Old 12-23-2016, 07:08   #38641 (permalink)
diesel6's Avatar
Member: 315867
Sonork: 100.1654770
Thanks Meter: 708
Brand : LYF
ProdName : LS-5009
ProdModel : LS-5009
Device : LS-5009
AndroidVer: 5.1.1
Manufact. : LYF
QLMxCPU : MSM8909
QLMxPRJ : LYF_LS-5009_00_223_160930
read full flash done
Operation : Read Flash [ v1.06 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 210 [MSM8909]
ID_BLOCK_S : 0379F31D
ID_BLOCK_I : 009600E1
ID_BLOCK_L : AA5A30CE69F5E2EDDA8F414E89D06068
ID_BLOCK_L : 5023ED3C31A00A9B3EF9D20B199482C9
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ]
ExtInfo : 0x0000C000/00100000/00001000/00001000
Boot Ok!
Brand : LYF
ProdName : LS-5009
ProdModel : LS-5009
Device : LS-5009
AndroidVer: 5.1.1
Manufact. : LYF
QLMxCPU : MSM8909
DevInfo : MSM8909__LYF__LYF__ANDR_v5.1.1__LS-5009__LS-5009__LS-5009__LYF_LS-5009_00_223_160930
Reading Flash Content ...
[Read Ok] : gpt_main0.bin
[Read Ok] : NON-HLOS.bin
[Read Ok] : sbl1.mbn
[Read Ok] : emmc_appsboot.mbn
[Read Ok] : rpm.mbn
[Read Ok] : tz.mbn
[Read Ok] : misc.img
[Read Ok] : splash.img
[Read Ok] : fs_gc.img
[Read Ok] : sec.dat
[Read Ok] : boot.img
[Read Ok] : system.img
[Read Ok] : persist.img
[Read Ok] : cache.img
[Read Ok] : recovery.img
[Read Ok] : userdata.img
[Read Ok] : gpt_backup0.bin
Android Info saved!
Read finished!
Configuration : MSM8909 / eMMC
Firmware Size : 2199 MiB
Done!
Elapsed: 00:05:04
Reconnect Power/Cable!
Old 12-23-2016, 07:43   #38642 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 4,073
QMobile I2 Write Firmware Done :)
Infinity SC Firmware Detected
FW Size : 1927 MiB
Load Ok!
File Info
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand   : Qmobile
Device Model   : QMobile_i2
Device CPU     : QMobile_i2
Device IntName : QMobile_i2
Device Version : 5.1
Device Compile : 3/11/2016 2:00:40 AM
Device Project : QMobile_i2_MP_11_03
Device ExtInfo : QMobile i2
Operation : Flash [ v1.24 ]
======= Flash
Files set for flashing :
[ MCU ] : SC77xx Infinity Package
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
 ====  Wait for phone...
Phone found! [ 28 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SPRD 773x eMMC loader v4 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
PMTManager : Load 0x17 records
PMTManager : PMT Update Ok!
Flashing now
Update BootCode : u-boot-spl-16k.bin
Write Data ...
Write Data Ok!
Update BootCode : u-boot.bin
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write FSImage : prodnv.img
Write Data ...
Write Data Ok!
Write CodeData : sc7731g_CP0_modem.bin
Write Data ...
Write Data Ok!
Write CodeData : DSP_DM_Gx.bin
Write Data ...
Write Data Ok!
Erase Block : RuntimeData
Erase block ...
Block erase Ok!
Write CodeData : sc8830g_modem_CP2_WCN_14D_W15.43.3_Release.bin
Write Data ...
Write Data Ok!
Erase block ...
Block erase Ok!
Write CodeData : logo_480x854.bin
Write Data ...
Write Data Ok!
Write CodeData : fblogo_480x854.bin
Write Data ...
Write Data Ok!
Write CodeData : boot.img
Write Data ...
Write Data Ok!
Write FSImage : system.img
Write Data ...
Write Data Ok!
Write FSImage : cache.img
Write Data ...
Write Data Ok!
Write CodeData : recovery.img
Write Data ...
Write Data Ok!
Erase Block : MISC
Erase block ...
Block erase Ok!
Write FSImage : userdata.img
Write Data ...
Write Data Ok!
Elapsed: 00:07:09
Old 12-23-2016, 07:54   #38643 (permalink)
Member: 654997
Thanks Meter: 4,073
Samsung C5212 (Clone) Format / Repair Done :)
Phone was hang on logo ......... bla bla
Operation : Format File System
Settings : SmartFormat is On
Waiting phone ...
Connect battery, press and hold '0' button
Connect USB cable and keep hold button, until phone will be detected
Init  : 55555555
Settings registers ...
1st boot Ok
==== CPU
CPU_ID : 8809 , rev : 4007
CPU_CN : RDA Micro CT , RDA8851L
==== FLASH
FL_VEN : 60C8 , rev : 1600
FL_CNM : GigaDevice , GD25Q32
FL_CAP : 00400000
Initial : 81C0024C
==== Booting
Sending RamRun Loader ...
Set : 8809 , 00400000
Use : 8809_00400000_usb.fp
Sending HdrConf ...
Sending LdrData ...
Loader sent, starting...
Flush : 0400F000
Loader run
Boot Done!
NVMFAT Area : 0x003A0000 , Len : 0x0005C000
Range as Factory Defined
Format User Area ...
CSD WR : 81C05954 , 81C05968
CSD DR : A2000000 , A2008000 , A2010000
CSD MB : 00008000
Format Done
Elapsed: 00:00:22
Old 12-23-2016, 11:47   #38644 (permalink)
Member: 1732025
Sonork: 100.1615024
Thanks Meter: 329
Thumbs up lenovo A3300GV Hang on Logo Done
Operation : Flash [ v1.56 ]
======= Flash
Wait for phone...
Phone found! [ 13 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x87
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A4838473264040502A11F04918B
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d2G8
[eMMC] : FLASH_CID : 90014A4838473264040502A11F04918B
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0xB5B9A195C290A26D40773261573BA520
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6582 , Project : huaqin82_tb_b2d_td , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3782 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000001400000-0x0000000000100000
Erase : 0x0000000003100000-0x000000007BE00000
Flash Pre-Erase Done, time used : 00:00:01
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_huaqin82_tb_b2d_td.bin
Preloader Sent , Init passed
PartCount : 0012
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:03:13
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : LOGO
Verify Passed : ANDROID
Verify Passed : CACHE
Verify Passed : USRDATA
Data Verify Done, time used : 00:00:10
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:03:43
The Following User Says Thank You to ssony For This Useful Post:
Old 12-23-2016, 11:52   #38645 (permalink)
Crazy Poster
Member: 2539445
Sonork: 100.1648344
Thanks Meter: 53
Nokia 215 Full Flash Done
Connect phone on selected interface...
Core : v2.23 , MTKx FlashEngine : v10.1
Verify files ...
MAUI : RM-1110_ROM_eMP_12.03.11
VIVA : RM-1110_VIVA_eMP_12.03.11
LANG : RM-1110_LANG_PACK_ROM_IJ_eMP_12.03.11_001
CUST : RM-1110_CUSTPACK_ROM_IJ_MEA_PK_eMP_12.03.11_001
JMPT : RM-1110_JUMP_TABLE_IJ_MEA_PK_eMP_12.03.11_001
 - > MODE : FullFlash
Dead Mode is Selected
Waiting for USB device...
1. Phone should be Off!
2. Battery must be charged and inserted! ( if not used external power )
 - > If phone can't switch to BL - use battery or flash from Local mode!
--- Insert USB cable now! ---
Wait for phone...
Phone found! [ 25 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6260_S0001
BB_CPU_SN : F726FA0DD3BE0C4A450FD3E3F0C6114F
BROM Protocol Version : 05
BROM Status : 0000
Comm Status : 0000
EXBL Status : Alive [ USB Load Active ]
Switch to BL done
BL Version : 01
Setting...
Setting done , result code 0x8000
Project ID : JET.10.01.11.p1
BROM/BL stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_eMP_Jet.fg
DA_VERIFY : 00
DA_JUMP   : 00040000
DA_AUTH   : Passed!
DA_INFO   : 0xC0 , Ver : 3.2 , BBID : 0x8B
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G
[0] : FLASH_DIE : 00C2 0025 0038 0000
[0] : FLASH_LEN : 0x01000000
FAT_RANGE : 0x00E80000-0x00FF3FFF , LEN : 0x00174000
SecureDecrypt : RM-1110_ROM_eMP_12.03.11
SecureDecrypt : RM-1110_VIVA_eMP_12.03.11
SecureDecrypt : RM-1110_LANG_PACK_ROM_IJ_eMP_12.03.11_001
SecureDecrypt : RM-1110_CUSTPACK_ROM_IJ_MEA_PK_eMP_12.03.11_001
SecureDecrypt : RM-1110_JUMP_TABLE_IJ_MEA_PK_eMP_12.03.11_001
OVRLP : 000069B900000001
PHPID : JET.10.01.11.p1
OVRLP : 00004DF900000001
DA : FORMAT_BIN
Processing Flash Pre-format
FILES : 5
SAFE_BLOCK : 04
FORMAT_BIN : Ok
WRITE_STYLE : DEF : 0x01 (SEQ)
Write : RM-1110_ROM_eMP_12.03.11
Write : RM-1110_LANG_PACK_ROM_IJ_eMP_12.03.11_001
Write : RM-1110_CUSTPACK_ROM_IJ_MEA_PK_eMP_12.03.11_001
Write : RM-1110_JUMP_TABLE_IJ_MEA_PK_eMP_12.03.11_001
Write : RM-1110_VIVA_eMP_12.03.11
CODE_DNLOAD : Ok
[VERIFY] DONE : RM-1110_ROM_eMP_12.03.11
[VERIFY] DONE : RM-1110_LANG_PACK_ROM_IJ_eMP_12.03.11_001
[VERIFY] DONE : RM-1110_CUSTPACK_ROM_IJ_MEA_PK_eMP_12.03.11_001
[VERIFY] DONE : RM-1110_JUMP_TABLE_IJ_MEA_PK_eMP_12.03.11_001
[VERIFY] DONE : RM-1110_VIVA_eMP_12.03.11
CODE_VERIFY : Ok
Executing FFS FORMAT now...
DA_RET   : DA_IN_PROGRESS
DA_RET   : FORMAT_DONE
Rebooting phone now
Flashing done!
Total flash time : 00:02:58
Reboot phone Ok
Phone found!
MTKx Nokia Phone detected
Read info... Ok
The Following User Says Thank You to GSM Muzammal For This Useful Post:
Old 12-23-2016, 12:15   #38646 (permalink)
amar181's Avatar
Member: 510122
Sonork: 100.1606547
Thanks Meter: 1,822
Mi Max Pattern remove [ Success Story]
Mi Max Pattern remove successfully with 1.06 version
Log
Operation : Reset Settings [ v1.06 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 652 [MSM8976]
ID_BLOCK_S : 0232D636
ID_BLOCK_I : 009B00E1
ID_BLOCK_L : 2891F2D09C6B5D00B1CB95D04436C609
ID_BLOCK_L : FAFA70D7E631D109F65172750274A0E5
Running FireHose on BBID : MSM8976 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ]
Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : BJNB4R
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP ( Google Reset Protection )
FRP removed!
Reset Ok!
Done!
Elapsed: 00:00:15
Old 12-23-2016, 12:20   #38647 (permalink)
saif@cellplus's Avatar
Member: 26488
Sonork: 100.1581233
Thanks Meter: 151
SAMSUNG B229 Unlock done
COM108 [VCP0] selected
module v2.05
Device: Samsung-SCH-B209, B229, B309, B319, B619, B339FM
operation: SP-unlock
Phone should be Switched ON !
connecting...
Connecting, wait...
Phone detected, wait...
step-1/1 done
step-1/2 done
step-1/3 done
step-1/4 done
step-1/5 done
step-2 done
step-3 done
operation finished
Finished, time used: 27 sec
The Following User Says Thank You to saif@cellplus For This Useful Post:
Old 12-23-2016, 12:35   #38648 (permalink)
4G Telecom's Avatar
Member: 2421242
Sonork: 100.1614558
Thanks Meter: 700
ZTE T815 Unlock Done
Operation : SP Unlock [ v1.50 ]
Mode : Direct Unlock
Wait for phone...
Phone found! [ 60 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01
Running DA ver.4.2 on BBID : 0x88
eMMC Flash : 90014A4834473164040501A2F70E12FD
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164040501A2F70E12FD
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0xBACC33788D42ADE35E467E60293275F0
EXT RAM : 0x20000000 [512 MiB]
SOC VERIFY : C1
Boot Ok!
SIM Lock Status : Locked!
Unlocking now ...
Unlock done!
The Following 2 Users Say Thank You to 4G Telecom For This Useful Post:
Old 12-23-2016, 15:08   #38649 (permalink)
Wasim007's Avatar
Member: 500302
Thanks Meter: 157
Arrow lyf-5009 flashing done....
Loading firmware ...
Load Ok!
Operation : Flash [ v1.06 ]
Verify FW package ...
Verification passed!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_S : 04626AAF
ID_BLOCK_L : 34CCA650FF6B90934C21D33CFB46CEFE
ID_BLOCK_L : 3954FA5546C971F217E6AB60628D9BA0
Pickup loader from firmware package
MemInfo : 0x0003 / 0x0200 / 0x00000001C3000000 [ eMMC 8 GiB ]
Boot Ok!
Files in Chain : 104
Flashing now
Flashing : NON-HLOS.bin
Flashing : sbl1.mbn
Flashing : sbl1.mbn
Flashing : emmc_appsboot.mbn
Flashing : rpm.mbn
Flashing : rpm.mbn
Flashing : tz.mbn
Flashing : tz.mbn
Flashing : zero.bin
Flashing : zero.bin
Flashing : splash.img
Flashing : fsg_rlc01a.img
Flashing : sec.dat
Flashing : boot.img
Flashing : system_1.img
Flashing : system_2.img
Flashing : system_3.img
Flashing : system_4.img
Flashing : system_5.img
Flashing : system_6.img
Flashing : system_7.img
Flashing : system_8.img
Flashing : system_9.img
Flashing : system_10.img
Flashing : system_11.img
Flashing : system_12.img
Flashing : system_13.img
Flashing : system_14.img
Flashing : system_15.img
Flashing : system_16.img
Flashing : system_17.img
Flashing : system_18.img
Flashing : system_19.img
Flashing : system_20.img
Flashing : system_21.img
Flashing : system_22.img
Flashing : system_23.img
Flashing : system_24.img
Flashing : system_25.img
Flashing : system_26.img
Flashing : system_27.img
Flashing : system_28.img
Flashing : system_29.img
Flashing : system_30.img
Flashing : system_31.img
Flashing : system_32.img
Flashing : system_33.img
Flashing : system_34.img
Flashing : persist_1.img
Flashing : cache_1.img
Flashing : cache_2.img
Flashing : cache_3.img
Flashing : recovery.img
Flashing : userdata_1.img
Flashing : userdata_2.img
Flashing : userdata_3.img
Flashing : userdata_4.img
Flashing : userdata_5.img
Flashing : userdata_6.img
Flashing : userdata_7.img
Flashing : userdata_8.img
Flashing : userdata_9.img
Flashing : userdata_10.img
Flashing : userdata_11.img
Flashing : userdata_12.img
Flashing : userdata_13.img
Flashing : userdata_14.img
Flashing : userdata_15.img
Flashing : userdata_16.img
Flashing : userdata_17.img
Flashing : userdata_18.img
Flashing : userdata_19.img
Flashing : userdata_20.img
Flashing : userdata_21.img
Flashing : userdata_22.img
Flashing : userdata_23.img
Flashing : userdata_24.img
Flashing : userdata_25.img
Flashing : userdata_26.img
Flashing : userdata_27.img
Flashing : userdata_28.img
Flashing : userdata_29.img
Flashing : userdata_30.img
Flashing : userdata_31.img
Flashing : userdata_32.img
Flashing : userdata_33.img
Flashing : userdata_34.img
Flashing : userdata_35.img
Flashing : userdata_36.img
Flashing : userdata_37.img
Flashing : userdata_38.img
Flashing : userdata_39.img
Flashing : gpt_main0.bin
Flashing : gpt_backup0.bin
Flash sequence completed!
Records in Chain : 26
Processing records now
Records sequence completed!
Boot settings configured!
Flashing done!
Done!
Elapsed: 00:06:34
The Following User Says Thank You to Wasim007 For This Useful Post:
Old 12-23-2016, 15:56   #38650 (permalink)
shazzmob's Avatar
Member: 2327602
Sonork: 100.1620953
Thanks Meter: 276
Q mobile z8 qlm MSM 8916 flashing done by shazz with cm2
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 410 [MSM8916]
ID_BLOCK_S : 0C92F747
ID_BLOCK_I : 007050E1
ID_BLOCK_L : 5CA4DE389703083BE459BBA4633EB696
ID_BLOCK_L : 49048A2516B921A22796FB3032FDEBD0
Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ]
ExtInfo : 0x00004000/00004000/00001000/00001000
Boot Ok!
Files in Chain : 164
Flashing now
Flashing : sbl1.mbn
Flashing : sbl1.mbn
Flashing : rpm.mbn
Flashing : rpm.mbn
Flashing : tz.mbn
Flashing : tz.mbn
Flashing : hyp.mbn
Flashing : hyp.mbn
Flashing : fsg.img
Flashing : sec.dat
Flashing : boot.img
Flashing : cache_4.img
Flashing : userdata_40.img
Flashing : userdata_41.img
Flashing : userdata_42.img
Flashing : userdata_43.img
Flashing : userdata_44.img
Flashing : userdata_45.img
Flashing : userdata_46.img
Flashing : userdata_47.img
Flashing : userdata_48.img
Flashing : userdata_49.img
Flashing : userdata_50.img
Flashing : userdata_51.img
Flashing : userdata_52.img
Flashing : userdata_53.img
Flashing : userdata_54.img
Flashing : userdata_55.img
Flashing : userdata_56.img
Flashing : userdata_57.img
Flashing : userdata_58.img
Flashing : userdata_59.img
Flashing : userdata_60.img
Flashing : userdata_61.img
Flashing : userdata_62.img
Flashing : userdata_63.img
Flashing : userdata_64.img
Flashing : userdata_65.img
Flashing : userdata_66.img
Flashing : userdata_67.img
Flashing : userdata_68.img
Flashing : userdata_69.img
Flashing : userdata_70.img
Flashing : userdata_71.img
Flashing : userdata_72.img
Flashing : userdata_73.img
Flashing : userdata_74.img
Flashing : userdata_75.img
Flashing : userdata_76.img
Flashing : userdata_77.img
Flashing : userdata_78.img
Flashing : userdata_79.img
Flashing : userdata_80.img
Flashing : userdata_81.img
Flashing : userdata_82.img
Flashing : userdata_83.img
Flashing : userdata_84.img
Flashing : userdata_85.img
Flashing : userdata_86.img
Flashing : userdata_87.img
Flashing : userdata_88.img
Flashing : userdata_89.img
Flashing : userdata_90.img
Flashing : userdata_91.img
Flashing : userdata_92.img
Flashing : userdata_93.img
Flashing : userdata_94.img
Flashing : userdata_95.img
Flashing : userdata_96.img
Flashing : userdata_97.img
Flashing : userdata_98.img
Flashing : userdata_99.img
Flashing : userdata_100.img
Flashing : userdata_101.img
Flashing : userdata_102.img
Flashing : userdata_103.img
Flashing : userdata_104.img
Flashing : userdata_105.img
Flashing : userdata_106.img
Flashing done!
Done!
Elapsed: 00:09:59
Old 12-23-2016, 17:03   #38651 (permalink)
vasimj's Avatar
Member: 930047
Thanks Meter: 52
MI 3s prime(2016032) phone lock done
image uploading site
The Following User Says Thank You to vasimj For This Useful Post:
Old 12-23-2016, 18:34   #38652 (permalink)
bright hlatini's Avatar
Member: 1614640
Thanks Meter: 468
Huawei Y511-U30 sim unlock done
Card found : S/N : xxxxxxx , v0134
Operation : SP Unlock [ v1.58 ]
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A4834473164048601A3F200518B
[eMMC] : FLASH_CID : 90014A4834473164048601A3F200518B
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
[eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB]
DEV RID : 0xD2FF4FA4B54E6F8088C50FEAEB611CB6
SOC VERIFY : C1
Boot Ok!
Unlocking now ...
Unlock done!
Done!
Elapsed: 00:01:03
The Following User Says Thank You to bright hlatini For This Useful Post:
Old 12-23-2016, 21:59   #38653 (permalink)
Member: 2579338
Thanks Meter: 21
mi 3s mi account reset done
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 430 [MSM8937]
ID_BLOCK_S : 008DA961
ID_BLOCK_I : 0004F0E1
ID_BLOCK_L : FDBA2905B7BE62355C10A0E77BEB1324
ID_BLOCK_L : 57A1DB7ABD9CB66413EA2F1A65D11D40
Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ]
Storage : MFR : 0x11 , VENDOR : TOSHIBA , NAME : 016G70
Boot Ok!
MIAccount reset passed!
Normal reset :
> Select "FORCED FIX" or "REPAIR" in FMT settings, press "Format FS / Reset Settings"
> PowerOn device and use. IF Device stuck on black screen with cable - use another FMT
> Not all devices supported yet! (tested on Hydrogen,Land,Redmi2)
Done!
Elapsed: 00:00:49
Old 12-24-2016, 06:45   #38654 (permalink)
Member: 654997
Thanks Meter: 4,073
QMobile X90 Write Factory Firmware Done :)
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A4838473165050703D851BF524F
[eMMC] : FLASH_INF : [HYNIX] , e1G8
[eMMC] : FLASH_CID : 90014A4838473165050703D851BF524F
DEV RID    : 0x2BFA537DF92C7C7940B746B727B7DE76
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : ztenj72_we_72_m536_kk , Storage : EMMC
BL : BatteryLevel : 3880 mV
Erase : 0x0000000000C00000-0x0000000000100000
Erase : 0x0000000002900000-0x00000000CEF40000
Flash Pre-Erase Done, time used : 00:00:02
Use : preloader_ztenj72_we_72_m536_kk.bin
PartCount : 0013
Repartition Done!
Use FLN Mode
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:03:21
Processing : Verify
Verify Passed : MBR
Data Verify Done, time used : 00:00:15
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:03:56
Old 12-24-2016, 07:23   #38655 (permalink)
Member: 1614640
Thanks Meter: 468
Huawei Y360-U31 slot permanently blocked unlocked in 42 seconds with CM2MTK
Card found : S/N : xxxxxxxxxxxx , v0134
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 11010030303447453001A3C9560C82CF
[eMMC] : FLASH_VEN : 0x11 , OEM : 0100
[eMMC] : FLASH_INF : [TOSHIBA] , 0EG40
[eMMC] : FLASH_CID : 11010030303447453001A3C9560C82CF
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000
[eMMC] : FLASH_LEN : 0x00000000EC000000
[eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB]
DEV RID : 0xD2FF4FA4BF7EDF36633A22678ADC8B61
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : HUAWEI
ProdName : Y360-U31
ProdModel : HUAWEI Y360-U31
Device : HWY360-U
AndroidVer: 4.4.2
MTKxCPU : MT6582
MTKxPRJ : ALPS.KK1.MP1.V2.10
SECURITY :
IMEI_SW [1] : 866838022658377
BTMAC Addr : A4BA7601B362
WiFi MAC : A4BA7601B363
MODEM :
BaseBand : MT6582_S00_MOLY_WR8_W1315_MD_WG_MP_V34_P1_1_wg_n
EXTRA :
LCD [0] : nt35512_wvga_dsi_vdo
LCD [1] : hx8379c_wvga_dsi_vdo ili9806e_dsi_vdo
LCD Res : 800x480
TOUCH [0] : GT1143
TOUCH [1] : MSG2138
TOUCH [2] : ft6336
CAM [0] : gc2355_mipi_raw
CAM [1] : ov2680_mipi_raw
CAM [2] : ov2680_mipi_raw_yiweili
CAM [3] : ov5670_mipi_raw
CAM [4] : hi551_mipi_raw
CAM [5] : ov5670_mipi_raw_yiweili
MODEM : wingtech82_wet_82kk_hspa_wt_pa_sky77590_band18_std _98360c30
LOCALE : es_US en_US zh_CN pt_BR es_ES pt_PT fr_FR de_DE ru_RU it_IT zh_HK zh_TW sv_SE nb_NO da_DK cs_CZ hu_HU sk_SK pl_PL ro_RO el_GR sr_RS mk_MK bg_BG fi_FI et_EE lv_LV lt_LT sl_SI hr_HR uk_UA tr_TR vi_VN in_ID nl_NL th_TH ms_MY ca_ES hi_IN en_GB my_MM ko_KR bs_BA mk_MK
Done!
Elapsed: 00:00:27
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Unlocking now ...
Unlock done!
Done!
Elapsed: 00:00:42
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.51413 seconds with 10 queries
