07-26-2020, 06:16 | #63901 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile b65 reset password done by cm2 Card found : 73CA70CC , v0144 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.06 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] SPRD mode : SC6531 : REV : E000 : NOR : [ 4MB ] Operation : Format FileSystem [ v1.06 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531E Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_078 6FAFA9D5F_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
The Following User Says Thank You to A.G.Shahid For This Useful Post: |
07-26-2020, 07:53 | #63902 (permalink) | |
Freak Poster Join Date: May 2016
Member: 2573102 Status: Offline Thanks Meter: 21 | Link! Quote:
07-26-2020, 08:15 | #63903 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile I5 MT6580 Pattren Reset Done With King Infinity CM2 Code: Card found : S/N : A19EC787 , v0144 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040501A13AEA516F Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040501A13AEA516F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F395A2E6100BFACA78D0A5F60D55 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
07-26-2020, 09:00 | #63904 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,428 | Qmobile : HD Plus Operation : Format FS / Reset Settings [ v2.05 ] Mode : Forced [ Format FS / Fix ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Qmobile : HD Plus Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : Forced Wipe Wipe Ok : Forced Wipe Reconnect Power/Cable! Done! Elapsed: 00:02:36 |
07-26-2020, 12:57 | #63905 (permalink) |
Freak Poster Join Date: Nov 2011 Location: Bahawal nager pakistan
Member: 1698141 Status: Offline Sonork: 1617901 Thanks Meter: 155 | Qmobile X700 PRO 2019 Read flash with cm2 Operation : Read Firmware [ v2.13 ] ExtSparse : Enabled ForceRead : Disabled 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM17) MODE : PRELOADER PORT PORT : 17 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6570 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT MODE : 0_base : BASE_v1812 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6570 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: 110100303034473930515387D0158115 EMMC: VEN : TOSHIBA | OEM : 01 | DEV : 004G90 EMMC: BOOT1 : 0x00200000 [ 2.00 MB ] BOOT2 : 0x00200000 [ 2.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0xEC000000 [ 3.69 GB ] CHIP : MT6570 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 26990DB5313B2194117FADEC539EDD0 DA : USB : HIGH-SPEED Boot done! Patch Level : MRA58K Display ID : MRA58K test-keys Ver. CodeName : REL Ver. Release : 6.0 Sec. Patch : 2017-03-05 Build Time : 1570527815 Product Model : X700 PRO 2019 Product Brand : welcome Product Name : X700_PRO_2019 Product Device : X700_PRO_2019 Product Manfct : welcome Board Platform : mt6570 Product Info : X700_PRO_2019 MT6570__welcome__X700_PRO_2019__6.0__MRA58K__X700_ PRO_2019 Read : preloader.bin Read : proinfo.img Read : nvram.bin Read : lk.bin Read : boot.img Read : recovery.img Read : logo.bin Read : md1rom.img Read : secro.img Read : system.img ExtSparse : Compression ratio : 6% Read : cache.img Read : userdata.img FW Size : 1.68 GB Android Info saved : _Android_info.txt Scatter : MT6570_Android_scatter.txt Saved to : C:\Users\Ideal\Desktop\MT6570__welcome__X700_PRO_2 019__6.0__MRA58K__X700_PRO_2019\ Done! Elapsed: 00:04:33 |
07-26-2020, 14:41 | #63906 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile sp1000 reset password done by cm2 Card found : S/N : 73CA70CC , v0144 Chinese Miracle II [MTK module] v 1.58 Operation : Reset UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 20 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 087CD88939EDF6F71A765D51257CB74C BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Read ExtData Sorting ExtData Sort Ok, Rebuild Ok Restore ExtData All done UserCode request removed UserCode set to default ( 0000 or 1122 ) Done! Elapsed: 00:00:23 Reconnect Power/Cable! |
07-26-2020, 18:08 | #63907 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 36
Member: 2371500 Status: Offline Thanks Meter: 5,812 | HiSense C20 FRP REMOVE DONE original poster taki19 Operation : Identify (ADB) [ v1.03 ] Waiting for device in ADB mode ... 1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need! 2. Insert USB cable, accept AUTH on PhoneScreen, if software ask! Connect Ok! Device Info : Vendor : Hisense Model : Hisense C20 Device : C20FE-1 Android : 5.1.1 Product : C20FE-1 Brand : Hisense Serial : 136ee03d Build_tm : 2018åนด 06æ 22æฅ ææäº 15:09:21 CST DisplayID : LMY47V release-keys Patch Ver : LMY47V SecPatch : 2017-05-01 Hardware : qcom HW Board : msm8929 CPU rel : arm64-v8a SIM Card : READY,ABSENT BaseBand : 1-00106-M8936FAAAANUZM-1.34757.2 BaseBand : 1-00106-M8936FAAAANUZM-1.34757.2 RIL ver : Qualcomm RIL 1.0 USB Conf : charging Sys USB : charging,adb FS Crypt : unencrypted Done! Elapsed: 00:00:17 Operation : Reset FRP (ADB) [ v1.03 ] Waiting for device in ADB mode ... 1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need! 2. Insert USB cable, accept AUTH on PhoneScreen, if software ask! Connect Ok! Device : C20FE-1 Model : Hisense C20 FRP reset passed! Make FACTORY RESET from menu! Done! Elapsed: 00:00:17 |
The Following 3 Users Say Thank You to profkefah For This Useful Post: |
07-27-2020, 06:25 | #63908 (permalink) |
Freak Poster Join Date: Jan 2016 Location: punjab pakistan Age: 34
Member: 2510895 Status: Offline Sonork: 100.1668345 Thanks Meter: 319 | tecno cf8 chian copy spd frp done.... mozair33 |
The Following 4 Users Say Thank You to mozair33 For This Useful Post: |
07-27-2020, 08:46 | #63909 (permalink) |
No Life Poster Join Date: Apr 2011 Location: Pakistan
Member: 1555233 Status: Offline Thanks Meter: 2,192 | KING CM2 QMobile i5.5 sp7731gea_hdr FRP REMOVE SUCCESSFULLY Card found : A9EC786B , v0144 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.05 Load IDBase v42913 Ok! Operation : Identify [ v2.05 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731x_BASE : SC7731G_eMMC_1GB_NS Sending Init Boot ... Boot sent! Kick FDL ... Kick FDL again ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Patch Level : MRA58K Display ID : QMobile_i5.5_MP_V2_20_09 Ver. Incmt : 4 Ver. CodeName : REL Ver. Release : 6.0 Sec. Patch : 2016-09-06 Build Time : 1478826689 Product Model : QMobile i5.5 Product Brand : QMobile Product Name : i5.5 Product Device : i5_5 Product Board : sp7731gea_hdr Product Manfct : QMobile Board Platform : sc8830 Product Info : i5_5 Platform Version: MOCORTM_14B_TShark_OC_W16.38_Debug Project Version: sc7731g_CP0_modem BASE Version: TM_BASE_15A_W16.38 MMI Version: sc7731g_modem HW Version: sc7731g_CP0_modem CMP_Time : 09-18-2016 15:19:59 MODEM TAG : MOCORTM_14B_TShark_OC_W16.38_Debug_TM_BASE_15A_W16 .38_sc7731g_CP0_modem_sc7731g_CP0_modem_sc7731g_mo dem UserData : STATE : PLAIN [EXTFS] Done! Elapsed: 00:02:55 Operation : Format FS / Reset Settings [ v2.05 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731x_BASE : SC7731G_eMMC_1GB_NS Sending Init Boot ... Boot sent! Kick FDL ... Kick FDL again ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:01:46 |
The Following 4 Users Say Thank You to amjadnona For This Useful Post: |
07-27-2020, 08:51 | #63910 (permalink) |
Member: 1555233 Status: Offline Thanks Meter: 2,192 | KING CM2 Vivo Y90 [1908] Pin,Pattern Unlock REMOVE SUCCESSFULLY Card found : A9EC786B , v0144 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.13 Load IDBase v714150 Ok! Operation : Identify [ v2.13 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM19) MODE : BOOTROM PORT : 19 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+ARB BROM : BOOTROM BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 [0200] V0: 0000 0000 [0001] BROM : SOCID : B114850D6616E5077E11957D1D72755AC15A2916D47F0581E4 DA47C5C97D44B1 BROM : Configuring target for META BROM : META configured! INIT : META confirmed! Boot done! AP_CHIP : MT6761,S01 AP_SWVR : alps-mp-o1.mp7.tc19sp-V1.19_k61v1.64.bsp_P104 AP_HWVR : S01 MD_CHIP : MT6761 MD_SWTM : 2000.00.00 MD_DSPV : 1.0 MD_DSPP : MOLY.LR12A.R2.MP.V32.21.P135 MD_SWVR : BBK_O1MP7_K61V1_64_BSP_HW MD_HWVR : Unknown Patch Level : O11019 Display ID : O11019 release-keys Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2020-05-01 Build Time : 1592916458 Product Model : vivo 1812 Product Brand : vivo Product Name : PD1917F_EX Product Device : PD1917F_EX Product Manfct : vivo Product Info : k61v1_64_bsp Done! Elapsed: 00:01:19 Operation : Reset Settings/Format FS [ v2.13 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM19) MODE : BOOTROM PORT : 19 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+ARB BROM : BOOTROM BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 [0200] V0: 0000 0000 [0001] BROM : SOCID : B114850D6616E5077E11957D1D72755AC15A2916D47F0581E4 DA47C5C97D44B1 BROM : Configuring target for META BROM : META configured! INIT : META confirmed! Boot done! AP_CHIP : MT6761,S01 AP_SWVR : alps-mp-o1.mp7.tc19sp-V1.19_k61v1.64.bsp_P104 AP_HWVR : S01 Format Ok : UserData Done! Elapsed: 00:00:38 Reconnect Power/Cable! |
The Following 5 Users Say Thank You to amjadnona For This Useful Post: |
07-27-2020, 08:57 | #63911 (permalink) |
Member: 1555233 Status: Offline Thanks Meter: 2,192 | KING CM2 Q Mobile Qsmart FRP REMOVE SUCCESSFULLY Operation : Format FS / Reset Settings [ v2.05 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:02:21 |
The Following 3 Users Say Thank You to amjadnona For This Useful Post: |
07-27-2020, 09:18 | #63912 (permalink) |
Banned Join Date: May 2013 Location: Hacked by Hackflax on tiktok
Member: 1941705 Status: Offline Thanks Meter: 1,248 | Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 316 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473165050728A12853726D Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A4838473165050728A12853726D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xCD5A15516B764D7ADAF5A19771E0E1DF INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : myPhone ProdName : IRON_2_EN ProdModel : IRON_2 Device : IRON_2_EN AndroidVer: 6.0 MTKxCPU : MT6580 MTKxPRJ : S153MWB_TL_M_A06_V0.7_201701111000 [Read Ok] : preloader_hy6580_we_m.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6580 / V1.1.2 / hy6580_we_m / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 2750 MiB Scatter saved to : C:\Users\Roman\Desktop\myPhone Hammer Iron 2\MT6580__myPhone__IRON_2__IRON_2_EN__6.0__S153MWB _TL_M_A06_V0.7_201701111000\ All done! Done! Elapsed: 00:12:35 Reconnect Power/Cable! |
The Following User Says Thank You to Xaker2012 For This Useful Post: |
07-27-2020, 10:55 | #63913 (permalink) |
No Life Poster Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | infinix x5516c frp remove done with king cm2 Operation : Reset Settings/Format FS [ v2.13 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM38) MODE : PRELOADER PORT PORT : 38 Waiting BOOT ack ... PRELOADER : ACK confirm FAIL! BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : TECNO : SECURE_v2 | Manual : Disabled BROM : SOCID : C9506FC906692C521D96816E72F141470D6F0898443A4AA6F6 384209DC092B29 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SWSEC.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 7001005442323831362325B83784697 EMMC: VEN : KINGSTON | OEM : 01 | DEV : TB2816 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A8000000 [ 14.63 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : A0F84E207803F579CB69B9DE7915D1A3 DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
07-27-2020, 11:37 | #63914 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile S3 MT6580 FRP Reset Done With King Infinity CM2 Code: Card found : S/N : A19EC787 , v0144 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A48414732650507A1EAED0DA243 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e2GA [eMMC] : FLASH_CID : 90014A48414732650507A1EAED0DA243 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB800000 [eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB] DEV RID : 0xD9C8F395622AD24851F217629EFA2033 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:45 Reconnect Power/Cable! |
The Following User Says Thank You to azhergoga007 For This Useful Post: |
07-27-2020, 12:45 | #63915 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile S4 MT6580 FRP Reset Done With King Infinity CM2 Code: Card found : S/N : A19EC787 , v0144 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100513832334D42005EB2CEBA33D1 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM328 [eMMC] : FLASH_CID : 150100513832334D42005EB2CEBA33D1 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xD9C8F395C8C5ACD48D61217693EF9C95 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:45 Reconnect Power/Cable! |
