08-18-2015, 10:19 | #24316 (permalink) |
No Life Poster Join Date: Nov 2012 Location: Ek India Happy Wala.. :-)
Member: 1834832 Status: Offline Thanks Meter: 1,450 | World 1st HTC D820U Factory File Read Done With CM2 18-08-2015 / 13:07:03 ================================================== ======= Card found: S/N XXXX:XXXX Chinese Miracle II [MTK module] v 1.24 Start at : [18-08-2015 / 13:07:30] Operation : Read Flash [ v1.24 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 34 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4838473264040507A28C102255 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d2G8 [eMMC] : FLASH_CID : 90014A4838473264040507A28C102255 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : HTC_D820u ProdName : HTC_D820u ProdModel : HTC_D820u Device : HTC_D820u AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.KK1.MP1.V2.10 [Read Ok] : preloader_tb08.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6582 / V1.1.1 / tb08 / EMMC FW Size : 934 MiB Scatter saved to : D:\MT6582__HTC_D820u__HTC_D820u__HTC_D820u__4.4.2_ _ALPS.KK1.MP1.V2.10\ All done! Done! Elapsed: 00:05:29 Reconnect Power/Cable! Finish at : [18-08-2015 / 13:13:00] WBR Hi-Tech Care |
08-18-2015, 10:41 | #24318 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Intex Neo 6, read code done- Quote:
08-18-2015, 10:47 | #24319 (permalink) |
No Life Poster Join Date: May 2012 Location: InfinityBox CM2
Member: 1763238 Status: Offline Thanks Meter: 371 | Spice MI-520 Read Flash / Format Done Code: Operation : Read Flash [ v1.25 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D4330344758016B0C317115 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : G40CM [eMMC] : FLASH_CID : 7001004D4D4330344758016B0C317115 [eMMC] : FLASH_LEN : 0x00000000E6800000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : Spice ProdName : MI-520 ProdModel : SpiceMI-520 Device : Spice AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : Spice_MI-520_IND_Ver7.0 [Read Ok] : preloader_wt98601.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6582 / V1.1.1 / wt98601 / EMMC FW Size : 950 MiB Scatter saved to : C:\Users\Desktop\MT6582__Spice__SpiceMI-520__Spice__4.4.2__Spice_MI-520_IND_Ver7.0\ All done! Done! Elapsed: 00:04:34 Reconnect Power/Cable! Code: Operation : Format FileSystem [ v1.25 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D4330344758016B0C317115 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : G40CM [eMMC] : FLASH_CID : 7001004D4D4330344758016B0C317115 [eMMC] : FLASH_LEN : 0x00000000E6800000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Backup : Skipped by user request FMT Mode set to : 0 Format : Cache and UserData (Full Factory Reset) Format CACHE block Format block Ok! Format UDA block Format block Ok! Done! Elapsed: 00:00:21 Reconnect Power/Cable! |
08-18-2015, 11:54 | #24320 (permalink) |
Junior Member Join Date: Aug 2015
Member: 2444497 Status: Offline Thanks Meter: 26 | Winstar W305 Code: Operation : Format File System [ v1.03 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 82 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0040 0016 0000 [0] Flash VEN : Winbond , W25Q32 [0] Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:56 Reconnect Power/Cable! |
The Following User Says Thank You to phone_care For This Useful Post: |
08-18-2015, 12:20 | #24321 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2406517 Status: Offline Sonork: 100.1641481 Thanks Meter: 38 | Q mobile r1000 spd6531 read info Phone found! [ 30 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0060 0017 0000 [0] Flash VEN : Winbond , W25Q64 [0] Flash CAP : 00800000 Read Flash Content Read Ok , collect info Platform : MOCOR_12C.W13.04.05_Release Project : SC6531_OPENPHONE HWInfo : SC6531_OPENPHONE Compile : 08-25-2014 16:03:44 Set FileInfo : Model Vendor : Q mobile Model Name : R1000 ExtInfo Data : english Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00800000_MO COR_12C.W13.04.05_Release_08252014160344_english__ Q mobile -R1000.bin Done! BR GSM BOSS |
The Following User Says Thank You to hamza gsm boss For This Useful Post: |
08-18-2015, 12:21 | #24322 (permalink) |
Member: 2406517 Status: Offline Sonork: 100.1641481 Thanks Meter: 38 | Q mobile r1000 spd6531 format sussesfull ==== Wait for phone... Phone found! [ 30 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0060 0017 0000 [0] Flash VEN : Winbond , W25Q64 [0] Flash CAP : 00800000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! BR GSM BOSS |
08-18-2015, 12:23 | #24323 (permalink) |
Member: 2406517 Status: Offline Sonork: 100.1641481 Thanks Meter: 38 | Q mobile E4 format done Wait for phone... Phone found! [ 35 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : 72F03698B521A5EC530799C4AD23E964 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E [0] : FLASH_DIE : 00C2 0025 0036 0000 [0] : FLASH_LEN : 0x00400000 SDS : 0x00000000 , 0x00000000 Backup done Executing FFS FORMAT now... FAT_RANGE : 0x003B5000-0x003FFFFF , LEN : 0x0004B000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! BR GSM BOSS |
08-18-2015, 12:26 | #24324 (permalink) |
Member: 2406517 Status: Offline Sonork: 100.1641481 Thanks Meter: 38 | Q mobile X6 format sussesfull Wait for phone... Phone found! [ 5 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 009800BC009000660076001600080000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x8B DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1 [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Format : UserData Only (Factory Reset) Format UDA block Format block Ok! Done! BR GSM BOSS |
08-18-2015, 13:09 | #24325 (permalink) |
Freak Poster Join Date: Oct 2009
Member: 1145301 Status: Offline Thanks Meter: 116 | intex auqa q1+ spd 7730 pattern lock successfully format with cm2spd [IMG]file:///D:/Documents%20and%20Settings/abc/Desktop/intex.JPG[/IMG] |
The Following User Says Thank You to mali_comm For This Useful Post: |
08-18-2015, 14:21 | #24328 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | Qmobile X800 (MT6592) Factory Firmware and NvRAM. Qmobile X800 (MT6592) Factory Firmware and NvRAM Backup Done. Code: Operation : Read Flash [ v1.25 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4838473264040501A108F1819B DA Stat : v4.2 on BBID : 0x8A DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d2G8 [eMMC] : FLASH_CID : 90014A4838473264040501A108F1819B [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : QMobile ProdName : X800 ProdModel : QMobile X800 Device : X800 AndroidVer: 4.4.2 MTKxCPU : MT6592 MTKxPRJ : ALPS.KK1.MP1.V2.10 [Read Ok] : preloader_pk_qmb.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6592 / V1.1.2 / pk_qmb / EMMC FW Size : 1188 MiB Scatter saved to : F:\MT6592__QMobile__QMobile X800__X800__4.4.2__ALPS.KK1.MP1.V2.10\ All done! Done! Elapsed: 00:06:11 Reconnect Power/Cable! Operation : Read NVRAM [ v1.25 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4838473264040501A108F1819B DA Stat : v4.2 on BBID : 0x8A DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d2G8 [eMMC] : FLASH_CID : 90014A4838473264040501A108F1819B [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Read Ok, MT6592_eMMC.spnv saved Done! Elapsed: 00:01:05 Reconnect Power/Cable! |
The Following User Says Thank You to Nasir Mobiles For This Useful Post: |
08-18-2015, 14:49 | #24329 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Q Mobile i7__4.4.2_Dead recovery Successful, Done .:: BY ::. ..::: Chinese Miracle-2 MTK:::.. Code:
The Following 4 Users Say Thank You to kabul For This Useful Post: |
08-18-2015, 15:50 | #24330 (permalink) |
Registered User Join Date: Dec 2004 Location: largest democratic country
Member: 100376 Status: Offline Sonork: 100.1591842 Thanks Meter: 150 | Lava X1 atomS format successfully to remove pattern lock Operation : Format File System [ v1.03 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 55 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Loader eMMC v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x0000000183CFB000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Done! Elapsed: 00:01:13 Reconnect Power/Cable! |
The Following User Says Thank You to sabby_singh For This Useful Post: |
