11-11-2016, 04:58 | #121 (permalink) |
Insane Poster Join Date: Apr 2009
Member: 1006072 Status: Offline Thanks Meter: 1 | Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 128318CB ID_BLOCK_I : 007050E1 ID_BLOCK_L : 49C762F6FE52E492 ID_BLOCK_L : 9B939302A85331CC Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , VER : 1 ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Files in Chain : 26 Flashing now Flashing : gpt_main0.bin Flashing : NON-HLOS.bin Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : hyp.mbn Flashing : hyp.mbn Flashing : splash.img Flashing : sec.dat Flashing : boot.img Flashing : system.img Flashing : cache.img Flashing : persist.img Flashing : recovery.img Flashing : userdata.img Flashing : gpt_backup0.bin Flashing done! Done! Elapsed: 00:02:35 Reconnect Power/Cable! Loading firmware ... Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : Xiaomi Device Manufact.: Xiaomi Device Model : wt88047 Device CPU : MSM8916 Device IntName : wt88047 Device Version : 5.1.1 CU_SWVer : Xiaomi Device Compile : 10/9/2016 7:04:40 AM Device ExtInfo : wt88047 Load Ok! ,,i want to try refllash extra data but how ?? |
11-11-2016, 09:03 | #123 (permalink) |
Freak Poster Join Date: Jan 2012 Location: On Earth
Member: 1716439 Status: Offline Thanks Meter: 38 | Need help,have sam g360f(msm8916) based, need to read or reset user code patten. made a EDL xiaomi cable with this can detect qualcomm hs-usb qdloader 9008 port, but software donīt conect it |
11-11-2016, 10:20 | #124 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,353 | Quote:
For connect need install correct driver. CM2 not work with 9008 port, only emergency or QHSUSB_BULK. Drivers on support. | |
11-11-2016, 14:54 | #128 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Slovakia Age: 40
Member: 17405 Status: Offline Thanks Meter: 345 | Modena E501 Qualcomm MSM8916 Snapdragon 410 Hang on: 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... |
11-11-2016, 15:20 | #129 (permalink) |
Member: 17405 Status: Offline Thanks Meter: 345 | Modena E501 - 2 Or Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 12A8F899 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 020DEB74624DF230 ID_BLOCK_L : 5EB32D15BA19C30D Use CM2 Internal Loader Error : Prepare target failed! Unsupported CPU??? Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
11-11-2016, 15:40 | #131 (permalink) | |
11-12-2016, 02:52 | #134 (permalink) | |
Member: 1006072 Status: Offline Thanks Meter: 1 | Quote:
problem solved,, can you help me in this link sir http://forum.gsmhosting.com/vbb/f296...ck-up-2152109/ | |
