10-13-2016, 17:10 | #36811 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Samsung J100h Hang Format Code: Operation : Check / Read Info [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1501004E3957524D4201D8B174A6119F Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMRW9 [eMMC] : FLASH_CID : 1501004E3957524D4201D8B174A6119F [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x0000000070000000 [eMMC] : FLASH_UCP : 1792 MiB [eMMC 2 GiB] DEV RID : 0xD5229C25646C37353E4E94FF4BA09E9D INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : samsung ProdName : Galaxy J1 ProdModel : SM-J100H Device : j13g AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1 SECURITY : IMEI_SW [1] : 359891060921219 IMEI_SW [2] : 359892060921217 BTMAC Addr : 7E9446657258 WiFi MAC : 000000000000 Done! Elapsed: 00:00:12 Reconnect Power/Cable! Operation : Format FileSystem [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1501004E3957524D4201D8B174A6119F Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMRW9 [eMMC] : FLASH_CID : 1501004E3957524D4201D8B174A6119F [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x0000000070000000 [eMMC] : FLASH_UCP : 1792 MiB [eMMC 2 GiB] DEV RID : 0xD5229C25646C37353E4E94FF4BA09E9D INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:25 Reconnect Power/Cable! |
10-13-2016, 17:11 | #36812 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Qmobile X2 Memory Full Format Code: Operation : Check / Read Info [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6571 BB_CPU_NME : [MediaTek] MT6571_S00 BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8B NAND Flash : 009800BC009000660076001600080000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1 [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1 DEV RID : 0xD5229C254CD6B0A82D833FE0F09BB725 INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : QMobile ProdName : s3510ap ProdModel : QMobile X2 Device : s3510ap AndroidVer: 4.4.2 MTKxCPU : MT6571 MTKxPRJ : ALPS.KK1.MP7.V1 SECURITY : IMEI_SW [1] : 357604061050488 IMEI_SW [2] : 357604066050483 BTMAC Addr : 806AB04AD3AA WiFi MAC : 806AB04A6FDC Done! Elapsed: 00:00:15 Reconnect Power/Cable! Operation : Format FileSystem [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6571 BB_CPU_NME : [MediaTek] MT6571_S00 BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8B NAND Flash : 009800BC009000660076001600080000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1 [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1 DEV RID : 0xD5229C254CD6B0A82D833FE0F09BB725 INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
10-13-2016, 17:12 | #36813 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Samsung G530h Pattern Read Code: Operation : Check / Read Info [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040501A238E7A13B Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040501A238E7A13B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD5229C25879409EC3643B627F176F7F5 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Samsung ProdName : SM-G530H ProdModel : SM-G530H Device : Samsung G530H(GALAXY Grand Prime) AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1 SECURITY : IMEI_SW [1] : 357378061456066 IMEI_SW [2] : 357379061456064 BTMAC Addr : FED646657221 WiFi MAC : 000000000000 Done! Elapsed: 00:00:11 Reconnect Power/Cable! Operation : Read Pattern/DP Lock [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040501A238E7A13B Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040501A238E7A13B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD5229C25879409EC3643B627F176F7F5 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... Get Locks ... PatternLock Sequnce : 752369841 Done! Elapsed: 00:00:25 Reconnect Power/Cable! |
10-13-2016, 17:13 | #36814 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Samsung J100h Pattern Read Code: Operation : Check / Read Info [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : 00AD00BC00900055005600AD00BC0000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x00A4 , [Hynix] H9DA4VH2GJMMCR_4EM [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0056 00AD 00BC [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/01/NIM_Px-2 DEV RID : 0xD5229C2512BCC64FA30447E7C8414735 INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : samsung ProdName : j13gxx ProdModel : SM-J100H Device : j13g AndroidVer: 4.4.4 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1 SECURITY : IMEI_SW [1] : 358414064325344 IMEI_SW [2] : 358415064325341 BTMAC Addr : FA2E46657218 WiFi MAC : 000000000000 Done! Elapsed: 00:00:16 Reconnect Power/Cable! Operation : Read Pattern/DP Lock [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : 00AD00BC00900055005600AD00BC0000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x00A4 , [Hynix] H9DA4VH2GJMMCR_4EM [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0056 00AD 00BC [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/01/NIM_Px-2 DEV RID : 0xD5229C2512BCC64FA30447E7C8414735 INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... Reading data ... Please, wait Checking ... Get Locks ... PatternLock Sequnce : 3215964 Done! Elapsed: 00:01:50 Reconnect Power/Cable! |
10-13-2016, 21:41 | #36815 (permalink) |
Registered User Join Date: Nov 2009 Location: Matanzas
Member: 1164681 Status: Offline Thanks Meter: 15 | I have this problem with a Huawei G610... Wait for phone... Phone found! [ 18 ] Sync... Inital Boot Ok! BB_CPU_PID : 6583 BB_CPU_NME : [MediaTek] MT6583|6589_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x86 NAND Flash : NOT INSTALLED eMMC Flash : 484A019064314734A3058604D341A6A5 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048605A3A5A641D3 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0x2FA52665FEB89800FC2FB64972761969 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6589 , Project : MTK6589 , Storage : eMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 4237 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000600000-0x0000000000100000 Erase : 0x0000000002720000-0x0000000055E60000 Flash Pre-Erase Done, time used : 00:00:01 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_huawei89_we_jb2.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0015 Update PMT by user request Repartition Failed! Something wrong with HW or BL? Try make "Flash Erase" first! Operation Failed Elapsed: 00:00:38 Reconnect Power/Cable! Operation : Flash Erase [ v1.56 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 18 ] Sync... Inital Boot Ok! BB_CPU_PID : 6583 BB_CPU_NME : [MediaTek] MT6583|6589_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x86 NAND Flash : NOT INSTALLED eMMC Flash : 484A019064314734A3058604D341A6A5 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048605A3A5A641D3 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0x2FA52665FEB89800FC2FB64972761969 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Erase Flash now ... Keep Preloader alive Flash erase done Done! Elapsed: 00:00:12 Reconnect Power/Cable! Operation : Flash [ v1.56 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 68 ] Sync... Inital Boot Ok! BB_CPU_PID : 6583 BB_CPU_NME : [MediaTek] MT6583|6589_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x86 NAND Flash : NOT INSTALLED eMMC Flash : 484A019064314734A3058604D341A6A5 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x40000000 [DA_ERROR] : DA Load failed! ErroCode : 0x2007 DA_START_LOAD_FAILED 0x00 Boot Error! Operation Failed Elapsed: 00:00:39 Reconnect Power/Cable! Operation : HW Test [ v1.56 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 68 ] Sync... Inital Boot Ok! BB_CPU_PID : 6583 BB_CPU_NME : [MediaTek] MT6583|6589_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x86 NAND Flash : NOT INSTALLED eMMC Flash : 484A019064314734A3058604D341A6A5 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x40000000 [DA_ERROR] : DA Load failed! ErroCode : 0x2007 DA_START_LOAD_FAILED 0x00 Boot Error! Operation Failed Elapsed: 00:00:16 Reconnect Power/Cable! Operation : Check / Read Info [ v1.56 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 68 ] Sync... Inital Boot Ok! BB_CPU_PID : 6583 BB_CPU_NME : [MediaTek] MT6583|6589_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x86 NAND Flash : NOT INSTALLED eMMC Flash : 484A019064314734A3058604D341A6A5 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x40000000 [DA_ERROR] : DA Load failed! ErroCode : 0x2007 DA_START_LOAD_FAILED 0x00 Boot Error! Operation Failed Elapsed: 00:00:17 Reconnect Power/Cable! Some help please!!!!! |
10-14-2016, 06:01 | #36816 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Qmobile E4 ll Format ll Imei Repair ll Read Flash FIle ll Done Code: Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 106 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : B54D4F730DB5B83A71E9081B705A47C3 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 INT_RAM : 0x0000D400 EXT_RAM : 0x00400000 Backup done Executing FFS FORMAT now... FAT_RANGE : 0x003B5000-0x003FFFFF , LEN : 0x0004B000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:18 Reconnect Power/Cable! Code: Operation : Repair Security [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 106 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : B54D4F730DB5B83A71E9081B705A47C3 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 INT_RAM : 0x0000D400 EXT_RAM : 0x00400000 Read Security data ... Verify Security data ... Set IMEI [0] : 353028070074731 Set IMEI [1] : 353028075074736 Repair Repair done! Done! Elapsed: 00:00:15 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 106 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : B54D4F730DB5B83A71E9081B705A47C3 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 INT_RAM : 0x0000D400 EXT_RAM : 0x00400000 Reading Flash Content now ... Read Flash now Read Ok , 4194304 bytes read Check and collect compile info File_Info : WBG1307QM_0202_PCB01_gprs_MT6250_S00.1307QM_0202_V0782.bin FileVersion : 1307QM_0202_V0782 Saved to : C:\InfinityBox\CM2MTK\Read_out\WBG1307QM_0202_PCB01_gprs_MT6250_S00.1307QM_0202_V0782.bin Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
10-14-2016, 07:03 | #36817 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Qmobile Power 2 Format Done Code: Operation : Format File System / Reset Settings [ v1.22 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 119 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:07 Reconnect Power/Cable! |
10-14-2016, 07:10 | #36818 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | GFive President Smart 2 Format Done Code: Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 106 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483447326111013DD9C56342A7 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x20000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A483447326111013DD9C56342A7 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xE6C52A7DB6EA91873F96D21969A32EE8 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:30 Reconnect Power/Cable! |
10-14-2016, 07:18 | #36819 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Reset Privacy Lock Done Code: Operation : Reset Privacy Lock [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 19 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483447326111013DD9C56342A7 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A483447326111013DD9C56342A7 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xE6C52A7DB6EA91873F96D21969A32EE8 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Checking data ... Process block #1 Process block #2 Privacy Lock reset Ok! Done! Elapsed: 00:00:23 Reconnect Power/Cable! |
10-14-2016, 07:25 | #36820 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Nokia 206 Dead Problem Solved Code: Core : v2.23 , BB5XG FlashEngine : v10.1 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm872__04.52.mcusw PPM : rm872__04.52.ppm_m2 CNT : rm872__04.52.image_m2_059Q4J7 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.53_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 356352055948801 IMEI 2 : 356352055948819 PCcode : 059Q4J7 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\356352055948801_XG213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm872__04.52.mcusw Image : rm872__04.52.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:04 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:01:48 Write , Start : 0x40280000 , Len : 0x01800000 Flashing , wait ... Region flash done, time : 00:00:32 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xFA4D ===Flashing [PPM]=== File : rm872__04.52.ppm_m2 Image : package_m2.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41A80000 , Len : 0x00680000 Erasing, wait ... Erase done, time : 00:00:18 Write , Start : 0x41A80000 , Len : 0x003C68F0 Flashing , wait ... Region flash done, time : 00:00:04 CRC check passed , 0xC9E6 ===Flashing [CNT]=== File : rm872__04.52.image_m2_059Q4J7 Image : package_m2_059Q4J7.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42100000 , Len : 0x01D20000 Erasing, wait ... Erase done, time : 00:03:24 Write , Start : 0x42100000 , Len : 0x01040000 Flashing , wait ... Region flash done, time : 00:00:20 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:05 No write data, skip CRC check passed , 0x5521 Flashing done! Total flash time : 00:06:42 Reboot phone now... Reading Phone Info.... Connected phone - 206 Software Info: V 04.52 30-06-13 RM-872 (c) Nokia IMEI: 356352055948801 PPM version : V 04.52 30-06-13 RM-872 (c) Nokia M2 Product code: 059Q4J7 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:08:04 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
10-14-2016, 08:07 | #36821 (permalink) |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | intex aqua raze clear pattern lock reset lock Code: Operation : Clear UserLocks [Pin/Pwd/Pattern/FVLock/GoogleAcc] [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 124 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 30000111374738308C1E0030D1D9669B Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 07G80 [eMMC] : FLASH_CID : 110100303038473730001E8C9B66C2D1 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x4AD5A99B4C425F6B4A5BEE0927C1175F INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! LSSDB Ok! LSSWL Ok! LSSSH Ok! LSSGS Ok! LSSKY Ok! Security Settings : Clear Ok! [Info] : That feature NOT RESET "PRIVACY PASSWORD LOCK"! Use separate button! [Info] : That feature NOT RESET "FRP/GoogleLOCK"! Use separate "FRP" reset! [Info] : If phone stuck on "Logo" : 1. Wait 2-3 minutes. Power Off phone by long press "Power" button 2. Power On phone again 3. Or wait up to 3-7 minutes, until phone start by itself 4. Also recommended reboot phone twice before start use it Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
10-14-2016, 09:09 | #36822 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Pakistan
Member: 192810 Status: Offline Sonork: Some people NEED change Thanks Meter: 860 | World First Haier G40 FRP Rest Done by CM2 Code: Operation : Check/Read Info [ v1.21 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 59 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : Haier G40 Model Brand : Haier Model Device: scx35_sp7731gea_lm_fs031 AndrVersion : 5.1 BaseBand CPU: SP7731GEA_LM_FS031 CompileDate : 6/17/2016 1:53:20 PM Project Ver : G40-H01-S006-PK_20160617_2143 Model Ext : Haier G40 ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:16 Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.21 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 59 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x0000000153AF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:23 |
10-14-2016, 10:28 | #36823 (permalink) |
No Life Poster Join Date: Nov 2007 Location: ☆I-LOVE Pakistan☆
Member: 627475 Status: Offline Sonork: 100.1594828 Thanks Meter: 1,144 | LG GB-102 SP Unlock Done By infinity Box Code: COM3 [VCP0] selected module v1.78 Device: LG-GB102 Checking data, wait... Action: "sp-unlock" direct unlock method #2 (Airtel etc.) Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: .01 ULC2GL UK-O2 GB102 00 AT 44 V10a 234-10 MAR-17-2010 +0 Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\InfinityBox\Pana01\LG-GB102_eeprom-static_20161014-140246.B1E.bin loading data... data loaded imei: 353#######71#### reading eeprom-security_35############... file saved: C:\InfinityBox\Pana01\LG-GB102_eeprom-security_35##7043#####_20161014-140247.B1E.bin reading eeprom-complete_353477######... file saved: C:\InfinityBox\Pana01\LG-GB102_eeprom-complete_35###7#######_20161014-140253.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-security Writing: eeprom-security probably you need to restore original imei after unlock process Write Done Finished, time used: 35 sec Remove/Install battery now ! |
10-14-2016, 10:30 | #36824 (permalink) |
No Life Poster Join Date: Jul 2006 Location: punjab Age: 43
Member: 315867 Status: Offline Sonork: 100.1654770 Thanks Meter: 708 | Brand : TCL ProdName : 4027A ProdModel : 4027A Device : Pixi3-45 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP6.V1 network unlock done Operation : SP Unlock [ v1.58 ] Mode : Direct Unlock 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 110100303034474530019F5DB6721399 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 0EG40 [eMMC] : FLASH_CID : 110100303034474530019F5DB6721399 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0xB662A14ECA045B070B65C9C1D573EDAF INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SIM Lock Status : Locked! Unlocking now ... Unlock done! Done! Elapsed: 00:00:29 Reconnect Power/Cable! |
The Following User Says Thank You to diesel6 For This Useful Post: |
10-14-2016, 10:43 | #36825 (permalink) |
Member: 315867 Status: Offline Sonork: 100.1654770 Thanks Meter: 708 | Brand : htc ProdName : htc_asia_sea_wwe ProdModel : HTC Desire 616 dual sim Device : htc_v3_dug AndroidVer: 4.2.2 MTKxCPU : MT6592 MTKxPRJ : SW_G98518A2_V019_M10_HTC_V3DUG_ASIA_MP repaire seq. done Operation : Repair Security [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6592 BB_CPU_NME : [MediaTek] MT6592_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8A NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164048602A48767911F Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048602A48767911F [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0xB662A14E89C2C88BE732AFF7066AD4F4 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Set IMEI [00] : 353 Set IMEI [01] : 353 Prepare finished. Security check required! Wait for phone... Phone found! [ 3 ] Sync... Repair done! Done! Elapsed: 00:00:33 Reconnect Power/Cable! |
