10-13-2021, 15:12 | #68266 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Itel l6502 remove frp done by cm2 Card found : 73CA70CC , v0150 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : L6502 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:19 |
10-13-2021, 16:27 | #68267 (permalink) |
Junior Member Join Date: Jan 2018
Member: 2802601 Status: Offline Thanks Meter: 4 | Hello team how are you I have problem with cm2 king when I open any setup it's not open just showing i icon then hide please fix my issues I have also delete fault.bin file not salve my problem |
10-14-2021, 06:59 | #68268 (permalink) |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Offline Thanks Meter: 1,640 | Mobicel RUBY FRP Done Code: Operation : Identify [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Device info : Patch Level : OPM2.171019.012 Display ID : OPM2.171019.012 release-keys Ver. Incmt : 1596076914 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2020-08-05 Build Time : 30.07.2020 Product Model : RUBY Product Brand : Mobicel Product Name : RUBY Product Info : RUBY Product Device : RUBY Product Manfct : Mobicel Product Board : k210 Board Platform : sp7731e NVMng : SecurityInfo IMEI[1] : 357803100723903 IMEI[2] : 357803101223903 IMEI[3] : 867400020316638 WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC : SLS:0, SKS:0, SKV:4 Platform Version: MOCORTM_17C_W18.23.4_P22_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W18.23.4_P22 HW Version: sc7731e_modem CMP_Time : 09-17-2019 20:33:29 MODEM TAG : MOCORTM_17C_W18.23.4_P22_Debug_FM_BASE_17C_W18.23.4_P22_sc7731e_modem_pike2_pub USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:01:59 Code: Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:01:24 |
The Following User Says Thank You to yuranc8 For This Useful Post: |
10-14-2021, 08:35 | #68269 (permalink) |
No Life Poster Join Date: Apr 2016 Location: B A N G L A D E S H
Member: 2556542 Status: Offline Thanks Meter: 1,790 | Dra-lx5 sim unlock done Code: Operation : Reset SimLock state [ v2.28 ] SECBackup : Enabled 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM7) MODE : BOOTROM PORT : 7 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN [RAPHAEL] BROM : MEID : ABC59480757787898E66C78278D2777A BROM : SecLevel : 0x000000E3 BROM : SecMode : SBC+SLA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 90AE9C1BBEDCED7625284D0048244DFE79C21E9C0666740C481A441209ACE2E9 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : CHANGE : v2112 AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_dura.bin EMI : CNT : 000E EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: CID : 150100464536324D4206F32606153759 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 464536324D42 EMMC: VEN : SAMSUNG : FE62MB EMMC: SNN : 4079355413 ( 0xF3260615) , MF : 3/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : E6FF03CD324F58E012A32AADB10EE3BD DA : USB : HIGH-SPEED Boot done! Backup sensetive data [ 16 ] Backup path : Backup\MT6739__ABC59480757787898E66C78278D2777A\ [21] Read : NVRAM [7] Read : NVDATA [14] Read : PROINFO [26] Read : LK [6] Read : NVCFG [10] Read : PROTECT1 [11] Read : PROTECT2 [1] Read : PGPT [0] Read : PRELOADER Backup done! Process Block #0 Process Block #1 INFO : Operation finished! Require make next steps : INFO : 1. Power on phone and wait full boot INFO : 2. Make factory reset from phone menu INFO : 3. If need - make ModemInit, repair security after Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to kothamamun For This Useful Post: |
10-14-2021, 09:40 | #68270 (permalink) |
Freak Poster Join Date: Sep 2017 Location: Tanzania
Member: 2758606 Status: Offline Sonork: pasua Thanks Meter: 108 | Lg (lgl23) format & frp done Operation : Identify [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD VOLUME UP KEY! 3. Insert USB cable, wait until Download mode screen will appear Wait for phone... Connection opened successfully! Waiting for loader ... Handshake passed! Collect info... Running : MiniOS v1.0 , ver.1.0 , with proto ver.01000001 HWInfo : BaseBand : MSM8974 HWInfo : ChargeLv : 60% HWInfo : MEM_INFO : 032G96 , MEM_LEN : 0x03A3E000 [eMMC 32 GiB] DevInfo : Model : LGL23 , Type : LGL2310d DevInfo : ANDROID 4.2.2 DevInfo : PSN : PT01S140114005360 , PID : 05dde023cf0cc1f4 DevInfo : IMEI : 358380050551443 DevInfo : SecMode : S , Build : U , RCT : 33383500 SWInfo : SWver : V10d , SW : LGL23AT-00-V10d-440-50-DEC-10-2013+0 SWInfo : FacSW : LGL23AT-00-V10d-OPEN-COM-DEC-10-2013+0 RegInfo : Region : COM , Provider : OPEN Prepare passed, mode 0x01 Boot done! Brand : KDDI ProdName : z_jp_kdi ProdModel : LGL23 Device : zee AndroidVer: 4.2.2 Manufact. : LGE LGMxCPU : MSM8974 Done! Elapsed: 00:00:39 Operation : Reset Settings/Format FS [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD VOLUME UP KEY! 3. Insert USB cable, wait until Download mode screen will appear Wait for phone... Connection opened successfully! Waiting for loader ... Handshake passed! Collect info... Prepare passed, mode 0x01 Boot done! Format UserData Format Cache Format done Reconnect Power/Cable! Done! Elapsed: 00:00:37 |
The Following User Says Thank You to massoudou For This Useful Post: |
10-14-2021, 10:00 | #68271 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Tecno K8 MT6735 FRP/Pattren Reset Done With King Infinity CM2 Code: Card found : A19EC787 , v0150 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.28 Load IDBase v718267 Ok! UserName and/or Password not set! Can't continue! Update failed! Check settings and/or internet connection! Operation : Reset Settings/Format FS [ v2.28 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM4) MODE : BOOTROM PORT : 4 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY [MTK] BROM : MEID : 66EA79F80EA641DF0585DFE92C144FC4 BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SLA : 0x000000FE BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 150100514536334D42031B94D83A0E45 DAInf: 4 : 2 : 155 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 510001154D333645941B0342450E3AD8 NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 DRAM : 0x0178 EMI : DEV : FireFly EMI : SRC : preloader_rlk6737m_35g_n.bin EMI : CNT : 0004 EMI : [00] : ID : 150100464536324D42 : VEN : SAMSUNG | DEV : FE62MB : RAM : [ 1.00 GB ] EMI : [01] : ID : 700100454841454538 : VEN : KINGSTON | DEV : EHAEE8 : RAM : [ 1.00 GB ] EMI : [02] : ID : 150100514536334D42 : VEN : SAMSUNG | DEV : QE63MB : RAM : [ 2.00 GB ] EMI : [03] : ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 2.00 GB ] EMI : Init EMI from PRELOADER INIT : 0xBC : DRAM [ 0x00000000 : [ 0 B ] ] DRAM : DRAM: 0x80000000 [ 2.00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: CID : 150100514536334D42031B94D83AB445 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 514536334D42 EMMC: VEN : SAMSUNG : QE63MB EMMC: SNN : 462739514 ( 0x1B94D83A) , MF : 11/2017 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : B3FF678284A966941FFAD89FA31C2AE STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM6) MODE : PRELOADER PORT PORT : 6 Boot done! SmartInfo : 0x8F5656 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:36 Reconnect Power/Cable! |
10-14-2021, 11:30 | #68272 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Vivo 1727 reset frp done by cm2 Card found : 73CA70CC , v0150 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 625 [MSM8953] ID_BLOCK_S : D522A8BE ID_BLOCK_L : 67B69D78E36ABBE7B385F707E3DE9221 ID_BLOCK_L : FBA03AC927CBEA5B3AB35516B15B6E2C Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8953 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RD64MB Boot Ok! Brand : vivo ProdName : msm8953_64 ProdModel : vivo 1727 Device : msm8953_64 AndroidVer: 8.1.0 Manufact. : vivo SysPatch : OPM1.171019.026 DevComTime: 5/13/2019 8:58:23 AM USERData : ENCRYPTED GCSec : NORMAL Done! Elapsed: 00:00:13 Reconnect Power/Cable! Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 625 [MSM8953] ID_BLOCK_S : D522A8BE ID_BLOCK_L : 67B69D78E36ABBE7B385F707E3DE9221 ID_BLOCK_L : FBA03AC927CBEA5B3AB35516B15B6E2C Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8953 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RD64MB Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
10-14-2021, 11:33 | #68273 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Oppo a5s reset frp done by cm2 Card found : 73CA70CC , v0150 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.28 Load IDBase v98353 Ok! Update configuration ... Update Ok! Load IDBase v98353 Ok! Operation : Reset Settings/Format FS [ v2.28 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM27) MODE : BOOTROM PORT : 27 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : BBCB095017BBFF8810F9E5D0B63F0683 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 1919FF7391D6EB0DA5628F20A29070FCA07AC5EF1FCDCBC95E D4A7431E318B78 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_oppo6765_18511.bin EMI : CNT : 0009 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 15010052483634414205F00D9A52C53D EMMC: VEN : SAMSUNG : OEM : 0 : ID : 524836344142 EMMC: VEN : SAMSUNG : RH64AB EMMC: SNN : 4027423314 ( 0xF00D9A52) , MF : 12/2018 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 16EAB20638B5A563AB4E6160917ADC33 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x805757 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:32 Reconnect Power/Cable! |
10-14-2021, 12:17 | #68274 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Qmobile M350 Read Pattern Done Operation : Read Pattern/DP Lock [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100463732324D42002781906883B7 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM227 [eMMC] : FLASH_CID : 150100463732324D42002781906883B7 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xE6C52A7D1504632C424ADDD9FE61B2DE INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... Get Locks ... PatternLock Sequnce : 12487 Done! Elapsed: 00:00:25 Reconnect Power/Cable! |
10-14-2021, 13:25 | #68275 (permalink) |
No Life Poster Join Date: Mar 2011 Location: PAKISTAN
Member: 1537135 Status: Offline Thanks Meter: 1,021 | Nokia 2.3 (TA-1206) FRP REMOVE DONE Infinity Box [CODECard found : C1B4DF65 , v0150 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.28 Load IDBase v718267 Ok! UserName and/or Password not set! Can't continue! Update failed! Check settings and/or internet connection! Operation : Identify [ v2.28 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM7) MODE : BOOTROM PORT : 7 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN [RAPHAEL] BROM : MEID : 706400C439615A74E31B8180434786FA BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : FE338E457A82B49850544B896444AE4755E8C95A9FB385CE5D 26411B4D43A8C7 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_t99621aa2.bin EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A400 [ 233.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : F40122426977696E2010000008D8A647 EMMC: VEN : BIWIN : OEM : 34 : ID : 426977696E20 EMMC: VEN : BIWIN : Biwin EMMC: SNN : 2264 ( 0x000008D8) , MF : 10/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x735000000 [ 28.83 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 9AC55DE37392D3C969CE471FADAB4D3 DA : USB : HIGH-SPEED Boot done! Product Brand : Nokia Product Model : Nokia 2.3 Product Name : Ironman_00WW Product Device : IRM_sprout Patch Level : QP1A.190711.020 Display ID : 00WW_2_340_SP03 Product Info : IRM_sprout Product Model : 00WW Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2021-02-05 Build Time : 02.02.2021 Product Board : MT6761 Board Platform : mt6761 Product Manfct : HMD Global USERDATA : FILESYSTEM : EXT4 with FBE ( File-Base Encryption ) NVRAM : 0xA008BEA6 NVRAM : State : Ok! INFO : WiFi MAC : AA0036004400 INFO : BlTh MAC : C010B13C77C9 INFO : IMEI[1] : ---------- INFO : IMEI[2] : 35----------- STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! Done! Elapsed: 00:00:18 Operation : Reset Settings/Format FS [ v2.28 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM7) MODE : BOOTROM PORT : 7 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN [RAPHAEL] BROM : MEID : 706400C439615A74E31B8180434786FA BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : FE338E457A82B49850544B896444AE4755E8C95A9FB385CE5D 26411B4D43A8C7 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_t99621aa2.bin EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A400 [ 233.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : F40122426977696E2010000008D8A647 EMMC: VEN : BIWIN : OEM : 34 : ID : 426977696E20 EMMC: VEN : BIWIN : Biwin EMMC: SNN : 2264 ( 0x000008D8) , MF : 10/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x735000000 [ 28.83 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 9AC55DE37392D3C969CE471FADAB4D3 DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:13 Reconnect Power/Cable! ][/CODE] |
The Following User Says Thank You to naveedullah0044 For This Useful Post: |
10-14-2021, 13:54 | #68276 (permalink) |
Major Poster Join Date: Mar 2014 Location: Gweru Zimbabwe
Member: 2147534 Status: Offline Thanks Meter: 13 | Nokia c10 network unlock done by great cm2 1st in the world Card found : DFCD1A5B , v0150 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : SP Unlock [ v2.14 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... >>> Device not found! >>> Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : SP Unlock [ v2.14 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : Mantis_00WW-user 11 RP1A.201005.001 V1.230_B01 release-keys Platform Version: MOCORTM_17C_W21.11.2_P3_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W21.11.2_P3 HW Version: sc7731e_modem CMP_Time : 05-25-2021 21:34:06 MODEM TAG : MOCORTM_17C_W21.11.2_P3_Debug_FM_BASE_17C_W21.11.2 _P3_sc7731e_modem_pike2_pub NVMng : SecurityInfo IMEI[1] : 357735915300560 IMEI[2] : 357735915300578 WIFIMAC : 44917C13B0ED BT_MAC : 44917C13B0EC SEC : SLS:2, SKS:0, SKV:4 SLStatus : 2C Status : Locked! Server unlock required! Connecting to server... Connected Init... Init: Ok Authenticating... Authenticated Checking Client version... Client version Ok Balance: 5, price:5 Process... Finished Unlocking device ... Sync data ... Device unlocked! Done! Elapsed: 00:00:49 THANK U INFINITY TEAM FOR FIXING UNLOCK DONE AND STILL LOCKED |
The Following 5 Users Say Thank You to Tinadenzy For This Useful Post: |
10-14-2021, 14:07 | #68277 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Itel l6006 reset frp done by cm2 Card found : 73CA70CC , v0150 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9832E_BASE : SC9832E_eMMC_1GB_0S Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:15 Done! Elapsed: 00:01:25 |
10-14-2021, 14:23 | #68278 (permalink) |
Banned Join Date: Oct 2016 Location: In Your Heart
Member: 2636401 Status: Offline Thanks Meter: 2,332 | Q Smart Gli Reset Factory Successfully With CM2 KING Card found : 768E9180 , v0150 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Identify [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_0S Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! |
The Following User Says Thank You to kk3 For This Useful Post: |
10-14-2021, 15:41 | #68279 (permalink) |
Freak Poster Join Date: Jun 2003 Location: zimbab Age: 46
Member: 32705 Status: Offline Thanks Meter: 66 | iTel A14 Network Unlocking Operation : SP Unlock [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_512MB_RS_LOW Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! NVMng : SecurityInfo IMEI[1] : 359900100570488 IMEI[2] : 359900100570496 IMEI[3] : 867400020316638 WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC : SLS:1, SKS:0, SKV:3 SLStatus : 32 Status : Locked! Server unlock required! Connecting to server... Connected Init... Init: Ok Authenticating... Authenticated Checking Client version... Client version Ok Balance: 5, price:5 Process... Finished Unlocking device ... Sync data ... Device unlocked! Done! Elapsed: 00:01:35 |
10-14-2021, 15:42 | #68280 (permalink) |
No Life Poster Join Date: Apr 2021 Location: GSM AFRICA TEAM (SA)
Member: 2986985 Status: Offline Thanks Meter: 163 | Nokia C10 (TA-1342) Sim Network Unlock done with infinity cm2 :) Code: Operation : SP Unlock [ v2.14 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : Mantis_00WW-user 11 RP1A.201005.001 V1.230_B01 release-keys Platform Version: MOCORTM_17C_W21.11.2_P3_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W21.11.2_P3 HW Version: sc7731e_modem CMP_Time : 05-25-2021 21:34:06 MODEM TAG : MOCORTM_17C_W21.11.2_P3_Debug_FM_BASE_17C_W21.11.2_P3_sc7731e_modem_pike2_pub NVMng : SecurityInfo IMEI[1] : 357735914789185 IMEI[2] : 357735914789193 WIFIMAC : 44917C117A3B BT_MAC : 44917C117A3A SEC : SLS:2, SKS:0, SKV:4 SLStatus : 2C Status : Locked! Server unlock required! Connecting to server... Connected Init... Init: Ok Authenticating... Authenticated Checking Client version... Client version Ok Balance: 755, price:5 Process... Finished Unlocking device ... Sync data ... Device unlocked! Done! Elapsed: 00:01:10 Thank infinity team |
The Following 5 Users Say Thank You to Gsm Africa Team For This Useful Post: |
