07-22-2017, 07:28 | #43711 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile M250 MT6261 Logo Hang Recover Done By Formate With Infinity CM2 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 20 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 142F6B6575DECD92E68DF3259ED88ED4 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09 [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Executing FFS FORMAT now... FAT_RANGE : 0x003B4000-0x003FDFFF , LEN : 0x0004A000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:09 Reconnect Power/Cable! |
07-22-2017, 07:58 | #43712 (permalink) |
Insane Poster Join Date: Jun 2011 Location: Algeria
Member: 1600534 Status: Offline Thanks Meter: 25 | read info condor G4 Code: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 21 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 1501005138585341420621D6E48BA287 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BASX8 [eMMC] : FLASH_CID : 1501005138585341420621D6E48BA287 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x499207F5749129F1C547AA14512F6732 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : condor ProdName : PGN513 ProdModel : PGN513 Device : PGN513 AndroidVer: 5.1 MTKxCPU : MT6580 MTKxPRJ : WBW5613AC_0203_T5282 SECURITY : IMEI_SW [1] : 353444074836605 IMEI_SW [2] : 353444076136608 BTMAC Addr : B898F73207D0 WiFi MAC : 9492BC145C2C MODEM : BaseBand : MT6580_S00_MOLY_WR8_W1449_MD_WG_MP_V6_P8_1_wg_n EXTRA : LCD : Not info available :( LCD Res : 1280x720 TOUCH [0] : GT1XX CAM [0] : gc0310_yuv CAM [1] : imx179_mipi_raw CAM [2] : ov5670_mipi_raw MODEM : gionee6580_we_l_hspa gionee6580_we_l_gprs LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES Done! Elapsed: 00:00:18 Reconnect Power/Cable! Code: Operation : Read Pattern/DP Lock [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 21 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 1501005138585341420621D6E48BA287 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BASX8 [eMMC] : FLASH_CID : 1501005138585341420621D6E48BA287 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x499207F5749129F1C547AA14512F6732 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! USBDL : Init HSUSB Ok Reading data ... Get Locks ... PatternLock Sequnce : 421536987 Done! Elapsed: 00:00:33 Reconnect Power/Cable! Code: Operation : Clear UserLocks [Pin/Pwd/Pattern/FVLock/GoogleAcc] [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 21 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 1501005138585341420621D6E48BA287 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BASX8 [eMMC] : FLASH_CID : 1501005138585341420621D6E48BA287 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x499207F5749129F1C547AA14512F6732 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! USBDL : Init HSUSB Ok LSSDB Ok! LSSWL Ok! LSSSH Ok! LSSGS Ok! Security Settings : Clear Ok! [Info] : That feature NOT RESET "PRIVACY PASSWORD LOCK"! Use separate button! [Info] : That feature NOT RESET "FRP/GoogleLOCK"! Use separate "FRP" reset! [Info] : If phone stuck on "Logo" : 1. Wait 2-3 minutes. Power Off phone by long press "Power" button 2. Power On phone again 3. Or wait up to 3-7 minutes, until phone start by itself 4. Also recommended reboot phone twice before start use it Done! Elapsed: 00:00:29 Reconnect Power/Cable! |
07-22-2017, 08:05 | #43713 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | QMobile A290 Write Factory Firmware Done :) Code: Scatter Load Ok , BaseBand : MT6572 , Project : s5201ap , Storage : EMMC Files found : 11 , Set to Flash : 10 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : QMobile Device Model : QMobile A290 Device CPU : MT6572 Device IntName : QMobile A290 Device Version : 4.4.2 Device Compile : 11/24/2014 4:40:27 AM Device Project : ALPS.KK1.MP7.V1 Device ExtInfo : QMobile A290 Ready to Flash! Start at : [7/22/2017 / 10:16:29 AM] Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 220 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040508A27F07325B Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x20000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040508A27F07325B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0x2BFA537DA3022F9A714BDCFD877074D9 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : s5201ap , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled Switching to HSUSB HSUSB Init Ok BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3594 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000000E5E00000 Flash Pre-Erase Done, time used : 00:00:02 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_s5201ap.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : FFFFFFFF PartErr : Not initialized , will update PMT now ... Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:02:34 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:45 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:50 Reconnect Power/Cable! |
07-22-2017, 08:16 | #43714 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile I SPD77xx Logo HAng Recover By Flashing With Infinity CM2 Card found: S/N : A19EC787 , v0136 Chinese Miracle II [SPD module] v 1.27 Set mode to : SP [SC773x] eMMC [Android 5.x] Loading : QMobilei4_MP_20150721.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC7731_UMS PacVersion : QMobilei4_MP_20150721 FastCheck : 0x00408D81BA Loading files ... File : fdl1.bin File : fdl2.bin File : nvitem.bin File : nvitem_wcn.bin File : u-boot-spl-16k.bin File : SC7702_sc7731g_band128.bin File : DSP_DM_G2.bin File : SC8800G_x30g_wcn_dts_modem.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : LOGO.bmp File : charge.bmp File : prodnv.img File : cache.img File : u-boot.bin File : SC7731_UMS.xml Load Ok! Operation : Flash [ v1.27 ] ======= Flash Files set for flashing : [ MCU ] : QMobilei4_MP_20150721.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC7731_UMS PacVersion : QMobilei4_MP_20150721 File : fdl1.bin File : fdl2.bin File : nvitem.bin File : nvitem_wcn.bin File : u-boot-spl-16k.bin File : SC7702_sc7731g_band128.bin File : DSP_DM_G2.bin File : SC8800G_x30g_wcn_dts_modem.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : LOGO.bmp File : charge.bmp File : prodnv.img File : cache.img File : u-boot.bin 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 16 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x18 records PMTManager : PMT Update Ok! Flashing now [FlashProc] : ERASE Current ID : ERASEUBOOT Current Part : uboot [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : SPLLOADER Current File : u-boot-spl-16k.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_W Current File : SC7702_sc7731g_band128.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DSP_W Current File : DSP_DM_G2.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_WCN Current File : SC8800G_x30g_wcn_dts_modem.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOT Current File : boot.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : RECOVERY Current File : recovery.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : SYSTEM Current File : system.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : USERDATA Current File : userdata.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOTLOGO Current File : LOGO.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : FASTBOOT_LOGO Current File : charge.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH Current Part : wruntimenv1 [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH_WCN Current Part : wcnruntimenv1 [FlashProc] : Ok! [FlashProc] : CODE Current ID : PRODNV Current File : prodnv.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : CACHE Current File : cache.img Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEMISC Current Part : misc [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASESD Current Part : internalsd [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : UBOOTLOADER Current File : u-boot.bin Flashing now ... [FlashProc] : Ok! Elapsed: 00:09:59 Reconnect Power/Cable! |
07-22-2017, 08:38 | #43715 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | ZTE Warid E7+ MT6582 Warid Logo Remove Done With Flashing With Infinity CM2 Scatter Load Ok , BaseBand : MT6582 , Project : e7 , Storage : EMMC Files found : 12 , Set to Flash : 11 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : alps Device Model : e7 Device CPU : MT6582 Device IntName : e7 Device Version : 4.4.2 Device Compile : 7/9/2014 6:53:11 AM Device Project : E7.V2.13 Device ExtInfo : E7+ Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 26 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 15010038574D42335201B2C362635199 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , R3BMW [eMMC] : FLASH_CID : 15010038574D42335201B2C362635199 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xD9C8F39548DB2E871AE105AE3557423F INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6582 , Project : e7 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : Only one records found, and determined as universal BL : eMMC supported by BootLoader! BL : BatteryLevel : 3914 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000001400000-0x0000000000100000 Erase : 0x0000000003100000-0x00000001CE280000 Flash Pre-Erase Done, time used : 00:00:04 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_e7.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0014 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : EBR2 Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:02:24 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : EBR2 Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:05 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:02:49 Reconnect Power/Cable! |
07-22-2017, 10:00 | #43716 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | Oppo F3 CPH 1609 Pattern Lock Remove Hello everyone chines friend created and given me oppo f3 cph 1609 tool i successfully remove pattern lock,hang on logo,flashing and successfully backup nv data |
07-22-2017, 10:28 | #43717 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | QMobile I7i format repair done via SVC mode :) Code: Operation : Format File System / Reset Settings [ v1.25 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 222 ] Port Opened Sync... InitSvc Done Wait for phone... Sync... Init Ok , reset settings ... Format Ok! Done |
07-22-2017, 10:31 | #43718 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | QMobile K160 Read User Code Done :) Code: Operation : Read User Code [ v1.25 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 40 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 •B lBoot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Check data... Can take some time User Code : 87654321 Done! Elapsed: 00:00:08 Reconnect Power/Cable! |
07-22-2017, 11:00 | #43719 (permalink) |
Freak Poster Join Date: Apr 2015 Location: maroc Age: 38
Member: 2373850 Status: Offline Sonork: himo Thanks Meter: 60 | oppo a37f formate one click Operation : Reset Settings [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 2447A22C ID_BLOCK_I : 007050E1 ID_BLOCK_L : B94B21DD78E6131EC9BE56BF78C3537B ID_BLOCK_L : 0271DF6E63F25CE9ECCB8C454FA6B09B Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
07-22-2017, 11:26 | #43720 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Samsung Clone S7562 Hang Logo Recover Done By Formate With Infinity CM2 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 26 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1501004E3958524D42007B5C18F29197 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMRX9 [eMMC] : FLASH_CID : 1501004E3958524D42007B5C18F29197 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x0000000070000000 [eMMC] : FLASH_UCP : 1792 MiB [eMMC 2 GiB] DEV RID : 0xD9C8F395E485E422F6FC58B60EFB4E8F INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
07-22-2017, 13:15 | #43721 (permalink) |
Major Poster Join Date: Jan 2017 Location: Pakistan Age: 30
Member: 2669080 Status: Offline Sonork: 100.1688344 Thanks Meter: 33 | Qmobile X32 V3 Frp Reset Done With Great CM2 Qmobile X32 V3 Frp Reset Done With Great CM2 Code: Set mode to : SP [SC773x] eMMC [Android 6.x] Operation : Format File System / Reset Settings [ v1.26 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 37 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x000000012ABF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:26 Reconnect Power/Cable! Br AMS2762 |
07-22-2017, 13:18 | #43722 (permalink) |
Member: 2669080 Status: Offline Sonork: 100.1688344 Thanks Meter: 33 | Extreme Ex7102 Pattern Reset Done One Click With Great CM2 Extreme Ex7102 Pattern Reset Done One Click With Great CM2 Code: Chinese Miracle II [SPD module] v 1.26 Set mode to : SP [SC773x] eMMC [Android 5.x] Operation : Format File System / Reset Settings [ v1.26 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 37 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x000000015FBF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:26 Reconnect Power/Cable! Br AMS2762 |
The Following User Says Thank You to AMS2762 For This Useful Post: |
07-22-2017, 13:20 | #43723 (permalink) |
Member: 2669080 Status: Offline Sonork: 100.1688344 Thanks Meter: 33 | Qmobile ECO100 Read Flash File Done With Great CM2 Qmobile ECO100 Read Flash File Done With Great CM2 Code: Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 57 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : DE6EA815043A68FBE1F9AE34CFEEBB17 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Reading Flash Content now ... Read Flash now Read Ok , 4194304 bytes read Check and collect compile info File_Info : RDR61D_F118_PCB01_gprs_MT6261_S00.A605_QMOBILE_ECO100_V09_20170408.bin FileVersion : A605_QMOBILE_ECO100_V09_20170408 Saved to : C:\InfinityBox\CM2MTK\Read_out\RDR61D_F118_PCB01_gprs_MT6261_S00.A605_QMOBILE_ECO100_V09_20170408.bin Done! Elapsed: 00:00:30 Reconnect Power/Cable! Br AMS2762 |
07-22-2017, 13:27 | #43724 (permalink) |
Freak Poster Join Date: Jul 2007 Location: Rawalpindi Pakistan Age: 37
Member: 541180 Status: Offline Sonork: 100.1626680 Thanks Meter: 147 | OPPO X9076 PATTERN READ DONE WITH CM2 Code: Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.14 Operation : Read PatternLock [ v1.14 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 801 [MSM8974] ID_BLOCK_S : 0B9E8870 ID_BLOCK_I : 007B40E1 ID_BLOCK_L : 758FE511BC2A57520D6292F33C078FBF ID_BLOCK_L : 7508B6191A8535BE53A2F72C26C9E7E4 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8974 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0001C000/00020000/00001000/00001000/00000000 Boot Ok! Read Ok! Trying decrypt ... PatternLock sequence : 753289 Done! Elapsed: 00:00:22 Reconnect Power/Cable! OPPO X9076 FIRMWARE READ DONE WITH CM2 Code: Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.14 Operation : Read Flash [ v1.14 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 801 [MSM8974] ID_BLOCK_S : 0B9E8870 ID_BLOCK_I : 007B40E1 ID_BLOCK_L : 758FE511BC2A57520D6292F33C078FBF ID_BLOCK_L : 7508B6191A8535BE53A2F72C26C9E7E4 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8974 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0001C000/00020000/00001000/00001000/00000000 Boot Ok! Brand : OPPO Device : FIND7 AndroidVer: 4.3 SWVersion : FIND7WX_12.A.14_INT_014_150407 Manufact. : OPPO QLMxCPU : MSM8974 DevInfo : MSM8974__OPPO__OPPO__ANDR_v4.3__FIND7__FIND7WX_12.A.14_INT_014_150407 Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sbl1.mbn [Read Ok] : dbi.mbn [Read Ok] : ddr.bin [Read Ok] : emmc_appsboot.mbn [Read Ok] : rpm.mbn [Read Ok] : boot.img [Read Ok] : tz.mbn [Read Ok] : pnvbak.img [Read Ok] : system.img [Read Ok] : userdata.img [Read Ok] : persist.img [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : misc.img [Read Ok] : lsplash.img [Read Ok] : driver.iso [Read Ok] : reserve4.bin [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8974 / eMMC Firmware Size : 1507 MiB Done! Elapsed: 00:03:42 Reconnect Power/Cable! OPPO X9076 SECURITY BACKUP DONE WITH CM2 Code: Operation : EDL Security Operation [ v1.14 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 801 [MSM8974] ID_BLOCK_S : 0B9E8870 ID_BLOCK_I : 007B40E1 ID_BLOCK_L : 758FE511BC2A57520D6292F33C078FBF ID_BLOCK_L : 7508B6191A8535BE53A2F72C26C9E7E4 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8974 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0001C000/00020000/00001000/00001000/00000000 Boot Ok! Backup Security Partitions Backup : FSG Backup : MODEMST1 Backup : MODEMST2 Backup saved to : C:\InfinityBox\CM2QLM\Backup\MSM8974_[007B40E1]_0B9E8870_SEC\ Done! Elapsed: 00:00:15 Reconnect Power/Cable! BR Qaiser Jameel Skype PKUNLOCK.COM |
07-22-2017, 13:36 | #43725 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | Infinity Chinese Miracle-2 QLM/QLM MODULE v1.14 Successfully REMOVE PATTERN LOCK(MICROMAX Q400)USB 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 00918770 ID_BLOCK_I : 009600E1 ID_BLOCK_L : 758FE511BC2A57520D6292F33C078FBF ID_BLOCK_L : 483B852429B822A32691FA3331FCEAD1 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:24 Reconnect Power/Cable! THANKS INFINITY-BOX TEAM |
