11-08-2016, 20:05 | #94 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Bogotá Colombia Age: 43
Member: 150844 Status: Offline Thanks Meter: 309 | Alcatel OT 5065N unsupported Code: Infinity-Box Qualcomm Module [QLM] v 1.02 Operation : Identify [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] ID_BLOCK_S : 066DC750 ID_BLOCK_I : 009600E1 ID_BLOCK_L : D3042F7F462740DE ID_BLOCK_L : FE2578B2C93F1C77 Use CM2 Internal Loader Error : Prepare target failed! Unsupported CPU??? Send log and report.log to support! Include device info also! Reconnect Power/Cable! Operation : Reset Settings [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] ID_BLOCK_S : 066DC750 ID_BLOCK_I : 009600E1 ID_BLOCK_L : D3042F7F462740DE ID_BLOCK_L : FE2578B2C93F1C77 Use CM2 Internal Loader Error : Prepare target failed! Unsupported CPU??? Send log and report.log to support! Include device info also! Reconnect Power/Cable! Operation : Read Flash [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Error : Fail to init protocol! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Read Flash [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] ID_BLOCK_S : 066DC750 ID_BLOCK_I : 009600E1 ID_BLOCK_L : D3042F7F462740DE ID_BLOCK_L : FE2578B2C93F1C77 Use CM2 Internal Loader Error : Prepare target failed! Unsupported CPU??? Send log and report.log to support! Include device info also! |
11-08-2016, 20:28 | #95 (permalink) |
Freak Poster Join Date: Feb 2009 Location: lake
Member: 983215 Status: Offline Thanks Meter: 49 | kyocera C6740n frp Operation : Identify [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0DA799E3 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 00C22A60E316CE61 ID_BLOCK_L : 7233E4F9729BE47B Use CM2 Internal Loader Error : Prepare target failed! Unsupported CPU??? Send log and report.log to support! Include device info also! Reconnect Power/Cable! Smart phone info; kyocera c6740n OS: Android (5.1) System chip: Qualcomm Snapdragon 410 8916 Processor: Quad-core, 1200 MHz, ARM Cortex-A53, 64-bit Graphics processor: Adreno 306 System memory: 1 GB RAM Built-in storage: 8 GB |
11-08-2016, 20:42 | #96 (permalink) |
No Life Poster Join Date: Nov 2007 Location: in the web Age: 41
Member: 630907 Status: Offline Thanks Meter: 127 | ZTE blade A460 not support¡¡ Hi, try read info and read firmware this zte blade A460 but not worck: Code: Card found : S/N : 5F5XXXX , v0134 Infinity-Box Qualcomm Module [QLM] v 1.02 Operation : Identify [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] ID_BLOCK_S : 01370DB3 ID_BLOCK_I : 009600E1 ID_BLOCK_L : 171794BA2C7013D9 ID_BLOCK_L : 2B0B32CB2B516737 Use CM2 Internal Loader Error : Prepare target failed! Unsupported CPU??? Send log and report.log to support! Include device info also! Reconnect Power/Cable! Operation : Read Flash [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] ID_BLOCK_S : 01370DB3 ID_BLOCK_I : 009600E1 ID_BLOCK_L : 171794BA2C7013D9 ID_BLOCK_L : 2B0B32CB2B516737 Use CM2 Internal Loader Error : Prepare target failed! Unsupported CPU??? Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
11-08-2016, 23:32 | #99 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | @erocelmaster, some ZTE will be in next update. This one - too. @viniicell, kyocera, unfortunately - not in near time. @bananin, will be added in v1.04 or v1.05. @crisss, will be enabled in v1.06. |
11-09-2016, 02:43 | #100 (permalink) |
Member: 150844 Status: Offline Thanks Meter: 309 | Avvio L500 Operation : Identify [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_S : 063BB300 ID_BLOCK_I : 008050E1 ID_BLOCK_L : 49C762F6FE52E492 ID_BLOCK_L : 9B939302A85331CC Use CM2 Internal Loader Error : Prepare target failed! Unsupported CPU??? Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
11-09-2016, 02:54 | #101 (permalink) |
Member: 150844 Status: Offline Thanks Meter: 309 | Motorola moto e xt1022 Operation : Identify [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x10] ID_BLOCK_S : 03902D7B ID_BLOCK_I : 008110E1 ID_BLOCK_L : 4B3F316ED227970E ID_BLOCK_L : 9B3F23E6A0BB0122 Use CM2 Internal Loader Error : Prepare target failed! Unsupported CPU??? Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
