12-15-2017, 21:01 | #46996 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Operation : Check / Read Info [ v1.58 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 14 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 110100303034473930514D58E2E571E5 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 09G40 [eMMC] : FLASH_CID : 110100303034473930514D58E2E571E5 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0xDEC55C3775723017BE0004F542E0B3BE INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : MTN ProdName : MTN-S720i ProdModel : MTN-S720i Device : MTN-S720i AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1.7 SECURITY : IMEI_SW [1] : 359767052724110 IMEI_SW [2] : 359767052930113 BTMAC Addr : BCE59F237D6F WiFi MAC : 509B93C8922C MODEM : BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V47_P5_1_wg_n EXTRA : LCD [0] : ili9806e_wvga LCD [1] : otm8019a_wvga LCD Res : 800x480 TOUCH [0] : ft5206 CAM [0] : sp2529_mipi_yuv CAM [1] : gc0329_yuv MODEM : HSPA_900_2100_BAND_1_8_EPSK_MTN_21R_S720i_NRLY LOCALE : en_US es_ES es_US fr_FR pt_BR pt_PT zh_CN zh_TW Done! Elapsed: 00:00:16 Reconnect Power/Cable! Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 14 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 110100303034473930514D58E2E571E5 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 09G40 [eMMC] : FLASH_CID : 110100303034473930514D58E2E571E5 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0xDEC55C3775723017BE0004F542E0B3BE INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:32 Reconnect Power/Cable! Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 14 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 110100303034473930514D58E2E571E5 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 09G40 [eMMC] : FLASH_CID : 110100303034473930514D58E2E571E5 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0xDEC55C3775723017BE0004F542E0B3BE INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... Brand : MTN ProdName : MTN-S720i ProdModel : MTN-S720i Device : MTN-S720i AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1.7 [Read Ok] : preloader_mtn.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6572 / V1.1.1 / mtn / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 798 MiB Scatter saved to : C:\Users\Yuslam Unique\Desktop\SP Backup\MT6572__MTN__MTN-S720i__MTN-S720i__4.4.2__ALPS.KK1.MP7.V1.7\ All done! Done! Elapsed: 00:04:26 Reconnect Power/Cable! |
The Following User Says Thank You to Yusuf Lawal For This Useful Post: |
12-16-2017, 05:41 | #46997 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Maxx Turbo Music SPD6531 Illegal use only Fix Done Only Formate With Infinity CM2 Card found: S/N : A19EC787 , v0136 Chinese Miracle II [SPD module] v 1.27 Set mode to : SPD6531 Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 101 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0040 0016 0000 [0] Flash VEN : Winbond , W25Q32 [0] Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:14 Reconnect Power/Cable! |
The Following User Says Thank You to azhergoga007 For This Useful Post: |
12-16-2017, 05:52 | #46998 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Rivo Rx280 MT6580 FRP Reset Done With King Infinity CM2 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100464A323541420238CED84773AD Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BA52J [eMMC] : FLASH_CID : 150100464A323541420238CED84773AD [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F395F0BA83ECB73D8C023D3FC17A INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:30 Reconnect Power/Cable! |
12-16-2017, 08:39 | #46999 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | OPPO A57 CPH1701 PATTERN LOCK & FRP REMOVE Done SUCCESSFULLY REMOVE PATTERN LOCK & FRP(OPPO A57 CPH1701)USB LOG REPORT THANKS INFINITY-BOX TEAM |
The Following 3 Users Say Thank You to gracy_elec For This Useful Post: |
12-16-2017, 08:49 | #47000 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile X30 MT6572 Dead Set Recover Done With Flashing With Infinity CM2 Card found : S/N : A19EC787 , v0136 Chinese Miracle II [MTK module] v 1.58 Scatter Load Ok , BaseBand : MT6572 , Project : s4050ap , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483447326111011B882C6762F5 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A483447326111011B882C6762F5 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F3954017A990641101A7C7E105A0 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : s4050ap , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3575 mV BL : [WARNING] : BatteryLevel LOW!!! BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000000E5E00000 Flash Pre-Erase Done, time used : 00:00:18 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_s4050ap.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:03:02 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:40 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:04:29 Reconnect Power/Cable! |
12-16-2017, 09:08 | #47001 (permalink) |
No Life Poster Join Date: Aug 2009 Location: madhya pradesh
Member: 1091455 Status: Offline Sonork: qq 2250871952 Thanks Meter: 769 | mi 4x patan remove done Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 435 [MSM8940] ID_BLOCK_S : 6FC37A7E ID_BLOCK_L : 90D94A68D4D305587973DD881C8E0E41 ID_BLOCK_L : 8D6B01A07746409E5920E1E4930BD78A Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000E8F800000 [ eMMC 64 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RH64AB Boot Ok! Format USER ... Format CACHE ... Format Ok! Done! Elapsed: 00:00:13 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to wasim786mansure For This Useful Post: |
12-16-2017, 10:58 | #47002 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile I7i Pro SPD77xx Dead Set ReAlive DOne By Flashing With Infinity CM2 Phone found! [ 90 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL Boot failed! Boot Ver : Spreadtrum Boot Block version 1.1 Boot failed! Reconnect Power/Cable! CRVersion : BP_R1.0.0 PacCPUinfo : SC77xx PacVersion : QMobile_i7i_PRO_MP_05_09 FastCheck : 0x009F8D9A99 Loading files ... File : fdl1.bin File : fdl2.bin File : nvitem.bin File : nvitem_wcn.bin File : prodnv.img File : u-boot-spl-16k.bin File : SC7702_pike_modem_AndroidM_mir_balun.dat File : DSP_DM_G2.bin File : SC8800G_pike_wcn_dts_modem.bin File : boot.img File : recovery.img File : system.img File : persist.img File : sysinfo.img File : userdata.img File : LOGO.bmp File : CHARGE.bmp File : cache.img File : u-boot.bin File : SC7720_UMS.xml Load Ok! Operation : Flash [ v1.27 ] ======= Flash Files set for flashing : [ MCU ] : X50129QM-V4ENG.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC77xx PacVersion : QMobile_i7i_PRO_MP_05_09 File : fdl1.bin File : fdl2.bin File : nvitem.bin File : nvitem_wcn.bin File : prodnv.img File : u-boot-spl-16k.bin File : SC7702_pike_modem_AndroidM_mir_balun.dat File : DSP_DM_G2.bin File : SC8800G_pike_wcn_dts_modem.bin File : boot.img File : recovery.img File : system.img File : persist.img File : sysinfo.img File : userdata.img File : LOGO.bmp File : CHARGE.bmp File : cache.img File : u-boot.bin 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 90 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x19 records PMTManager : PMT Update Ok! Flashing now [FlashProc] : CODE Current ID : PRODNV Current File : prodnv.img Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEUBOOT Current Part : uboot [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : SPLLOADER Current File : u-boot-spl-16k.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_W Current File : SC7702_pike_modem_AndroidM_mir_balun.dat Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DSP_W Current File : DSP_DM_G2.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_WCN Current File : SC8800G_pike_wcn_dts_modem.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOT Current File : boot.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : RECOVERY Current File : recovery.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : SYSTEM Current File : system.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : PERSIST Current File : persist.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : SYSINFO Current File : sysinfo.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : USERDATA Current File : userdata.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOTLOGO Current File : LOGO.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : FASTBOOT_LOGO Current File : CHARGE.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH Current Part : wruntimenv1 [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH_WCN Current Part : wcnruntimenv1 [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : CACHE Current File : cache.img Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEMISC Current Part : misc [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : UBOOTLOADER Current File : u-boot.bin Flashing now ... [FlashProc] : Ok! Elapsed: 00:09:45 Reconnect Power/Cable! |
12-16-2017, 13:21 | #47003 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Oppo A37W FRP Reser Done With King Infinity CM2 Card found : A19EC787 , v0136 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.14 Operation : Identify [ v1.14 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Error : Fail to init protocol! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Reset Settings [ v1.14 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 25CAAF72 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 77F1EB13C22855500F64ECF13E058DBD ID_BLOCK_L : 81FC42EDEE71D96A6F4E03F8CA253318 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
12-16-2017, 14:50 | #47004 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | China M4 MT6572 Restert Probelm Fix Only Formate With Infinity CM2 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 110100303034473930101B54958D5171 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 09G40 [eMMC] : FLASH_CID : 110100303034473930101B54958D5171 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F395684A3EAEA6B7C67C7C13E48B INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:42 Reconnect Power/Cable! |
12-16-2017, 15:27 | #47005 (permalink) |
No Life Poster Join Date: Jul 2011 Location: malawi
Member: 1614640 Status: Offline Thanks Meter: 468 | GIONEE S6s FLASH FIRMWARE DONE Card found : S/N : XXXXXX , v0135 Chinese Miracle II [MTK module] v 1.58 Scatter Load Ok , BaseBand : MT6753 , Project : gionee6753_65u_m0 , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 520001154D42315889AA0742BDB2C9D2 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMB1X [eMMC] : FLASH_CID : 150100525831424D4207AA89D2C914BD [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0xD2FF4FA48D8D8C8ABB8725942DB0893E INT RAM : 0x00020000 EXT RAM : 0xC0000000 [3 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6753 , Project : gionee6753_65u_m0 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3860 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 1 Erase : 0x0000000001C80000-0x000000018E380000 Flash Pre-Erase Done, time used : 00:00:00 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_gionee6753_65u_m0.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0016 Update PMT by user request [SpecOp] : Extend UserArea Repartition Done! Use FLN Mode Processing : Flash Write Flash now : LK Image Flash Ok Flash now : BOOT Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : SECRO Image Flash Ok Flash now : TEE1 Image Flash Ok Flash now : TEE2 Image Flash Ok Flash now : SYSTEM Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USERDATA Image Flash Ok Flash Write Done, time used : 00:07:30 Processing : Verify Verify Passed : LK Verify Passed : BOOT Verify Passed : RECOVERY Verify Passed : LOGO Verify Passed : SECRO Verify Passed : TEE1 Verify Passed : TEE2 Verify Passed : SYSTEM Verify Passed : CACHE Verify Passed : USERDATA Data Verify Done, time used : 00:01:32 Update Mirror PMT [SpecOp] : Extend UserArea Update Done! Update RomInfo done Done! Elapsed: 00:09:17 Reconnect Power/Cable! |
The Following User Says Thank You to bright hlatini For This Useful Post: |
12-16-2017, 17:42 | #47006 (permalink) | |
Freak Poster Join Date: Sep 2006 Location: Gujranwala Pakistan Age: 34
Member: 357540 Status: Offline Sonork: 100.1591584 Thanks Meter: 453 | Motorola Moto E3 Power TEST REPORT DONE BY CM2 KING Quote:
JOB DONE BY HMA MOBILES | |
The Following User Says Thank You to dildadoost For This Useful Post: |
12-17-2017, 05:39 | #47007 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Shadow Clone
Member: 1357650 Status: Offline Sonork: 100.1611843 Thanks Meter: 126 | ASUS_X00ID 7.1.1 FRP Done 1st.. ASUS_X00ID 7.1.1 FRP Done Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 430 [MSM8937] ID_BLOCK_S : 22A077FD ID_BLOCK_L : 0F9BC48C4380B39C171FD003C6D520CF ID_BLOCK_L : 3DC4C98ACB7B127BFD25387803303DF2 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RX1BMB Boot Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:23 Reconnect Power/Cable! |
The Following 6 Users Say Thank You to TestCard17 For This Useful Post: |
12-17-2017, 09:00 | #47008 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile Z10 MT6537 FRP Reset Done With King Infinity CM2 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 484A01906532474112430705AB01079C Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e2GA [eMMC] : FLASH_CID : 90014A4841473265050743129C07B2AB [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB800000 [eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB] DEV RID : 0xD9C8F395D0E6744E66F1EA16A7393F14 INT RAM : 0x00020000 EXT RAM : 0xC0000000 [3 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:44 Reconnect Power/Cable! |
12-17-2017, 09:33 | #47009 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Jazz It1460 Pro MT6580 FRP Reset Done With King Infinity CM2 Card found : S/N : A19EC787 , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100464E58324D4201C783DABA3451 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM2XN [eMMC] : FLASH_CID : 150100464E58324D4201C783DABA3451 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xD9C8F39503D0BF5F265278146035FFE6 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:11 Reconnect Power/Cable! |
12-17-2017, 10:16 | #47010 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Qmobile Noir i6 Metal One Format done Set mode to : SP [SC773x] eMMC [Android 6.x] Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x0000000117FF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:29 Reconnect Power/Cable! |
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post: |
