07-20-2017, 19:22 | #43696 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | QMobile X30 Hang Logo Write File Code: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483447326111010AD9E64E2265 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A483447326111010AD9E64E2265 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD5229C25061480C248E4516CA7F2265D INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : TINNO ProdName : QMobile X30 ProdModel : QMobile X30 Device : QMobile X30 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1 Done! Elapsed: 00:00:12 Reconnect Power/Cable! Scatter Load Ok , BaseBand : MT6572 , Project : s4050ap , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483447326111010AD9E64E2265 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A483447326111010AD9E64E2265 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD5229C25061480C248E4516CA7F2265D INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : s4050ap , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 4115 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000000E5E00000 Flash Pre-Erase Done, time used : 00:00:14 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_s4050ap.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:02:51 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:40 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:04:05 Reconnect Power/Cable! |
The Following User Says Thank You to Tanha0321 For This Useful Post: |
07-21-2017, 06:28 | #43698 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Oppo A37f FRP Reset Done With Great Infinity CM2 Card found : A19EC787 , v0136 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.14 Operation : Reset Settings [ v1.14 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 2152EA38 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 4DB72D2984121F0AF5AAAAAB74CF4787 ID_BLOCK_L : 0944CA6556F961E2E7D6BB7072BDAB90 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
07-21-2017, 06:59 | #43699 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Rivo Rx60 MT6582 Pattren Read Done With Great Infinity CM2 Card found : S/N : A19EC787 , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Read Pattern/DP Lock [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 26 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483847326404050BA2997922B7 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A483847326404050BA2997922B7 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xD9C8F3953E2C43AB3EC69D198712695B INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... Get Locks ... PatternLock Sequnce : 4756 Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
The Following User Says Thank You to azhergoga007 For This Useful Post: |
07-21-2017, 07:05 | #43700 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Rivo Rx40 MT6572 User Codde Reset Done With Great Infinity CM2 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 26 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A2058494E594816A15813C140C7 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , HYNIX [eMMC] : FLASH_CID : 90014A2058494E594816A15813C140C7 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F395F12C11DE5A8B9A90FE79628E INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! LSSDB Ok! LSSWL Ok! LSSSH Ok! Security Settings : Clear Ok! [Info] : That feature NOT RESET "PRIVACY PASSWORD LOCK"! Use separate button! [Info] : That feature NOT RESET "FRP/GoogleLOCK"! Use separate "FRP" reset! [Info] : If phone stuck on "Logo" : 1. Wait 2-3 minutes. Power Off phone by long press "Power" button 2. Power On phone again 3. Or wait up to 3-7 minutes, until phone start by itself 4. Also recommended reboot phone twice before start use it Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
07-21-2017, 07:56 | #43701 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | Infinity Chinese Miracle-2 QLM/QLM MODULE v1.14 Successfully REMOVE P LOCK & MI ACCOUNT(MI REDMI 4A MODEL NO 2016116)USB 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Reset Settings [ v1.14 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 425 [MSM8917] ID_BLOCK_S : 4F3FBFB3 ID_BLOCK_I : 000560E1 ID_BLOCK_L : AB14775319E8D08332461255C9B5458A ID_BLOCK_L : 09F78D24EBC2C41AC5A47D6817875316 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HAG4a2 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:17 Reconnect Power/Cable! ################################################## ################################################## #### 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 425 [MSM8917] ID_BLOCK_S : 4F3FBFB3 ID_BLOCK_I : 000560E1 ID_BLOCK_L : AB14775319E8D08332461255C9B5458A ID_BLOCK_L : 09F78D24EBC2C41AC5A47D6817875316 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HAG4a2 Boot Ok! MIAccount reset passed! Normal reset : > Select "FORCED FIX" or "REPAIR" in FMT settings, press "Format FS / Reset Settings" > PowerOn device and use. IF Device stuck on black screen with cable - use another FMT > Not all devices supported yet! (tested on Hydrogen,Land,Redmi2) Done! Elapsed: 00:00:23 Reconnect Power/Cable! THANKS INFINITY-BOX TEAM |
07-21-2017, 08:37 | #43702 (permalink) |
No Life Poster Join Date: Jul 2011 Location: malawi
Member: 1614640 Status: Offline Thanks Meter: 468 | ZTE BLADE L110 FRP UNLOCK DONE Operation : Format File System / Reset Settings [ v1.24 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 103 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x000000006ADF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
The Following User Says Thank You to bright hlatini For This Useful Post: |
07-21-2017, 10:16 | #43703 (permalink) |
Junior Member Join Date: Oct 2010
Member: 1411141 Status: Offline Thanks Meter: 7 | remove FRP intel A41 ..want to remove frp... which cpu i have to select ?? is there any way to find out which chipset is used in any android phone ? Last edited by kevinsatani; 07-21-2017 at 10:22. |
07-21-2017, 12:52 | #43706 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Pakistan
Member: 897524 Status: Offline Sonork: 100,1609543 Thanks Meter: 172 | Successfully unlocked vodafone 500 Operation : SP Unlock [ v1.58 ] Mode : Direct Unlock 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 3000011137473830F11600309BCB2F3B Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 07G80 [eMMC] : FLASH_CID : 1101003030384737300016F13B2F439B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xB582A661590178AD801ABA01B4F53290 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SIM Lock Status : Locked! Unlocking now ... Unlock done! Done! Elapsed: 00:00:47 Reconnect Power/Cable! BR |
The Following User Says Thank You to gsmcrazy1 For This Useful Post: |
07-21-2017, 12:56 | #43707 (permalink) |
Member: 1614640 Status: Offline Thanks Meter: 468 | DELUXE CELL C FRP UNLOCK DONE Operation : Check/Read Info [ v1.24 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 103 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : Deluxe Model Brand : Cell_C Model Device: Cell_C AndrVersion : 6.0 BaseBand CPU: SP7731CEB CompileDate : 11/22/2016 6:15:51 AM Project Ver : Cell_C_Deluxe_IND_Ver1.0_161110_1200 Model Ext : Deluxe ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:30 Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.24 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 103 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x000000005DEF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
07-21-2017, 15:53 | #43708 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Madagascar
Member: 233142 Status: Offline Sonork: 100.1595099 Thanks Meter: 527 | Typhoon t2 hang on logo done Code: Card found : S/N : XXXXXXXX , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:36 Reconnect Power/Cable! Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 3701FF454D4330384710F60007E01371 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x37 , OEM : 01FF [eMMC] : FLASH_INF : [NOT_IN_BASE] , G80CM [eMMC] : FLASH_CID : 3701FF454D4330384710F60007E01371 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001CD000000 [eMMC] : FLASH_UCP : 7376 MiB [eMMC 8 GiB] DEV RID : 0x4B1992B1185631ABF7039C38198C7DC7 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : TT ProdName : Typhoon-T2 ProdModel : Typhoon-T2 Device : T2 AndroidVer: 5.1 MTKxCPU : MT6580 MTKxPRJ : ALPS.L1.MP6.V2_YUANDA6580.WE.L Done! Elapsed: 00:00:17 Reconnect Power/Cable! Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:42 Reconnect Power/Cable! Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:42 Reconnect Power/Cable! Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:41 Reconnect Power/Cable! Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Open port error , something went wrong! Boot Error! Operation Failed Elapsed: 00:00:24 Reconnect Power/Cable! Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:42 Reconnect Power/Cable! Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 3701FF454D4330384710F60007E01371 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x37 , OEM : 01FF [eMMC] : FLASH_INF : [NOT_IN_BASE] , G80CM [eMMC] : FLASH_CID : 3701FF454D4330384710F60007E01371 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001CD000000 [eMMC] : FLASH_UCP : 7376 MiB [eMMC 8 GiB] DEV RID : 0x4B1992B1185631ABF7039C38198C7DC7 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : TT ProdName : Typhoon-T2 ProdModel : Typhoon-T2 Device : T2 AndroidVer: 5.1 MTKxCPU : MT6580 MTKxPRJ : ALPS.L1.MP6.V2_YUANDA6580.WE.L [Read Ok] : preloader_yuanda6580_we_l.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6580 / V1.1.2 / yuanda6580_we_l / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 1393 MiB Scatter saved to : C:\Users\Abdallah\Documents\MT6580__TT__Typhoon-T2__T2__5.1__ALPS.L1.MP6.V2_YUANDA6580.WE.L\ All done! Done! Elapsed: 00:12:12 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 3701FF454D4330384710F60007E01371 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x37 , OEM : 01FF [eMMC] : FLASH_INF : [NOT_IN_BASE] , G80CM [eMMC] : FLASH_CID : 3701FF454D4330384710F60007E01371 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001CD000000 [eMMC] : FLASH_UCP : 7376 MiB [eMMC 8 GiB] DEV RID : 0x4B1992B1185631ABF7039C38198C7DC7 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:01:39 Reconnect Power/Cable! |
07-21-2017, 20:02 | #43709 (permalink) |
No Life Poster Join Date: Dec 2005 Location: mt brazil
Member: 211017 Status: Offline Thanks Meter: 312 | Remove FRP Moto G3 Operation : Enable ADB (Moto) [ v1.0 ] Waiting for NetInterface arrival ... 1. Power off device. Press and hold 'VOL DOWN' and 'POWER ON' buttons 2. Select by 'VOL DOWN' or 'VOL UP' FACTORY MODE , press 'POWER ON' 3. Connect USB cable, when device boot complete! Connect Ok! Waiting ... Trying link with : 192.168.137.2 Connected to device! Device : XT1543 VerInfo : OSPREY_DSTV_CUST Version : Blur_Version.24.221.16.osprey_retla_ds.retla.en.01 Enabling ADB ... 1. Disconnect cable from device, press and hold 'VOLUME_DOWN' and 'POWER_ON' 2. Select 'FACTORY MODE' and press 'POWER ON'! 3. Wait for device boot completely! Done! Elapsed: 00:00:09 Operation : Reset FRP (ADB) [ v1.0 ] Waiting for device in ADB mode ... 1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need! 2. Insert USB cable, accept AUTH on PhoneScreen, if software ask! Connect Ok! Device : osprey_retla_ds Model : MotoG3 FRP reset passed! Make FACTORY RESET from menu! Done! Elapsed: 00:00:11 |
07-22-2017, 06:32 | #43710 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile I7i SPD77xx XXX Virous Remove Done By Flashing With Infinity CM2 Loading : QMobile_i7i_MP_31_10.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC77xx PacVersion : QMobile_i7i_MP_29_10 FastCheck : 0x004CE01FF1 Loading files ... File : fdl1.bin File : fdl2.bin File : nvitem.bin File : nvitem_wcn.bin File : u-boot-spl-16k.bin File : SC7702_sc7731g_band128.bin File : DSP_DM_G2.bin File : SC8800G_x30g_wcn_dts_modem.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : LOGO.bmp File : charge.bmp File : prodnv.img File : cache.img File : u-boot.bin File : SC7731_UMS.xml Load Ok! Operation : Flash [ v1.27 ] ======= Flash Files set for flashing : [ MCU ] : QMobile_i7i_MP_31_10.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC77xx PacVersion : QMobile_i7i_MP_29_10 File : fdl1.bin File : fdl2.bin File : nvitem.bin File : nvitem_wcn.bin File : u-boot-spl-16k.bin File : SC7702_sc7731g_band128.bin File : DSP_DM_G2.bin File : SC8800G_x30g_wcn_dts_modem.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : LOGO.bmp File : charge.bmp File : prodnv.img File : cache.img File : u-boot.bin 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 16 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x17 records PMTManager : PMT Update Ok! Flashing now [FlashProc] : ERASE Current ID : ERASEUBOOT Current Part : uboot [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : SPLLOADER Current File : u-boot-spl-16k.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_W Current File : SC7702_sc7731g_band128.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DSP_W Current File : DSP_DM_G2.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_WCN Current File : SC8800G_x30g_wcn_dts_modem.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOT Current File : boot.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : RECOVERY Current File : recovery.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : SYSTEM Current File : system.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : USERDATA Current File : userdata.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOTLOGO Current File : LOGO.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : FASTBOOT_LOGO Current File : charge.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH Current Part : wruntimenv1 [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH_WCN Current Part : wcnruntimenv1 [FlashProc] : Ok! [FlashProc] : CODE Current ID : PRODNV Current File : prodnv.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : CACHE Current File : cache.img Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEMISC Current Part : misc [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : UBOOTLOADER Current File : u-boot.bin Flashing now ... [FlashProc] : Ok! Elapsed: 00:02:46 Reconnect Power/Cable! |
