08-20-2020, 19:31 | #663 (permalink) |
Freak Poster Join Date: Mar 2006
Member: 251872 Status: Offline Thanks Meter: 309 | Searching... Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 000127ED7D314082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): D9EC27ED Firmware version: 0136.02 === Process started: 8/20/2020 22:59:52 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Service stage 1 confirmed Securing session... Session secured ok Upgrading dongle... Wait 4-5 minutes ! DO NOT disconnect Box/Dongle ! |
08-20-2020, 19:56 | #664 (permalink) |
Freak Poster Join Date: Feb 2007 Location: HERE IN SOME ROAD
Member: 447104 Status: Offline Thanks Meter: 17 | === DongleManager [Infinity] v1.80 [20/08/2020 19:51:50] === Searching... Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0000BA847F634082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): E3ECBA84 Firmware version: 0143.02 === Process started: 20/08/2020 19:51:52 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0007] No updates found for your Smart-Card. DO NOT try more today ! CM2MT2 NOT WORKING ? WHAT'S WRONG? |
08-20-2020, 20:26 | #666 (permalink) | |
08-21-2020, 21:14 | #668 (permalink) | |
Probably your dongle support period is expired. How to check - https://www.infinity-box.com/doc/?r=17 If support is expired please contact to your seller and renew support for 1 or 2 years - https://www.infinity-box.com/buy/ | |
The Following 2 Users Say Thank You to YellowBoss For This Useful Post: |
09-01-2020, 16:50 | #669 (permalink) |
Junior Member Join Date: Mar 2016
Member: 2550256 Status: Offline Thanks Meter: 0 | === DongleManager [Infinity] v1.80 [9/1/2020 20:13:06] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: GsmEasy S-Reader 0 HWID: 00012B23212B4082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 2E522B23 Firmware version: 0118.02 === Process started: 9/1/2020 20:13:08 === Connecting to server Connection to server failedSocket Error # 10054 Connection reset by peer. |
09-01-2020, 19:11 | #670 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
You should disable your PC Firewall and Antivirus and try again. Also you may try with VPN - https://www.vpngate.net/en/ | |
09-24-2020, 10:06 | #671 (permalink) |
Junior Member Join Date: Sep 2008
Member: 872306 Status: Offline Thanks Meter: 0 | Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Generic EMV Smartcard Reader 0 HWID: 01099169147D1292 === Process started: 24/09/2020 10:05:04 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to https://www.infinity-box.com/support/?r=2 |
09-24-2020, 10:29 | #672 (permalink) | |
1. Install REQUIRED Card-Reader Drivers - https://www.infinity-box.com/support/?r=6 File with Drivers: CardReader_Fetian_FT2K.7z File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 2. Run DongleManager 3. Update Dongle firmware ONCE OR 1. Insert Smart-Card into another Card-Reader. Good result for today gives Alcor Card-Reader. 2. Run DongleManager - https://www.infinity-box.com/support/?r=5 3. Update Dongle firmware ONCE In case of problem DO NOT update card again but contact to support ! | |
09-24-2020, 12:13 | #673 (permalink) |
Member: 872306 Status: Offline Thanks Meter: 0 | Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: FT SCR2000 0 HWID: 01099169147D1292 === Process started: 24/09/2020 12:13:30 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Service stage 1 confirmed Securing session... Session secured ok Upgrading dongle... Wait 4-5 minutes ! DO NOT disconnect Box/Dongle ! Card returned error - 0000 at 2660/11781 Error upgrading applets: Card returned error - 0000 at 2660/11781 Disconnected |
09-24-2020, 12:16 | #674 (permalink) | |
