11-14-2015, 10:08 | #28036 (permalink) | ||
No Life Poster Join Date: Jul 2015 Location: India
Member: 2421242 Status: Offline Sonork: 100.1614558 Thanks Meter: 700 | read info Quote:
The Following 2 Users Say Thank You to 4G Telecom For This Useful Post: |
11-14-2015, 11:10 | #28037 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | Nokia 130 (RM-1035) Flashing :- Code: Core : v2.12 , MTKx FlashEngine : v8.6 Verify files ... MAUI : RM-1035_ROM_eMP_10.01.11 VIVA : RM-1035_VIVA_eMP_10.01.11 LANG : RM-1035_LANG_PACK_ROM_IJ_eMP_10.01.11_001 CUST : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 JMPT : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 27 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : F4773DD94E5032977DAE1E4B5DDD5EEF BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Crystal.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E [0] : FLASH_DIE : 00C2 0025 0036 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 SecureDecrypt : RM-1035_ROM_eMP_10.01.11 SecureDecrypt : RM-1035_VIVA_eMP_10.01.11 SecureDecrypt : RM-1035_LANG_PACK_ROM_IJ_eMP_10.01.11_001 SecureDecrypt : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 SecureDecrypt : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 OVRLP : 000069B900000001 PHPID : CRYSTAL.10.01.11.p2 === Backup Enabled Reading RPL backup... Read Error : Not allowed === Backup OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok ERASE_MAUI_INFO : 0x0001C000 WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1035_ROM_eMP_10.01.11 Write : RM-1035_LANG_PACK_ROM_IJ_eMP_10.01.11_001 Write : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 Write : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 Write : RM-1035_VIVA_eMP_10.01.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1035_ROM_eMP_10.01.11 [VERIFY] DONE : RM-1035_LANG_PACK_ROM_IJ_eMP_10.01.11_001 [VERIFY] DONE : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 [VERIFY] DONE : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 [VERIFY] DONE : RM-1035_VIVA_eMP_10.01.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:00:54 Reboot phone Ok |
11-14-2015, 11:50 | #28038 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Pakistan
Member: 192810 Status: Offline Sonork: Some people NEED change Thanks Meter: 860 | Qmobile Z4 "47" Infected Virus Files Removed by CM2 Code: Operation : Check / Read Info [ v1.37 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 14 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 4900011530305532CF6017414D806766 DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , A00U2 [eMMC] : FLASH_CID : 1501004932553030411760CF6667804D [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : QMobile ProdName : QMobile ProdModel : Z4 Device : QMobile AndroidVer: 4.2.1 MTKxCPU : MT6589 MTKxPRJ : ALPS.JB2.MP.V1.2 MODEM : BaseBand : MT6589_S00_MOLY_WR8_W1248_MD_WG_MP_V6_P22 EXTRA : LCD [0] : gn_truly_r63315 LCD [1] : gn_sharp_r63311 LCD [2] : gn_jdi_r63311 LCD Res : 1920x1080 TOUCH [0] : gn_goodix_gt915 TOUCH [1] : #GT9XX TOUCH [2] : #cy8ctma300 TOUCH [3] : GT818B-fpga CAM [0] : gn_truly_ov12830_mipi_raw CAM [1] : ov12830_truly_mipi_raw CAM [2] : ov12830_mipi_raw CAM [3] : ov5648_mipi_raw CAM [4] : ov5648_mipi_truly_raw MODEM : WBW5885_gionee89_dwe_jb2_md1_hspa LOCALE : en_US ar_EG fa_IR ur_PK ldpi hdpi mdpi xhdpi xxhdpi Done! Elapsed: 00:00:17 Reconnect Power/Cable! Operation : Remove Viruses [SmartAV] [ v1.37 ] SmartAV Conf : 100/75/4000 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 14 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 4900011530305532CF6017414D806766 DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , A00U2 [eMMC] : FLASH_CID : 1501004932553030411760CF6667804D [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 47 Removing infected files and scripts ... SmartAV Report : Removed 47 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #2 : PostFix Ok! Done! Done! Elapsed: 00:00:46 Reconnect Power/Cable! Operation : Format FileSystem [ v1.37 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 14 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 4900011530305532CF6017414D806766 DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , A00U2 [eMMC] : FLASH_CID : 1501004932553030411760CF6667804D [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
11-14-2015, 11:53 | #28039 (permalink) |
Member: 192810 Status: Offline Sonork: Some people NEED change Thanks Meter: 860 | Rivo RX60 "32" Infected Virus Files Done by CM2 Code: Operation : Check / Read Info [ v1.37 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 14 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3758564D4201884AC60F126D DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D4201884AC60F126D [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : RHYTHM ProdName : RX60 ProdModel : RHYTHM RX60 Device : RHYTHM_RX60 AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : RIVO_RHYTHM_RX60_S006_20150109 EXTRA : LCD [0] : ili9806e_dsi_vdo_fwvga_txd_aw1055 LCD [1] : otm8018b_dsi_vdo_fwvga_dj_aw1055 LCD Res : 854x480 TOUCH [0] : ft6436l_zaw1055 TOUCH [1] : gt9xx_1055 TOUCH [2] : msg2256_1055 TOUCH [3] : # CAM [0] : s5k4h5yx_mipi_raw_zaw1055 CAM [1] : ov8858_mipi_raw_zaw1055 CAM [2] : hi545_mipi_raw_zaw1055 CAM [3] : ov5648_mipi_raw_zaw1055 CAM [4] : hi258_mipi_yuv_zaw1055ba CAM [5] : gc2235_mipi_raw_zaw1055ba MODEM : aw1055_md1_hspa_gemini_g4w1_w2100 LOCALE : en_US es_ES zh_CN zh_TW ru_RU pt_BR fr_FR de_DE tr_TR it_IT in_ID ms_MY vi_VN ar_EG th_TH pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ iw_IL my_MM km_KH ko_KR ur_PK Done! Elapsed: 00:00:10 Reconnect Power/Cable! Operation : Remove Viruses [SmartAV] [ v1.37 ] SmartAV Conf : 100/75/4000 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 14 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3758564D4201884AC60F126D DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D4201884AC60F126D [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 32 Removing infected files and scripts ... SmartAV Report : Removed 32 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #2 : PostFix Ok! Done! Done! Elapsed: 00:01:22 Reconnect Power/Cable! Operation : Format FileSystem [ v1.37 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 14 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3758564D4201884AC60F126D DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D4201884AC60F126D [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:23 Reconnect Power/Cable! |
11-14-2015, 12:03 | #28040 (permalink) |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | intex aqua y2 pro reset privacy lock with lost of any data Code: Operation : Reset Privacy Lock [ v1.36 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 59 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 110100303034473930108A0B4D87718B DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : 09G40 [eMMC] : FLASH_CID : 110100303034473930108A0B4D87718B [eMMC] : FLASH_EXT : 00200000/00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Checking data ... Processing with "Safe UserData" mode SafeDetect : Done! Will reset now! Privacy Lock reset Ok! Done! Elapsed: 00:00:40 Reconnect Power/Cable! |
11-14-2015, 12:27 | #28041 (permalink) |
Registered User Join Date: Feb 2008 Location: India
Member: 714467 Status: Offline Sonork: 100.1641520 Thanks Meter: 46 | Micromax Q411 MTK 6735 Read patten Done Wait for phone... Phone found! [ 102 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6735 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6735_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 510001154D533237CD820042C5E28A57 DA Stat : v4.2 on BBID : 0x93 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMS27 [eMMC] : FLASH_CID : 150100513732534D420082CD578A82C5 [eMMC] : FLASH_EXT : 00400000/00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... FS Size : 4527 MiB Magic Ok Mount point : /data Get PatternLock ... PatternLock Sequnce : 2456987 Done! Elapsed: 00:00:23 Reconnect Power/Cable! |
11-14-2015, 12:40 | #28042 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Rivo Advance A255 Read Flash File Done Code: Operation : Read Flash [ v1.37 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 66 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 0B9C068D92749B4D66DD1B7E6E223E32 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DC , [MX] MX25U6435E [0] : FLASH_DIE : 00C2 0025 0037 0000 [0] : FLASH_LEN : 0x00800000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 SDS_INFO : 0x007FE000 , 0x00002000 Reading Flash Conent now ... Read Flash now Read Ok , 8388608 bytes read Check and collect compile info File_Info : FARSIGHTED61A_12832_11C_PCB01_gprs_MT6261_S00.RIVO_ADVANCE_A255_V06.bin FileVersion : RIVO_ADVANCE_A255_V06 Saved to : C:\InfinityBox\CM2MTK\Read_out\FARSIGHTED61A_12832_11C_PCB01_gprs_MT6261_S00.RIVO_ADVANCE_A255_V06.bin Done! Elapsed: 00:00:39 Reconnect Power/Cable! |
11-14-2015, 13:01 | #28043 (permalink) |
Member: 355782 Status: Offline Thanks Meter: 1,265 | Qmobile M400 Phone Lock removed. Code: Chinese Miracle II [MTK module] v 1.37 Operation : Reset UserCode [ v1.37 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 9 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 99E379EDA8FD346E969F2B7B2EA3D506 BROM Protocol Version : 05 Setting... Setting done , result code 0x0000 BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00300000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 SDS_INFO : Not exists Backup done Read ExtData Sorting ExtData Sort Ok, Rebuild Ok Restore ExtData All done UserCode request removed UserCode set to default ( 0000 or 1122 ) Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
11-14-2015, 13:36 | #28045 (permalink) |
No Life Poster Join Date: Jul 2006 Location: punjab Age: 43
Member: 315867 Status: Offline Sonork: 100.1654770 Thanks Meter: 708 | croma tab smart av done Chinese Miracle II [MTK module] v 1.37 Operation : Check / Read Info [ v1.37 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 8801034E436172642034AD4A81634187 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0088 , OEM : 0103 [eMMC] : FLASH_INF : [NOT_IN_BASE] , draC [eMMC] : FLASH_CID : 8801034E436172642034AD4A81634187 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00000000 [eMMC] : FLASH_LEN : 0x00000001CE100000 [eMMC] : FLASH_UCP : 7393 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : CROMA ProdName : mbk82_tb_kk ProdModel : CRXT 1125Q Device : mbk82_tb_kk AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : GP728F_MT8382_7703-12_V5.1_20140709 MODEM : BaseBand : MT6582_S00_MOLY_WR8_W1315_MD_WG_MP_V15_P2_1_wg_n Done! Elapsed: 00:00:09 Reconnect Power/Cable! Operation : Remove Viruses [SmartAV] [ v1.37 ] SmartAV Conf : 100/75/4000 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 8801034E436172642034AD4A81634187 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0088 , OEM : 0103 [eMMC] : FLASH_INF : [NOT_IN_BASE] , draC [eMMC] : FLASH_CID : 8801034E436172642034AD4A81634187 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00000000 [eMMC] : FLASH_LEN : 0x00000001CE100000 [eMMC] : FLASH_UCP : 7393 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 59 Removing infected files and scripts ... SmartAV Report : Removed 59 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #2 : PostFix Ok! Done! Done! Elapsed: 00:01:22 Reconnect Power/Cable! Operation : Format FileSystem [ v1.37 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 8801034E436172642034AD4A81634187 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0088 , OEM : 0103 [eMMC] : FLASH_INF : [NOT_IN_BASE] , draC [eMMC] : FLASH_CID : 8801034E436172642034AD4A81634187 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00000000 [eMMC] : FLASH_LEN : 0x00000001CE100000 [eMMC] : FLASH_UCP : 7393 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
11-14-2015, 13:52 | #28048 (permalink) |
Member: 355782 Status: Offline Thanks Meter: 1,265 | Qmobile A8i Backup Done:- Read Factory Firmware Code: Operation : Read Flash [ v1.37 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35585A4D42011B6DDC2241BD DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMZX5 [eMMC] : FLASH_CID : 1501004E35585A4D42011B6DDC2241BD [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : QMobile ProdName : QMobile ProdModel : A8i Device : QMobile AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1 [Read Ok] : preloader_gionee72_wet_jb3.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : spdata.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6572 / V1.1.1 / gionee72_wet_jb3 / EMMC FW Size : 938 MiB Scatter saved to : F:\Firmware\MT6572__QMobile__A8i__QMobile__4.2.2__ALPS.JB3.MP.V1\ All done! Done! Elapsed: 00:04:53 Reconnect Power/Cable! Read NVRAM Code: Operation : Read NVRAM [ v1.37 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35585A4D42011B6DDC2241BD DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMZX5 [eMMC] : FLASH_CID : 1501004E35585A4D42011B6DDC2241BD [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [Info] : Can't identify BB version! Read Ok, MT6572_eMMC.spnv saved Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
11-14-2015, 13:57 | #28049 (permalink) | |||
Freak Poster Join Date: May 2009 Location: *JAVA*
Member: 1026340 Status: Offline Sonork: 100.1621159 Thanks Meter: 142 | remove monkey test samsung note 3 sc read info Quote:
remove virus Quote:
format Quote:
11-14-2015, 14:17 | #28050 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Inside Universe
Member: 442808 Status: Offline Thanks Meter: 195 | Intex Aqua 3G Strong Sucessfully Repair No Media file Show Code: Operation : Check/Read Info [ v1.05 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 73 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Generic Loader NAND v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : NAND Flash , Structure : Ok! ExtraInfo : HWInfo not exists, normal phone ExtraInfo : GSM Phone Elapsed: 00:00:26 Reconnect Power/Cable! Code: Operation : Format File System [ v1.05 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 73 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Generic Loader NAND v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected NAND Flash , Structure detect Ok! Formatting NAND Flash Format UserData Format Ok! Format Cache Format Ok! Done! Elapsed: 00:00:32 Reconnect Power/Cable! |
The Following User Says Thank You to situ_saraf For This Useful Post: |
