11-26-2016, 14:02 | #37891 (permalink) |
No Life Poster Join Date: Oct 2009 Location: india Age: 37
Member: 1146038 Status: Offline Thanks Meter: 196 | itel it1508 Plus FRP done but my phone ver . 5.1 Code: Operation : Format File System / Reset Settings [ v1.24 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 22 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.24 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 22 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x000000014ABF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
11-26-2016, 14:43 | #37892 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | GFIVE President G6 Plus Virus Write File Code: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473264040506A2D131326F Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A4838473264040506A2D131326F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xD5229C2505FDA2FD0458B389883AEB64 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : GFIVE ProdName : hct82_cwet_kk ProdModel : GFIVE President G6 Plus Device : hct82_cwet_kk AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : GFIVE_President_G6_Plus_20150626 SECURITY : IMEI_SW [1] : 866384020978210 IMEI_SW [2] : 866384021081212 BTMAC Addr : FEDE46658269 WiFi MAC : 000000000000 Done! Elapsed: 00:00:08 Reconnect Power/Cable! Scatter Load Ok , BaseBand : MT6582 , Project : hct82_cwet_kk , Storage : EMMC Files found : 13 , Set to Flash : 12 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473264040506A2D131326F Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A4838473264040506A2D131326F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xD5229C2505FDA2FD0458B389883AEB64 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6582 , Project : hct82_cwet_kk , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3971 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000001CEE00000 Flash Pre-Erase Done, time used : 00:00:16 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_hct82_cwet_kk.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0014 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : EBR2 Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash now : FAT Image Flash Ok Flash Write Done, time used : 00:02:00 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : EBR2 Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Verify Passed : FAT Data Verify Done, time used : 00:00:37 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:12 Reconnect Power/Cable! |
11-26-2016, 14:44 | #37893 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Qmobile I5 Hang Logo Write File Code: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 110100303034473930519C8EB651611D Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 09G40 [eMMC] : FLASH_CID : 110100303034473930519C8EB651611D [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0xD5229C255D0203FFC988F2390B0440B3 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : QMobile ProdName : QMobile i5 ProdModel : QMobile i5 Device : QMobile i5 AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.KK1.MP1.V2.10 SECURITY : IMEI_SW [1] : 353861061875264 IMEI_SW [2] : 353861066875269 BTMAC Addr : D83C6936C4FC WiFi MAC : D83C69369CF2 Done! Elapsed: 00:00:07 Reconnect Power/Cable! Scatter Load Ok , BaseBand : MT6582 , Project : s4700 , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 110100303034473930519C8EB651611D Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 09G40 [eMMC] : FLASH_CID : 110100303034473930519C8EB651611D [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0xD5229C255D0203FFC988F2390B0440B3 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6582 , Project : s4700 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3538 mV BL : [WARNING] : BatteryLevel LOW!!! BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000000E5E00000 Flash Pre-Erase Done, time used : 00:00:12 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_s4700.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:03:18 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:51 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:04:40 Reconnect Power/Cable! |
11-26-2016, 14:45 | #37894 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Qmobile M95 Virus write File Code: Operation : Check/Read Info [ v1.24 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : scx35_sp7731geaplus_dt Model Brand : QMobile Model Device: scx35_sp7731gea AndrVersion : 4.4.3 BaseBand CPU: SP7731GEA CompileDate : 7/31/2015 12:00:38 PM Project Ver : KOT49H 14B_test-keys Model Ext : QMobile M95 ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:23 Reconnect Power/Cable! Infinity SC Firmware Detected FW Size : 1239 MiB Load Ok! Operation : Flash [ v1.24 ] ======= Flash Files set for flashing : [ MCU ] : SC77xx Infinity Package 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x17 records PMTManager : PMT Update Ok! Flashing now Update BootCode : u-boot-spl-16k.bin Write Data ... Write Data Ok! Update BootCode : u-boot.bin Erase block ... Block erase Ok! Write Data ... Write Data Ok! Write FSImage : prodnv.img Write Data ... Write Data Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Write CodeData : sc7731g_CP0_modem.bin Write Data ... Write Data Ok! Write CodeData : DSP_DM_Gx.bin Write Data ... Write Data Ok! Write CodeData : sc8830g_modem_CP2_WCN_14D_W15.16_Release.bin Write Data ... Write Data Ok! Write CodeData : logo_540x960.bin Write Data ... Write Data Ok! Write CodeData : fblogo_540x960.bin Write Data ... Write Data Ok! Write CodeData : boot.img Write Data ... Write Data Ok! Write FSImage : system.img Write Data ... Write Data Ok! Write FSImage : cache.img Write Data ... FSImage : Make and Flush SPImage Write Data Ok! Write CodeData : recovery.img Write Data ... Write Data Ok! Process : Flush Flush Ok! Write FSImage : userdata.img Write Data ... FSImage : Make and Flush SPImage Write Data Ok! Elapsed: 00:06:10 Reconnect Power/Cable! |
11-26-2016, 14:45 | #37895 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Qmobile A35 Hang Logo Format Code: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8C00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : 00AD00BC00900055005600AD00BC0000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x00A4 , [Hynix] H9DA4VH2GJMMCR_4EM [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0056 00AD 00BC [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/01/NIM_Px-2 DEV RID : 0xD5229C2546DB00E362911392B91DE72F INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : QMobile ProdName : A35 ProdModel : QMobile A35 Device : A35 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : A35_MP_131101 SECURITY : IMEI_SW [1] : 359663050491721 IMEI_SW [2] : 359663055491726 BTMAC Addr : 7A3F74657233 WiFi MAC : 4491DBAD5906 Done! Elapsed: 00:00:12 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8C00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : 00AD00BC00900055005600AD00BC0000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x00A4 , [Hynix] H9DA4VH2GJMMCR_4EM [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0056 00AD 00BC [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/01/NIM_Px-2 DEV RID : 0xD5229C2546DB00E362911392B91DE72F INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:14 Reconnect Power/Cable! |
11-26-2016, 14:46 | #37896 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Qmobile S1 Android Error Write File Code: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A48384731650507BDA1C5066221 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A48384731650507BDA1C5066221 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xD5229C25E6A6032404C4BEBBA1F1F463 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : QMobile ProdName : QMobile S1 ProdModel : QMobile S1 Device : QMobile AndroidVer: 5.0 MTKxCPU : MT6582 MTKxPRJ : ALPS.L0.MP2.V1_TINNO6582.WT.L_P7 SECURITY : IMEI_SW [1] : 353030070487244 IMEI_SW [2] : 353030075487249 BTMAC Addr : A0F89557BCAE WiFi MAC : A0F895576CCC Done! Elapsed: 00:00:13 Reconnect Power/Cable! Scatter Load Ok , BaseBand : MT6582 , Project : s5222 , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A48384731650507BDA1C5066221 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A48384731650507BDA1C5066221 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xD5229C25E6A6032404C4BEBBA1F1F463 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6582 , Project : s5222 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3959 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000001CEE00000 Flash Pre-Erase Done, time used : 00:00:07 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_s5222.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:04:22 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:01:26 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:06:13 Reconnect Power/Cable! |
11-26-2016, 14:48 | #37897 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | GFIVE President Smart 5 Virus Write File Code: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1101003030344745300157CDCB9F4249 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 0EG40 [eMMC] : FLASH_CID : 1101003030344745300157CDCB9F4249 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0xD5229C25C66CA95F8A00D41D74A1A946 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : GFIVE ProdName : vanzo72_cwet_kk ProdModel : GFIVE President Smart 5 Device : vanzo72_cwet_kk AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1 Done! Elapsed: 00:00:11 Reconnect Power/Cable! Scatter Load Ok , BaseBand : MT6572 , Project : vanzo72_cwet_kk , Storage : EMMC Files found : 11 , Set to Flash : 10 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : GFIVE Device Model : vanzo72_cwet_kk Device CPU : MT6572 Device IntName : vanzo72_cwet_kk Device Version : 4.4.2 Device Compile : 5/19/2015 6:34:30 AM Device Project : ALPS.KK1.MP7.V1 Device ExtInfo : GFIVE President Smart 5 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1101003030344745300157CDCB9F4249 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 0EG40 [eMMC] : FLASH_CID : 1101003030344745300157CDCB9F4249 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0xD5229C25C66CA95F8A00D41D74A1A946 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : vanzo72_cwet_kk , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3754 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000600000-0x0000000000100000 Erase : 0x0000000002300000-0x00000000E8C80000 Flash Pre-Erase Done, time used : 00:00:02 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_vanzo72_cwet_kk.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0013 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:02:11 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:35 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:08 Reconnect Power/Cable! |
11-26-2016, 14:49 | #37898 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Qmobile A10_Lite Virus Write File Code: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6575 BB_CPU_NME : [MediaTek] MT6575|MT6577_S00 BB_CPU_EXT : 0xCB00 , 0x8B00 , 0xE201 Processing BROM stage i2c Init : 0300771F SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x84 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , HYNIX [eMMC] : FLASH_CID : 90014A2058494E594816A1FD507C50FD [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0xD5229C25033DCBDDBEEE116169A60EEF INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : QMobile ProdName : QMobile_A10_Lite ProdModel : QMobile A10 Lite Device : QMobile_A10_Lite AndroidVer: 4.1.2 MTKxCPU : MT6577 MTKxPRJ : ALPS.JB.MP.V1.19 SECURITY : IMEI_SW [1] : 7D506FA54E26BCF IMEI_SW [2] : A2DEBAF83B33F12 BTMAC Addr : C1E0028B0C08 WiFi MAC : 0C08890F8B4B Done! Elapsed: 00:00:11 Reconnect Power/Cable! Scatter Load Ok , BaseBand : MT6577 , Project : MTK6577 , Storage : eMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6575 BB_CPU_NME : [MediaTek] MT6575|MT6577_S00 BB_CPU_EXT : 0xCB00 , 0x8B00 , 0xE201 Processing BROM stage i2c Init : 0300771F SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x84 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , HYNIX [eMMC] : FLASH_CID : 90014A2058494E594816A1FD507C50FD [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0xD5229C25033DCBDDBEEE116169A60EEF INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6577 , Project : MTK6577 , Storage : eMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : Old Dedvice , skip BatteryLevel check BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000600000-0x0000000000008000 Erase : 0x0000000000F28000-0x00000000A65C0000 Flash Pre-Erase Done, time used : 00:00:08 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_tinno77_s8201_jb.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:05:12 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:01:02 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:06:51 Reconnect Power/Cable! |
11-26-2016, 14:49 | #37899 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Qmobile X2 Hang Logo Format Code: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6571 BB_CPU_NME : [MediaTek] MT6571_S00 BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8B NAND Flash : 009800BC009000660076001600080000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1 [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1 DEV RID : 0xD5229C25296AEAC4CBE7B08D66CE2F8B INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : QMobile ProdName : s3510ap ProdModel : QMobile X2 Device : s3510ap AndroidVer: 4.4.2 MTKxCPU : MT6571 MTKxPRJ : ALPS.KK1.MP7.V1 SECURITY : IMEI_SW [1] : 357604061664031 IMEI_SW [2] : 357604066664036 BTMAC Addr : 000046657101 WiFi MAC : 000000000000 Done! Elapsed: 00:00:18 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6571 BB_CPU_NME : [MediaTek] MT6571_S00 BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8B NAND Flash : 009800BC009000660076001600080000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1 [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1 DEV RID : 0xD5229C25296AEAC4CBE7B08D66CE2F8B INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:17 Reconnect Power/Cable |
11-26-2016, 14:50 | #37900 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Qmobile A110 Hang Logo Format Code: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8C00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : 00C800F4000000000000000000000000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x00B2 , NAND_UNKNOWN [NAND] : FLASH_DIE : 00C8 00F4 0000 0000 0000 0001 0BC7 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/01/NIM_Px-2 DEV RID : 0xD5229C25773EAFA363AC80C3B16E899B INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : QMobile ProdName : A110 ProdModel : A110 Device : QMobile A110 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1.P88 SECURITY : IMEI_SW [1] : 353614060136737 IMEI_SW [2] : 353614065136732 BTMAC Addr : 00738DD5B442 WiFi MAC : 00738DD55090 Done! Elapsed: 00:00:12 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8C00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : 00C800F4000000000000000000000000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x00B2 , NAND_UNKNOWN [NAND] : FLASH_DIE : 00C8 00F4 0000 0000 0000 0001 0BC7 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/01/NIM_Px-2 DEV RID : 0xD5229C25773EAFA363AC80C3B16E899B INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
11-26-2016, 14:50 | #37901 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | World firs Qtab V9 Lite MT6735 Read File/FRP Rest Done By Father Off All Infinity CM2 Read File/FRP.. |
The Following User Says Thank You to azhergoga007 For This Useful Post: |
11-26-2016, 14:51 | #37902 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Qmobile I9 Hang Logo Write File Code: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 11010030303447393051E0CE768961F1 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 09G40 [eMMC] : FLASH_CID : 11010030303447393051E0CE768961F1 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0xD5229C25C5CC938E83F3A6E1F98B279E INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : QMobile ProdName : QMobile i9 ProdModel : QMobile i9 Device : QMobile i9 AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.KK1.MP1.V2.10 SECURITY : IMEI_SW [1] : 353616060956238 IMEI_SW [2] : 353616065956233 BTMAC Addr : BCD1D3C332A5 WiFi MAC : BCD1D3C2BAEB Done! Elapsed: 00:00:09 Reconnect Power/Cable! Scatter Load Ok , BaseBand : MT6582 , Project : s5501 , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 11010030303447393051E0CE768961F1 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 09G40 [eMMC] : FLASH_CID : 11010030303447393051E0CE768961F1 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0xD5229C25C5CC938E83F3A6E1F98B279E INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6582 , Project : s5501 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3757 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000000E3800000 Flash Pre-Erase Done, time used : 00:00:03 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_s5501.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:03:16 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:46 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:04:23 Reconnect Power/Cable! |
11-26-2016, 14:51 | #37903 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Qmobile T200 Pattern Format Code: Operation : Check/Read Info [ v1.24 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : QMobile T200 Model Brand : QMobile T200 Model Device: QMobile AndrVersion : 4.4.3 BaseBand CPU: SP7731GEA CompileDate : 4/4/2015 9:05:24 AM Project Ver : QMobileT200_MP_11_04 Model Ext : QMobile T200 ExtraInfo : HWInfo exists!!! This phone have DYNAMIC HW settings!!! Elapsed: 00:00:19 Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.24 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x000000005DBFB000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
11-26-2016, 14:52 | #37904 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Qmobile X25 Virus Write File Code: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040501A1DE358181 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040501A1DE358181 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD5229C254CAD3A9B18AC3FE35043D8A1 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : QMobile ProdName : X25 ProdModel : QMobile X25 Device : X25 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP6.V1 SECURITY : IMEI_SW [1] : 355794060534863 IMEI_SW [2] : 355794065534868 BTMAC Addr : D83C6901BBB0 WiFi MAC : D83C690143F6 Done! Elapsed: 00:00:09 Reconnect Power/Cable! Scatter Load Ok , BaseBand : MT6572 , Project : s4011 , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040501A1DE358181 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040501A1DE358181 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD5229C254CAD3A9B18AC3FE35043D8A1 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : s4011 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3683 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000000E5E00000 Flash Pre-Erase Done, time used : 00:00:07 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_s4011.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:02:59 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:46 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:04:08 Reconnect Power/Cable! |
11-26-2016, 15:01 | #37905 (permalink) |
No Life Poster Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Qmobile A290 hang logo Write flash DOne With CM2 Wait for phone... Phone found! [ 21 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A48344732611101079AF5DF6237 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A48344732611101079AF5DF6237 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0x0386520D9A5B03BE3443E9A217365881 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : s5201ap , Storage : EMMC Setting : Flash Pre-Erase : Off ( Write Flash Only ) Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 3669 mV BL : BatteryLevel Ok SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:03:19 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:43 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:04:18 Reconnect Power/Cable! ''''''''''''''' |
The Following User Says Thank You to Nadeem Waris For This Useful Post: |
