11-09-2016, 10:23 | #108 (permalink) |
No Life Poster Join Date: Jun 2007 Location: India
Member: 523972 Status: Offline Sonork: 100.1596548 Thanks Meter: 1,259 | Lenovo Vibe K5 Plus A6020A46 Lenovo Vibe K5 Plus A6020A46 Card found :v0134 Infinity-Box Qualcomm Module [QLM] v 1.02 Operation : Identify [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Identify [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_S : 07BAF11E ID_BLOCK_I : 0090B0E1 ID_BLOCK_L : 975D31BA47C23F3B ID_BLOCK_L : A7DF2E1BD07AD60F Use CM2 Internal Loader Error : Prepare target failed! Unsupported CPU??? Send log and report.log to support! Include device info also! Reconnect Power/Cable! B.R., B.Uttam |
11-09-2016, 11:31 | #109 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,036 | CoolPad Modena / E510 / Y76 Phone is domestic sold: With Specs like here. Advertised like supported in initial release, but in fact i face: Code: Operation : Identify [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0F03EF99 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 020DEB74624DF230 ID_BLOCK_L : 5EB32D15BA19C30D Use CM2 Internal Loader Error : Prepare target failed! Unsupported CPU??? Send log and report.log to support! Include device info also! Reconnect Power/Cable! Position initialy is closed D+ to GND and opening it start recognition process ... Due to no boot way with just 2 side keys.... WBR, DebeliaMark, BG |
The Following 2 Users Say Thank You to debeliamark For This Useful Post: |
11-09-2016, 12:07 | #110 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,353 | Quote:
What device supported/not supported/will be supported - depend on much facts. Exactly this one - seems as not yet and not in near future. Have no chances to play with coolpad, kyocera and similar brands phones. | |
11-09-2016, 13:29 | #111 (permalink) | |
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,036 | Quote:
In any case the product is good, even in initially state. Here is Infinity readout from OT-5051X if someone need it. Tnx for explanation. | |
11-09-2016, 14:29 | #112 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,353 | As can see, almost all EU devices have enabled SB, that is make process of adding them more difficult, anyway, near 10-30 different SB enabled devices added in every update. |
11-09-2016, 15:00 | #113 (permalink) | |
No Life Poster Join Date: Jul 2002 Location: Hungary, Győr Age: 46
Member: 13569 Status: Offline Sonork: 1619596 Thanks Meter: 72 | Quote:
If one SB == for one device, than can we know somehow what device types are surely supported? (Exact modells i mean) Thanx dazexy | |
11-09-2016, 16:07 | #114 (permalink) |
Freak Poster Join Date: Sep 2007 Location: algeria Age: 35
Member: 580077 Status: Offline Sonork: 100.1591941 Thanks Meter: 207 | oppo a37f Code: Operation : Identify [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 1FC71BA3 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 49C762F6FE52E492 ID_BLOCK_L : 9B939302A85331CC Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , VER : 1 ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Brand : OPPO ProdName : A37f ProdModel : A37f AndroidVer: 5.1.1 Manufact. : OPPO QLMxCPU : MSM8916 Done! Elapsed: 00:00:05 Reconnect Power/Cable! Operation : Reset Settings [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 1FC71BA3 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 49C762F6FE52E492 ID_BLOCK_L : 9B939302A85331CC Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , VER : 1 ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP ( Google Reset Protection ) FRP removed! Done! Elapsed: 00:00:14 Reconnect Power/Cable! |
11-09-2016, 16:11 | #115 (permalink) |
Member: 580077 Status: Offline Sonork: 100.1591941 Thanks Meter: 207 | Code: 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 1FC71BA3 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 49C762F6FE52E492 ID_BLOCK_L : 9B939302A85331CC Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , VER : 1 ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Brand : OPPO ProdName : A37f ProdModel : A37f AndroidVer: 5.1.1 Manufact. : OPPO QLMxCPU : MSM8916 DevInfo : MSM8916__OPPO__OPPO__ANDR_v5.1.1__A37f__A37f ReportFile : C:\InfinityBox\CM2QLM\QLM_report.log Info : Device is not supported yet! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
11-10-2016, 18:18 | #119 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Bogotá Colombia Age: 43
Member: 150844 Status: Offline Thanks Meter: 309 | ZTE N9130 Code: Operation : Identify [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0E85AB3F ID_BLOCK_I : 007050E1 ID_BLOCK_L : 85A2E3D511D7D099 ID_BLOCK_L : D86B81EFE5383E69 Use CM2 Internal Loader Error : Prepare target failed! Unsupported CPU??? Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
11-11-2016, 04:02 | #120 (permalink) |
Insane Poster Join Date: Nov 2011 Location: Philippines
Member: 1689073 Status: Offline Sonork: dgsimpao Thanks Meter: 19 | LG D295 Dead.... back-up badly needed Operation : Identify [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_S : 09A6771E ID_BLOCK_I : 008140E1 ID_BLOCK_L : 49C762F6FE52E492 ID_BLOCK_L : 9B939302A85331CC Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , VER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000 Boot Ok! Brand : lge ProdName : l70pds_global_com ProdModel : LG-D295 Device : l70pds AndroidVer: 4.4.2 Manufact. : LGE QLMxCPU : MSM8610 |
