What to do: 1. Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - http://www.infinity-box.com/support/?r=6 Also you can insert Smart-Card into another Card-Reader. 2. Run DongleManager 3. Update Dongle firmware now ONLY ONE TIME - DO NOT update Smart-Card many times otherwise your account will be locked automatically after 3 tries - DO NOT use any kind of usb sharing/trace/spy/debug software to avoid problem with Dongle ! |
you must install good drivers or use good pc and then try again. |
What is your Support Validity Date ? How to check - http://www.infinity-box.com/doc.php?id=17 If you have active support - run DongleManager software and update Box/Dongle firmware. If support is not active - please contact to any seller and renew support. |
"Support renew" order refunden, payment returned to seller. You must buy new Smary-Card or Infinity-Box Dongle because your old Smart-Card is damaged and can not be updated any more |
hello team i face again this error today after update driver :( Scanning... HWID: 0202AC7024881292 Select Box/Dongle Type: instead of Autodetect Box/Dongle type selected: Main Infinity-Box/Dongle HWID: 0202AC7024881292 Box/Dongle type selected: Main Infinity-Box/Dongle ---------- Process started: 2/1/2017 11:46:09 AM ---------- DongleManager [Infinity-Box] v1.67 [2/1/2017 11:46:09 AM] PC HWID: C9C56D009F3118207B70E0987C3322B4 Card-Reader: FT SCR2000 0 HWID: 0202AC7024881292 Type: Main Infinity-Box/Dongle S/N: -------- Version: Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Service stage 1 confirmed Securing session... Session secured ok Upgrading dongle... DO NOT disconnect Box/Dongle ! WAIT 3-4 minutes ! Last APDU: 133 sec Card returned error - 0000 at 667/8500 Error upgrading applets: Card returned error - 0000 at 667/8500 Disconnected |
You know well that your box is damaged and can not be updated any more. "Support renew" order refunden, payment returned to seller. You must buy new Smary-Card or Infinity-Box Dongle because your old Smart-Card is damaged and can not be updated any more can you put that activation to my new infinity smart card plz??? |
What can be wrong? Finally I managed to update Best Card to CM2 test version Code: Scanning... DongleManager detects card, read user info etc. But CM2 software doesn't start, all the time "Dongle is not connected" :confused: BR |
i have this problem after update firmware with dongle manager please hepl Box/Dongle type selected: Main Infinity-Box/Dongle ---------- Process started: 01/02/2017 16:36:07 ---------- DongleManager [Infinity-Box] v1.67 [01/02/2017 16:36:07] PC HWID: E2903F5699BF40370B3D825BE572B2C5 Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0000E167FF021982 Type: Main Infinity-Box/Dongle S/N: -------- Version: Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 |
and this after read with cardid Database: ./FSCard.ini Card-Reader: Alcor Micro USB Smart Card Reader 0 ATR: 3B759400006202020201 Historical ATR bytes: 0062020202 Card Manager: A0000000030000 SerialNumber: 0000E167 ROM: Integrated Circuit Fabricator: 4090 Integrated Circuit Type: 0062 OS: Identifier: 0011 Release Date: 0202 Release Level: 0100 EEPROM: Fabrication Date: 6021 Serial Number: 0000E167 Batch Identifier: FF02 Module Fabricator: 1982 Module Packaging Date: 6021 IC Card Manufacturer: 1983 IC Em******* Date: 6021 Pre Personalizer: 1984 Pre Personalization Date: 6021 Pre Personalization Equipment Identifier: 00030001 Personalizer: FFFF Personalization Date: FFFF Personalization Equipment Identifier: FFFFFFFF m_iopCard.Serial: 0000E167FF021982 Extended Info is not available: Card returned error message . ISO7816 error 0x6A86 (Wrong parameter(s) P1-P2. Incorrect parameters P1-P2 ) |
result ? |
