08-30-2015, 15:39 | #24706 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Pakistan
Member: 192810 Status: Offline Sonork: Some people NEED change Thanks Meter: 860 | Code: Operation : Check / Read Info [ v1.26 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 166 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A483447316404860AA2E5E0A0CB [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x00000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! ProdName : GT-I9082 ProdModel : GT-I9082 Device : GT-I9082 AndroidVer: 4.2.2 MTKxCPU : MT6575 MTKxPRJ : ALPS.JB.MP.V1.16 MODEM : BaseBand : MT6575_S01_MAUI_11AMD_W12_22_SP_V23 Done! Elapsed: 00:00:34 Reconnect Power/Cable! Scatter Load Ok , BaseBand : MT6575 , Project : MTK6575 , Storage : eMMC Files found : 12 , Set to Flash : 11 Ready to Flash! Operation : Flash [ v1.26 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 113 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A483447316404860AA2E5E0A0CB [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6575 , Project : MTK6575 , Storage : eMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000600000-0x0000000000060000 Erase : 0x0000000000D80000-0x0000000081664000 Flash Pre-Erase Done, time used : 00:00:06 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_hexing75_jb.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0013 Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : EBR2 Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:01:40 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : EBR2 Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:43 Update RomInfo done Done! Elapsed: 00:02:47 Reconnect Power/Cable! |
08-30-2015, 16:47 | #24707 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Q Mobile_i5_ Dead Recovery Time Only 04:14" Successful, Done .:: BY-V1.26::. ..::: Chinese Miracle-2 MTK:::.. Code:
The Following 5 Users Say Thank You to kabul For This Useful Post: |
08-30-2015, 17:57 | #24708 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | nokia C1-01 code read Code: Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - C1-01 Software ver : V 06.05 05-09-11 RM-607 (c) Nokia IMEI : 359745049267427 XappVer : 00000834 PPM : V 06.05 05-09-11 RM-607 (c) Nokia MI CNT : Content: mi_059J840 V 06.05 05-09-11 RM-607 (c) Nokia Product SN : EAD847FAI Product code : 0596697 Base Prd.code: 0585582 Module code : 0204427 Long Prod.SN : 0 Hardware info======= HWID : 2001 Batery: 3824 mV CMT BT: 19b5-22012 LCDVer: TPO Lock info =========== IMEI : 359745049267427 IMEI spNet : 3A 95 47 05 94 62 47 02 IMEI svNet : 33 95 47 05 94 62 47 22 F0 Sl Conf : 001-01-00000000000 Sl Prof : 800000000003000-B Sl Aux : 000B0000 Hw Sig : 189EADF61001E7A5 Country : Test SIM (Open) Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; CRT308 Backup Created CMLA Key status : Not Present SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User Code : 77766 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! |
08-30-2015, 18:05 | #24709 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | nokia 220 flashing Code: Verify files ... MAUI : RM-969_ROM_eMP_10.03.11 VIVA : RM-969_VIVA_eMP_10.03.11 LANG : RM-969_LANG_PACK_ROM_IJ_eMP_10.03.11 CUST : RM-969_CUSTPACK_ROM_IJ_MEA_IR_eMP_10.03.11 JMPT : RM-969_JUMP_TABLE_IJ_MEA_IR_eMP_10.03.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 43 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 044FE732B89463FBCA961B7C060B6A36 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : Rivendell.10.03.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Rivendell.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000 SecureDecrypt : RM-969_ROM_eMP_10.03.11 SecureDecrypt : RM-969_VIVA_eMP_10.03.11 SecureDecrypt : RM-969_LANG_PACK_ROM_IJ_eMP_10.03.11 SecureDecrypt : RM-969_CUSTPACK_ROM_IJ_MEA_IR_eMP_10.03.11 SecureDecrypt : RM-969_JUMP_TABLE_IJ_MEA_IR_eMP_10.03.11 OVRLP : 000069B900000001 PHPID : Rivendell.10.03.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok ERASE_MAUI_INFO : 0x00040000 WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-969_ROM_eMP_10.03.11 Write : RM-969_LANG_PACK_ROM_IJ_eMP_10.03.11 Write : RM-969_CUSTPACK_ROM_IJ_MEA_IR_eMP_10.03.11 Write : RM-969_JUMP_TABLE_IJ_MEA_IR_eMP_10.03.11 Write : RM-969_VIVA_eMP_10.03.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-969_ROM_eMP_10.03.11 [VERIFY] DONE : RM-969_LANG_PACK_ROM_IJ_eMP_10.03.11 [VERIFY] DONE : RM-969_CUSTPACK_ROM_IJ_MEA_IR_eMP_10.03.11 [VERIFY] DONE : RM-969_JUMP_TABLE_IJ_MEA_IR_eMP_10.03.11 [VERIFY] DONE : RM-969_VIVA_eMP_10.03.11 CODE_VERIFY : Ok FORMAT FFS : skipped Rebooting phone now Flashing done! Total flash time : 00:02:26 Reboot phone Ok |
08-30-2015, 18:32 | #24710 (permalink) |
No Life Poster Join Date: Nov 2008 Location: ĦĦInFiNiTy CM2 For EvER!!
Member: 901711 Status: Offline Sonork: 100.1606138 Thanks Meter: 427 | >>>..::LeNoVo S850 // MT6582 ReAd FacToRy FiRMWaRe::..<<< LENOVO S850_MT6582 No Operator LOGO READ INFO & READ FIRMWARE Code: Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3858564D42013299D458A127 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMVX8 [eMMC] : FLASH_CID : 1501004B3858564D42013299D458A127 [eMMC] : FLASH_LEN : 0x00000003A3E00000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : Lenovo ProdName : scofield_row ProdModel : Lenovo S850 Device : S850 AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : S850_ROW_S217_150420 [Read Ok] : preloader_scofield_row.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : preload.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6582 / V1.1.1 / scofield_row / EMMC FW Size : 1920 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6582__Lenovo__Lenovo S850__S850__4.4.2__S850_ROW_S217_150420\ LENOVO S850 |
The Following 2 Users Say Thank You to maomatrix For This Useful Post: |
08-30-2015, 18:34 | #24711 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Samsung GT-I9082 format done Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E3958524D42007ED4DA714141 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMRX9 [eMMC] : FLASH_CID : 1501004E3958524D42007ED4DA714141 [eMMC] : FLASH_LEN : 0x0000000070000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Backup : Skipped by user request FMT Mode set to : 0 Format : Cache and UserData (Full Factory Reset) Format CACHE block Format block Ok! Format UDA block Format block Ok! Done! Elapsed: 00:00:26 |
08-31-2015, 04:11 | #24712 (permalink) |
No Life Poster Join Date: Apr 2014 Location: west java
Member: 2162000 Status: Offline Sonork: 100.1670061 Thanks Meter: 205 | Nokia 220 RM 969 DONE BY FLASHING here log registered to: solusi handphone Connect phone on selected interface... Core : v2.10 , MTKx FlashEngine : v8.1 Verify files ... MAUI : RM-969_ROM_eMP_20.14.11 VIVA : RM-969_VIVA_eMP_20.14.11 LANG : RM-969_LANG_PACK_ROM_ME_eMP_20.14.11_001 CUST : RM-969_CUSTPACK_ROM_ME_APAC_ID_eMP_20.14.11_001 JMPT : RM-969_JUMP_TABLE_ME_APAC_ID_eMP_20.14.11_001 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 119 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 7BE2C74BD585F2D799416B74F10599A1 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : Rivendell.10.03.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Rivendell.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000 SecureDecrypt : RM-969_ROM_eMP_20.14.11 SecureDecrypt : RM-969_VIVA_eMP_20.14.11 SecureDecrypt : RM-969_LANG_PACK_ROM_ME_eMP_20.14.11_001 SecureDecrypt : RM-969_CUSTPACK_ROM_ME_APAC_ID_eMP_20.14.11_001 SecureDecrypt : RM-969_JUMP_TABLE_ME_APAC_ID_eMP_20.14.11_001 OVRLP : 000069B900000001 PHPID : Rivendell.10.03.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok ERASE_MAUI_INFO : 0x00040000 WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-969_ROM_eMP_20.14.11 Write : RM-969_LANG_PACK_ROM_ME_eMP_20.14.11_001 Write : RM-969_CUSTPACK_ROM_ME_APAC_ID_eMP_20.14.11_001 Write : RM-969_JUMP_TABLE_ME_APAC_ID_eMP_20.14.11_001 Write : RM-969_VIVA_eMP_20.14.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-969_ROM_eMP_20.14.11 [VERIFY] DONE : RM-969_LANG_PACK_ROM_ME_eMP_20.14.11_001 [VERIFY] DONE : RM-969_CUSTPACK_ROM_ME_APAC_ID_eMP_20.14.11_001 [VERIFY] DONE : RM-969_JUMP_TABLE_ME_APAC_ID_eMP_20.14.11_001 [VERIFY] DONE : RM-969_VIVA_eMP_20.14.11 CODE_VERIFY : Ok FORMAT FFS : skipped Rebooting phone now Flashing done! Total flash time : 00:02:28 this screen shoot B R |
The Following User Says Thank You to solusi hp For This Useful Post: |
08-31-2015, 04:13 | #24713 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Dera Ismail Khan (KPK) Pak
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | q mobile v2 Clear pin code Code: Operation : Clear UserLocks [Pin/Pwd/Pattern/FVLock/GoogleAcc] [ v1.26 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 26 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040502A17DAA813D DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164040502A17DAA813D [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! LSSA Ok! LSSW Ok! LSSS Ok! LSSK Ok! LSSG Ok! Security Settings : Clear Ok! [Info] : Android 5.x / MT67xx : If phone stuck on "Logo" 1. Wait 2-3 minutes. Power Off phone by long press "Power" button 2. Power On phone again 3. Or wait up to 3-7 minutes, until phone start by itself 4. Also recommended reboot phone twice before start use it Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
08-31-2015, 05:41 | #24714 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | gionee p4 flash done Code: Operation : Flash [ v1.26 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 53 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3758564D42010FA6BC9E9103 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D42010FA6BC9E9103 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6582 , Project : gionee82_wet_jb5 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000880000-0x0000000000100000 Erase : 0x0000000002580000-0x00000001CEE00000 Flash Pre-Erase Done, time used : 00:00:10 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_gionee82_wet_jb5.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0015 Update PMT by user request Repartition Done! Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : EBR2 Image Flash Ok Flash now : SPDATA Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash now : FAT Image Flash Ok Flash Write Done, time used : 00:04:24 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : EBR2 Verify Passed : SPDATA Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Verify Passed : FAT Data Verify Done, time used : 00:02:24 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:07:14 Reconnect Power/Cable! |
08-31-2015, 06:22 | #24715 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | karbon a1+super format done Code: Operation : Format FileSystem [ v1.26 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 126 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 009800BC009000660076001500010000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x8B DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0087 , UNKNOWN [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0015 0001 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Format : UserData Only (Factory Reset) Format UDA block Format block Ok! Done! Elapsed: 00:00:28 Reconnect Power/Cable! |
08-31-2015, 06:37 | #24716 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | Reall World 1st MMobile Tablet T20 Read factory Firmware Done. Code: Operation : Read Flash [ v1.26 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8B00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 0300771F SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : G40CM [eMMC] : FLASH_CID : 7001004D4D433034475803A23BBAD0D3 [eMMC] : FLASH_LEN : 0x00000000E6800000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... MT657x Old CPU : Skip Initial Info read [Image Ok] : preloader_md708.bin [Image Ok] : DSP_BL [Image Ok] : MBR [Image Ok] : EBR1 [Image Ok] : lk.bin [Image Ok] : boot.img [Image Ok] : recovery.img [Image Ok] : secro.img [Image Ok] : logo.bin [Image Ok] : system.img [Image Ok] : cache.img [Image Ok] : userdata.img Brand : Mmobile ProdName : Mmobile T20 ProdModel : T20 Device : SPLENDOR T20 AndroidVer: 4.1.2 MTKxCPU : MT6577 [ScatCFG] : MT6577 / V1.0.0 / md708 / EMMC FW Size : 701 MiB Scatter saved to : F:\Firmware\MT6577__Mmobile__T20__SPLENDOR T20__4.1.2__\ All done! Done! Elapsed: 00:11:03 Reconnect Power/Cable! |
08-31-2015, 06:41 | #24717 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | lenovo a1000 read ff done Code: Operation : Read Flash [ v1.26 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 53 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8B00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 0300771F SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : M00U5 [eMMC] : FLASH_CID : 1501004B355530304D02A31F68766005 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... MT657x Old CPU : Skip Initial Info read [Image Ok] : preloader_huaqin17_td_tb_jb.bin [Image Ok] : DSP_BL [Image Ok] : MBR [Image Ok] : EBR1 [Image Ok] : lk.bin [Image Ok] : boot.img [Image Ok] : recovery.img [Image Ok] : secro.img [Image Ok] : logo.bin [Image Ok] : system.img [Image Ok] : cache.img [Image Ok] : userdata.img Brand : Lenovo ProdName : IdeaTab_A1000-G ProdModel : IdeaTabA1000-G Device : A1000G AndroidVer: 4.1.2 MTKxCPU : MT6577 MTKxPRJ : A1000G_A412_01_09_130907_2G [ScatCFG] : MT6577 / V1.0.0 / huaqin17_td_tb_jb / EMMC FW Size : 685 MiB Scatter saved to : D:\MT6577__Lenovo__IdeaTabA1000-G__A1000G__4.1.2__A1000G_A412_01_09_130907_2G\ All done! Done! Elapsed: 00:06:51 Reconnect Power/Cable! |
08-31-2015, 06:47 | #24718 (permalink) |
Member: 355782 Status: Offline Thanks Meter: 1,265 | Nokia 130 unable to open browser Nokia 130 unable to open browser solved by format with CM2MTK. Code: Operation : Format FileSystem [ v1.26 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 7 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : C74E8C03078EE2D4787F8B69CC483A77 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_NkJ.fg DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G [0] : FLASH_DIE : 00C2 0025 0038 0000 [0] : FLASH_LEN : 0x01000000 Executing FFS FORMAT now... FAT_RANGE : 0x00E80000-0x00FF3FFF , LEN : 0x00174000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
08-31-2015, 07:07 | #24719 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | micromaxx a102 format done Code: Operation : Format FileSystem [ v1.26 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 53 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3758564D42011ABACA357109 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D42011ABACA357109 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Backup : Skipped by user request FMT Mode set to : 0 Format : UserData Only (Factory Reset) Format UDA block Format block Ok! Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
08-31-2015, 07:09 | #24720 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | lava iris flair352 format done Code: Operation : Format FileSystem [ v1.26 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 53 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E3958524D4200B07DC4216177 DA Stat : v4.2 on BBID : 0x8B DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMRX9 [eMMC] : FLASH_CID : 1501004E3958524D4200B07DC4216177 [eMMC] : FLASH_LEN : 0x0000000070000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Backup : Skipped by user request FMT Mode set to : 0 Format : UserData Only (Factory Reset) Format UDA block Format block Ok! Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
