : ID : 150100514436334D42 : VEN : SAMSUNG | DEV : QD63MB : RAM : [ 2,00 GB ] EMI : [07] : eMMC : DDR3 : ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3,00 GB ] EMI : [08] : eMMC : DDR3 : ID : 150100475036424D42 : VEN : SAMSUNG | DEV : GP6BMB : RAM : [ 3,00 GB ] EMI : [09] : eMMC : DDR3 : ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4,00 GB ] EMI : [0A] : eMMC : DDR3 : ID : 13014E53304A394137 : VEN : MICRON | DEV : S0J9A7 : RAM : [ 2,00 GB ] EMI : [0B] : eMMC : DDR3 : ID : 13014E53304A394638 : VEN : MICRON | DEV : S0J9F8 : RAM : [ 4,00 GB ] EMI : [0C] : eMMC : DDR3 : ID : 13014E53304A394E38 : VEN : MICRON | DEV : S0J9N8 : RAM : [ 4,00 GB ] EMI : [0D] : eMMC : LP_DDR4X : ID : 90014A484347386134 : VEN : HYNIX | DEV : HCG8a4 : RAM : [ 4,00 GB ] EMI : Init EMI from PRELOADER DA : SETUP EMI PARAMS FAILED! ERROR : EMI SETTING VERSION ERROR Error : Fail to init protocol! >>> Internal EMI : Select other EMI number! External Preloader - make sure it correct for connected device! Reconnect Power/Cable! |
