07-19-2017, 14:21 | #43651 (permalink) |
Freak Poster Join Date: Jan 2004 Location: Estonia,UK Bognor Regis Age: 44
Member: 50306 Status: Offline Thanks Meter: 51 | oppo a57 frp done 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 435 [MSM8940] ID_BLOCK_S : CA62401B ID_BLOCK_I : 0006B0E1 ID_BLOCK_L : 13CB4AF6C8D8BFB09BF7CB79C691EEAB ID_BLOCK_L : C6E16861C482039B92AB606F43129813 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HBG4a2 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
The Following User Says Thank You to cesarq For This Useful Post: |
07-19-2017, 15:57 | #43652 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Voice V60 MT6583 Hanging Probel Solve Only Formate With Infinity CM2 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 26 ] Sync... Inital Boot Ok! BB_CPU_PID : 6583 BB_CPU_NME : [MediaTek] MT6583|6589_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x86 NAND Flash : NOT INSTALLED eMMC Flash : 4B000115303055352E01024D8790D38A Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , M00U5 [eMMC] : FLASH_CID : 1501004B355530304D02012E8AD39087 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F395BCF8AE0A3D705E52A233FB01 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
07-19-2017, 20:10 | #43653 (permalink) |
No Life Poster Join Date: Mar 2016 Location: Ukraine
Member: 2550141 Status: Offline Thanks Meter: 1,115 | Samsung GT-N7100 - Flashing With Infinity CM2 Code: Phone found on COM4 Connect ADB - Ok Model - GT-N7100 Product - t03gxx CPU - smdk4x12_prime Phone version - N7100XXUENA1 Android version - 4.3 CSC country code - Russia CSC sales code - SER Phone serial No - 00000000000 Phone not Rooted Connect ADB - Ok Reboot... Phone Disconnected Phone found on COM3 Port open Ok! LOKE received! Prepare Ok! Enter Setup... Setup Done! Re-Partition enabled Uploading Pit File Start Flashing PIT Prepare PIT Flashing... Flashing PIT done Try download PIT... Download PIT Ok! Start flashing! Flashing boot.img Flashing recovery.img Flashing system.img Flashing sboot.bin Flashing param.bin Flashing tz.img Flashing modem.bin Flashing cache.img Flashing hidden.img Flashing done Reboot phone... Phone Disconnected |
07-19-2017, 21:11 | #43654 (permalink) | |
No Life Poster Join Date: Dec 2015 Location: hossting
Member: 2501288 Status: Offline Thanks Meter: 328 | Connect mode: hold volume up and Volume down the connect USB TECNO N9S Quote:
07-20-2017, 05:33 | #43655 (permalink) |
Freak Poster Join Date: Nov 2013 Location: San Fernando La Union Age: 34
Member: 2068959 Status: Offline Thanks Meter: 252 | LG-F510L HANG LOGO DONE BY FLASHING Card found : AB8C3A61 , v0136 Infinity-Box LG Service Tool [ LGS ] v1.03 Loading firmware ... FType : KDZ file BB_Gen : QLM Model : LG-F510L Version : F510L20b SWInfo : 6.0.1 user File [0] : PrimaryGPT_0.bin File [1] : modem_32768.bin File [2] : pmic_196608.bin File [3] : sbl1_197632.bin File [4] : tz_199680.bin File [5] : sdi_201728.bin File [6] : hyp_202752.bin File [7] : rpm_203776.bin File [8] : aboot_204800.bin File [9] : sbl1bak_208896.bin File [10] : pmicbak_210944.bin File [11] : tzbak_211968.bin File [12] : hypbak_214016.bin File [13] : rpmbak_215040.bin File [14] : abootbak_216064.bin File [15] : sdibak_220160.bin File [16] : persist_262144.bin File [17] : sec_344064.bin File [18] : rct_347136.bin File [19] : laf_360448.bin File [20] : boot_458752.bin File [21] : recovery_540672.bin File [22] : factory_720896.bin File [23] : raw_resources_835584.bin File [24] : raw_resourcesbak_843776.bin File [25] : system_851968.bin File [26] : system_1116040.bin File [27] : system_1380256.bin File [28] : system_1640328.bin File [29] : system_1644328.bin File [30] : system_1904544.bin File [31] : system_2164616.bin File [32] : system_2168616.bin File [33] : system_2428832.bin File [34] : system_2688904.bin File [35] : system_2692904.bin File [36] : system_2953120.bin File [37] : system_3213192.bin File [38] : system_3217192.bin File [39] : system_3477408.bin File [40] : system_3739552.bin File [41] : system_4001696.bin File [42] : system_4263840.bin File [43] : system_4525984.bin File [44] : system_4788128.bin File [45] : system_5050272.bin File [46] : system_5312416.bin File [47] : system_5574560.bin File [48] : system_5836704.bin File [49] : system_6098848.bin File [50] : system_6360992.bin File [51] : system_6619136.bin File [52] : system_6881280.bin File [53] : system_7143424.bin File [54] : system_7405568.bin File [55] : system_7407496.bin File [56] : system_7411496.bin File [57] : system_7929856.bin File [58] : system_7931784.bin File [59] : system_7935784.bin File [60] : system_8454144.bin File [61] : system_8458144.bin File [62] : BackupGPT_61070336.bin Load Ok! Operation : Flash [ v1.03 ] Forced Flash : Disabled Factory Reset : Enabled 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD VOLUME UP KEY! 3. Insert USB cable, wait until Download mode screen will appear Wait for phone... Connection opened successfully! Waiting for loader ... Handshake passed! Collect info... Prepare passed, mode 0x01 Boot done! [INFO] : Low Battery level ignored by user request! Loading firmware Load ok! Checking compatibility Checking passed! Prepare device Prepare Passed! Secure prepare passed! Start flashing device Flash : PrimaryGPT_0.bin Flash : modem_32768.bin Flash : pmic_196608.bin Flash : sbl1_197632.bin Flash : tz_199680.bin Flash : sdi_201728.bin Flash : hyp_202752.bin Flash : rpm_203776.bin Flash : aboot_204800.bin Flash : sbl1bak_208896.bin Flash : pmicbak_210944.bin Flash : tzbak_211968.bin Flash : hypbak_214016.bin Flash : rpmbak_215040.bin Flash : abootbak_216064.bin Flash : sdibak_220160.bin Flash : persist_262144.bin Flash : sec_344064.bin Flash : rct_347136.bin Flash : laf_360448.bin Flash : boot_458752.bin Flash : recovery_540672.bin Flash : factory_720896.bin Flash : raw_resources_835584.bin Flash : raw_resourcesbak_843776.bin Flash : system_851968.bin Flash : system_1116040.bin Flash : system_1380256.bin Flash : system_1640328.bin Flash : system_1644328.bin Flash : system_1904544.bin Flash : system_2164616.bin Flash : system_2168616.bin Flash : system_2428832.bin Flash : system_2688904.bin Flash : system_2692904.bin Flash : system_2953120.bin Flash : system_3213192.bin Flash : system_3217192.bin Flash : system_3477408.bin Flash : system_3739552.bin Flash : system_4001696.bin Flash : system_4263840.bin Flash : system_4525984.bin Flash : system_4788128.bin Flash : system_5050272.bin Flash : system_5312416.bin Flash : system_5574560.bin Flash : system_5836704.bin Flash : system_6098848.bin Flash : system_6360992.bin Flash : system_6619136.bin Flash : system_6881280.bin Flash : system_7143424.bin Flash : system_7405568.bin Flash : system_7407496.bin Flash : system_7411496.bin Flash : system_7929856.bin Flash : system_7931784.bin Flash : system_7935784.bin Flash : system_8454144.bin Flash : system_8458144.bin Flash : BackupGPT_61070336.bin Processing Post-Flashing tune Flash done! Reconnect Power/Cable! Done! Elapsed: 00:06:24 |
07-20-2017, 05:51 | #43656 (permalink) |
Freak Poster Join Date: Nov 2015 Location: Pakistan Age: 24
Member: 2488001 Status: Offline Sonork: 100.1669288 Thanks Meter: 295 | Q Mobile X6i 3g dead Recovered Done Set mode to : SP [SC7715] eMMC [Generic] Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 19 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! DS : Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! Set mode to : SP [SC7715] NAND [Generic] Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 19 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Loader NAND v1.1 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : NAND Flash , Structure : Ok! Reading extended info ... Model Name : X6i Model Brand : QMobile Model Device: X6i AndrVersion : 4.4.2 BaseBand CPU: SCX15_SP7715GA CompileDate : 9/2/2015 7:19:30 AM Project Ver : QMobileX6i_MP_26_06 Model Ext : QMobile X6i ExtraInfo : HWInfo not exists, normal phone ExtraInfo : NAND PageType : Blk 256k , Page 4k Elapsed: 00:00:36 Reconnect Power/Cable! Infinity SC Firmware Detected FW Size : 337 MiB Load Ok! Operation : Flash [ v1.27 ] ======= Flash Files set for flashing : [ MCU ] : SC77xx Infinity Package 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 19 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Loader NAND v1.1 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x16 records PMTManager : PMT Update Ok! Flashing now Update BootCode : u-boot-spl-16k.bin Write Data ... Write Data Ok! Update BootCode : u-boot.bin Write Data ... Write Data Ok! Write FSImage : prodnv_b256k.img Write Data ... Write Data Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Write CodeData : sc7715_modem.bin Write Data ... Write Data Ok! Write CodeData : DSP_DM_Gx.bin Write Data ... Write Data Ok! Write CodeData : CP2._CP2_WCN_14C_W15.18_Release.bin Write Data ... Write Data Ok! Write CodeData : logo_480x854.bin Write Data ... Write Data Ok! Write CodeData : boot.img Write Data ... Write Data Ok! Write FSImage : system_b256k.img Write Data ... Write Data Ok! Write FSImage : cache_b256k.img Write Data ... Write Data Ok! Write CodeData : recovery.img Write Data ... Write Data Ok! Write FSImage : userdata_b256k.img Write Data ... Write Data Ok! Elapsed: 00:01:19 Reconnect Power/Cable! |
07-20-2017, 07:04 | #43657 (permalink) |
Freak Poster Join Date: Mar 2013
Member: 1893978 Status: Offline Thanks Meter: 33 | Moto c3 power xt1706 frp done Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D333145DE16074217175EA8 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM31E [eMMC] : FLASH_CID : 150100514531334D420716DEA85E6317 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x60D7AB4EEB3E42DFFC2858DF45BBF658 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : motorola ProdName : taido_row ProdModel : XT1706 Device : taido_row AndroidVer: 6.0 MTKxCPU : MT6735 MTKxPRJ : XT1706_USR_S141_1703291051_mp1V2.39.1_ROW EXTRA : LCD : Not info available LCD Res : 1280x720 TOUCH [0] : GT1XX CAM [0] : imx219_mipi_raw CAM [1] : imx219_mipi_raw_ofilm CAM [2] : ov5695_mipi_raw CAM [3] : ov5695_mipi_raw_ofilm MODEM : taido_row_lwg_md1 LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES Done! Elapsed: 00:00:10 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D333145DE16074217175EA8 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM31E [eMMC] : FLASH_CID : 150100514531334D420716DEA85E6317 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x60D7AB4EEB3E42DFFC2858DF45BBF658 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
The Following User Says Thank You to .::universe::. For This Useful Post: |
07-20-2017, 08:18 | #43658 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Oppo A33FW Pattren Read Done With Great Infinity CM2 Card found : A19EC787 , v0136 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.14 Operation : Read PatternLock [ v1.14 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 233E2B24 ID_BLOCK_I : 007050E1 ID_BLOCK_L : A14339C570FEEBE6C1B65E4780DB5B73 ID_BLOCK_L : 1568D6797AE555DEF3C2974C46A94784 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Read Ok! Trying decrypt ... PatternLock sequence : 4253 Done! Elapsed: 00:00:13 Reconnect Power/Cable! |
07-20-2017, 08:22 | #43659 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | HOTWAV C5 Read Factory Firmware / Format Done :) Code: Operation : Check/Read Info [ v1.25 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 193 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : k15_v8_1_hotwav_64_8_dt Model Brand : HOTWAV Model Device: k15_v8_1_hotwav_64_8 AndrVersion : 5.1 BaseBand CPU: K15_V8_1_HOTWAV CompileDate : 11/1/2016 1:53:17 AM Project Ver : LMY47D release-keys Model Ext : C5 ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:24 Reconnect Power/Cable! Code: Operation : Read FullFlash [ v1.25 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 193 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected eMMC Flash , Structure detect Ok! [FW_READER] : Prepare Ok! - > Wait phone connected ... Phone found! [ 193 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! - > Wait phone connected ... Phone found! [ 193 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! Model Name : k15_v8_1_hotwav_64_8_dt Model Brand : HOTWAV Model Device: k15_v8_1_hotwav_64_8 AndrVersion : 5.1 BaseBand CPU: K15_V8_1_HOTWAV Project Ver : LMY47D release-keys Model Ext : C5 [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : sc7731g_CP0_modem.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : nvitem_w.bin [Read Ok] : sc8830g_modem_CP2_WCN_14D_W15.31.1_Release.bin [Read Ok] : nvitem_wcn.bin [Read Ok] : logo_720x1280.bin [Read Ok] : fblogo_720x1280.bin [Read Ok] : thirdlogo.bin [Read Ok] : forthlogo.bin [Read Ok] : boot.img [Read Ok] : system.img [Build Ok] : cache.img [Read Ok] : recovery.img [Build Ok] : userdata.img AndroidInfo created Firmware Size : 1640 MiB Saved to : F:\backup files\K15_V8_1_HOTWAV_k15_v8_1_hotwav_64_8_5.1_LMY47D_release-keys_C5\ Done! Elapsed: 00:09:19 Reconnect Power/Cable! Code: Operation : Format File System / Reset Settings [ v1.25 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 193 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x0000000166FF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Done! Elapsed: 00:00:32 Reconnect Power/Cable! |
07-20-2017, 08:51 | #43660 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile S1 MT6582 Dead Set Re Alive DOne By Flashing With Infinity CM2 Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 26 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473165050734EA695513C5 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A4838473165050734EA695513C5 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xD9C8F39564AAA2820D91CF729A8A6845 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6582 , Project : s5222 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 3714 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000001CEE00000 Flash Pre-Erase Done, time used : 00:00:08 SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:04:01 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:01:25 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:05:52 Reconnect Power/Cable! |
07-20-2017, 08:57 | #43661 (permalink) |
The Following User Says Thank You to azhergoga007 For This Useful Post: |
07-20-2017, 08:58 | #43662 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Gfive Power3 MT6580 Hanging Probelam Fix Only Formate With Infinity CM2 Card found : S/N : A19EC787 , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 26 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100463732324D42009103D6CB4303 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM227 [eMMC] : FLASH_CID : 150100463732324D42009103D6CB4303 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xD9C8F395DEBAEAFE3EC16CBE72B0479A INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:34 Reconnect Power/Cable! |
07-20-2017, 10:01 | #43663 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,425 | LG D802 Reset Settings/Format FS Done Operation : Identify [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD VOLUME UP KEY! 3. Insert USB cable, wait until Download mode screen will appear Wait for phone... Connection opened successfully! Waiting for loader ... Handshake passed! Collect info... Running : MiniOS v1.0 , ver.1.0 , with proto ver.01000001 HWInfo : BaseBand : MSM8974 HWInfo : ChargeLv : 47% HWInfo : MEM_INFO : 032GE4 , MEM_LEN : 0x03A3E000 [eMMC 32 GiB] DevInfo : Model : LG-D802 , Type : D80220b DevInfo : ANDROID 4.4.2 DevInfo : PSN : CY13S140409002819 , PID : 04ac997c06a06156 DevInfo : IMEI : 358635059696998 DevInfo : SecMode : S , Build : U , RCT : 000F4244 SWInfo : SWver : 20b , SW : LGD802AT-00-20b-OPEN-CN-MAR-16-2014+0 SWInfo : FacSW : LGD802AT-00-20b-OPEN-CN-MAR-16-2014+0 RegInfo : Region : CN , Provider : OPEN Prepare passed, mode 0x00 Boot done! Brand : lge ProdName : g2_open_cn ProdModel : LG-D802 Device : g2 AndroidVer: 4.4.2 Manufact. : LGE LGMxCPU : MSM8974 Done! Elapsed: 00:00:17 Operation : Reset Settings/Format FS [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD VOLUME UP KEY! 3. Insert USB cable, wait until Download mode screen will appear Wait for phone... Connection opened successfully! Waiting for loader ... Handshake passed! Collect info... Prepare passed, mode 0x00 Boot done! Format UserData Format Cache Format done Reconnect Power/Cable! Done! Elapsed: 00:00:24 |
The Following 2 Users Say Thank You to Akhtar Ali Jatt For This Useful Post: |
07-20-2017, 10:14 | #43664 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,425 | Qmobile Jazz X JS2 Format Done Code: Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 6 ] Port Opened Sync... InitSvc Done Wait for phone... Sync... Init Ok , reset settings ... Format Ok! Done Elapsed: 00:00:12 Reconnect Power/Cable! |
07-20-2017, 10:17 | #43665 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,425 | Vgo Tel i199 Format And Read Flash File Done Code: Operation : Read UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 5 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 7C0426357247C5E9C3CA8D1D53220A85 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00300000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Read ExtData Sorting ExtData Reading UserCode Active : Yes , Code : 2772 PLock|MobTrack : Not active Done! Elapsed: 00:00:04 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 5 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 7C0426357247C5E9C3CA8D1D53220A85 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00300000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Reading Flash Content now ... Read Flash now Read Ok , 3145728 bytes read Check and collect compile info File_Info : NEOTEL61M_2432_BU1_11C_PCB01_gsm_MT6261_S00.VGOTEL_I199_V3_1_V05_20161125.bin FileVersion : Vgotel_i199_V3.1_V05_20161125 Saved to : C:\InfinityBox\CM2MTK\Read_out\NEOTEL61M_2432_BU1_11C_PCB01_gsm_MT6261_S00.VGOTEL_I199_V3_1_V05_20161125.bin Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
