05-02-2022, 14:05 | #70861 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Orange Leaf Mobile O500 PrivacyLock & Smart reset Done 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM16) MODE : PRELOADER PORT PORT : 16 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY [MTK] BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 460001154D323237861A00426343F4DE DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: CID : 150100463732324D42001A86DEF44363 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 463732324D42 : PRV : 0x00 EMMC: VEN : SAMSUNG : F722MB EMMC: SNN : 445046516 ( 0x1A86DEF4 ) , MF : 4/2016 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 1F79C41EDFE1BEF57BEA7BB116CABBF5 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Backup sensetive data [ 18 ] Backup path : Backup\MT6580__1F79C41EDFE1BEF57BEA7BB116CABBF5\ [3] Read : NVRAM [14] Read : NVDATA [2] Read : PROINFO [7] Read : LK [4] Read : PROTECT1 [0] Read : PRELOADER Backup done! INFO : [1] PrivacyLock reset done! Process Block #2 INFO : [2] PrivacyLock reset done! Done! Elapsed: 00:00:59 Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.34 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM16) MODE : PRELOADER PORT PORT : 16 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY [MTK] BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 460001154D323237861A00426343F4DE DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: CID : 150100463732324D42001A86DEF44363 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 463732324D42 : PRV : 0x00 EMMC: VEN : SAMSUNG : F722MB EMMC: SNN : 445046516 ( 0x1A86DEF4 ) , MF : 4/2016 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 1F79C41EDFE1BEF57BEA7BB116CABBF5 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x8E5454 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:44 Reconnect Power/Cable! |
05-02-2022, 16:01 | #70862 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Ethiopia
Member: 449991 Status: Offline Thanks Meter: 933 | redmi 9 DA : SETUP EMI PARAMS FAILED! fixed and repair imei successfully redmi 9 DA : SETUP EMI PARAMS FAILED! fixed and repair imei successfully use preloder below remove hardware protection then done PTFN : MediaTek USB Port (COM48) MODE : BOOTROM PORT : 48 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 8F49446F7E46B42F765F353EC8D50861 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : A7A90CEB01381F8B2AC17224D5AB120F4B7C7B240EEEE1DB93 D2EE1000BBD5F6 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI not found BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 13014E53304A333944102405806728BB EMMC: VEN : MICRON : OEM : 78 : ID : 53304A333944 : PRV : 0x10 EMMC: VEN : MICRON : S0J39D EMMC: SNN : 604340327 ( 0x24058067 ) , MF : 2/2021 EMI : DEV : MT6765 EMI : SRC : preloader_k65v1_64_bsp.bin EMI : CNT : 000B EMI : [00] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 512.00 MB ] EMI : [01] : eMMC : LP_DDR4X : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 3.00 GB ] EMI : [02] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 2.00 GB ] EMI : [03] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 2.00 GB ] EMI : [04] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [05] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [06] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ] EMI : [07] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [08] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6.00 GB ] EMI : [09] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 2.00 GB ] EMI : [0A] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x180000000 [ 6.00 GB ] EMMC: CID : 13014E53304A333944102405806728BB EMMC: VEN : MICRON : OEM : 78 : ID : 53304A333944 : PRV : 0x10 EMMC: VEN : MICRON : S0J39D EMMC: SNN : 604340327 ( 0x24058067 ) , MF : 2/2021 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x1D1F000000 [ 116.48 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 9758AF8EEBA74C32B7FC5E2EBD43A9DE DA : USB : HIGH-SPEED Boot done! NVRAM : 0xB40ADDD0 NVRAM : State : Ok! NVRAM : SecLv : Vendor Signed INFO : WiFi MAC : BC6AD1983E57 INFO : BlTh MAC : BC6AD1983E56 INFO : IMEI[1] : 0000000000 INFO : IMEI[2] : 000000000000000 INFO : set IMEI[1] : 3529000000000000 INFO : set IMEI[2] : 35200000000000000 Update NVRAM ... Update NVRAM Ok! Update dependencies ... Update dependencies Ok! Done! Elapsed: 00:01:18 Reconnect Power/Cable! |
The Following User Says Thank You to dereje For This Useful Post: |
05-02-2022, 17:24 | #70863 (permalink) |
Freak Poster Join Date: May 2016
Member: 2573102 Status: Offline Thanks Meter: 21 | Jazz Digit4G Crown SP-unlock done! Operation : SP Unlock [ v2.14 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : sp9820e_1h10ll_native-user 4.4.4 KTU84P eng.sz1002.20220121.145338 test-keys Platform Version: MOCORTM_19A_W19.39.5_P2_Debug Project Version: sharkle_Feature_Phone BASE Version: FM_BASE_19A_W19.39.5_P2 HW Version: sc9820e_modem CMP_Time : 12-04-2019 16:52:39 MODEM TAG : MOCORTM_19A_W19.39.5_P2_Debug_FM_BASE_19A_W19.39.5 _P2_sc9820e_modem_sharkle_Feature_Phone NVMng : SecurityInfo IMEI[1] : 35 IMEI[2] : 35 WIFIMAC : F0 BT_MAC : B0 SEC : SLS:0, SKS:0, SKV:4 SLStatus : 31 Unlocking device ... Sync data ... Device unlocked! Done! Elapsed: 00:00:23 |
The Following 2 Users Say Thank You to khankh For This Useful Post: |
05-03-2022, 08:09 | #70864 (permalink) |
No Life Poster Join Date: Nov 2008 Location: RVIII
Member: 890926 Status: Offline Thanks Meter: 2,053 | Huawei Y5 FRP Huawei Y5 Code: Operation : Reset Settings/Format FS [ v2.34 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM23) MODE : BOOTROM PORT : 23 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY [MTK] BROM : MEID : E8F1B197859398E2DDAD52D152746642 BROM : SecLevel : 0x00000001 BROM : SecMode : SBC BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM AGENT : 0_base : BASE_v2152 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_5.2152.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 90014A484147346132D4C267A5344D77 DAInf: 4 : 2 : 155 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 484A01906134474167C2D432774D34A5 NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 DRAM : 0x0178 EMI : DEV : FireFly EMI : SRC : preloader_hq6737t_66_1ha_m0.bin EMI : CNT : 0006 EMI : [00] : ID : 110100303136473332 : VEN : TOSHIBA | DEV : 016G32 : RAM : [ 2.00 GB ] EMI : [01] : ID : 150100514531334D42 : VEN : SAMSUNG | DEV : QE13MB : RAM : [ 2.00 GB ] EMI : [02] : ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 2.00 GB ] EMI : [03] : ID : 13014E51334A393652 : VEN : MICRON | DEV : Q3J96R : RAM : [ 2.00 GB ] EMI : [04] : ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 2.00 GB ] EMI : [05] : ID : 450100444634303136 : VEN : SANDISK | DEV : DF4016 : RAM : [ 2.00 GB ] EMI : Init EMI from PRELOADER INIT : 0xBC : DRAM [ 0x00000000 : [ 0 B ] ] DRAM : DRAM: 0x80000000 [ 2.00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: CID : 90014A484147346132D4C267A5345577 EMMC: VEN : HYNIX : OEM : 74 : ID : 484147346132 : PRV : 0xD4 EMMC: VEN : HYNIX : HAG4a2 EMMC: SNN : 3261572404 ( 0xC267A534 ) , MF : 5/2018 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 17877D91FE00F8F17AE7C501C88D0C15 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM30) MODE : PRELOADER PORT PORT : 30 Boot done! SmartInfo : 0x8E5654 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:01:13 |
05-03-2022, 14:18 | #70865 (permalink) |
No Life Poster Join Date: Sep 2021 Location: Germany
Member: 2996196 Status: Offline Thanks Meter: 632 | Itel p37 clone pin reset and read firmware done by cm2 Operation : Reset Settings/Format FS [ v2.32 ] Mode : FACTORY RESET ( WIPE ) 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM19) MODE : PRELOADER PORT PORT : 19 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : LEGACY [MTK] BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : CHANGE : v1844 AGENT : Found MT6582 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 484A019064314734A1060504718190E5 DAInf: 4 : 2 : 135 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: CID : 90014A4834473164040506A1E5908171 EMMC: VEN : HYNIX : OEM : 74 : ID : 483447316404 EMMC: VEN : HYNIX : H4G1d EMMC: SNN : 111273360 ( 0x06A1E590) , MF : 8/2014 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE9000000 [ 3.64 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 4893BD98926D6E48F4B9BF929B85CC57 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Done! Elapsed: 00:00:34 Reconnect Power/Cable! Operation : Read Firmware [ v2.32 ] ExtSparse : Enabled ForceRead : Disabled 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM19) MODE : PRELOADER PORT PORT : 19 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : LEGACY [MTK] BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : CHANGE : v1844 AGENT : Found MT6582 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 484A019064314734A1060504718190E5 DAInf: 4 : 2 : 135 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: CID : 90014A4834473164040506A1E5908171 EMMC: VEN : HYNIX : OEM : 74 : ID : 483447316404 EMMC: VEN : HYNIX : H4G1d EMMC: SNN : 111273360 ( 0x06A1E590) , MF : 8/2014 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE9000000 [ 3.64 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 4893BD98926D6E48F4B9BF929B85CC57 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Patch Level : LRX21M Display ID : Q93_C.BH.2020_M10D_ZX_P37_KH_14_V01_20220111 Ver. CodeName : REL Ver. Release : 5.0.2 Sec. Patch : 2021-11-15 Build Time : 11.01.2022 Product Model : P37 Product Name : P37 Product Device : gionee6582_wt_l Product Board : P37 Product Brand : HB Product Manfct : HB Board Platform : mt6582 Product Info : gionee6582_wt_l MT6582__HB__P37__5.0.2__Q93_C.BH.2020_M10D_ZX_P37_ KH_14_V01_20220111__LRX21M__gionee6582_wt_l Read : preloader.bin Read : mbr.img Read : ebr.img Read : proinfo.img Read : nvram.bin Read : lk.bin Read : boot.img Read : recovery.img Read : secro.img Read : logo.bin Read : system.img ExtSparse : Compression ratio : 24% Read : cache.img Read : userdata.img FW Size : 1.23 GB Android Info saved : _Android_info.txt Scatter : MT6582_Android_scatter.txt Saved to : F:\Firmwares\ITEL\MT6582__HB__P37__5.0.2__Q93_C.BH .2020_M10D_ZX_P37_KH_14_V01_20220111__LRX21M__gion ee6582_wt_l\ Done! Elapsed: 00:10:58 |
The Following User Says Thank You to Jacobkamudyariw For This Useful Post: |
05-04-2022, 05:05 | #70866 (permalink) |
No Life Poster Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | oppo A16e frp done Operation : Reset Settings/Format FS [ v2.34 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM68) MODE : BOOTROM PORT : 68 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 3D25583E5C93C666A7ED1393D9C8EB3C BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : DA965798AD6D76B02C47F267954D5A979A718C10B37B2F97F4 FF1A3FE376FF1E BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 150100445036444242024D7DD491C88F EMMC: VEN : SAMSUNG : OEM : 0 : ID : 445036444242 : PRV : 0x02 EMMC: VEN : SAMSUNG : DP6DBB EMMC: SNN : 1300092049 ( 0x4D7DD491 ) , MF : 12/2021 EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0008 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 150100445036444242024D7DD491C88F EMMC: VEN : SAMSUNG : OEM : 0 : ID : 445036444242 : PRV : 0x02 EMMC: VEN : SAMSUNG : DP6DBB EMMC: SNN : 1300092049 ( 0x4D7DD491 ) , MF : 12/2021 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 5969F6CFC79134E9F7983C4C1A016A6D DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:38 Reconnect Power/Cable! |
05-04-2022, 07:15 | #70867 (permalink) | ||
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Intex Cloud Q11 read firmware and reset userlock + google protection done- Quote:
Infinity-Box Team. | ||
05-04-2022, 12:52 | #70868 (permalink) |
No Life Poster Join Date: Aug 2020 Location: Mozambique Age: 20
Member: 2965136 Status: Offline Sonork: 58846 Thanks Meter: 1,202 | Nokia TA-1352 SP Unlock Done Code: Card found : 46828B86 , v0153 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : SP Unlock [ v2.14 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : Cosmo_00WW-user 11 RP1A.201005.001 V1.350_B01 release-keys Platform Version: MOCORTM_20A_W21.15.3_P13_Debug Project Version: sharkl3_pub BASE Version: 4G_MODEM_20A_W21.15.3_P13 HW Version: sc9863A_modem CMP_Time : 08-09-2021 10:39:43 MODEM TAG : MOCORTM_20A_W21.15.3_P13_Debug_4G_MODEM_20A_W21.15.3_P13_sc9863A_modem_sharkl3_pub NVMng : SecurityInfo IMEI[1] : 356616850801062 IMEI[2] : 356616850801070 WIFIMAC : 44917C48F7D9 BT_MAC : 44917C48F7D8 SEC : SLS:2, SKS:0, SKV:4 SLStatus : 2C Status : Locked! Server unlock required! Connecting to server... Connected Init... Init: Ok Authenticating... Authenticated Checking Client version... Client version Ok Balance: 10, price:5 Process... Finished Unlocking device ... Sync data ... Device unlocked! Done! Elapsed: 00:00:31 |
The Following 2 Users Say Thank You to tayobjoy1 For This Useful Post: |
05-04-2022, 15:13 | #70869 (permalink) |
Member: 2996196 Status: Offline Thanks Meter: 632 | Hisense u605 frp reset done by cm2 Operation : Identify [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_0S Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Device info : Patch Level : OPM2.171019.012 Display ID : Hisense_U605_00_S02_20190118 Ver. Incmt : Hisense_U605_00_S02_0105 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2019-01-05 Build Time : 18.01.2019 Product Model : Hisense U605 Product Brand : Hisense Product Name : U605 Product Device : HS7731ESP Product Board : Hisense_U605 Product Manfct : Hisense Product Info : sp7731e_fs280 Product Board : sp7731e_fs280 Board Platform : sp7731e NVMng : SecurityInfo IMEI[1] : 867790041913920 IMEI[2] : 867400020316620 IMEI[3] : 867400020316638 WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC : SLS:0, SKS:0, SKV:4 Platform Version: MOCORTM_17C_W18.23.4_P9_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W18.23.4_P9 HW Version: sc7731e_modem CMP_Time : 10-13-2018 10:47:12 MODEM TAG : MOCORTM_17C_W18.23.4_P9_Debug_FM_BASE_17C_W18.23.4 _P9_sc7731e_modem_pike2_pub USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:00:46 Operation : Format FS / Reset Settings [ v2.14 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_0S Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:04:21 |
The Following 2 Users Say Thank You to Jacobkamudyariw For This Useful Post: |
05-04-2022, 16:39 | #70870 (permalink) |
Member: 2996196 Status: Offline Thanks Meter: 632 | Itel p37 P651W frp reset done by cm2 Operation : Identify [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : P651W Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Device info : Product Brand : Itel Product Device : P651W Product Model : itel P651W Product Name : P651W Patch Level : QP1A.190711.020 Display ID : P651W-F3116-10.0-OP-V032-20210816 Ver. Incmt : OP-V032-20210816 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2021-08-05 Build Time : 16.08.2021 Product Name : F3116 Product Device : itel-P651W Product Info : P651W Product Board : P651W Board Platform : sp7731e Product Manfct : itel NVMng : SecurityInfo IMEI[1] : 358421270161025 IMEI[2] : 358421270161033 IMEI[3] : 867400020316638 WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC : SLS:0, SKS:0, SKV:4 Platform Version: MOCORTM_17C_W20.21.2_P9_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W20.21.2_P9 HW Version: sc7731e_modem CMP_Time : 01-28-2021 11:10:37 MODEM TAG : MOCORTM_17C_W20.21.2_P9_Debug_FM_BASE_17C_W20.21.2 _P9_sc7731e_modem_pike2_pub USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:01:21 Operation : Format FS / Reset Settings [ v2.14 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : P651W Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:30 |
05-04-2022, 16:55 | #70871 (permalink) |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Offline Thanks Meter: 1,640 | iTEL A23S Pro L5006s NETWORK UNLOCK Done Code: Card found : 5C203D37 , v0153 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : SP Unlock [ v2.14 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... >>> Device not found! >>> Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : SP Unlock [ v2.14 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : L5006S-F3212MZ-10.0-MZ-Vodacom-V014-20210901 Platform Version: MOCORTM_18A_W20.23.2_P8_Debug Project Version: sharkle_Smart_Phone BASE Version: FM_BASE_18A_W20.23.2_P8 HW Version: sc9832e_modem CMP_Time : 12-29-2020 18:41:45 MODEM TAG : MOCORTM_18A_W20.23.2_P8_Debug_FM_BASE_18A_W20.23.2_P8_sc9832e_modem_sharkle_Smart_Phone NVMng : SecurityInfo IMEI[1] : 357068261930255 IMEI[2] : 354648020000004 WIFIMAC : CCA3BDE24C16 BT_MAC : CCA3BDE24C15 SEC : SLS:0, SKS:0, SKV:4 SLStatus : 31 Unlocking device ... Sync data ... Device unlocked! Done! Elapsed: 00:01:33 |
The Following User Says Thank You to yuranc8 For This Useful Post: |
05-04-2022, 17:03 | #70872 (permalink) |
Junior Member Join Date: Jul 2015 Location: Nigeria
Member: 2435886 Status: Offline Thanks Meter: 1 | PLEASE REFUND CREDITS INFINITY BOX CHARGE 10 CREDITS FOR UNLOCKING DEVICE Card found : 5B715C61 , v0152 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : SP Unlock [ v2.14 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : Cosmo_00WW-user 11 RP1A.201005.001 V1.610_B01 release-keys Platform Version: MOCORTM_20A_W21.15.3_P17_Debug Project Version: sharkl3_pub BASE Version: 4G_MODEM_20A_W21.15.3_P17 HW Version: sc9863A_modem CMP_Time : 10-29-2021 20:11:24 MODEM TAG : MOCORTM_20A_W21.15.3_P17_Debug_4G_MODEM_20A_W21.15 .3_P17_sc9863A_modem_sharkl3_pub NVMng : SecurityInfo IMEI[1] : 356748979725607 IMEI[2] : 356748979725615 WIFIMAC : 44917C23767D BT_MAC : 44917C23767C SEC : SLS:2, SKS:0, SKV:4 SLStatus : 2C Status : Locked! Server unlock required! Connecting to server... Connected Init... Init: Ok Authenticating... Authenticated Checking Client version... Client version Ok Balance: 25, price:5 Process... Process : Operation may took 10-15 minutes! >>> Repeat unlock/repair procedure after requested time again! Reconnect Power/Cable! Operation : SP Unlock [ v2.14 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : Cosmo_00WW-user 11 RP1A.201005.001 V1.610_B01 release-keys Platform Version: MOCORTM_20A_W21.15.3_P17_Debug Project Version: sharkl3_pub BASE Version: 4G_MODEM_20A_W21.15.3_P17 HW Version: sc9863A_modem CMP_Time : 10-29-2021 20:11:24 MODEM TAG : MOCORTM_20A_W21.15.3_P17_Debug_4G_MODEM_20A_W21.15 .3_P17_sc9863A_modem_sharkl3_pub NVMng : SecurityInfo IMEI[1] : 356748979725607 IMEI[2] : 356748979725615 WIFIMAC : 44917C23767D BT_MAC : 44917C23767C SEC : SLS:2, SKS:0, SKV:4 SLStatus : 2C Status : Locked! Server unlock required! Connecting to server... Connected Init... Init: Ok Authenticating... Authenticated Checking Client version... Client version Ok Balance: 20, price:5 Process... Finished Unlocking device ... Sync data ... Device unlocked! Done! Elapsed: 00:00:41 |
05-04-2022, 18:44 | #70873 (permalink) |
Member: 2680008 Status: Offline Thanks Meter: 1,640 | iTEL A23s L5006S NETWORK UNLOCK Done Code: Card found : 5C203D37 , v0153 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : SP Unlock [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : L5006S Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! NVMng : SecurityInfo IMEI[1] : 357068261807883 IMEI[2] : 354648020000004 IMEI[3] : 867400020316638 WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC : SLS:0, SKS:0, SKV:4 SLStatus : 11 Unlocking device ... Sync data ... Device unlocked! Done! Elapsed: 00:01:20 |
05-04-2022, 18:47 | #70874 (permalink) |
Member: 2680008 Status: Offline Thanks Meter: 1,640 | iTEL A23S L5006S NETWORK UNLOCK Done Code: Operation : Identify [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : L5006S Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Device info : Product Brand : Itel Product Device : L5006S Product Model : itel L5006S Product Name : L5006S Patch Level : QP1A.190711.020 Display ID : L5006S-F3212MZ-10.0-MZ-Vodacom-V015-20211126 Ver. Incmt : MZ-Vodacom-V015-20211126 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2021-11-05 Build Time : 26.11.2021 Product Name : F3212MZ Product Device : itel-L5006S Product Info : L5006S Product Board : L5006S Board Platform : sp9832e Product Manfct : itel NVMng : SecurityInfo IMEI[1] : 357068261437186 IMEI[2] : 354648020000004 IMEI[3] : 867400020316638 WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC : SLS:0, SKS:0, SKV:4 Platform Version: MOCORTM_18A_W20.23.2_P8_Debug Project Version: sharkle_Smart_Phone BASE Version: FM_BASE_18A_W20.23.2_P8 HW Version: sc9832e_modem CMP_Time : 12-29-2020 18:41:45 MODEM TAG : MOCORTM_18A_W20.23.2_P8_Debug_FM_BASE_18A_W20.23.2_P8_sc9832e_modem_sharkle_Smart_Phone USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:01:11 Code: Operation : SP Unlock [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : L5006S Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! NVMng : SecurityInfo IMEI[1] : 357068261437186 IMEI[2] : 354648020000004 IMEI[3] : 867400020316638 WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC : SLS:0, SKS:0, SKV:4 SLStatus : 31 Unlocking device ... Sync data ... Device unlocked! Done! Elapsed: 00:00:48 |
The Following 2 Users Say Thank You to yuranc8 For This Useful Post: |
05-05-2022, 06:22 | #70875 (permalink) |
No Life Poster Join Date: Feb 2010 Location: india
Member: 1246696 Status: Offline Sonork: 100.1681950 Thanks Meter: 650 | vivo v15 factry reset done Operation : Reset Settings/Format FS [ v2.33 ] Mode : FACTORY RESET ( WIPE ) 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM7) MODE : BOOTROM PORT : 7 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Sylvia TYPE : MODERN [RAPHAEL] BROM : MEID : AB88D721C2BAD28050B7083ED8B03291 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 3AEC243418F88559758129926C58C799001CD099F5CCDBD854 99E26B33B5D4FA BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6771 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 90014A68433861503E032D68C5B695C3 EMMC: VEN : HYNIX : OEM : 74 : ID : 68433861503E : PRV : 0x03 EMMC: VEN : HYNIX : hC8aP> EMMC: SNN : 761841078 ( 0x2D68C5B6 ) , MF : 9/2018 EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0004 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00039000 [ 228.00 KB ] DRAM: 0x180000000 [ 6.00 GB ] EMMC: CID : 90014A68433861503E032D68C5B695C3 EMMC: VEN : HYNIX : OEM : 74 : ID : 68433861503E : PRV : 0x03 EMMC: VEN : HYNIX : hC8aP> EMMC: SNN : 761841078 ( 0x2D68C5B6 ) , MF : 9/2018 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 7914793694CA8316B04AF2615658EAD2 DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Done! Elapsed: 00:00:19 Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.33 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM7) MODE : BOOTROM PORT : 7 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Sylvia TYPE : MODERN [RAPHAEL] BROM : MEID : AB88D721C2BAD28050B7083ED8B03291 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 3AEC243418F88559758129926C58C799001CD099F5CCDBD854 99E26B33B5D4FA BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6771 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 90014A68433861503E032D68C5B695C3 EMMC: VEN : HYNIX : OEM : 74 : ID : 68433861503E : PRV : 0x03 EMMC: VEN : HYNIX : hC8aP> EMMC: SNN : 761841078 ( 0x2D68C5B6 ) , MF : 9/2018 EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0004 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00039000 [ 228.00 KB ] DRAM: 0x180000000 [ 6.00 GB ] EMMC: CID : 90014A68433861503E032D68C5B695C3 EMMC: VEN : HYNIX : OEM : 74 : ID : 68433861503E : PRV : 0x03 EMMC: VEN : HYNIX : hC8aP> EMMC: SNN : 761841078 ( 0x2D68C5B6 ) , MF : 9/2018 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 7914793694CA8316B04AF2615658EAD2 DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:21 Reconnect Power/Cable! |
The Following User Says Thank You to umar342 For This Useful Post: |
