04-30-2022, 16:03 | #70831 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Lmkj d302 hang on logo done by cm2 Card found : S/N : 73CA70CC , v0153 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 29 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 11010030303447453001700DA15A32DF Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 0EG40 [eMMC] : FLASH_CID : 11010030303447453001700DA15A32DF [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0x0B9C44DE483B398BEA33FE82A3FB01B9 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
04-30-2022, 16:04 | #70832 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile power 3 reset password done by cm2 Card found : S/N : 73CA70CC , v0153 Chinese Miracle II [MTK module] v 1.58 Operation : Reset UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : ACDF61F94DA9E4FC6DFE7D7AC14F3924 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EC , [GigaDevice] GD25LQ32 [0] : FLASH_DIE : 00C8 0060 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Read ExtData Sorting ExtData Sort Ok, Rebuild Ok Restore ExtData All done UserCode request removed UserCode set to default ( 0000 or 1122 ) Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
04-30-2022, 16:05 | #70833 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile Gabbar Pro Full Flash Done By CM2 Card found : S/N : 73CA70CC , v0153 Chinese Miracle II [MTK module] v 1.58 Load File File_Info : HONGYU61M_11C_PCB01_gprs_MT6261_S00.QMOBILE_GABBAR _PRO_V02_191024.bin FileVersion : QMobile_Gabbar_Pro_V02_191024 Load File Ok Operation : Flash [ v1.58 ] ======= Flash Files set for flashing : [ MCU ] : HONGYU61M_11C_PCB01_gprs_MT6261_S00.QMOBILE_GABBAR _PRO_V02_191024.bin 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : E2797ADD26E6949C0C15ABA8BC6945AE BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09 [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 File_Info : HONGYU61M_11C_PCB01_gprs_MT6261_S00.QMOBILE_GABBAR _PRO_V02_191024.bin FileVersion : QMobile_Gabbar_Pro_V02_191024 Flash now Erase region , wait ... Write data , wait ... Write : HONGYU61M_11C_PCB01_gprs_MT6261_S00.QMOBILE_GABBAR _PRO_V02_191024.bin Done! Elapsed: 00:00:50 Reconnect Power/Cable! |
04-30-2022, 16:06 | #70834 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Read Factory Firmware Done By CM2 Card found : 73CA70CC , v0153 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.34 Load IDBase v312457 Ok! Update configuration ... Load IDBase v312457 Ok! Card found : 73CA70CC , v0153 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.34 Load IDBase v312457 Ok! Update configuration ... Load IDBase v312457 Ok! Operation : Read Firmware [ v2.34 ] ExtSparse : Enabled ForceRead : Enabled 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM28) MODE : BOOTROM PORT : 28 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 6530D45E0ABB7C9EB36922F4FA7441CC BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : F067A20E2E2A0DB7C7B455B2D255A7DA6E47AB27C29069B6BD A96DF55B9D673B BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 150100445036444142025D1FD3F3B845 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 445036444142 : PRV : 0x02 EMMC: VEN : SAMSUNG : DP6DAB EMMC: SNN : 1562366963 ( 0x5D1FD3F3 ) , MF : 11/2021 EMI : DEV : FireFly EMI : SRC : preloader_x688b_h659.bin EMI : CNT : 0014 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 150100445036444142025D1FD3F3B845 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 445036444142 : PRV : 0x02 EMMC: VEN : SAMSUNG : DP6DAB EMMC: SNN : 1562366963 ( 0x5D1FD3F3 ) , MF : 11/2021 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : C88A3FCD387B256733FE23E740C5E8D7 DA : USB : HIGH-SPEED Boot done! Product Brand : Infinix Product Device : Infinix-X688B Product Model : Infinix X688B Product Name : X688B-GL Patch Level : RP1A.200720.011 Display ID : X688B-H659ABCDEFGHIJKLMNO-R-GL-220216V458 Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2022-02-05 Build Time : 16.02.2022 Product Info : x688b_h659 Product Board : Infinix-X688B Board Platform : mt6765 Product Manfct : INFINIX MOBILITY LIMITED MT6765__INFINIX_MOBILITY_LIMITED__Infinix_X688B__1 1__X688B-H659ABCDEFGHIJKLMNO-R-GL-220216V458__RP1A.200720.011__x688b_h659 Read : preloader.bin Read : proinfo.img Read : persist.img ExtSparse : Compression ratio : 99% Read : tkv.img Read : recovery.img Read : md1rom.img Read : spmfw.img Read : tinysys-scp.bin Read : sspm.img Read : gz.img Read : nvram.bin Read : lk.bin Read : boot.img Read : logo.bin Read : dtbo.img Read : tz.img Read : vbmeta.img Read : vbmeta_system.img Read : vbmeta_vendor.img Read : super.img ExtSparse : Compression ratio : 7% Read : cache.img Read : tranfs.img Read : userdata.img FW Size : 5.76 GB Android Info saved : _Android_info.txt Scatter : MT6765_Android_scatter.txt Saved to : C:\InfinityBox\CM2MT2\Backup\MT6765__INFINIX_MOBIL ITY_LIMITED__Infinix_X688B__11__X688B-H659ABCDEFGHIJKLMNO-R-GL-220216V458__RP1A.200720.011__x688b_h659\ Done! Elapsed: 00:13:39 |
05-01-2022, 06:14 | #70835 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Oppo A1K MT6765 FRP/Pattren Reset Done With King Infinity CM2 Code: Card found : A19EC787 , v0153 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.34 Load IDBase v312457 Ok! UserName and/or Password not set! Can't continue! Load IDBase v312457 Ok! Operation : Reset Settings/Format FS [ v2.34 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM69) MODE : BOOTROM PORT : 69 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 4DCB9ABB96830A88C84DDEEA0F8AEAD3 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 82263976D99E76D2CECCDA207D1BF995639129C2758606DFCF3CDA1722C4B6FD BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 150100514436334D4203FFABF20F76E9 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 514436334D42 : PRV : 0x03 EMMC: VEN : SAMSUNG : QD63MB EMMC: SNN : 4289458703 ( 0xFFABF20F ) , MF : 7/2019 EMI : DEV : FireFly EMI : SRC : preloader_oppo6762_18540.bin EMI : CNT : 0009 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 150100514436334D4203FFABF20F76E9 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 514436334D42 : PRV : 0x03 EMMC: VEN : SAMSUNG : QD63MB EMMC: SNN : 4289458703 ( 0xFFABF20F ) , MF : 7/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 26000AFB572CA692BBC17E2675AFD711 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x815757 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:42 Reconnect Power/Cable! |
05-01-2022, 06:26 | #70836 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Tecno B1f MT6580 FRP/Pattren Reset Done With King Infinity CM2 Code: Operation : Reset Settings/Format FS [ v2.34 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM69) MODE : BOOTROM PORT : 69 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY [MTK] BROM : MEID : 1280EDA1734D145DC490777D1AB6A224 BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SEC : 0x00000001 AGENT : TECNO : LB6 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_SWSEC.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 460001154D323645B074034201C62D68 DAInf: 4 : 2 : 156 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 150100464536324D420374B0682DC601 NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 DRAM : 0x0178 EMI : DEV : FireFly EMI : SRC : preloader_b1_f8018.bin EMI : CNT : 0006 EMI : [00] : ID : 150100513732534D42 : VEN : SAMSUNG | DEV : Q72SMB : RAM : [ 1.00 GB ] EMI : [01] : ID : 90014A483847316505 : VEN : HYNIX | DEV : H8G1e : RAM : [ 1.00 GB ] EMI : [02] : ID : ADDE14A7424AAD : VEN : UNKNOWN | DEV : §BJ* : RAM : [ 512.00 MB ] EMI : [03] : ID : 150100464E36324D42 : VEN : SAMSUNG | DEV : FN62MB : RAM : [ 1.00 GB ] EMI : [04] : ID : 700100464D41454538 : VEN : KINGSTON | DEV : FMAEE8 : RAM : [ 1.00 GB ] EMI : [05] : ID : 150100464536324D42 : VEN : SAMSUNG | DEV : FE62MB : RAM : [ 1.00 GB ] EMI : Init EMI from PRELOADER INIT : 0xBC : DRAM [ 0x00000000 : [ 0 B ] ] DRAM : DRAM: 0x40000000 [ 1.00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: CID : 150100464536324D420374B0682DC601 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 464536324D42 : PRV : 0x03 EMMC: VEN : SAMSUNG : FE62MB EMMC: SNN : 1957718061 ( 0x74B0682D ) , MF : 12/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : B47AAD383AB0A440339CAF141AC11972 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM20) MODE : PRELOADER PORT PORT : 20 Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:01:41 Reconnect Power/Cable! |
05-01-2022, 07:50 | #70837 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile 4G plus SPD9820E Logo Stuck Fix With Fromating Only By King Infinity CM2 Code: Card found : A19EC787 , v0153 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9820E_BASE : SC9820e_eMMC_512MB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:17 |
05-01-2022, 07:51 | #70838 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | ViVo Y21 V2111 Reset Frp Unlock Done Operation : Reset Settings/Format FS [ v2.34 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM25) MODE : BOOTROM PORT : 25 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : E325AFEFF239BE506BCCC09F88ABFC7D BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 116F39A3A5C22EB3601EBDA91BC2F1CA0EE366E40B2B1E73C3 890453D2F22CDE BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : Vivo : SEC_MT6765 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : All Vivo MT6769 MT6768 DA_2.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 150100445036444242025835E83AC8E5 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 445036444242 : PRV : 0x02 EMMC: VEN : SAMSUNG : DP6DBB EMMC: SNN : 1479927866 ( 0x5835E83A ) , MF : 12/2021 EMI : DEV : FireFly EMI : SRC : preloader_k62v1_64_bsp.bin EMI : CNT : 0009 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 150100445036444242025835E83AC8E5 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 445036444242 : PRV : 0x02 EMMC: VEN : SAMSUNG : DP6DBB EMMC: SNN : 1479927866 ( 0x5835E83A ) , MF : 12/2021 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : FFA1F156CB9AC6F14AB8029AD2F09185 DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
05-01-2022, 08:30 | #70839 (permalink) |
No Life Poster Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | realmew c2 reset done Operation : Reset Settings/Format FS [ v2.34 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM30) MODE : BOOTROM PORT : 30 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 6C79DA9086A9E386D9A923F31EEF46BC BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 6F4C71D49201B3203CEFA02A079E577096BAB301CEA75D4741 391CFA81009797 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 150100514436334D42030566904C4717 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 514436334D42 : PRV : 0x03 EMMC: VEN : SAMSUNG : QD63MB EMMC: SNN : 90607692 ( 0x0566904C ) , MF : 4/2020 EMI : DEV : FireFly EMI : SRC : preloader_oppo6762_18540.bin EMI : CNT : 0009 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 150100514436334D42030566904C4717 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 514436334D42 : PRV : 0x03 EMMC: VEN : SAMSUNG : QD63MB EMMC: SNN : 90607692 ( 0x0566904C ) , MF : 4/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 3D2E3D8D6C70F736C75029EB6EF2A7C4 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x815757 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:41 Reconnect Power/Cable! |
05-01-2022, 11:06 | #70840 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Vgo Tel S22 Read Flash File Done By CM2 Card found : S/N : 73CA70CC , v0153 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 20 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 0D24668AD2F18EC1B2712B1D2C8ED760 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 File_Info : FISE61D_11C_PCB01_gprs_MT6261_S00.MM61052_61D_ZN_B 1909_VGOTEL_S22_V008.bin FileVersion : MM61052_61D_ZN_B1909_VGOTEL_S22_V008 Done! Elapsed: 00:00:08 Reconnect Power/Cable! Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 20 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 0D24668AD2F18EC1B2712B1D2C8ED760 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Reading Flash Content now ... Read Flash now Read Ok , 4194304 bytes read Check and collect compile info File_Info : FISE61D_11C_PCB01_gprs_MT6261_S00.MM61052_61D_ZN_B 1909_VGOTEL_S22_V008.bin FileVersion : MM61052_61D_ZN_B1909_VGOTEL_S22_V008 Saved to : C:\InfinityBox\CM2MTK\Read_out\FISE61D_11C_PCB01_g prs_MT6261_S00.MM61052_61D_ZN_B1909_VGOTEL_S22_V00 8.bin Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
The Following User Says Thank You to A.G.Shahid For This Useful Post: |
05-01-2022, 11:38 | #70843 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | TECNO-LE7 Frp Code: Product Brand : TECNO Product Device : TECNO-LE7 Product Model : TECNO LE7 Product Name : LE7-GL Patch Level : RP1A.200720.011 Display ID : LE7-H697GHIJKL-R-GL-211118V485 Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2021-10-05 Build Time : 17.11.2021 Product Info : le7_h697 Product Board : TECNO-LE7 Board Platform : mt6768 Product Manfct : TECNO MOBILE LIMITED USERDATA : FILESYSTEM : F2FS with FBE ( File-Base Encryption ) NVRAM : 0xB9122381 NVRAM : State : Ok! INFO : WiFi MAC : AA0036004400 INFO : BlTh MAC : 2C4DDE6C9F48 INFO : IMEI[1] : INFO : IMEI[2] : STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY NOT PROGRAMMED [USABLE] Done! Elapsed: 00:00:29 Operation : Reset Settings/Format FS [ v2.34 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM9) MODE : BOOTROM PORT : 9 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN [RAPHAEL] BROM : MEID : 1825066E2D99FE677D9E53A66FA48E25 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 9C1463A99C4244BA8B7D91308FEC349AF44FECE633A1A0D77FBDFD46226008BD BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 90014A68444561503303102A0ADA7811 EMMC: VEN : HYNIX : OEM : 74 : ID : 684445615033 : PRV : 0x03 EMMC: VEN : HYNIX : hDEaP3 EMMC: SNN : 271190746 ( 0x102A0ADA ) , MF : 7/2021 EMI : DEV : FireFly EMI : SRC : preloader_le7_h697.bin EMI : CNT : 0008 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 90014A68444561503303102A0ADA7811 EMMC: VEN : HYNIX : OEM : 74 : ID : 684445615033 : PRV : 0x03 EMMC: VEN : HYNIX : hDEaP3 EMMC: SNN : 271190746 ( 0x102A0ADA ) , MF : 7/2021 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x1D1F000000 [ 116.48 GB ] CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 85FC6A3FF9C6B56B6DDE801866D880BB DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:21 Reconnect Power/Cable! |
05-01-2022, 11:39 | #70844 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | VGO TEL I550 Pasword Code: Operation : Read UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 59 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 9BED74CFA268EC9D4997B249ABBF373B BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Read ExtData Sorting ExtData Reading UserCode Active : Yes , Code : 0318 PLock|MobTrack : Not active Done! Elapsed: 00:00:06 Reconnect Power/Cable! |
05-01-2022, 11:40 | #70845 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | QMobile X30 Flash Code: Brand : TINNO ProdName : QMobile X30 ProdModel : QMobile X30 Device : QMobile X30 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1 Done! Elapsed: 00:00:29 Reconnect Power/Cable! Scatter Load Ok , BaseBand : MT6572 , Project : s4050ap , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A48344732611101D777F23562F3 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A48344732611101D777F23562F3 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD5229C25C382E611EF76B8ECC50E699A INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : s4050ap , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Disabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 3693 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000000E5E00000 Flash Pre-Erase Done, time used : 00:00:05 SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:03:00 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:21 Reconnect Power/Cable! |
