11-14-2013, 09:20 | #18646 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | C2-03 Code: registered to: saeedullah_khan Connect phone on selected interface... Core : v1.75 , BB5XG FlashEngine : v6.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : CNT : rm702__07.65.image_m_c_059D436 Flashing phone now... Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.46_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 359324041049629 IMEI 2 : 359324041049637 PCcode : 059D475 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\InfinityBox_install_BEST_v1.75\Backup\Cert\359324041049629_XG213_CRT.rpl ===Flashing [CNT]=== File : rm702__07.65.image_m_c_059D436 Image : package_m_c_059D436.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x424C0000 , Len : 0x01960000 Erasing, wait ... Erase done, time : 00:04:04 Write , Start : 0x424C0000 , Len : 0x00D20000 Flashing , wait ... Region flash done, time : 00:00:22 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:08 No write data, skip CRC check passed , 0xE976 Flashing done! Total flash time : 00:04:35 Reboot phone now... Reading Phone Info.... Connected phone - C2-03 Software Info: V 06.51 15-07-11 RM-702 (c) Nokia IMEI: 359324041049629 PPM version : V 06.51 15-07-11 RM-702 (c) Nokia M_A Product code: 059D475 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 42 certs Data exist, skip certificate repair... Battery voltage is enough for start AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:05:34 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Backup Certificates now... Backup CRT308 data... CRT308 Backup Created Check communication with phone.... Communication verify done... Preparing... SL3 Simlock read (XGOLD) ... Ok WMDRM Key read ... Ok Reboot.... Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF EBL Loader : Custom Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL : Custom EBL sent Ok EBL : Quantum_Bootloader_10.56_M1S1 Boot done! Read CRT block... Read EEPROM block... SL3 Simlock found (XGOLD) ... WMDRM Key found ... ===== USER CODE ===== Executing Code extraction... - > Phone Lock Code : 12345 ===== USER CODE ===== NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\InfinityBox_install_BEST_v1.75\Backup\Cert\359324041049629_XG213.rpl Connect phone on selected interface... |
11-14-2013, 12:13 | #18647 (permalink) |
Product Supporter Join Date: Mar 2008 Location: India
Member: 718725 Status: Offline Sonork: 100.1604953 QQ 2339690693 Thanks Meter: 6,705 | Zte S183 Unlock Done By Infinty CDMA Code: COM69 [QCUSB_COM69_1] selected module v1.95 Device: ZTE-S183, C132 operation: SP-unlock Phone should be Switched ON ! connecting... Jun 14 2013 Jun 14 2013 ZTE C132 Jun 14 2013 selected.. ESN(hex) : 80305B55 Password accepted.. downloading mode... waiting respon... waiting chip ready... unlocking in progress.. unlocking in progress 50%.. unlocking in progress 100%.. done... Finished, time used: 16 sec B.R., Prem_India |
11-14-2013, 14:36 | #18648 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Nokia 6303i classic Code: registered to: saeedullah_khan Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 6303i classic Software ver : V 06.61 08-02-10 RM-638 (c) Nokia IMEI : 358302032616805 XappVer : 000006D6 DSP Ver : ICPR91_09w49_2 PPM : V 06.61 08-02-10 RM-638 (c) Nokia MR2 CNT : Content: mr2_0594563_002 V 06.61 08-02-10 RM-638 (c) Nokia Product SN : M4F021716 Product code : 0594563 Base Prd.code: 0590358 Module code : 0204472 Long Prod.SN : 0 Hardware info======= HWID : 1000 Retu : 35 Tahvo : 00 Batery: 4041 mV CMT BT: 1673-46034 LCDVer: SHARP Lock info =========== IMEI : 358302032616805 IMEI spNet : 3A 85 03 02 23 16 86 00 IMEI svNet : 33 85 03 02 23 16 86 20 F2 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User Code : 34009 MMC pwd : Backup saved UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Core : v1.75 , BB5XG FlashEngine : v6.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm638__10.80.mcusw PPM : rm638__10.80.ppm_meac CNT : rm638__10.80.image_meac_0594548_010 Flashing phone now... Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Manual mode selected Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok WMDRM read ... Ok Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000010000022600000001020C192102054100 CPU ID : RAP3Gv4 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 0720010830770E495535B125F85713B30DEF23E1 ASIC MODE ID: 00 ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D ROM ID: 67E82268F29CEA60 Use RAP3Gv40_2nd.fg , Rev : 3.0 Ver : 12.8.0 Processing RAWLOADER... FLIC : 003000EC Req : XSR 1.6 Use RAP3Gv40_XSR17_alg.fg , Rev : 3.0 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : 108AF4DB7EC8B1B36E9D6A60F7EB2996DC7B2B5D ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 358302032616805 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\InfinityBox_install_BEST_v1.75\Backup\Cert\358302032616805.rpl === SW Version Check === - > UPGRADE === SW Version Check === ===Flashing [MCU]=== Erase : Processing rm638__10.80.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm638__10.80.mcusw CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [ISA+DYNSW] Total writen 126 blocks TIME : Write time : 00:00:55 MCU Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [PPM]=== Erase : Processing rm638__10.80.ppm_meac Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm638__10.80.ppm_meac Total writen 23 blocks TIME : Write time : 00:00:11 PPM Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [CNT]=== Erase : Processing rm638__10.80.image_meac_0594548_010 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm638__10.80.image_meac_0594548_010 Total writen 105 blocks TIME : Write time : 00:00:55 CNT Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Flashing done! Total flash time : 00:02:04 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 6303i classic Software Info: V 10.80 21-01-11 RM-638 (c) Nokia IMEI: 358302032616805 PPM version : V 10.80 21-01-11 RM-638 (c) Nokia MEC Product code: 0594563 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 34 certs Data exist, skip certificate repair... Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! Phone disconected! Connect phone on selected interface... Elapsed: 00:02:56 Connect phone on selected interface... |
11-14-2013, 14:37 | #18649 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Nokia C6-00 Code: registered to: saeedullah_khan Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Set phone in Local mode... Restarting... Done! Format File System... Operating mode is OK, no need change... Scanning FS parametres... Checking Data... Detected : 2 drive(s)... Start formating.... Using Series 60 format algorithm... ================================== Formating drive : C now... Step1 : OK Step2 : OK End format... ================================== Formating drive : D now... Step1 : OK Step2 : OK End format... ================================== Done! Resetting selected items... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:06 Reading Phone Info.... Connected phone - Nokia C6-00 Software ver : V ICPR72_10w28.3 09-11-10 RM-612 (c) Nokia IMEI : 356994047539212 XappVer : 000006D6 Ape Ver : v 20.0.042 APE Var : v 20.0.04220.0.042.24.0120.0.042.C01.01 APE ADSP: 256 DSP Ver : ICPR72_10w26 APE Test: 0.014 PPM : CNT : Product SN : MOK795571 Product code : 0596783 Base Prd.code: 0588602 Long Prod.SN : 0 Hardware info======= HWID : 1000 Retu : 16 Tahvo : 22 Batery: 3862 mV APE HW: 256 Lock info =========== IMEI : 356994047539212 IMEI spNet : 3A 65 99 04 74 35 29 01 IMEI svNet : 33 65 99 04 74 35 29 11 F2 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! Backup Certificates now... Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok WMDRM read ... Ok Check communication with phone.... Reboot.... Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 12300007E0D40252F4BCA8A525BE04AE587D1BF7 ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 Use URAPIDOv11_2nd.fg , Rev : 2.0 Ver : 12.8.0 Processing RAWLOADER... 2nd boot not accepted... Alive Request not done :( Boot error... :( Looks like ASIC not supported, or HW failure Supported : RapuYama, RAP3Gv4, BroadComm, RAPIDO If RAPIDO - use dead mode for read rpl/force local SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\InfinityBox_install_BEST_v1.75\Backup\Cert\356994047539212_SIM.rpl Phone disconected! Connect phone on selected interface... |
The Following User Says Thank You to saeedullah_khan For This Useful Post: |
11-15-2013, 09:42 | #18650 (permalink) | |
No Life Poster Join Date: Nov 2009 Location: portugal Age: 47
Member: 1166261 Status: Offline Sonork: 100.1623881 Thanks Meter: 266 | lumia 800 unlock wed sucess: Quote:
The Following User Says Thank You to carlos32 For This Useful Post: |
11-15-2013, 17:30 | #18651 (permalink) |
No Life Poster Join Date: Oct 2009 Location: serbia Age: 44
Member: 1131244 Status: Offline Sonork: 100.1596724 Thanks Meter: 376 | Lumia 620 RM-846 flash success Code: card found: S/N 41E7:xxxx registered to: galijus Connect phone on selected interface... Core : v1.74 , WP8x FlashEngine : v3.2 FFU : RM846_3046.0000.1329.2002_RETAIL_eu_hungary_398_02_255112_prd_signed.ffu Checking FFU file, wait... FFU Revision ID : 2.0 FFU Model ID : Nokia.MSM8227.P5122 FFU RootKeyHash : 67131691EEDD1F38568C7FFAE284FB2621680FEA FFU Languages : Albanian , Arabic , Azerbaijan(Latin) , Belorusian , Bulgarian , Catalan , Croatian , Czech , Danish (Denmark) , Dutch (Netherlands) , English (UK) , English , Estonian , Filipino (Philippines) , Finnish , French , German , Greek , Hwbre (Israel) , Hindi (India) , Hungarian , Indonesian , Italian , Japanese , Kazakh , Korean , Latvian , Lithuanian , Macedonian , Malay (Malaysia) , Norwegian (Bokmal , Norway) , Persian (Iran) , Polish , Portuguese(Brazil) , Portuguese(Portugal) , Romanian , Russian , Serbian (Latin) , Chinese , Slovak , Slovenian , Spanish(Mexico) , Spanish , Swedish , Thai , Chinese(Taiwan) , Turkish , Ukrainian , Uzbekistan(Latin) , Vietnamese , FFU ChipSectors : 15155200 FFU Header : 0x000C0000 FFU Payload : 0x51340000 FFU FastVerify : Ok Waiting for phone... Dead mode is selected , no phone in normal mode found 1. Press and hold : "Volume Down" + "Power On" 2. Insert USB cable 3. When cable connected and you feel short vibra - release buttons Device catched in BOOT mode! Collect Info... === Nokia Flash App info : Protocol Version : 1.14 Protocol Implementation : 1.25 === Phone Initial info : Phone Model ID : Nokia.MSM8227.P5122.1.2 === Security Initial info : Security Status : 010100000101 Secure FFU Status : 000000000000 Device RootKey : 67131691EEDD1F38568C7FFAE284FB2621680FEA === Other info : SD present : False FFU : RM846_3046.0000.1329.2002_RETAIL_eu_hungary_398_02_255112_prd_signed.ffu Checking... Device RootKey Match with FFU RootKey! Device ProductID Match with FFU ProductID! ProductID : Nokia.MSM8227.P5122 DevRKH : 67131691EEDD1F38568C7FFAE284FB2621680FEA All Ok, Continue flashing... Perform Data Partition Erase Erase done FFU : RM846_3046.0000.1329.2002_RETAIL_eu_hungary_398_02_255112_prd_signed.ffu Flashing FFU Sending FFU Header Data... Header sent , accepted Sending FFU Payload Data... Finishing flashing Flashing done! Green Light :) Total flash time : 00:03:33 Rebooting Connect phone on selected interface... |
The Following User Says Thank You to galijus For This Useful Post: |
11-16-2013, 08:23 | #18652 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | X2-02 Code: Core : v1.75 , BB5XG FlashEngine : v6.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : CNT : rm694__11.84.image_m_a_059D1B3 Flashing phone now... Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Custom mode selected Backup CRT308 data... CRT308 Backup Created Check communication with phone.... ADL req restart Communication verify done... Preparing... Check communication with phone... SL3 Simlock read (XGOLD) ... Ok WMDRM Key read ... Ok Reboot.... -> If Phone start charge - just reinsert battery fast Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.46_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 355907057042563 IMEI 2 : 355907057042571 PCcode : V NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\InfinityBox_install_BEST_v1.75\Backup\Cert\355907057042563_XG213.rpl ===Flashing [CNT]=== File : rm694__11.84.image_m_a_059D1B3 Image : package_m_a_059D1B3.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42300000 , Len : 0x01B20000 Erasing, wait ... Erase done, time : 00:02:54 Write , Start : 0x42300000 , Len : 0x00DC0000 Flashing , wait ... Region flash done, time : 00:00:20 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:05 No write data, skip CRC check passed , 0x1F63 Flashing done! Total flash time : 00:03:21 Reboot phone now... Reading Phone Info.... Connected phone - X2-02 Software Info: V 11.84 13-09-12 RM-694 (c) Nokia IMEI: 355907057042563 PPM version : V 11.84 13-09-12 RM-694 (c) Nokia M_A Product code: 059P1X1 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 43 certs Data exist, skip certificate repair... Battery voltage is enough for start AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:04:08 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
11-16-2013, 08:49 | #18653 (permalink) |
Junior Member Join Date: Nov 2012 Location: guangzhou Age: 33
Member: 1845162 Status: Offline Sonork: 100.1647427 Thanks Meter: 1 | --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 05E0010505AC8E5698DB926A8C6A768DE7D19197 CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 Wait for device bootup -> Bootcode start in CMT fail ! Need flash via programming device -> Error while flashing... Phone disconected! Connect phone on selected interface... |
11-16-2013, 09:46 | #18654 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Asha 303 Flash Done :) Code: Core : v1.75 , BB5XG FlashEngine : v6.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm763__14.87.mcusw PPM : rm763__14.87.ppm_ma2 CNT : rm763__14.87.image_ma2_059J1N7 Flashing phone now... Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001051 EM1 ID: 00001060 PUBLIC ID: 3E330004FFFB3C40E46523A9514F7CF94BF7D36E ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 004000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : ACE39760399CD7A3FE439DCC52111C24D435D533 ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 358279045115266 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\35827904511xxxx_CRT.rpl === SW Version Check === - > UPGRADE === SW Version Check === ===Flashing [MCU]=== Erase : Processing rm763__14.87.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm763__14.87.mcusw CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [ISA+DYNSW] CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [ISA+EXTDRV] Total writen 291 blocks TIME : Write time : 00:00:06 MCU Write done ADL: Request programm status NAND status : 00000005 / 00000005 / 00000000 ===Flashing [PPM]=== Erase : Processing rm763__14.87.ppm_ma2 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm763__14.87.ppm_ma2 Total writen 53 blocks TIME : Write time : 00:00:01 PPM Write done ADL: Request programm status NAND status : 00000005 / 00000005 / 00000000 ===Flashing [CNT]=== Erase : Processing rm763__14.87.image_ma2_059J1N7 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:02 Write : Processing rm763__14.87.image_ma2_059J1N7 Total writen 329 blocks TIME : Write time : 00:00:05 CNT Write done ADL: Request programm status NAND status : 00000005 / 00000005 / 00000000 ADL: Close_Session Content: 000300000000050000000500000000 ADL: Reboot Flashing done! Total flash time : 00:00:16 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 303 Software Info: V 14.87 17-10-12 RM-763 (c) Nokia IMEI: 35827904511XXXX PPM version : V 14.87 17-10-12 RM-763 (c) Nokia MA2 Product code: 059J1F0 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 43 certs Data exist, skip certificate repair... Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:00:50 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
11-16-2013, 09:51 | #18655 (permalink) | |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Quote:
BTW:flash phone with UFs/Jaf Interface if any error , start new thread with screen-shot(with latest ver) | |
11-16-2013, 12:06 | #18656 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | 206 Code: registered to: saeedullah_khan Connect phone on selected interface... Backup Certificates now... Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF EBL Loader : Custom Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL : Custom EBL sent Ok EBL : Quantum_Bootloader_10.56_M1S1 Boot done! Read CRT block... Read EEPROM block... SL3 Simlock found (XGOLD) ... WMDRM Key found ... CMLA Key found ... ===== USER CODE ===== Executing Code extraction... - > Phone Lock Code : 77992 ===== USER CODE ===== NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... CMLA_KEY Data saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\InfinityBox_install_BEST_v1.75\Backup\Cert\356324053907386_XG213.rpl Connect phone on selected interface... Core : v1.75 , BB5XG FlashEngine : v6.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : CNT : rm872__04.52.image_m2_059Q4L5 Flashing phone now... Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.53_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 356324053907386 IMEI 2 : 356324053907394 PCcode : "Q h NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\InfinityBox_install_BEST_v1.75\Backup\Cert\356324053907386_XG213_CRT.rpl ===Flashing [CNT]=== File : rm872__04.52.image_m2_059Q4L5 Image : package_m2_059Q4L5.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42100000 , Len : 0x01D20000 Erasing, wait ... Erase done, time : 00:03:36 Write , Start : 0x42100000 , Len : 0x01040000 Flashing , wait ... Region flash done, time : 00:00:23 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:06 No write data, skip CRC check passed , 0x5723 Flashing done! Total flash time : 00:04:06 Reboot phone now... Reading Phone Info.... Connected phone - 206 Software Info: V 03.58 05-12-12 RM-872 (c) Nokia IMEI: 356324053907386 PPM version : V 03.58 05-12-12 RM-872 (c) Nokia M2 Product code: 059Q4L5 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 58 certs Data exist, skip certificate repair... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:05:06 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Format File System... Operating mode is OK, no need change... Scanning FS parametres... Checking Data... Detected : 1 drive(s)... Start formating.... Using Series 40 format algorithm... ================================== Formating drive : C now... Step1 : OK Step2 : OK End format... ================================== Info : Reflash CNT only for repair content and user certificates Done! Phone disconected! Connect phone on selected interface... |
11-16-2013, 12:14 | #18657 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Nokia 5310 XpressMusic Code: registered to: saeedullah_khan Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Core : v1.74 , BB5XG FlashEngine : v6.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : CNT : rm303__10.10.image_m4_red Flashing phone now... Check files done... -> SWversion check skipped : Custom mode selected Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... Ok SL2 Simlock read ... Ok WMDRM read ... Ok SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\InfinityBox_install_BEST_v1.74\Backup\Cert\356817021113995_SIM.rpl Getting product info... RAP_BOOT: 0803000102010000 RAP_PUBLIC: 0AF00118180E03548BD16BF3A1BEE20B4016DCB4 CMT_ROOTKEY: BAF3A9C3DBFA8454937DB77F2B8852B1 RAP_PAPUBKEY: 3E96DE4212587183E5E16BB2C79692A53C19875D Checking CNT sector PN<>FL PN CNT sector : 128 kb ConvertImage: Processing rm303__10.10.image_m4_red ConvertImage: Page Size is 128K, no need convert Loader len: 296064, CHK: B8EC ADL -> Sending loader... Update Server code succesfully sent to phone! TIME : Boot time : 00:00:05 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! ===Flashing [CNT]=== Erase : Processing rm303__10.10.image_m4_red Found 2 areas to erase Erasing area 0x018A0000 - 0x01B1FFFF, NOR, CMT Result: 0000 Erasing area 0x01B20000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:47 Write : Processing rm303__10.10.image_m4_red Total 512 [512/0/0] blocks to write, writing... TIME : Write time : 00:00:41 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:02:29 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5310 XpressMusic Software Info: V 10.10 23-03-09 RM-303 (c) Nokia IMEI: 356817021113995 PPM version : V 10.10 23-03-09 RM-303 (c) Nokia M4 Product code: 0573037 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:03:22 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
11-16-2013, 12:52 | #18658 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Nokia N8-00 Code: Backup Certificates now... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 27100208A4DB03441526B9E20D67A75CBEAB7387 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 005000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : D172C32473AE199B213465ABB3853246F9631231 ADL: Reading certificates... Reading NPC certificate... IMEI : 359054041752977 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... ADL: Reading certificates done! :) ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Wait, reconneting... SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok WMDRM read ... Ok CRT308 Backup Created NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\InfinityBox_install_BEST_v1.75\Backup\Cert\359054041752977_2nd.rpl All done, Disconnecting Elapsed: 00:00:18 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Core : v1.75 , BB5XG FlashEngine : v6.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : CNT : RM-596_025.007_U07.01_79.92.uda.fpsx Flashing phone now... Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Custom mode selected Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok WMDRM read ... Ok Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 27100208A4DB03441526B9E20D67A75CBEAB7387 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 005000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : D172C32473AE199B213465ABB3853246F9631231 ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 359054041752977 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\InfinityBox_install_BEST_v1.75\Backup\Cert\359054041752977_2nd.rpl === SW Version Check === - > UPGRADE === SW Version Check === ===Flashing [CNT]=== Erase : Processing RM-596_025.007_U07.01_79.92.uda.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing RM-596_025.007_U07.01_79.92.uda.fpsx Total writen 383 blocks TIME : Write time : 00:00:17 CNT Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Flashing done! Total flash time : 00:00:18 Reboot phone now... Reading Phone Info.... Connected phone - Nokia N8-00 Software Info: V 92_11w25.1 01-07-11 RM-596 (c) Nokia IMEI: 359054041752977 Ape Version: 022.014 Product code: 059G158 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:00:54 Connect phone on selected interface... |
11-16-2013, 13:11 | #18659 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | X2-02 Code: registered to: saeedullah_khan Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - X2-02 Software ver : V 11.57 31-03-12 RM-694 (c) Nokia IMEI 1 : 353695056987365 IMEI 2 : 353695056987373 XappVer : 000006D6 PPM : V 11.57 31-03-12 RM-694 (c) Nokia M_A CNT : Content: ctv PK v1 V 11.57 31-03-12 RM-694 (c) Nokia Product SN : B091AD3AH Product code : 059P1X1 Base Prd.code: 059C943 Module code : 0204922 Long Prod.SN : 0 Hardware info======= HWID : 1001 Batery: 3686 mV CMT BT: 19e2-47026 LCDVer: TPO Lock info =========== IMEI : 353695056987365 IMEI spNet : 3A 35 96 05 65 89 37 06 IMEI svNet : 33 35 96 05 65 89 37 06 F5 Sl Conf : 001-01-00000000000 Sl Prof : 800000000003000-B Sl Aux : 000B0000 Hw Sig : AB7B3ECEEEF1DA23 Country : Test SIM (Open) Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; CRT308 Backup Created CMLA Key status : Not Present SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User Code : 34536 MMC pwd : Backup saved UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Core : v1.75 , BB5XG FlashEngine : v6.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : CNT : rm694__11.84.image_m_a_059D1B3 Flashing phone now... Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Custom mode selected Backup CRT308 data... CRT308 Backup Created Check communication with phone.... ADL req restart Communication verify done... Preparing... Check communication with phone... Batery voltage : 3686 mV -> Batery voltage less, than 3,8V (3686mV). Continue at user risk SL3 Simlock read (XGOLD) ... Ok WMDRM Key read ... Ok Reboot.... -> If Phone start charge - just reinsert battery fast Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.46_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 353695056987365 IMEI 2 : 353695056987373 PCcode : V NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\InfinityBox_install_BEST_v1.75\Backup\Cert\353695056987365_XG213.rpl ===Flashing [CNT]=== File : rm694__11.84.image_m_a_059D1B3 Image : package_m_a_059D1B3.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42300000 , Len : 0x01B20000 Erasing, wait ... Erase done, time : 00:01:23 Write , Start : 0x42300000 , Len : 0x00DC0000 Flashing , wait ... Region flash done, time : 00:00:21 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip CRC check passed , 0x1F63 Flashing done! Total flash time : 00:01:47 Reboot phone now... Reading Phone Info.... Connected phone - X2-02 Software Info: V 11.57 31-03-12 RM-694 (c) Nokia IMEI: 353695056987365 PPM version : V 11.57 31-03-12 RM-694 (c) Nokia M_A Product code: 059P1X1 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 43 certs Data exist, skip certificate repair... Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:02:42 Connect phone on selected interface... |
11-16-2013, 13:24 | #18660 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Nokia 5236 Code: Core : v1.75 , BB5XG FlashEngine : v6.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-625_51.1.002_prd.core.C00 PPM : RM-625_51.1.002_prd.rofs2.V12 PPM2 : RM-625_51.1.002_C01_prd.rofs3.fpsx CNT : RM625_51.1.002_000_001_U003.uda.fpsx Flashing phone now... Rules accepted for : RAPIDO Generation Check files done... -> SWversion check skipped : Manual mode selected Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok WMDRM read ... Ok SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\InfinityBox_install_BEST_v1.75\Backup\Cert\353783045930322_SIM.rpl Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Batery valtage : 3710 mV -> Batery voltage less, than 3,8V (3710mV). Continue at user risk Reboot.... Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101051105 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1950001552A0005282A136946DEEEB9659346A74 ASIC MODE ID: 00 ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing RAP3NAND ... Processing PASUBTOC ... Processing PAPUBKEYS... Processing UPDAPP ... Boot Done! :) TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! RHASH : B8C3ADECFC997FCD8081D3DEAF870B8C RPAKeys : 7DC72D3FDC552426A4479BC820097D304CFB6C15 Pr.Code : 059B7J2 IMEI : 353783045930322 ADL : Auth done... === SW Version Check === - > REFLASHING or UPGRADE === SW Version Check === ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing RM-625_51.1.002_prd.core.C00 Found 5 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT Result: 0000 Erasing area 0x00400000 - 0x007FFFFF, NAND, CMT Result: 0000 Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT Result: 0000 Erasing area 0x00D60000 - 0x09E5FFFF, NAND, CMT Result: 0000 Erase partition 0x0A Partition erase Ok Partitioning : Ok [5] TIME : Erase time : 00:00:00 Write : Processing RM-625_51.1.002_prd.core.C00 Total 418 [418/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*ENO] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS+CORE] CMT : Writing Hash CERT [SOS+ROFS1] TIME : Write time : 00:00:34 MCU Write done ===Flashing [PPM]=== Erase : Processing RM-625_51.1.002_prd.rofs2.V12 Found 1 areas to erase Erasing area 0x06CE0000 - 0x0915FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-625_51.1.002_prd.rofs2.V12 Total 81 [81/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS2] TIME : Write time : 00:00:07 PPM Write done ===Flashing [PPM2]=== Erase : Processing RM-625_51.1.002_C01_prd.rofs3.fpsx Found 1 areas to erase Erasing area 0x09160000 - 0x09E5FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-625_51.1.002_C01_prd.rofs3.fpsx Total 28 [28/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS3] TIME : Write time : 00:00:02 PPM Write done ===Flashing [CNT]=== Erase : Processing RM625_51.1.002_000_001_U003.uda.fpsx Found 1 areas to erase Erasing area 0x09E60000 - 0x0F47FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM625_51.1.002_000_001_U003.uda.fpsx Total 60 [60/0/0] blocks to write, writing... TIME : Write time : 00:00:06 CNT Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:00:52 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5236 Software Info: V ICPR72_11w16.1 28-07-11 RM-625 (c) Nokia IMEI: 353783045930322 Ape Version: V 51.1.002 Product code: 059B7J2 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:01:48 Connect phone on selected interface... |
