12-19-2015, 14:56 | #29536 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Q Mobile i12__Read Pattern Just 1 Click Successfully,Time 00:16" .:: BY ::. ..::: Infinity Chinese Miracle-2 :::.. Code:
The Following 4 Users Say Thank You to kabul For This Useful Post: |
12-19-2015, 14:56 | #29537 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | celkon c5+ format done Code: Operation : Format File System [ v1.08 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 199 ] Open Port Failed! Reconnect Power/Cable! Operation : Format File System [ v1.08 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 199 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:10 Reconnect Power/Cable! Operation : Read FullFlash [ v1.08 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 199 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Read Flash Content Read Ok , collect info Set FileInfo : Model Vendor : celkon Model Name : c5+ Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_GD25LQ32__celkon-c5+.bin Done! Elapsed: 00:01:05 Reconnect Power/Cable! |
The Following User Says Thank You to rehmani For This Useful Post: |
12-19-2015, 14:59 | #29538 (permalink) |
No Life Poster Join Date: May 2008
Member: 770299 Status: Offline Sonork: 100.1603105 Thanks Meter: 1,029 | Q Mobile M88 spread SP7731 read flash successfully done. Q Mobile M88 spread SP7731 read flash successfully Code: Operation : Check/Read Info [ v1.08 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 151 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : M88 Model Brand : QMobile Model Device: M88 AndrVersion : 4.4.2 BaseBand CPU: SP7731GEA CompileDate : 1438315139 Project Ver : QMobileM88_MP_31_07 Model Ext : QMobile M88 ExtraInfo : HWInfo not exists, normal phone ExtraInfo : GSM Phone Elapsed: 00:00:18 Reconnect Power/Cable! Operation : Read FullFlash [ v1.08 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 151 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected eMMC Flash , Structure detect Ok! [FW_READER] : Step #1 Passed! [FW_READER] : Step #2 Passed! [FW_READER] : Step #3 Passed! Phone found! [ 52 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! Model Name : M88 Model Brand : QMobile Model Device: M88 AndrVersion : 4.4.2 BaseBand CPU: SP7731GEA Project Ver : QMobileM88_MP_31_07 Model Ext : QMobile M88 [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : sc7731g_CP0_modem.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : nvitem.bin [Read Ok] : sc8830g_modem_CP2_WCN_14D_W15.22.3_Release.bin [Read Ok] : nvitem_wcn.bin [Read Ok] : logo_480x854.bin [Read Ok] : fblogo_480x854.bin [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : userdata.img Firmware Size : 1019 MiB Saved to : C:\Users\Desktop\SP7731GEA_M88_4.4.2_QMobileM88_MP_31_07\ Done! |
12-19-2015, 15:08 | #29539 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Nokia 208 Flash Done :) Code: Core : v2.14 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm949__10.34.mcusw PPM : rm949__10.34.ppm_m2 CNT : rm949__10.34.image_m2_059S623 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x16 IF xCPUID : XGOLD 618 [XMM6180 QUARK] IF uCHIPID : 50A90409100CEE20 IF Resp Data : 50A9070100030101 Wait for user action : Insert battery Sending EBL Loader ... EBL Loader Ok EBL Loader ready Sending EBL ... EBL sent Ok EBL : QUARK_1340.100_M1S1 QUARK EEP config Ok FLASHID : 20004000 , [ MuxOneNAND ] Boot conf set, Target Ready Boot done! Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 356698051103167 IMEI 2 : 356698051103175 Phone Product Code : 059S623 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : F:\1+Flashing Software\1+BEST\InfinityBox\BEST\Backup\Cert\356698051103167_XG618_CRT.rpl ===Flashing [MCU]=== Processing file : rm949__10.34.mcusw Region count : 8 00 : [ PSI ] : psi_flash_unsigned.fls 01 : [ BCore ] : slb_signed.fls 02 : [ Code ] : main_toc_signed.fls 03 : [ Code ] : rm949__10.34.mcusw_signed_mcusw.fls 04 : [ Code ] : swap_signed.fls 05 : [ Cust ] : dynsw.fls 06 : [ Code ] : aeneas_signed.fls 07 : [ Code ] : fota_signed.fls Parse done , flashing now Flash : 00 : psi_flash_unsigned.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x00090000 , Len : 0x00020000 Erase now... Erase done Region Start : 0x00090000 , Data Len : 0x00010FB0 Region Load done Write done psi_flash_unsigned.fls image flash done Flash : 01 : slb_signed.fls Sending Sec-Pack SecInfo Area : 0x0001 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x60000000 , Len : 0x00040000 Erase now... Erase done Region Start : 0x60000000 , Data Len : 0x00040000 Region Load done Write done slb_signed.fls image flash done Flash : 02 : main_toc_signed.fls Sending Sec-Pack SecInfo Area : 0x0002 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x60040000 , Len : 0x00000400 Erase now... Erase done Region Start : 0x60040000 , Data Len : 0x00000400 Region Load done Write done main_toc_signed.fls image flash done Flash : 03 : rm949__10.34.mcusw_signed_mcusw.fls Sending Sec-Pack SecInfo Area : 0x0003 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x62E00000 , Len : 0x01100000 Erase now... Erase done Erase area 0x01 , Start 0xFFF00000 , Len : 0x00080000 Erase now... Erase done Region Start : 0x62E00000 , Data Len : 0x00F5CAC4 Region Load done Write done rm949__10.34.mcusw_signed_mcusw.fls image flash done Flash : 04 : swap_signed.fls Sending Sec-Pack SecInfo Area : 0x0004 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x80000000 , Len : 0x00F00000 Erase now... Erase done Region Start : 0x80000000 , Data Len : 0x00C2E6C4 Region Load done Write done swap_signed.fls image flash done Flash : 05 : dynsw.fls Sending Sec-Pack SecInfo Area : 0x0005 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x62080000 , Len : 0x00100000 Erase now... Erase done Region Start : 0x62080000 , Data Len : 0x00044000 Region Load done Write done dynsw.fls image flash done Flash : 06 : aeneas_signed.fls Sending Sec-Pack SecInfo Area : 0x0006 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x63F79C00 , Len : 0x00080000 Erase now... Erase done Region Start : 0x63F79C00 , Data Len : 0x00046870 Region Load done Write done aeneas_signed.fls image flash done Flash : 07 : fota_signed.fls Sending Sec-Pack SecInfo Area : 0x0007 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x61F00004 , Len : 0x0017FFFC Erase now... Erase done Region Start : 0x61F00004 , Data Len : 0x00149A90 Region Load done Write done fota_signed.fls image flash done ===Flashing [PPM]=== Processing file : rm949__10.34.ppm_m2 Region count : 1 00 : [ Cust ] : package_m2.ppm_ebl_psi.fls Parse done , flashing now Flash : 00 : package_m2.ppm_ebl_psi.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x80F00000 , Len : 0x00B00000 Erase now... Erase done Region Start : 0x80F00000 , Data Len : 0x0053F280 Region Load done Write done package_m2.ppm_ebl_psi.fls image flash done ===Flashing [CNT]=== Processing file : rm949__10.34.image_m2_059S623 Region count : 1 00 : [ Cust ] : package_m2_059S623.image.fls Parse done , flashing now Flash : 00 : package_m2_059S623.image.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0xA1000000 , Len : 0x0C580000 Erase now... Erase done Erase area 0x01 , Start 0xAE000000 , Len : 0x00300000 Erase now... Erase done Region Start : 0xA1000000 , Data Len : 0x0210AA00 Region Load done Write done package_m2_059S623.image.fls image flash done Flashing done! Total flash time : 00:00:24 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 208 Dual SIM Software Info: V 10.34 13-03-14 RM-949 (c) Nokia IMEI: 356698051103167 PPM version : V 10.34 13-03-14 RM-949 (c) Nokia M2 Product code: 059S623 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:00:59 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
12-19-2015, 15:37 | #29540 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Pakistan
Member: 192810 Status: Offline Sonork: Some people NEED change Thanks Meter: 860 | Qmobile Power 4 hang on Logo Done by Format Code: Operation : Read FullFlash [ v1.08 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0040 0016 0000 [0] Flash VEN : Winbond , W25Q32 [0] Flash CAP : 00400000 Read Flash Content Read Ok , collect info Set FileInfo : Model Vendor : Qmobile Model Name : Power_4 ExtInfo Data : Eng Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_W25Q32_Eng__Qmobile -Power_4.bin Done! Elapsed: 00:00:35 Reconnect Power/Cable! Operation : Format File System [ v1.08 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0040 0016 0000 [0] Flash VEN : Winbond , W25Q32 [0] Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:10 Reconnect Power/Cable! |
The Following User Says Thank You to DUNIYA JAMAL For This Useful Post: |
12-19-2015, 15:40 | #29541 (permalink) |
Member: 192810 Status: Offline Sonork: Some people NEED change Thanks Meter: 860 | Qmobile A300 Hang on Logo Done by Flashing Code: Operation : Check / Read Info [ v1.39 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 14 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164048601A3E3144177 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048601A3E3144177 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : QMobile ProdName : A300 ProdModel : QMobile A300 Device : QMobile A300 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1.P65 EXTRA : LCD [0] : ili9806c_fwvga_dsi_vdo_txdkj LCD [1] : otm8018b_dsi_vdo LCD Res : 854x480 TOUCH [0] : GT9XX TOUCH [1] : FT5x36 CAM [0] : ov5645_mipi_yuv CAM [1] : ov5644_mipi_yuv CAM [2] : hi704_yuv CAM [3] : sp0a19_yuv MODEM : tinno72_s7810bp_pk_gprs_gemini LOCALE : en_US es_ES zh_CN zh_TW ru_RU pt_BR fr_FR de_DE tr_TR it_IT in_ID ms_MY vi_VN ar_EG ur_PK fa_IR th_TH pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ iw_IL my_MM km_KH ko_KR hdpi Done! Elapsed: 00:00:08 Reconnect Power/Cable! Scatter Load Ok , BaseBand : MT6572 , Project : s7810bp , Storage : EMMC Files found : 12 , Set to Flash : 11 Ready to Flash! Operation : Flash [ v1.39 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 14 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164048601A3E3144177 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048601A3E3144177 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : s7810bp , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3712 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000600000-0x0000000000100000 Erase : 0x0000000002300000-0x00000000E3E00000 Flash Pre-Erase Done, time used : 00:00:09 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_s7810bp.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0013 Update PMT by user request Repartition Done! Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash now : FAT Image Flash Ok Flash Write Done, time used : 00:03:28 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Verify Passed : FAT Data Verify Done, time used : 00:01:24 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:05:17 Reconnect Power/Cable! |
12-19-2015, 15:45 | #29542 (permalink) |
No Life Poster Join Date: Oct 2015 Location: Unknown
Member: 2469611 Status: Offline Thanks Meter: 389 | Q Mobile LT 700 Read FF Done Start at : [12/19/2015 / 7:32:17 PM] Operation : Check / Read Info [ v1.39 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6735 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6735_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 510001154153583802950642DFB4D3DE DA Stat : v4.2 on BBID : 0x93 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BASX8 [eMMC] : FLASH_CID : 150100513858534142069502DED392DF [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : QMobile ProdName : LT700 ProdModel : LT700 Device : GBL7325QM AndroidVer: 5.0 MTKxCPU : MT6735 MTKxPRJ : GBL7325QM_0102_T5463 Done! Elapsed: 00:00:12 Reconnect Power/Cable! Finish at : [12/19/2015 / 7:32:30 PM] Start at : [12/19/2015 / 7:32:46 PM] Operation : Read Flash [ v1.39 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6735 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6735_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 510001154153583802950642DFB4D3DE DA Stat : v4.2 on BBID : 0x93 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BASX8 [eMMC] : FLASH_CID : 150100513858534142069502DED392DF [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : QMobile ProdName : LT700 ProdModel : LT700 Device : GBL7325QM AndroidVer: 5.0 MTKxCPU : MT6735 MTKxPRJ : GBL7325QM_0102_T5463 MediaTek MT67xx [x64] : Normalize settings Ok [Read Ok] : preloader_gionee6735_65c_l.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : tz1.img [Read Ok] : tz2.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6735 / V1.1.2 / gionee6735_65c_l / EMMC FW Size : 2532 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6735__QMobile__LT700 __GBL7325QM__5.0__GBL7325QM_0102_T5463\ All done! Done! Elapsed: 00:07:21 Reconnect Power/Cable! Finish at : [12/19/2015 / 7:40:07 PM] |
The Following User Says Thank You to CYB3R GSM For This Useful Post: |
12-19-2015, 21:04 | #29543 (permalink) |
No Life Poster Join Date: Sep 2012 Location: Ghana
Member: 1809548 Status: Offline Sonork: mysty619/100.167036 Thanks Meter: 120 | Tecno M9 read flash file done Start at : [12/19/2015 / 9:34:43 AM] Operation : Read Flash [ v1.38 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 4B000115303055385447034D6790B672 DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , M00U8 [eMMC] : FLASH_CID : 1501004B385530304D03475472B69067 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : TECNO ProdName : lcsh89_we_jb2 ProdModel : TECNO M9 Device : TECNO-M9 AndroidVer: 4.2.1 MTKxCPU : MT6589 MTKxPRJ : ALPS.JB2.MP.V1.2 [Read Ok] : preloader_lcsh89_we_jb2.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6589 / V1.0.0 / lcsh89_we_jb2 / EMMC FW Size : 808 MiB Scatter saved to : C:\Users\Sabit\Desktop\infinity backup\MT6589__TECNO__TECNO_M9__TECNO-M9__4.2.1__ALPS.JB2.MP.V1.2\ All done! Done! Elapsed: 00:05:11 Reconnect Power/Cable! Finish at : [12/19/2015 / 9:39:55 AM] |
12-19-2015, 21:06 | #29544 (permalink) |
Member: 1809548 Status: Offline Sonork: mysty619/100.167036 Thanks Meter: 120 | samsung s6 clone read flash file done Start at : [12/19/2015 / 9:40:53 AM] Operation : Read Flash [ v1.38 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 11010030303447453001129A65EB626D DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 0EG40 [eMMC] : FLASH_CID : 11010030303447453001129A65EB626D [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : alps ProdName : rtech72_we_72_kk ProdModel : G9200 Device : rtech72_we_72_kk AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP6.V1 [Read Ok] : preloader_rtech72_we_72_kk.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6572 / V1.1.1 / rtech72_we_72_kk / EMMC FW Size : 933 MiB Scatter saved to : C:\Users\Sabit\Desktop\infinity backup\MT6572__alps__G9200__rtech72_we_72_kk__4.4. 2__ALPS.KK1.MP6.V1\ All done! Done! Elapsed: 00:05:45 Reconnect Power/Cable! Finish at : [12/19/2015 / 9:46:40 AM] |
12-19-2015, 21:06 | #29545 (permalink) |
12-19-2015, 21:09 | #29546 (permalink) |
Member: 1809548 Status: Offline Sonork: mysty619/100.167036 Thanks Meter: 120 | samsung clone note 5 read firmware done Start at : [12/19/2015 / 9:53:09 AM] Operation : Read Flash [ v1.38 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 11010030303447453001885E8925428B DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 0EG40 [eMMC] : FLASH_CID : 11010030303447453001885E8925428B [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : alps ProdName : rtech72_we_72_kk ProdModel : SM-910U Device : rtech72_we_72_kk AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP6.V1 [Read Ok] : preloader_rtech72_we_72_kk.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6572 / V1.1.1 / rtech72_we_72_kk / EMMC FW Size : 933 MiB Scatter saved to : C:\Users\Sabit\Desktop\infinity backup\MT6572__alps__SM-910U__rtech72_we_72_kk__4.4.2__ALPS.KK1.MP6.V1\ All done! Done! Elapsed: 00:05:32 Reconnect Power/Cable! Finish at : [12/19/2015 / 9:58:41 AM] |
12-19-2015, 21:09 | #29547 (permalink) |
12-20-2015, 06:30 | #29548 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Calme s12 pac file read done Code: Operation : Read FullFlash [ v1.08 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 184 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 eMMC loader v1.1 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected eMMC Flash , Structure detect Ok! [FW_READER] : Step #1 Passed! [FW_READER] : Step #2 Passed! [FW_READER] : Step #3 Passed! Phone found! [ 184 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 eMMC loader v1.1 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! Model Name : w360a2_0201 Model Brand : KENXINDA Model Device: w360a2_0201 AndrVersion : 4.4.2 BaseBand CPU: W360A2_0201 Project Ver : MocorDroid V0 Model Ext : SPARK_S12 [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : nvitem.bin [Read Ok] : nvitem_wcn.bin [Read Ok] : sc7715_modem.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : CP2._CP2_WCN_14C_W14.45_Release.bin [Read Ok] : logo_320x480.bin [Read Ok] : fblogo_320x480.bin [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : userdata.img Firmware Size : 535 MiB Saved to : C:\Documents and Settings\saeed\My Documents\W360A2_0201_w360a2_0201_4.4.2_MocorDroid_V0\ Done! Elapsed: 00:09:12 Reconnect Power/Cable! |
The Following User Says Thank You to saeedullah_khan For This Useful Post: |
12-20-2015, 06:30 | #29549 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Qmobile R850 Read Factory File Done Code: Operation : Read Flash [ v1.39 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 37 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 7662C6AAB5E9DF364DD9642349B3350D BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3700 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DC , [MX] MX25U6435E [0] : FLASH_DIE : 00C2 0025 0037 0000 [0] : FLASH_LEN : 0x00800000 INT_RAM : 0x0000D000 EXT_RAM : 0x00800000 SDS_INFO : 0x007FE000 , 0x00002000 Reading Flash Conent now ... Read Flash now Read Ok , 8388608 bytes read Check and collect compile info File_Info : KEYTAK60A_64_11B_PCB01_gprs_MT6260_S00.MAUI_11B_W13_08_MP_V3_F5.bin FileVersion : MAUI.11B.W13.08.MP.V3.F5 [ScatCFG] : MT6260 / MAUI.11B.W13.08.MP.V3.F5 / NOR , SF Firmware saved to : C:\InfinityBox\CM2MTK\Read_out\KEYTAK60A_64_11B_PCB01_gprs_MT6260_S00\ Done! Elapsed: 00:00:25 Reconnect Power/Cable! |
12-20-2015, 06:56 | #29550 (permalink) |
No Life Poster Join Date: Nov 2010 Location: Searching....
Member: 1442705 Status: Offline Thanks Meter: 1,061 | Samsung Og SM-B310E read flash and read code Done Read User Code Absar_Global |
The Following 2 Users Say Thank You to Absar_Global For This Useful Post: |
