09-28-2020, 11:42 | #64501 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile super phone sp2000 reset password done by cm2 Card found : S/N : 73CA70CC , v0145 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 3 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : C6D8D211E0B4BCC227491FF034307BB5 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 File_Info : FISE61D_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F9.bin FileVersion : MAUI.11C.W13.52.MP.V2.F9 Done! Elapsed: 00:00:07 Reconnect Power/Cable! Operation : Reset UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 3 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : C6D8D211E0B4BCC227491FF034307BB5 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Read ExtData Sorting ExtData Sort Ok, Rebuild Ok Restore ExtData All done UserCode request removed UserCode set to default ( 0000 or 1122 ) Done! Elapsed: 00:00:11 Reconnect Power/Cable! |
09-28-2020, 11:45 | #64502 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Vgotel i255 reset password done by cm2 Card found : S/N : 73CA70CC , v0145 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 3 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : F91022560537B94C57DA59F35E2FCD90 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00300000 SDS_INFO : 0x002FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 File_Info : FISE61M_11C_PCB01_gsm_MT6261_S00.MAUI_11C_W13_52_M P_V2_F15.bin FileVersion : MAUI.11C.W13.52.MP.V2.F15 Done! Elapsed: 00:00:07 Reconnect Power/Cable! Operation : Reset UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 3 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : F91022560537B94C57DA59F35E2FCD90 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00300000 SDS_INFO : 0x002FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Read ExtData Sorting ExtData Sort Ok, Rebuild Ok Restore ExtData All done UserCode request removed UserCode set to default ( 0000 or 1122 ) Done! Elapsed: 00:00:11 Reconnect Power/Cable! |
09-28-2020, 11:54 | #64503 (permalink) |
No Life Poster Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | infinix Smart 4 Frp Remove Done With King Cm2 Operation : Reset Settings/Format FS [ v2.15 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM38) MODE : PRELOADER PORT PORT : 38 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : TECNO : SECURE_v2 | Manual : Disabled BROM : SOCID : 2DD46175260F34BCD59956E10D211B168F2E74895D7285F15B 50B0E0542604BD AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SWSEC.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 150100514436334D420148B0D3BF1727 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QD63MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : F959BBBA6CCCB093E930C2105D81D1E2 DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
09-28-2020, 14:45 | #64504 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Lava Iris 702 MT6580 Flash Done With King Infinity CM2 Code: Card found : S/N : A19EC787 , v0145 Chinese Miracle II [MTK module] v 1.58 Operation : HW Test [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100463732324D4200F2DACE81A39D Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM227 [eMMC] : FLASH_CID : 150100463732324D4200F2DACE81A39D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xD9C8F395305231434375A161DAA29B6F INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [Processing] FlashMemory Read-Write test [eMMC] : [SAMSUNG] , BM227 , 0x1D2000000 , 7456 MiB [eMMC] : CID : 150100463732324D4200F2DACE81A39D [eMMC] : MODE : SQ-WR [PASSED] : eMMC RW Check #1 Ok! [eMMC] : MODE : RA-WR [PASSED] : eMMC RW Check #2 Ok! [eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed! All Done! Done! Elapsed: 00:00:26 Reconnect Power/Cable! Scatter Load Ok , BaseBand : MT6580 , Project : lava6580_sp462 , Storage : EMMC Files found : 9 , Set to Flash : 8 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : Lava Device Model : iris702 Device CPU : MT6580 Device IntName : iris702 Device Version : 6.0 Device Compile : 14/8/17 11:38:20 Device Project : alps-mp-m0.mp1-V2.34_lava6580.weg.m_P30 Device ExtInfo : iris702 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100463732324D4200F2DACE81A39D Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM227 [eMMC] : FLASH_CID : 150100463732324D4200F2DACE81A39D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xD9C8F395305231434375A161DAA29B6F INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6580 , Project : lava6580_sp462 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 4034 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 1 Erase : 0x0000000001C80000-0x00000001CF300000 Flash Pre-Erase Done, time used : 00:00:04 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_lava6580_sp462.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0013 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : LK Image Flash Ok Flash now : BOOT Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : SECRO Image Flash Ok Flash now : SYSTEM Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USERDATA Image Flash Ok Flash Write Done, time used : 00:07:31 Processing : Verify Verify Passed : LK Verify Passed : BOOT Verify Passed : RECOVERY Verify Passed : LOGO Verify Passed : SECRO Verify Passed : SYSTEM Verify Passed : CACHE Verify Passed : USERDATA Data Verify Done, time used : 00:00:09 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:08:02 Reconnect Power/Cable! |
09-28-2020, 18:18 | #64505 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Tecno camon 11 frp reset done Code: Card found : A6936825 , v0145 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.15 Load IDBase v99153 Ok! Update configuration ... Update Ok! Load IDBase v99153 Ok! Operation : Identify [ v2.15 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM30) MODE : PRELOADER PORT PORT : 30 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : TECNO : SECURE_v2 | Manual : Disabled BROM : SOCID : F0FB26678CA2874324C109CC6D47B86E5495C6A83714C3ECCF0E2981E325DA10 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SWSEC.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 90014A484247346132A521001152A697 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HBG4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 5D4F326E3AF05EA4D5F5C4E7782911C4 DA : USB : HIGH-SPEED Boot done! Patch Level : O11019 Display ID : CF7-H399BCDEFH-O-200630V244 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2020-07-05 Build Time : 30.06.2020 Product Brand : TECNO Product Manfct : TECNO MOBILE LIMITED Product Model : TECNO CF7 Product Device : TECNO-CF7 Product Name : H399 Product Info : TECNO-CF7 Product Board : TECNO-CF7 Board Platform : mt6739 USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption *) NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] STORAGE : LifeStatus : eMMC : NOT implemented in selected DA! PRELOADER : DEVICE : DEV : MT6739 NME : preloader_cf7_h399.bin CNT : 0007 EMI : [00] : eMMC : DDR3 : ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ] EMI : [01] : eMMC : DDR3 : ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 3.00 GB ] EMI : [02] : eMMC : DDR3 : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 3.00 GB ] EMI : [03] : eMMC : DDR3 : ID : 150100514536334D42 : VEN : SAMSUNG | DEV : QE63MB : RAM : [ 2.00 GB ] EMI : [04] : eMMC : DDR3 : ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 2.00 GB ] EMI : [05] : eMMC : DDR3 : ID : 700100464D42434A43 : VEN : KINGSTON | DEV : FMBCJC : RAM : [ 3.00 GB ] EMI : [06] : eMMC : DDR3 : ID : 13014E53304A394237 : VEN : MICRON | DEV : S0J9B7 : RAM : [ 3.00 GB ] Done! Elapsed: 00:00:15 Code: Operation : Reset Settings/Format FS [ v2.15 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM30) MODE : PRELOADER PORT PORT : 30 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : TECNO : SECURE_v2 | Manual : Disabled BROM : SOCID : F0FB26678CA2874324C109CC6D47B86E5495C6A83714C3ECCF0E2981E325DA10 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SWSEC.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 90014A484247346132A521001152A697 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HBG4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 5D4F326E3AF05EA4D5F5C4E7782911C4 DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:13 Reconnect Power/Cable! |
The Following User Says Thank You to Yusuf Lawal For This Useful Post: |
09-29-2020, 02:05 | #64506 (permalink) |
No Life Poster Join Date: Apr 2005 Location: Pretoria South Africa Age: 45
Member: 132635 Status: Offline Thanks Meter: 360 | Hisense u963 android 10 unlock Done There is unlock option in sp2 for sc9832 But luckily there is option to repair Imei So change any imei that you have unlock code Today i done it |
The Following 2 Users Say Thank You to usman0000 For This Useful Post: |
09-29-2020, 07:14 | #64507 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile X30 MT6572 Flashing Done With King Infinity CM2 Code: Card found : S/N : A19EC787 , v0145 Chinese Miracle II [MTK module] v 1.58 Scatter Load Ok , BaseBand : MT6572 , Project : s4050ap , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473261110130D15C3722E9 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A4834473261110130D15C3722E9 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F39581ECF1528190206A1C196B1F INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : s4050ap , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3455 mV BL : [WARNING] : BatteryLevel LOW!!! BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000000E5E00000 Flash Pre-Erase Done, time used : 00:00:06 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_s4050ap.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:03:00 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:40 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:04:07 Reconnect Power/Cable! |
09-29-2020, 07:22 | #64508 (permalink) |
Major Poster Join Date: May 2020 Location: pakistan
Member: 2956389 Status: Offline Thanks Meter: 124 | QMobile Evok Power Lite pattern lock & frp reset done by cm2 Operation : Identify [ v2.15 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM10) MODE : PRELOADER PORT PORT : 10 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT MODE : 0_base : BASE_v2028 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 460001154D32584EB25C0142873480F0 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100464E58324D42015CB2F0803487 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FNX2MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 374DB56A338453ABA266B2F013014D0A STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Patch Level : NRD90M Ver. CodeName : REL Ver. Release : 7.0 Sec. Patch : 2017-06-05 Build Time : 19.06.2017 Product Model : QMobile Evok Power Lite Product Brand : QMobile Product Manfct : QMobile Board Platform : mt6580 Product Info : Evok_Power_Lite Display ID : QMobileEvok Power Lite_MP_19_06 Product Name : Evok_Power_Lite Product Device : Evok_Power_Lite Product Board : s5033c_qmobile_s2_we USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption ***) Done! Elapsed: 00:00:26 Operation : Reset Settings/Format FS [ v2.15 ] Mode : FULL FACTORY ( FORCED + FRP ) 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM10) MODE : PRELOADER PORT PORT : 10 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT MODE : 0_base : BASE_v2028 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 460001154D32584EB25C0142873480F0 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100464E58324D42015CB2F0803487 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FNX2MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 374DB56A338453ABA266B2F013014D0A STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:34 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to MAHER GEE For This Useful Post: |
09-29-2020, 10:00 | #64509 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile J7 MT6595 FRP Reset Done With King Infinity CM2 Code: Card found : S/N : A19EC787 , v0145 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital Boot Ok! BB_CPU_PID : 6595 BB_CPU_NME : [MediaTek] MT6595_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x8C NAND Flash : NOT INSTALLED eMMC Flash : 150100424A4E42345207FA6D499E93C3 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , R4BNJ [eMMC] : FLASH_CID : 150100424A4E42345207FA6D499E93C3 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0xD9C8F39573BB79F198196AD2F9731686 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
09-29-2020, 10:35 | #64510 (permalink) |
Freak Poster Join Date: Jul 2008
Member: 818995 Status: Offline Thanks Meter: 75 | Tecno spark go frp one clik with cm2 Operation : Reset Settings/Format FS [ v2.15 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM3) MODE : PRELOADER PORT PORT : 3 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : TECNO : SECURE_v2 | Manual : Enabled BROM : SOCID : 851E8FB08074BBC2E728F4D729964187D24B87A7262914286C 6F79F3890F2AC4 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SWSEC.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 90014A484147346132A552002006A577 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HAG4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 6D94E66CED20F1C724030AF7D1E1C5D DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
The Following User Says Thank You to mandeep145 For This Useful Post: |
09-29-2020, 11:01 | #64511 (permalink) |
No Life Poster Join Date: Apr 2015 Location: LOOLCANO Taba Day.
Member: 2385819 Status: Offline Sonork: No More Used Thanks Meter: 827 | Vivo Y19 Format Done Via Meta Mode. Card found : DB4A00CC , v0144 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.14 Load IDBase v714150 Ok! Operation : Reset Settings/Format FS [ v2.14 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM23) MODE : PRELOADER PORT PORT : 23 Waiting BOOT ack ... PRELOADER : ACK confirmed! INIT : META confirmed! Boot done! AP_CHIP : MT6768 AP_SWTM : Wed Aug 26 11:17:39 CST 2020 AP_SWVR : alps-mp-p0.mp3.tc19sp.sp2-V1.0.1_bbk.p0mp3.k68v1.64_P209 Format Ok : UserData Done! Elapsed: 00:00:35 Reconnect Power/Cable! |
09-29-2020, 13:07 | #64512 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Itel w5001p read flash file done by cm2 Card found : 73CA70CC , v0145 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.07 Load IDBase v8331 Ok! Operation : Read FW [ v2.07 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Device info : Patch Level : OPM2.171019.012 Display ID : W5001P-F3102-8.1-OP-V058-20200114 Ver. Incmt : OP-V058-20200114 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2020-01-05 Build Time : 14.01.2020 Product Model : itel W5001P Product Brand : Itel Product Name : F3102 Product Device : itel-W5001P Product Manfct : itel Product Info : F3102 Product Board : itel-W5001P Board Platform : sp7731e AndroidVer : 8 VlnrLevel : 0x00 SP7731E__itel__itel_W5001P__8.1.0__W5001P-F3102-8.1-OP-V058-20200114__OPM2.171019.012__F3102 Read : prodnv.img ExtSparse : Compression ratio : 67% Read : phase.cfg Read : recovery.img Read : tos.bin Read : sml.bin Read : u-boot.bin Read : boot_logo.bmp Read : fastboot_logo.bmp Read : nvitem_w.bin Make : persist.img Read : gnssmodem.bin Read : gnssbdmodem.bin Read : modem_wcn.img Read : modem_w.bin Read : deltanv_w.bin Read : gdsp_w.bin Read : pm_sys.bin Read : boot.img Read : system.img ExtSparse : Compression ratio : 86% Make : cache.img Read : vendor.img ExtSparse : Compression ratio : 85% Read : cover.bin Read : vbmeta.img Read : chargelogo.bin Read : chargeremind.bin Read : lkcharge.bin Make : userdata.img Read : u-boot-spl.bin Firmware size : 0x77785C10 ( 1.87 GiB ) Android Info saved : _Android_info.txt Reconnect Power/Cable! Done! Elapsed: 00:14:01 Please Link Share Subscribe My Youtube Channel Flash File Link https://www.youtube.com/watch?v=g4DCEApGXzI |
The Following 2 Users Say Thank You to A.G.Shahid For This Useful Post: |
09-29-2020, 14:23 | #64513 (permalink) |
Member: 818995 Status: Offline Thanks Meter: 75 | Tecno Spark GO frp done with cm2 Operation : Reset Settings/Format FS [ v2.15 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM3) MODE : PRELOADER PORT PORT : 3 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : TECNO : SECURE_v2 | Manual : Enabled BROM : SOCID : 851E8FB08074BBC2E728F4D729964187D24B87A7262914286C 6F79F3890F2AC4 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SWSEC.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 90014A484147346132A552002006A577 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HAG4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 6D94E66CED20F1C724030AF7D1E1C5D DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to mandeep145 For This Useful Post: |
09-29-2020, 15:19 | #64514 (permalink) |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Offline Thanks Meter: 1,640 | Movitel M9102B sc9832e Identify, Dump FW, Write FW Done Code: Operation : Identify [ v2.07 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9832E_BASE : SC9832E_eMMC_1GB_SS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Device info : Patch Level : OPM2.171019.012 Display ID : Movitel_M9102B_V001_20190215_1648_1.0 Ver. Incmt : 20190215.164823 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2019-02-05 Build Time : 15.02.2019 Product Model : M9102B Product Brand : Movitel Product Name : M9102B Product Device : M9102B Product Manfct : HYST Product Info : M9102B Product Board : M9102B Board Platform : sp9832e NVMng : SecurityInfo IMEI[1] : 351641094208713 IMEI[2] : 351641094208721 IMEI[3] : 867400020316638 WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC : SLS:0, SKS:0, SKV:3 Platform Version: MOCORTM_17B_Release_W18.39.7_P3_Debug Project Version: sharkle_Smart_Phone BASE Version: FM_BASE_17B_Release_W18.39.7_P3 HW Version: sc9832e_modem CMP_Time : 11-21-2018 21:12:39 MODEM TAG : MOCORTM_17B_Release_W18.39.7_P3_Debug_FM_BASE_17B_Release_W18.39.7_P3_sc9832e_modem_sharkle_Smart_Phone USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption *) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:04:06 Code: Operation : Read FW [ v2.07 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9832E_BASE : SC9832E_eMMC_1GB_SS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Device info : Patch Level : OPM2.171019.012 Display ID : Movitel_M9102B_V001_20190215_1648_1.0 Ver. Incmt : 20190215.164823 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2019-02-05 Build Time : 15.02.2019 Product Model : M9102B Product Brand : Movitel Product Name : M9102B Product Device : M9102B Product Manfct : HYST Product Info : M9102B Product Board : M9102B Board Platform : sp9832e AndroidVer : 8 VlnrLevel : 0x00 SP9832E_HYSTM9102B8.1.0Movitel_M9102B_V001_20190215_1648_1.0OPM2.171019.012_M9102B Read : prodnv.img ExtSparse : Compression ratio : 12% Read : phase.cfg Read : recovery.img Read : tos.bin Read : sml.bin Read : u-boot.bin Read : boot_logo.bmp Read : fastboot_logo.bmp Read : nvitem_l.bin Read : gnssmodem.bin Read : gnssbdmodem.bin Read : modem_wcn.img Make : persist.img Read : modem_l.bin Read : deltanv_l.bin Read : gdsp_l.bin Read : ldsp_l.bin Read : pm_sys.bin Read : boot.img Read : system.img ExtSparse : Compression ratio : 59% Make : cache.img Read : vendor.img ExtSparse : Compression ratio : 54% Read : vbmeta.img Make : userdata.img Read : u-boot-spl.bin Firmware size : 0x5917C2C4 ( 1.39 GiB ) Android Info saved : _Android_info.txt Reconnect Power/Cable! Done! Elapsed: 00:20:33 Code: Open : SPD_PROG.xml Reading package ... Read package finished! Created by Infinity-Box (c) 2020 Chinese Miracle II : Spreadtrum / UniSoc Service Module Device Info file : _Android_info.txt Patch Level : OPM2.171019.012 Display ID : Movitel_M9102B_V001_20190215_1648_1.0 Ver. Incmt : 20190215.164823 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2019-02-05 Build Time : 15.02.2019 Product Model : M9102B Product Brand : Movitel Product Name : M9102B Product Device : M9102B Product Manfct : HYST Product Info : M9102B Product Board : M9102B Board Platform : sp9832e SECSolution : LEGACY [SS] Operation : Flash Firmware [ v2.07 ] Setting : Update NVRAM : False Setting : Force NVRAM : False Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : INFINITY FW PACKAGE Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x21 PMTMng : Update PMT Ok! FSIMG : prodnv.img CODE : recovery.img CODE : tos.bin CODE : tos.bin CODE : sml.bin CODE : sml.bin UBOOT : u-boot.bin UBOOT : u-boot.bin CODE : boot_logo.bmp CODE : fastboot_logo.bmp CODE : gnssmodem.bin CODE : gnssbdmodem.bin CODE : modem_wcn.img FSIMG : persist.img CODE : modem_l.bin CODE : deltanv_l.bin CODE : gdsp_l.bin CODE : ldsp_l.bin CODE : pm_sys.bin CODE : boot.img FSIMG : system.img FSIMG : cache.img FSIMG : vendor.img CODE : vbmeta.img CODE : vbmeta.img FSIMG : userdata.img UBOOT : u-boot-spl.bin ERASE : MISC ERASE : UBOOT_LOG ERASE : FLASH_L Flashing finished! Reconnect Power/Cable! Done! Elapsed: 00:06:01 |
The Following 2 Users Say Thank You to yuranc8 For This Useful Post: |
09-29-2020, 15:30 | #64515 (permalink) |
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Gionee s8s privacy lock removed [world 1st] no other tool support in the whole world Code: Operation : Identify [ v2.15 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM5) MODE : PRELOADER PORT PORT : 5 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : Vivo : Y83 | Manual : Disabled BROM : SOCID : 56636DB4BAA07E57DAA9B67A5E4924A67D5B697663E47352B55F87385B4DF0B5 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_VIP.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x30000000 [ 768.00 MB ] EMMC: 880103534C443332472052107359C531 EMMC: VEN : FORESEE | OEM : 301 | DEV : SLD32G EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x73A000000 [ 28.91 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 82CC4CE11D54BE24CBC4CAE7CF0F5DA8 DA : USB : HIGH-SPEED Boot done! Patch Level : PPR1.180610.011 Display ID : SWPS8sR50_A_T0004 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2018-12-05 Build Time : 24.01.2019 Product Model : S8s Product Brand : GIONEE Product Name : S8s Product Device : S8s Product Manfct : GIONEE Product Info : S8s Product Board : v6202o Board Platform : mt6765 USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption **) NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] STORAGE : LifeStatus : eMMC : NOT implemented in selected DA! PRELOADER : DEVICE : DEV : MT6765 NME : preloader_v6202o.bin CNT : 0003 EMI : [00] : eMMC : LP_DDR4 : ID : 880103 : VEN : FORESEE | DEV : : RAM : [ 3.00 GB ] EMI : [01] : eMMC : LP_DDR4 : ID : E00117425330333247 : VEN : UNKNOWN | DEV : BS032G : RAM : [ 3.00 GB ] EMI : [02] : eMMC : LP_DDR4 : ID : F40122426977696E20 : VEN : BIWIN | DEV : Biwin : RAM : [ 3.00 GB ] Done! Elapsed: 00:00:19 Code: Operation : Reset PrivacyLock [ v2.15 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM5) MODE : PRELOADER PORT PORT : 5 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : Vivo : Y83 | Manual : Disabled BROM : SOCID : 56636DB4BAA07E57DAA9B67A5E4924A67D5B697663E47352B55F87385B4DF0B5 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_VIP.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x30000000 [ 768.00 MB ] EMMC: 880103534C443332472052107359C531 EMMC: VEN : FORESEE | OEM : 301 | DEV : SLD32G EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x73A000000 [ 28.91 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 82CC4CE11D54BE24CBC4CAE7CF0F5DA8 DA : USB : HIGH-SPEED Boot done! Backup sensetive data [ 11 ] Backup path : Backup\MT6765__82CC4CE11D54BE24CBC4CAE7CF0F5DA8\ [24] Read : NVRAM [8] Read : NVDATA [15] Read : PROINFO [25] Read : LK [7] Read : NVCFG [10] Read : PROTECT1 [11] Read : PROTECT2 [13] Read : PERSIST [0] Read : PRELOADER [12] Read : SECCFG Backup done! Process Block #2 Process Block #3 INFO : [2] PrivacyLock reset done! Done! Elapsed: 00:00:25 Reconnect Power/Cable! |
The Following 5 Users Say Thank You to Yusuf Lawal For This Useful Post: |
