10-17-2020, 16:53 | #64651 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | OPPO A37f Format Code: Brand : OPPO ProdName : A37f ProdModel : A37f Device : A37f AndroidVer: 5.1.1 SWVersion : A37fEX_11.A.36_INT_036_201902272247 Manufact. : OPPO SysPatch : LMY47V DevComTime: 2/27/2019 4:42:27 PM QLMxCPU : MSM8916 USERData : NORMAL GCSec : EMPTY Done! Elapsed: 00:00:16 Reconnect Power/Cable! Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 20C568CC ID_BLOCK_L : D92B41BD1886B3BE69DE361FD8A3331B ID_BLOCK_L : 9CF759F0E56CDE576A450EC7CD203E1D Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:25 Reconnect Power/Cable! |
10-17-2020, 16:54 | #64652 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | GENIUS TAB Q4 Flash Code: Loading firmware ... Detected RockChip UnionImage UIMGModel : Genius Tab Q4 UIMGInfo : RK30SDK Machine : RK3066 Device : GENIUS TAB Q4 Version : 4.1.1 Load Ok! Operation : Write Firmware [ v2.02 ] ----- > Phone/Tablet : 1. Power Off device 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable! Press 'POWER_ON' button for a few second! ----- > IoT/Box : 1. Reset device power 2. PRESS and HOLD 'RESET' KEY! 3. Insert OTG/USB cable! Press 'POWER_ON' button for a few second! Wait for device ... Device Connected! Interface test : Passed Device mode : 0x0006 Machine : RK3066 Device : GENIUS TAB Q4 ExtInfo : 4.1.1 SoC CPU : 310B SoC PDT : 2012 SoC SWN : 1130 SoC REV : V100 Flash CSx : 0x00 Flash Type : ADDE94DA74 [ NAND ] Flash Vend : HYNIX Flash Size : 0x0000000200000000 ( 8.00 GiB ) Flash Info : 2097152/8192/31/40/5 Connect Ok! Loading firmware ... UnionImage container info : File [1] : RK3188Loader(L)_V1.24.bin File [2] : parameter File [3] : Image/misc.img File [4] : Image/kernel.img File [5] : Image/boot.img File [6] : Image/recovery.img File [7] : Image/system.img File [8] : backupimage/backup.img File [9] : update-script File [10] : recover-script Load firmware done! Initialize PMT as RK-PARAMS Upgrade PMT done! Flashing : Image/kernel.img Flashing : Image/boot.img Flashing : Image/recovery.img Flashing : backupimage/backup.img Flashing : Image/system.img Flashing finished! Done! Elapsed: 00:02:12 |
10-17-2020, 16:55 | #64653 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | VGOTEL NEW_5 Frp Code: Brand : VGOTEL ProdName : NEW_5 ProdModel : NEW 5 Device : NEW_5 AndroidVer: 8.1.0 Done! Elapsed: 00:00:07 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 56 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 45010044463430313601F0B1AE0C462B Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x45 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , 6104F [eMMC] : FLASH_CID : 45010044463430313601F0B1AE0C462B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0xD5229C254636975603BF42A37C3A6B00 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
10-17-2020, 16:56 | #64654 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Infinix-X680B Frp Code: Patch Level : QP1A.190711.020 Display ID : X680B-H6215EF-Q-OP-200509V94 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2020-04-05 Build Time : 1589021022 Product Info : x680b_h6215 Product Board : Infinix-X680B Board Platform : mt6765 USERDATA : FILESYSTEM : F2FS with FBE ( File-Base Encryption ) STORAGE : LifeStatus : Verify NOT supported by DA/HW! Done! Elapsed: 00:00:22 Operation : Reset Settings/Format FS [ v2.14 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM56) MODE : PRELOADER PORT PORT : 56 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : INFINIX : SEC_NEW | Manual : Disabled BROM : SOCID : C19E159E094896EC21B02D906EF875D30D6E40E1F91F9D6285B11561DB400A27 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: 150100445036444142038EF4DC0257B9 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : DP6DAB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 2BED660A3BF537A9A899F324F02F6F34 DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
10-17-2020, 16:57 | #64655 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | TECNO KC3 Frp Code: Patch Level : PPR1.180610.011 Display ID : KC3-H627G-P-200617V305 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2020-06-05 Build Time : 1592385718 Product Model : TECNO KC3 Product Brand : TECNO Product Name : H627 Product Device : TECNO-KC3 Product Manfct : TECNO MOBILE LIMITED Product Info : kc3_h627mt62 Product Board : TECNO-KC3 Board Platform : mt6765 USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption *) STORAGE : LifeStatus : Verify NOT supported by DA/HW! Done! Elapsed: 00:00:31 Operation : Reset Settings/Format FS [ v2.14 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM56) MODE : PRELOADER PORT PORT : 56 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : INFINIX : SEC_NEW | Manual : Disabled BROM : SOCID : D9B4901774E7CE2F11D3A6F9BBF199BBE498D63EE9073E111F72EB6E98F01C62 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: 90014A484347386134A210116568C6E5 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HCG8a4 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : E8C378A2F3FA9DD679E9F64C1CFB64D2 DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
10-17-2020, 16:58 | #64656 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | QMobile X30 Flash Code: Brand : TINNO ProdName : QMobile X30 ProdModel : QMobile X30 Device : QMobile X30 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1 Done! Elapsed: 00:00:08 Reconnect Power/Cable! Scatter Load Ok , BaseBand : MT6572 , Project : s4050ap , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 193 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A48344732611101ECB701BE22CF Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A48344732611101ECB701BE22CF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD5229C2524FF2102DC45149DA2F46BB7 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : s4050ap , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Disabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 4022 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000000E5E00000 Flash Pre-Erase Done, time used : 00:00:08 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_s4050ap.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:03:00 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:24 Reconnect Power/Cable! |
10-18-2020, 09:26 | #64657 (permalink) |
Freak Poster Join Date: Jan 2017
Member: 2671513 Status: Offline Thanks Meter: 121 | Lenovo TB-7304I : identify + smart reset + read firmware + read nvram Operation : Identify [ v2.16 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM223) MODE : BOOTROM PORT : 223 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : MEID : 2CF5057352272ABF731649A038D44F1A BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Lenovo : X-TAB | Manual : Disabled BROM : SLA BROM : SLA Passed! BROM : SLA CHLNG not used AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 150100464536324D4203FAFDD900409D DAInf: 4 : 2 : 155 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 460001154D323645FDFA03429D4000D9 NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 DRAM : 0x0178 EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0 INIT : 0xBC : eMMC [ 0x40000000 : [ 1,00 GB ] ] DRAM : DRAM: 0x40000000 [ 1,00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100464536324D4203FAFDD900C49D EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FE62MB EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x3A3E00000 [ 14,56 GB ] SRAM: 0x00020000 [ 128,00 KB ] DRAM: 0x40000000 [ 1,00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 31A94A827F35B24133677FD5CD7C0A13 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM235) MODE : PRELOADER PORT PORT : 235 Boot done! Patch Level : NRD90M Display ID : TB-7304I_S000049_180828_ROW Ver. CodeName : REL Ver. Release : 7.0 Sec. Patch : 2018-07-05 Build Time : 28.08.2018 Product Model : Lenovo TB-7304I Product Brand : Lenovo Product Name : LenovoTB-7304I Product Device : TB-7304I Product Manfct : LENOVO Board Platform : mt6737m Product Info : TB-7304I USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption *) IMEI[0] : 86************* NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] Backup sensetive data [ 8 ] Backup path : Backup\MT6735__31A94A827F35B24133677FD5CD7C0A13\ [3] Read : NVRAM [19] Read : NVDATA [2] Read : PROINFO [6] Read : LK [4] Read : PROTECT1 [5] Read : PROTECT2 Backup done! Done! Elapsed: 00:00:41 ************************************************* Operation : Reset Settings/Format FS [ v2.16 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM223) MODE : BOOTROM PORT : 223 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : MEID : 2CF5057352272ABF731649A038D44F1A BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Lenovo : X-TAB | Manual : Disabled BROM : Change Configuration settings for target BROM : SLA BROM : SLA Passed! BROM : SLA CHLNG not used AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 150100464536324D4203FAFDD900409D DAInf: 4 : 2 : 155 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 460001154D323645FDFA03429D4000D9 NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 DRAM : 0x0178 EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0 INIT : 0xBC : eMMC [ 0x40000000 : [ 1,00 GB ] ] DRAM : DRAM: 0x40000000 [ 1,00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100464536324D4203FAFDD900C49D EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FE62MB EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x3A3E00000 [ 14,56 GB ] SRAM: 0x00020000 [ 128,00 KB ] DRAM: 0x40000000 [ 1,00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 31A94A827F35B24133677FD5CD7C0A13 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM235) MODE : PRELOADER PORT PORT : 235 Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:01:01 Reconnect Power/Cable! ************************************************** ** Operation : Read Firmware [ v2.16 ] ExtSparse : Enabled ForceRead : Disabled 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM223) MODE : BOOTROM PORT : 223 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : MEID : 2CF5057352272ABF731649A038D44F1A BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Lenovo : X-TAB | Manual : Disabled BROM : Change Configuration settings for target BROM : SLA BROM : SLA Passed! BROM : SLA CHLNG not used AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 150100464536324D4203FAFDD900409D DAInf: 4 : 2 : 155 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 460001154D323645FDFA03429D4000D9 NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 DRAM : 0x0178 EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0 INIT : 0xBC : eMMC [ 0x40000000 : [ 1,00 GB ] ] DRAM : DRAM: 0x40000000 [ 1,00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100464536324D4203FAFDD900C49D EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FE62MB EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x3A3E00000 [ 14,56 GB ] SRAM: 0x00020000 [ 128,00 KB ] DRAM: 0x40000000 [ 1,00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 31A94A827F35B24133677FD5CD7C0A13 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM235) MODE : PRELOADER PORT PORT : 235 Boot done! Patch Level : NRD90M Display ID : TB-7304I_S000049_180828_ROW Ver. CodeName : REL Ver. Release : 7.0 Sec. Patch : 2018-07-05 Build Time : 28.08.2018 Product Model : Lenovo TB-7304I Product Brand : Lenovo Product Name : LenovoTB-7304I Product Device : TB-7304I Product Manfct : LENOVO Board Platform : mt6737m Product Info : TB-7304I MT6737M__LENOVO__Lenovo_TB-7304I__7.0__TB-7304I_S000049_180828_ROW__NRD90M__TB-7304I SecureDevice : Paired type! -> INFO : That device MAY dead after ReadOut Flashing in some rare cases! Read : preloader.bin Read : proinfo.img Read : nvram.bin Read : lk.bin Read : boot.img Read : recovery.img Read : logo.bin Read : secro.img Read : tz.img Read : system.img ExtSparse : Compression ratio : 96% Read : cache.img Read : userdata.img FW Size : 283,24 MB Android Info saved : _Android_info.txt Scatter : MT6737M_Android_scatter.txt Saved to : O:\+\cm2 dump\lenovo 7304i\MT6737M__LENOVO__Lenovo_TB-7304I__7.0__TB-7304I_S000049_180828_ROW__NRD90M__TB-7304I\ Done! Elapsed: 00:10:06 ************************************************ Operation : Read Security [ v2.16 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM223) MODE : BOOTROM PORT : 223 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : MEID : 2CF5057352272ABF731649A038D44F1A BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Lenovo : X-TAB | Manual : Disabled BROM : Change Configuration settings for target BROM : SLA BROM : SLA Passed! BROM : SLA CHLNG not used AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 150100464536324D4203FAFDD900409D DAInf: 4 : 2 : 155 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 460001154D323645FDFA03429D4000D9 NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 DRAM : 0x0178 EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0 INIT : 0xBC : eMMC [ 0x40000000 : [ 1,00 GB ] ] DRAM : DRAM: 0x40000000 [ 1,00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100464536324D4203FAFDD900C49D EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FE62MB EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x3A3E00000 [ 14,56 GB ] SRAM: 0x00020000 [ 128,00 KB ] DRAM: 0x40000000 [ 1,00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 31A94A827F35B24133677FD5CD7C0A13 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM235) MODE : PRELOADER PORT PORT : 235 Boot done! SEC Data : IMEI[0] : 86************* NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] NVM saved as : MT6735__eMMC__86*************.mt_sec NVM saved to : O:\+\cm2 dump\lenovo 7304i\nv\ Done! Elapsed: 00:00:41 Reconnect Power/Cable! |
10-19-2020, 07:41 | #64659 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Balkan Age: 50
Member: 1473716 Status: Offline Thanks Meter: 1,273 | Wiko Goa unlock done Card found : S/N : 07EXXXXX , v0145 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 38 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.2017-06-20.16:16 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040503A2EADD221D Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040503A2EADD221D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0x7FBB533344FF75AD4CF14ADB82C93D9B INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : WIKO ProdName : wiko ProdModel : GOA Device : wiko AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP6.V1 Done! Elapsed: 00:00:14 Reconnect Power/Cable! Operation : SP Unlock [ v1.58 ] Mode : Direct Unlock 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 38 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.2017-06-20.16:16 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040503A2EADD221D Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040503A2EADD221D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0x7FBB533344FF75AD4CF14ADB82C93D9B INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SIM Lock Status : Locked! Unlocking now ... Unlock done! Done! Elapsed: 00:00:33 Reconnect Power/Cable! |
The Following User Says Thank You to gile@gile For This Useful Post: |
10-19-2020, 11:46 | #64660 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Oale X1 Flash Code: Patch Level : MRA58K Display ID : U190HB_M_V010En Ver. CodeName : REL Ver. Release : 6.0 Sec. Patch : 2016-02-01 Build Time : 1574737854 Product Model : gxq6580_we_m Product Brand : alps Product Name : full_gxq6580_we_m Product Device : gxq6580_we_m Product Manfct : alps Board Platform : mt6580 Product Info : gxq6580_we_m USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption ***) Done! Elapsed: 00:00:23 Preloader [HW DEV] Info : EMI : DEV : MT6752 EMI : SRC : preloader_gxq6580_we_m.bin EMI : CNT : 000E EMI : [00] : eMMC : DDR2 : ID : 110100303034474530 : VEN : TOSHIBA | DEV : 004GE0 : RAM : [ 512.00 MB ] EMI : [01] : eMMC : DDR2 : ID : 1501004B3758564D42 : VEN : SAMSUNG | DEV : K7XVMB : RAM : [ 1.00 GB ] EMI : [02] : eMMC : DDR3 : ID : 90014A483847316505 : VEN : HYNIX | DEV : H8G1e : RAM : [ 1.00 GB ] EMI : [03] : eMMC : DDR3 : ID : 150100513732534D42 : VEN : SAMSUNG | DEV : Q72SMB : RAM : [ 1.00 GB ] EMI : [04] : eMMC : DDR3 : ID : 150100463732324D42 : VEN : SAMSUNG | DEV : F722MB : RAM : [ 1.00 GB ] EMI : [05] : eMMC : DDR3 : ID : 880103455042313030 : VEN : FORESEE | DEV : EPB100 : RAM : [ 1.00 GB ] EMI : [06] : eMMC : DDR3 : ID : 700100454838434538 : VEN : KINGSTON | DEV : EH8CE8 : RAM : [ 1.00 GB ] EMI : [07] : eMMC : DDR3 : ID : 700100454838454538 : VEN : KINGSTON | DEV : EH8EE8 : RAM : [ 1.00 GB ] EMI : [08] : eMMC : DDR3 : ID : 150100513832334D42 : VEN : SAMSUNG | DEV : Q823MB : RAM : [ 2.00 GB ] EMI : [09] : eMMC : DDR3 : ID : 1501003030434E5630 : VEN : SAMSUNG | DEV : 00CNV0 : RAM : [ 1.00 GB ] EMI : [0A] : eMMC : DDR3 : ID : 8801034E4361726420 : VEN : FORESEE | DEV : NCard : RAM : [ 1.00 GB ] EMI : [0B] : eMMC : DDR3 : ID : 150100303058505630 : VEN : SAMSUNG | DEV : 00XPV0 : RAM : [ 1.00 GB ] EMI : [0C] : eMMC : DDR3 : ID : 9901994F726967696E : VEN : UNKNOWN | DEV : Origin : RAM : [ 1.00 GB ] EMI : [0D] : eMMC : DDR3 : ID : 13014E51324A393551 : VEN : MICRON | DEV : Q2J95Q : RAM : [ 1.00 GB ] Operation : Write Flash [ v2.14 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :9 [FL] : Set : preloader_gxq6580_we_m.bin [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : recovery.img [FL] : Set : logo.bin [FL] : Set : secro.img [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0x58309624 [ 1.38 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM193) MODE : PRELOADER PORT PORT : 193 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 4E03018864726143A1C14620AF840361 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 8801034E436172642046C1A1610384AF EMMC: VEN : FORESEE | OEM : 301 | DEV : NCard EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1CE100000 [ 7.22 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : FD53E3E69571B3A8C6748D86D1577875 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : False (CUST) SEC_DL : SECURE USB DL DISABLED SEC_ID : 0x35464646304237304435444533464335 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000000080000 Erase : 0x0000000001C80000 : 0x00000000E3380000 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Update bootloader code ... Update bootloader Ok! Write : LK Write : BOOT Write : RECOVERY Write : LOGO Write : SECRO Write : SYSTEM Write : CACHE Write : USERDATA [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:07:38 Reconnect Power/Cable! |
10-19-2020, 11:47 | #64661 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Qmobile M5 Format Code: Operation : Format FileSystem [ v1.06 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Spreadtrum Boot Block version 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_01626D923C14_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:28 Reconnect Power/Cable! |
10-19-2020, 11:48 | #64662 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | OPPO A5S Format Code: AP_CHIP : MT6765,S01 AP_SWTM : Thu Jul 16 22:09:52 CST 2020 AP_SWVR : CPH1909_11_A.39_200716_65984d1d AP_HWVR : S01 MD_CHIP : MT6765 MD_SWTM : 2000.00.00 MD_DSPV : 1.0 MD_DSPP : MOLY.LR12A.R2.TC16.SP.V50.5.P95 MD_SWVR : OPPO_O1MP6_K65V1_64_BSP_HW MD_HWVR : Unknown Patch Level : O11019 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2020-07-05 Product Manfct : OPPO Done! Elapsed: 00:01:23 Operation : Reset Settings/Format FS [ v2.14 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM58) MODE : BOOTROM PORT : 58 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+ARB BROM : BOOTROM BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 [0200] V0: 0000 0000 [0001] BROM : SOCID : 21DB12F2951FA4D3714796B64AB969E4D99F34B6762E9B2CA370DAF8C5E1E3D1 BROM : Configuring target for META BROM : META configured! INIT : META confirmed! Boot done! AP_CHIP : MT6765,S01 AP_SWTM : Thu Jul 16 22:09:52 CST 2020 AP_SWVR : CPH1909_11_A.39_200716_65984d1d AP_HWVR : S01 Format Ok : UserData Done! Elapsed: 00:00:42 Reconnect Power/Cable! |
10-19-2020, 11:49 | #64663 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | OPPO A37f Pattern Code: Brand : OPPO ProdName : A37f ProdModel : A37f Device : A37f AndroidVer: 5.1.1 SWVersion : A37fEX_11.A.38_INT_038_201907110016 Manufact. : OPPO SysPatch : LMY47V DevComTime: 7/10/2019 7:29:34 PM QLMxCPU : MSM8916 USERData : NORMAL GCSec : EMPTY Done! Elapsed: 00:00:42 Reconnect Power/Cable! Operation : Read PatternLock [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 10AC5A20 ID_BLOCK_L : A55F35C16CFAE7E2DDB242438CD75F6F ID_BLOCK_L : 671EA00B0C97C74C41ACE1DED4DBD5F6 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Read Ok! Trying decrypt ... PatternLock sequence : 35684217 Done! Elapsed: 00:00:33 Reconnect Power/Cable! |
10-19-2020, 11:49 | #64664 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | QMobile X11 Flash Code: Brand : QMobile ProdName : X11 ProdModel : QMobile X11 Device : X11 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP6.V1 Done! Elapsed: 00:00:09 Reconnect Power/Cable! Scatter Load Ok , BaseBand : MT6572 , Project : s3511 , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 56 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040503A135C061C5 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040503A135C061C5 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD5229C2589B8BF077110B205C788285E INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : s3511 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Disabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3746 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000000E5E00000 Flash Pre-Erase Done, time used : 00:00:05 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_s3511.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:01:20 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:01:47 Reconnect Power/Cable! |
10-19-2020, 11:50 | #64665 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Infinix-X652B Frp Code: Patch Level : PPR1.180610.011 Display ID : X652B-H627CDM-P-200413V239 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2020-04-05 Build Time : 1586821956 Product Model : Infinix X652B Product Brand : Infinix Product Name : H627 Product Device : Infinix-X652B Product Manfct : INFINIX MOBILITY LIMITED Product Info : x652b_h627 Product Board : Infinix-X652B Board Platform : mt6765 Product Brand : orange USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption *) STORAGE : LifeStatus : Verify NOT supported by DA/HW! Done! Elapsed: 00:00:23 Operation : Reset Settings/Format FS [ v2.14 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM56) MODE : PRELOADER PORT PORT : 56 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : INFINIX : SECURE_BASE | Manual : Disabled BROM : SOCID : E92A64AFF17FDE0E742934A22FEB91ADA5123FBF93F557DFA9C8B5C29EEA0B7F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SWSEC.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: 150100525036344D42010AEB6AD227A9 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : RP64MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : AE5BC7C47693A4DAF08257A1A3A266 DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
