01-19-2011, 00:45 | #8101 (permalink) |
Freak Poster Join Date: Feb 2009 Location: Colombia Unlock
Member: 978651 Status: Offline Sonork: 1672421 Thanks Meter: 85 | modulo v3.71 Servicio: Alcatel-305X, 305A Checkeando datos, espere... Habilitada la deteccion avanzada del chip Action: rebuild security area ====> Boot ... Mantenga Presionado el boton Power ! 19200 fixed Conectando, espere... Iniciando [6223:8A05:8A00]... CPU: MT6223 chip: 0011:9A07:A00C status: 01 Tamaño del boot packet: 0400 Deje de presionar el boton power ahora ! Boot Done ====> Iniciar ... detecting chip #00 in region #00... Flash EC240200000000:2BEA0000000000 Flash Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 numero de flash chip/regiones detectadas: 01/01 Iniciar Done ====> Seleccionar velocidad ... 921600 Seleccionar velocidad Done ====> Iniciar bootcode ... Iniciar bootcode Done ====> Comprobar la integridad del firmware ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.F7 9E7FD2.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN_6B2FA2BD].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: F79E7FD2 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, BDA22F6B code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification Version: 164 provider: 305A-2BCECO3 Personalización CP16NB12 Personalización XP16NB12 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished Estado sim-lock: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected Personalización XP16NB12 customization name adjusted Flash EC240200000000:2BEA0000000000 Flash EC240200000000:2BEA0000000000 Escribir security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... Listo Flash EC240200000000:2BEA0000000000 Flash EC240200000000:2BEA0000000000 Escribir security area (sec info, hash) security area (sec info, hash) calculation done Comprobar la integridad del firmware Done ====> Comprobar el contenido del firmware ... Comprobar el contenido del firmware Done ====> Backup de datos requeridos ... Imei original: FFFFFFFFFFFFFF Flash EC240200000000:2BEA0000000000 Backup de datos requeridos Done ====> Revisión de datos requeridos ... Revisión de datos requeridos Done ====> Operacion Especial ... Operacion Especial Done ====> Escribir ... Escribir Done ====> Finalizado ... FFS formatting... Flash EC240200000000:2BEA0000000000 Finalizado Done Archivo guardado: C:\Archivos de programa\InfinityBox\MModule\backup_security\Alcat el-305X,305A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08 A_W08_36_SP1_V34__system_log_F79E7FD2_6B2FA2BD_201 10106-180924.B0X.bin Finalizado, tiempo usado: 2 min 47 sec Quite/coloque la bateria ahora ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to oscarjr85 For This Useful Post: |
01-19-2011, 00:45 | #8102 (permalink) |
Member: 978651 Status: Offline Sonork: 1672421 Thanks Meter: 85 | COM9 [VCP0] selected modulo v1.38 Servicio: Alcatel-E101 "Deteccion avanzada de chip" activado Action: unlock Checkeando datos, espere... Boot ... El Telefono deberia estar APAGADO ! Presiona boton POWER Ahora ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Seleccionar velocidad ... 812500 Seleccionar velocidad done Check hardware ... Flash 012A7E2A242A00:54000000000000 Flash AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... leyendo Alcatel-E101_eeprom_calibration-1... Archivo guardado: C:\Archivos de programa\InfinityBox\HModule\Alcatel-E101_eeprom_calibration-1_20110118-181344.80E.bin Read data done Check data ... Check data done Escribir ... .. Flash 012A7E2A242A00:54000000000000 Escribir simlock Escribir done Finalizado, tiempo usado: 1 min 35 sec Quite/coloque la bateria ahora ! |
01-19-2011, 00:46 | #8103 (permalink) |
Member: 978651 Status: Offline Sonork: 1672421 Thanks Meter: 85 | COM9 [VCP0] selected modulo v1.38 Servicio: Alcatel-E227 "Deteccion avanzada de chip" activado Action: unlock Checkeando datos, espere... Boot ... El Telefono deberia estar APAGADO ! Presiona boton POWER Ahora ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Seleccionar velocidad ... 812500 Seleccionar velocidad done Check hardware ... Flash 012A7E2A242A00:54000000000000 Flash AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... leyendo Alcatel-E227_eeprom_calibration-1... Archivo guardado: C:\Archivos de programa\InfinityBox\HModule\Alcatel-E227_eeprom_calibration-1_20110118-132052.80E.bin Read data done Check data ... Check data done Escribir ... .......... .......... .. Flash 012A7E2A242A00:54000000000000 Escribir simlock Escribir done Finalizado, tiempo usado: 1 min 32 sec Quite/coloque la bateria ahora ! |
01-19-2011, 00:46 | #8104 (permalink) |
Member: 978651 Status: Offline Sonork: 1672421 Thanks Meter: 85 | COM9 [VCP0] selected modulo v1.38 Servicio: Alcatel-E101 "Deteccion avanzada de chip" activado Action: unlock Checkeando datos, espere... Boot ... El Telefono deberia estar APAGADO ! Presiona boton POWER Ahora ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Seleccionar velocidad ... 812500 Seleccionar velocidad done Check hardware ... Flash 012A7E2A242A00:54000000000000 Flash AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... leyendo Alcatel-E101_eeprom_calibration-1... Archivo guardado: C:\Archivos de programa\InfinityBox\HModule\Alcatel-E101_eeprom_calibration-1_20110117-110851.80E.bin Read data done Check data ... Check data done Escribir ... .. Flash 012A7E2A242A00:54000000000000 Escribir simlock Escribir done Finalizado, tiempo usado: 1 min 9 sec Quite/coloque la bateria ahora ! |
01-19-2011, 00:46 | #8105 (permalink) |
Member: 978651 Status: Offline Sonork: 1672421 Thanks Meter: 85 | COM9 [VCP0] selected modulo v1.38 Servicio: Alcatel-E207 "Deteccion avanzada de chip" activado Action: unlock Checkeando datos, espere... Boot ... El Telefono deberia estar APAGADO ! Presiona boton POWER Ahora ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Seleccionar velocidad ... 812500 Seleccionar velocidad done Check hardware ... Flash 012A7E2A242A00:54000000000000 Flash AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... leyendo Alcatel-E207_eeprom_calibration-1... Archivo guardado: C:\Archivos de programa\InfinityBox\HModule\Alcatel-E207_eeprom_calibration-1_20110109-131325.80E.bin Read data done Check data ... Check data done Escribir ... .. Flash 012A7E2A242A00:54000000000000 Escribir simlock Escribir done Finalizado, tiempo usado: 1 min 25 sec Quite/coloque la bateria ahora ! |
01-19-2011, 00:55 | #8106 (permalink) |
Member: 978651 Status: Offline Sonork: 1672421 Thanks Meter: 85 | COM9 [VCP0] selected modulo v1.78 Servicio: LG-MG160 Checkeando datos, espere... Action: write flash Escribir Firmware MG160aP16FL-AM_MD2-V09b_000-00_Mar-28-2007+0_firmware_Comcel.B1M.bin saltar: FFS-1/Customization Escribir Language Pack MG160aP16FL-AM_MD2-V09b_000-00_Mar-28-2007+0_LP_En_Es_Pt_Comcel.B1P.bin saltar: Graphics Pack saltar: FFS-2/File system Escribir Eeprom MG160a_eeprom_eeprom_complete_03.B1E.bin Boot ... Mantenga Presionado el boton Power ! e-gold: 820000 loading... next part... boot answer: 01 Deje de presionar el boton power ahora ! Boot Done Seleccionar velocidad ... 921600 Seleccionar velocidad Done Connecting ... Flash 0001:011A Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: .00 ULC2GL x 0 A 0 q Check parameters Done backup critical area ... leyendo eeprom-static... Archivo guardado: C:\Archivos de programa\InfinityBox\Pana01\LG-MG160_eeprom-static_20110118-135429.B1E.bin loading data... data loaded imei: 35617601133493300 leyendo eeprom-security_35617601133493300... Archivo guardado: C:\Archivos de programa\InfinityBox\Pana01\LG-MG160_eeprom-security_35617601133493300_20110118-135431.B1E.bin leyendo eeprom-complete_35617601133493300... Archivo guardado: C:\Archivos de programa\InfinityBox\Pana01\LG-MG160_eeprom-complete_35617601133493300_20110118-135432.B1E.bin backup critical area Done Check memory ... Check memory Done Escribir ... reset... Listo Erasing: Firmware Writing: Firmware Erasing: Language Pack Writing: Language Pack Erasing: Eeprom Writing: Eeprom Escribir Done Finalizado, tiempo usado: 3 min 10 sec Quite/coloque la bateria ahora ! |
01-19-2011, 00:58 | #8107 (permalink) |
Member: 978651 Status: Offline Sonork: 1672421 Thanks Meter: 85 | COM9 [VCP0] selected modulo v1.78 Servicio: ZTE-S315 Checkeando datos, espere... Action: "sp-unlock" unlock method-1 Boot ... Mantenga Presionado el boton Power ! e-gold: 820000 loading... next part... boot answer: 01 Deje de presionar el boton power ahora ! Boot Done Seleccionar velocidad ... 921600 Seleccionar velocidad Done Connecting ... Flash 00EC:257E Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: CEL-P108A27FM U V1.0.0B03 Sep 15 2009 15 57 13 COMCEL-P108A27FM Check parameters Done backup critical area ... leyendo eeprom-static... Archivo guardado: C:\Archivos de programa\InfinityBox\Pana01\ZTE-S315_eeprom-static_20110113-165107.B1E.bin loading data... data loaded leyendo eeprom-security... Archivo guardado: C:\Archivos de programa\InfinityBox\Pana01\ZTE-S315_eeprom-security_20110113-165108.B1E.bin leyendo eeprom-complete... Archivo guardado: C:\Archivos de programa\InfinityBox\Pana01\ZTE-S315_eeprom-complete_20110113-165109.B1E.bin reading additional data... Archivo guardado: C:\Archivos de programa\InfinityBox\Pana01\ZTE-S315_lock-area_20110113-165112.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Escribir ... Erasing: lock-area Writing: lock-area Escribir Done Finalizado, tiempo usado: 23 sec Quite/coloque la bateria ahora ! |
01-19-2011, 00:59 | #8108 (permalink) |
Member: 978651 Status: Offline Sonork: 1672421 Thanks Meter: 85 | firmware database date: 23.12.2010 Lenguaje seleccionado: Espanol [The_Dj] Cargando datos, Espere... [Infinity Box] v1.78 smart-card: connected S/N: 7A2C:0116 Espere... Servicio: LG-MG160 Ready Loadng data, wait... Phone must be SWITCHED ON ! Conectando, espere... coneccion Ok Action: imei version de software: MG160aP16FL-57-V10a-732-101-Apr 11 2007+11 Imei original: 01137300575699200 Nuevo imei: 17041017489682 imei verification Ok Listo Finished |
01-19-2011, 00:59 | #8109 (permalink) |
Member: 978651 Status: Offline Sonork: 1672421 Thanks Meter: 85 | COM9 [VCP0] selected modulo v1.78 Servicio: ZTE-125 Checkeando datos, espere... Action: "sp-unlock" unlock method-1 Boot ... Mantenga Presionado el boton Power ! e-gold: 820000 loading... next part... boot answer: 01 Deje de presionar el boton power ahora ! Boot Done Seleccionar velocidad ... 921600 Seleccionar velocidad Done Connecting ... Flash 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: CEL-P108A7 V B01-EnEs-CO01 g3dBV2.0 04.12.00 18.26.11 08.02.00 N Check parameters Done backup critical area ... leyendo eeprom-static... Archivo guardado: C:\Archivos de programa\InfinityBox\Pana01\ZTE-125_eeprom-static_20101225-142733.B1E.bin loading data... data loaded leyendo eeprom-security... Archivo guardado: C:\Archivos de programa\InfinityBox\Pana01\ZTE-125_eeprom-security_20101225-142734.B1E.bin leyendo eeprom-complete... Archivo guardado: C:\Archivos de programa\InfinityBox\Pana01\ZTE-125_eeprom-complete_20101225-142736.B1E.bin reading additional data... Archivo guardado: C:\Archivos de programa\InfinityBox\Pana01\ZTE-125_lock-area_20101225-142740.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Escribir ... Erasing: lock-area Writing: lock-area Escribir Done Finalizado, tiempo usado: 27 sec Quite/coloque la bateria ahora ! |
01-19-2011, 01:00 | #8110 (permalink) |
Member: 978651 Status: Offline Sonork: 1672421 Thanks Meter: 85 | COM9 [VCP0] selected modulo v1.78 Servicio: ZTE-A35 Checkeando datos, espere... Action: "repair imei" Nuevo imei: 170410175095269 Boot ... Mantenga Presionado el boton Power ! e-gold: 820000 loading... next part... boot answer: 01 Deje de presionar el boton power ahora ! Boot Done Seleccionar velocidad ... 921600 Seleccionar velocidad Done Connecting ... Flash 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: ARO-P108A7 Z B01-EnEs-DOM02 g3dBV2.0 ES-DOM-CLARO-P108A7 Z V1.0. Check parameters Done backup critical area ... leyendo eeprom-static... Archivo guardado: C:\Archivos de programa\InfinityBox\Pana01\ZTE-A35_eeprom-static_20101221-175313.B1E.bin loading data... data loaded leyendo eeprom-security... Archivo guardado: C:\Archivos de programa\InfinityBox\Pana01\ZTE-A35_eeprom-security_20101221-175314.B1E.bin leyendo eeprom-complete... Archivo guardado: C:\Archivos de programa\InfinityBox\Pana01\ZTE-A35_eeprom-complete_20101221-175315.B1E.bin reading additional data... Archivo guardado: C:\Archivos de programa\InfinityBox\Pana01\ZTE-A35_imei-area_20101221-175320.B1E.bin reading additional data... Archivo guardado: C:\Archivos de programa\InfinityBox\Pana01\ZTE-A35_lock-area_20101221-175324.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found imei found #1 Check memory Done Escribir ... Erasing: imei-area Writing: imei-area Erasing: lock-area Writing: lock-area Erasing: eeprom-security Writing: eeprom-security Escribir Done Finalizado, tiempo usado: 50 sec Quite/coloque la bateria ahora ! Finished |
01-19-2011, 01:00 | #8111 (permalink) |
Member: 978651 Status: Offline Sonork: 1672421 Thanks Meter: 85 | COM9 [VCP0] selected modulo v1.78 Servicio: ZTE-S315+ Checkeando datos, espere... Action: "sp-unlock" unlock method-1 Boot ... Mantenga Presionado el boton Power ! e-gold: 820000 loading... next part... boot answer: 01 Deje de presionar el boton power ahora ! Boot Done Seleccionar velocidad ... 921600 Seleccionar velocidad Done Connecting ... Flash 00EC:257E Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: CEL-P108A27FM U V1.0.0B03 Sep 15 2009 15 57 13 COMCEL-P108A27FM Check parameters Done backup critical area ... leyendo eeprom-static... Archivo guardado: C:\Archivos de programa\InfinityBox\Pana01\ZTE-S315+_eeprom-static_20101219-135459.B1E.bin loading data... data loaded leyendo eeprom-security... Archivo guardado: C:\Archivos de programa\InfinityBox\Pana01\ZTE-S315+_eeprom-security_20101219-135500.B1E.bin leyendo eeprom-complete... Archivo guardado: C:\Archivos de programa\InfinityBox\Pana01\ZTE-S315+_eeprom-complete_20101219-135501.B1E.bin reading additional data... Archivo guardado: C:\Archivos de programa\InfinityBox\Pana01\ZTE-S315+_lock-area_20101219-135504.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Escribir ... Erasing: lock-area Writing: lock-area Escribir Done Finalizado, tiempo usado: 25 sec Quite/coloque la bateria ahora ! |
01-19-2011, 01:01 | #8112 (permalink) |
Member: 978651 Status: Offline Sonork: 1672421 Thanks Meter: 85 | COM9 [VCP0] selected modulo v1.78 Servicio: ZTE-A36 Checkeando datos, espere... Action: "sp-unlock" unlock method-1 Boot ... Mantenga Presionado el boton Power ! e-gold: 820000 loading... next part... boot answer: 01 Deje de presionar el boton power ahora ! Boot Done Seleccionar velocidad ... 921600 Seleccionar velocidad Done Connecting ... Flash 00EC:257E Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: CW-P108A8FM Z B01-EnEs-PA01 g3dBV2.0 ES-PA-CW-P108A8FM Z V1.0.0 Check parameters Done backup critical area ... leyendo eeprom-static... Archivo guardado: C:\Archivos de programa\InfinityBox\Pana01\ZTE-A36_eeprom-static_20101203-172648.B1E.bin loading data... data loaded leyendo eeprom-security... Archivo guardado: C:\Archivos de programa\InfinityBox\Pana01\ZTE-A36_eeprom-security_20101203-172649.B1E.bin leyendo eeprom-complete... Archivo guardado: C:\Archivos de programa\InfinityBox\Pana01\ZTE-A36_eeprom-complete_20101203-172650.B1E.bin reading additional data... Archivo guardado: C:\Archivos de programa\InfinityBox\Pana01\ZTE-A36_lock-area_20101203-172653.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Escribir ... Erasing: lock-area Writing: lock-area Escribir Done Finalizado, tiempo usado: 24 sec Quite/coloque la bateria ahora ! |
01-19-2011, 07:58 | #8113 (permalink) |
No Life Poster Join Date: May 2008 Location: persian Age: 43
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | motorolla c115 flash done COM4 [VCP2] selected Action: flash Write: Firmware Write: Language Pack Write: Flex Skip: Eeprom Device: C113(a),C114,C115,C116,C117,C118 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 Release Power button ! Connect Done Boot... Boot Done Set Baud... 921600 Set Baud Done Check Flash-1... SW version: 1.0.10.E. HW version: _E88 imei otp: 359814000111386 Check Flash-1 Done Check Flash-2... Check Flash-2 Done Write... Writing: all flash areas Write Done Finished, time used: 96 sec Remove/Install battery now ! |
The Following User Says Thank You to sirnavid2010 For This Useful Post: |
01-19-2011, 08:13 | #8114 (permalink) |
No Life Poster Join Date: Oct 2007 Location: india
Member: 618404 Status: Offline Thanks Meter: 311 | g6600 huawei unlocking done. COM3 [VCP0] selected module v3.72 Action: "sp-unlock" unlock method: smart fast Model: Huawei-G6600 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: E5.2AV01V01.04 Version: BYD35_09A_PMWY_HW 82 byte(s) read imei: 357xxxxxxxxxx connection Ok 189 byte(s) read reading data... building new data... writing data... 177 byte(s) read reading data... reading data #2... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 18 sec Remove/Install battery now ! |
The Following User Says Thank You to rajesh_ch For This Useful Post: |
01-19-2011, 08:26 | #8115 (permalink) |
Freak Poster Join Date: Apr 2005 Location: Pakistan
Member: 138388 Status: Offline Thanks Meter: 22 | ot505 alcatel unlocked COM11 [VCP0] selected module v3.73 Device: Alcatel-505X Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:87FE:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:2BEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.1806A 0E3.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN_59B64033].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 1806A0E3 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, 3340B659 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 268 provider: 505X-2ASFFR1 customization: CP26CQ24 customization: XP26CQ24 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XP26CQ24 customization name adjusted flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: FFFFFFFFFFFFFF flash: EC240200000000:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC240200000000:2BEA0000000000 Finalization Done br tariq |
The Following User Says Thank You to tariqjaved For This Useful Post: |
