03-12-2020, 13:13 | #166 (permalink) |
Freak Poster Join Date: Jul 2015 Location: Kathmandu nepal
Member: 2430157 Status: Offline Sonork: dsakkkkmriz Thanks Meter: 49 | Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: FT SCR2000 0 HWID: 0109776824881292 === Process started: 3/12/2020 17:54:48 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: |
03-12-2020, 23:29 | #167 (permalink) | |
Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - https://www.infinity-box.com/support/?r=6 OR Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader) The next steps are: - run DongleManager - update Dongle firmware IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again ! | |
03-13-2020, 12:44 | #168 (permalink) | |
Member: 2430157 Status: Offline Sonork: dsakkkkmriz Thanks Meter: 49 | Quote:
reader also change driver ok . error again plz fix this solution always update time this problem other dongol no problem update === DongleManager [Infinity] v1.74 [3/13/2020 17:24:39] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: FT SCR2000 0 HWID: 0109776824881292 === Process started: 3/13/2020 17:24:39 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Service stage 1 confirmed Securing session... Session secured ok Upgrading dongle... Wait 4-5 minutes ! DO NOT disconnect Box/Dongle ! Error upgrading applets: Card returned error - 0000 at 6099/8681 Disconnected | |
03-13-2020, 18:48 | #169 (permalink) | |
Follow the instruiction: Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - https://www.infinity-box.com/support/?r=6 OR Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader) The next steps are: - run DongleManager - update Dongle firmware IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again ! | |
03-20-2020, 15:24 | #170 (permalink) |
No Life Poster Join Date: Jul 2014 Location: EARTH
Member: 2221849 Status: Offline Sonork: offline Thanks Meter: 279 | === DongleManager [Infinity] v1.72 [20-Mar-20 16:22:34] === Box/Dongle type selected: [BEST] Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 020365721C6A1292 === Process started: 20-Mar-20 16:22:34 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 |
03-20-2020, 19:42 | #171 (permalink) | |
04-04-2020, 11:05 | #174 (permalink) | |
Registered User Join Date: Oct 2017 Location: WorldWide
Member: 2769779 Status: Offline Thanks Meter: 7 | hello i have this problem ! how to fix ??? Quote:
04-04-2020, 12:10 | #176 (permalink) | |
Member: 2769779 Status: Offline Thanks Meter: 7 | Hi I have had this problem with Best and Best2 for 7 days. This is a new photo. Quote:
04-04-2020, 12:13 | #177 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | photo is not requered. You should find file with name fault.bin in BEST or BEST2 folder. Instruction - https://www.infinity-box.com/support/?r=4 Waiting for your result, information and fault.bin file. |
04-04-2020, 14:21 | #178 (permalink) |
Member: 2769779 Status: Offline Thanks Meter: 7 | I didn't find the fault.bin file on my computer or in the Best2 folder. Where is the exact location of this file? If you can check using Teamviewer or anydesk? Last edited by ramin gsm; 04-04-2020 at 14:30. |
