11-13-2020, 22:44 | #691 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
Update it ONCE again now | |
12-17-2020, 11:26 | #692 (permalink) | |
Member: 1043909 Status: Online Thanks Meter: 60,926 | Quote:
fault.bin file has info how to fix PC of your user ! User can update dongle without fault.bin in this case user may get problem again later | |
01-24-2021, 18:26 | #693 (permalink) | |
Junior Member Join Date: Oct 2005 Location: Egypt
Member: 192649 Status: Offline Sonork: 100.1577644 Thanks Meter: 1 | i can't update firmware v0147 i can't update firmware v0147 Quote:
01-24-2021, 22:13 | #696 (permalink) |
Product Supporter Join Date: Jul 2008 Location: iran-shiraz
Member: 814775 Status: Offline Sonork: 100.1587334 Thanks Meter: 973 | I had a problem updating the SIM card, although I recently activated it, but it gives the following message S/N: 7462732D Expired: 18-Sep-2022; Support: Active |
01-26-2021, 13:55 | #698 (permalink) |
Junior Member Join Date: Apr 2006 Age: 49
Member: 264749 Status: Offline Thanks Meter: 1 | === DongleManager [Infinity] v1.81 [26.01.2021 15:54:57] === Searching... Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0000E23AFF001982 Box/Dongle found: Infinity-Box/Dongle [CM2] Reading... Serial No (S/N): 0049E23A Firmware version: 0147.02 === Process started: 26.01.2021 15:55:02 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Write to https://www.infinity-box.com/support/?r=2 |
01-26-2021, 14:08 | #699 (permalink) | |
Please make step-by-step NOW: - reboot PC - update dongle with DongleManager - delete fault.bin file (if any) Before run Infinity CM2MT2 always close boot-helper installation package ! | |
01-26-2021, 14:16 | #700 (permalink) |
No Life Poster Join Date: May 2016 Location: IR
Member: 2575029 Status: Offline Thanks Meter: 122 | === DongleManager [Infinity] v1.80 [2021-01-26 16:45:53] === Searching... Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0104977420881292 Box/Dongle found: [BEST] Serial No (S/N): 91659774 Firmware version: 0122.02 Box/Dongle misconfiguration Diagnostic code: 70 "UK Edition" status: Off Last launched Application: 0030 v.0147 => Activations: - 00: Infinity-Box/Dongle v0147 - 03: [BEST] v0122 - 0F: #15 => Options: - Infinity BEST - Infinity BEST2 - amt |
01-26-2021, 14:18 | #701 (permalink) | |
01-27-2021, 07:53 | #702 (permalink) |
Freak Poster Join Date: Jan 2009 Location: INDIA,U.P.BALLIA
Member: 947347 Status: Offline Sonork: 100.108278 Thanks Meter: 21 | === DongleManager [Infinity] v1.81 [27-01-2021 12:22:53] === Box/Dongle type selected: Infinity-Box/Dongle [CM2] Card-Reader: FT SCR2000 0 HWID: 0000FC7612BF4082 Box/Dongle found: Infinity-Box/Dongle [CM2] Reading... Serial No (S/N): C0E6FC76 Firmware version: 0147.02 === Process started: 27-01-2021 12:22:55 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Write to https://www.infinity-box.com/support/?r=2 |
01-27-2021, 07:54 | #703 (permalink) |
Member: 947347 Status: Offline Sonork: 100.108278 Thanks Meter: 21 | === DongleManager [Infinity] v1.81 [27-01-2021 12:24:35] === Searching... Card-Reader: FT SCR2000 0 HWID: 0000FC7612BF4082 Box/Dongle found: Infinity-Box/Dongle [CM2] Serial No (S/N): C0E6FC76 Firmware version: 0147.02 Box/Dongle misconfiguration Diagnostic code: 70 "UK Edition" status: Off Last launched Application: 0030 v.0147 => Activations: - 00: Infinity-Box/Dongle [CM2] v0147 => Options: - Infinity-Box/Dongle [CM2] |
01-27-2021, 07:56 | #704 (permalink) |
Member: 947347 Status: Offline Sonork: 100.108278 Thanks Meter: 21 | plz help === DongleManager [Infinity] v1.81 [27-01-2021 12:24:35] === Searching... Card-Reader: FT SCR2000 0 HWID: 0000FC7612BF4082 Box/Dongle found: Infinity-Box/Dongle [CM2] Serial No (S/N): C0E6FC76 Firmware version: 0147.02 Box/Dongle misconfiguration Diagnostic code: 70 "UK Edition" status: Off Last launched Application: 0030 v.0147 => Activations: - 00: Infinity-Box/Dongle [CM2] v0147 => Options: - Infinity-Box/Dongle [CM2] === DongleManager [Infinity] v1.81 [27-01-2021 12:22:53] === Box/Dongle type selected: Infinity-Box/Dongle [CM2] Card-Reader: FT SCR2000 0 HWID: 0000FC7612BF4082 Box/Dongle found: Infinity-Box/Dongle [CM2] Reading... Serial No (S/N): C0E6FC76 Firmware version: 0147.02 === Process started: 27-01-2021 12:22:55 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Write to https://www.infinity-box.com/support/?r=2 |
01-27-2021, 11:28 | #705 (permalink) | |
Please make step-by-step NOW: - reboot PC - update dongle with Infinity DongleManager.exe - delete fault.bin file (if you have it in CM2 folder) Before run Infinity CM2MT2 always close boot-helper installation package ! | |
