Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2018 Location: Congo Brazzaville
Member: 2809120 Status: Offline Thanks Meter: 81 | itel S16 Pro cannot be connected with CM2 i try to remove FRP on Itel W6503 S16 Pro without success Operation : Format FS / Reset Settings [ v2.12 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_2GB_RS Sending Init Boot ... Boot sent! Kick FDL ... >>> ERROR : FDL NOT started! >>> Error : Fail to boot FDL! >>> Unsupported device with selected fdl or settings! Change settings! Reconnect Power/Cable! Operation : Identify [ v2.12 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_0S Sending Init Boot ... Boot sent! Kick FDL ... >>> ERROR : FDL NOT started! >>> Error : Fail to boot FDL! >>> Unsupported device with selected fdl or settings! Change settings! Reconnect Power/Cable! Operation : Format FS / Reset Settings [ v2.12 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! >>> ERROR : Protocol HandShake failed! >>> Error : Fail to init protocol! >>> Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Format FS / Reset Settings [ v2.12 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH Card found : 21B1154E , v0148 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.12 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.12 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9863x_BASE : SC9863_eMMC_2GB_RS Sending Init Boot ... Boot sent! Kick FDL ... >>> ERROR : FDL NOT started! >>> Error : Fail to boot FDL! >>> Unsupported device with selected fdl or settings! Change settings! Reconnect Power/Cable! Operation : Format FS / Reset Settings [ v2.12 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9863x_BASE : SC9863_eMMC_2GB_RS Sending Init Boot ... Boot sent! Kick FDL ... >>> ERROR : FDL NOT started! >>> Error : Fail to boot FDL! >>> Unsupported device with selected fdl or settings! Change settings! Reconnect Power/Cable! Operation : Format FS / Reset Settings [ v2.12 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9863x_BASE : SC9863_eMMC_2GB_RS Sending Init Boot ... Boot sent! Kick FDL ... >>> ERROR : FDL NOT started! >>> Error : Fail to boot FDL! >>> Unsupported device with selected fdl or settings! Change settings! Reconnect Power/Cable! so i wnat to know if infinity support this phone |
![]() | #4 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2016 Location: Africa
Member: 2601900 Status: Offline Thanks Meter: 511 | S16 is a signed phone so even he read the phone in diag it won't mean a thing, the only option for him is to use pac file in cm2spd2 to service his phone, i hope team will add itel, mobicel and tecno spd phones soon |
![]() | #5 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2007
Member: 462970 Status: Offline Thanks Meter: 20,232 | Quote:
https://forum.gsmhosting.com/vbb/14407864-post37.html | |
The Following 2 Users Say Thank You to JayDi For This Useful Post: |
![]() | #6 (permalink) | |
Member: 2809120 Status: Offline Thanks Meter: 81 | itel S16 PRO W6503 CORRECT STEP TO REMOVE FRP Quote: below link discussion is regarding flash of itel S16 W6502 not remove FRP on Itel S16 Pro W6503, i found flash file of S16 Pro W6503; so i want to know how to remove FRP on this itel W6503, using flash file which is on support. thanks for your help regards | |
![]() | #7 (permalink) |
Member: 2809120 Status: Offline Thanks Meter: 81 | Hi Jaydi on above post is regarding flash of itel S16 W6502 wich will be supported by next update 2.13. My question is about itel S16 pro W6503 with FRP i found flash file on support ; so please i would like to know how to remove FRP on this phone using current firmware which is on support thanks for your explanation regards leroi |
![]() | #10 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2006 Location: Pakistan karachi
Member: 314003 Status: Offline Thanks Meter: 2,933 | ZTE Z3 First Time Cannect 2nd Time Not Cannect Code: Patch Level : PPR1.180610.011 Display ID : PK_ZONGZ3_A5_2019_V1.0 Ver. Incmt : 20191224.142013 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-12-05 Build Time : 24.12.2019 Product Model : Z3 Product Brand : ZTE Product Name : P963F30P Product Device : P963F30P Product Manfct : ZTE Product Info : P963F30P Product Name : s9863a1h10_Natv Product Device : s9863a1h10 Product Board : lucyzh64 Board Platform : sp9863a Platform Version: MOCORTM_18B_W19.10.2_ZLA_P16_Debug Project Version: sharkl3_pub BASE Version: FM_BASE_18B_W19.10.2_ZLA_P16 HW Version: sc9863A_modem CMP_Time : 11-19-2019 18:08:48 MODEM TAG : MOCORTM_18B_W19.10.2_ZLA_P16_Debug_FM_BASE_18B_W19.10.2_ZLA_P16_sc9863A_modem_sharkl3_pub USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:02:02 Code: Operation : Identify [ v2.12 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : INFINITY FW PACKAGE Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... >>> ERROR : FLASH FDL NOT started! >>> Error : Fail to boot FDL! >>> Unsupported device with selected fdl or settings! Change settings! Reconnect Power/Cable! |
![]() | #11 (permalink) | |
![]() | #12 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,933 | How To Setting Change Code: Patch Level : PPR1.180610.011 Display ID : PK_ZONGZ3_A5_2019_V1.0 Ver. Incmt : 20191224.142013 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-12-05 Build Time : 24.12.2019 Product Model : Z3 Product Brand : ZTE Product Name : P963F30P Product Device : P963F30P Product Manfct : ZTE Product Info : P963F30P Product Name : s9863a1h10_Natv Product Device : s9863a1h10 Product Board : lucyzh64 Board Platform : sp9863a Platform Version: MOCORTM_18B_W19.10.2_ZLA_P16_Debug Project Version: sharkl3_pub BASE Version: FM_BASE_18B_W19.10.2_ZLA_P16 HW Version: sc9863A_modem CMP_Time : 11-19-2019 18:08:48 MODEM TAG : MOCORTM_18B_W19.10.2_ZLA_P16_Debug_FM_BASE_18B_W19.10.2_ZLA_P16_sc9863A_modem_sharkl3_pub USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:01:23 Open : SPD_PROG.xml Reading package ... Read package finished! Created by Infinity-Box (c) 2020 Chinese Miracle II : Spreadtrum / UniSoc Service Module Device Info file : _Android_info.txt Patch Level : PPR1.180610.011 Display ID : PK_ZONGZ3_A5_2019_V1.0 Ver. Incmt : 20191224.142013 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-12-05 Build Time : 24.12.2019 Product Model : Z3 Product Brand : ZTE Product Name : P963F30P Product Device : P963F30P Product Manfct : ZTE Product Info : P963F30P Product Name : s9863a1h10_Natv Product Device : s9863a1h10 Product Board : lucyzh64 Board Platform : sp9863a SECSolution : MODERN [RS/0S/1S/2S] Operation : Flash Firmware [ v2.12 ] Setting : Update NVRAM : False Setting : Force NVRAM : False Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : INFINITY FW PACKAGE Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... >>> ERROR : FLASH FDL NOT started! >>> Error : Fail to boot FDL! >>> Unsupported device with selected fdl or settings! Change settings! Reconnect Power/Cable! |
![]() | #14 (permalink) | |
Junior Member ![]() ![]() Join Date: Dec 2014 Location: Umuahia
Member: 2314220 Status: Offline Sonork: [email protected] Thanks Meter: 1 | Quote: | |
