12-20-2017, 13:39 | #47071 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 14 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0002 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM36E [eMMC] : FLASH_CID : 150100514536334D42032836F2E68453 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xDEC55C372A8B9FF65126D953C6181C00 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : TECNO ProdName : H501 ProdModel : TECNO Camon CX Device : TECNO-CX AndroidVer: 7.0 MTKxCPU : MT6755 MTKxPRJ : CX-H501DEFG-N-170829V143 [Read Ok] : preloader_rlk6750_65_n.bin [Read Ok] : recovery.img [Read Ok] : md1img.img [Read Ok] : md1dsp.img [Read Ok] : md1arm7.img [Read Ok] : md3img.img [Read Ok] : lk.bin [Read Ok] : lk2.bin [Read Ok] : boot.img [Read Ok] : logo.bin [Read Ok] : tz1.img [Read Ok] : tz2.img [Read Ok] : secro.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6755 / V1.1.2 / rlk6750_65_n / EMMC Android Info saved HWConfig Info saved FW Size : 3707 MiB Scatter saved to : C:\Users\Yuslam Unique\Desktop\SP Backup\MT6755__TECNO__TECNO_Camon_CX__TECNO-CX__7.0__CX-H501DEFG-N-170829V143\ All done! Done! Elapsed: 00:08:04 Reconnect Power/Cable! MT6755__TECNO__TECNO_Camon_CX__TECNO-CX__7.0__CX-H501DEFG-N-170829V143 |
The Following User Says Thank You to Yusuf Lawal For This Useful Post: |
12-20-2017, 14:02 | #47072 (permalink) |
Freak Poster Join Date: Aug 2017 Location: Mindanao Philippines
Member: 2752651 Status: Offline Thanks Meter: 182 | Oppo R11+ Clone Running Out Of Space Pop Up Problem Done By CM2 Code: Chinese Miracle II [MTK module] v 1.58 Start at : [12/20/2017 / 7:04:34 PM] Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8C00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : 00AD00BC00900055005400AD00BC0000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x008B , [HYNIX] H9DA4VH2GJAMCR_4EM [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0054 00AD 00BC [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/01/NIM_Px-2 DEV RID : 0xE5C818C31F6E93650BB2A89ACA7FC68D INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Done! Elapsed: 00:00:10 Reconnect Power/Cable! Finish at : [12/20/2017 / 7:04:44 PM] Code: Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8C00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : 00AD00BC00900055005400AD00BC0000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x008B , [HYNIX] H9DA4VH2GJAMCR_4EM [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0054 00AD 00BC [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/01/NIM_Px-2 DEV RID : 0xE5C818C31F6E93650BB2A89ACA7FC68D INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to meerl329 For This Useful Post: |
12-20-2017, 15:28 | #47073 (permalink) |
No Life Poster Join Date: Mar 2016 Location: Ukraine
Member: 2550141 Status: Offline Thanks Meter: 1,115 | Huawei Y6 SCL L04 Read Pattren Lock with Infinity CM2 Code: Operation : Read PatternLock [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 01CAB2D9 ID_BLOCK_L : EE164C8A25B1BEA996CB050AD5AC2424 ID_BLOCK_L : 81FC42EDEE71D96A6F4E03F8CA253318 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Read Ok! Trying decrypt ... PatternLock sequence : 1235789 Code: Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 01CAB2D9 ID_BLOCK_L : EE164C8A25B1BEA996CB050AD5AC2424 ID_BLOCK_L : 81FC42EDEE71D96A6F4E03F8CA253318 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Brand : Huawei ProdName : msm8909 ProdModel : msm8909 Device : msm8909 AndroidVer: 5.1.1 Manufact. : unknown SysPatch : LMY47V DevComTime: 08.09.2016 15:58:37 QLMxCPU : MSM8909 USERData : NORMAL GCSec : NORMAL Done! Elapsed: 00:00:12 Code: Operation : Read Flash [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 01CAB2D9 ID_BLOCK_L : EE164C8A25B1BEA996CB050AD5AC2424 ID_BLOCK_L : 81FC42EDEE71D96A6F4E03F8CA253318 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Brand : Huawei ProdName : msm8909 ProdModel : msm8909 Device : msm8909 AndroidVer: 5.1.1 Manufact. : unknown QLMxCPU : MSM8909 DevInfo : MSM8909__unknown__Huawei__ANDR_v5.1.1__msm8909__msm8909__msm8909 Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : sbl1.mbn [Read Ok] : sec.dat [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : oemdata.bin [Read Ok] : misc.img [Read Ok] : fs_gc.img [Read Ok] : NON-HLOS.bin [Read Ok] : persist.img [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : rec2.img [Read Ok] : cache.img [Read Ok] : cust.img [Read Ok] : system.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8909 / eMMC Firmware Size : 2256 MiB Done! Elapsed: 00:05:00 |
The Following User Says Thank You to localizator For This Useful Post: |
12-20-2017, 15:58 | #47074 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Balkan Age: 50
Member: 1473716 Status: Offline Thanks Meter: 1,273 | VIVAX FLY 2 FRP Reset done VIVAX FLY 2 FRP Reset done Card found : S/N : 07XXXXXX , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 97 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D33323886870042CF9C7396 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM328 [eMMC] : FLASH_CID : 150100513832334D42008786967393CF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x7FBB5333D38596660E0D7F81AE712A9F INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : VIVAX ProdName : VIVAX FLY 2 ProdModel : VIVAX FLY 2 Device : VIVAX AndroidVer: 5.1 MTKxCPU : MT6735 MTKxPRJ : FLY2_V1.15 Done! Elapsed: 00:00:08 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 97 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D33323886870042CF9C7396 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM328 [eMMC] : FLASH_CID : 150100513832334D42008786967393CF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x7FBB5333D38596660E0D7F81AE712A9F INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
12-21-2017, 02:17 | #47075 (permalink) |
Member: 2550141 Status: Offline Thanks Meter: 1,115 | Xiaomi Redmi 4A Reset MIAccount/Read Flash Done with Infinity CM2 Identify Code: Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 425 [MSM8917] ID_BLOCK_S : 95F3FFDF ID_BLOCK_L : 7F38AB87353CE4B7DE923E69FD6991A6 ID_BLOCK_L : BD3B3190277610CE8910B1B4C33BE7DA Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HAG4a2 Boot Ok! Brand : Xiaomi ProdName : rolex ProdModel : Redmi 4A Device : rolex AndroidVer: 6.0.1 Manufact. : Xiaomi SysPatch : MMB29M DevComTime: 27.09.2017 2:25:03 QLMxCPU : MSM8937 USERData : ENCRYPTED GCSec : NORMAL Code: Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 425 [MSM8917] ID_BLOCK_S : 95F3FFDF ID_BLOCK_L : 7F38AB87353CE4B7DE923E69FD6991A6 ID_BLOCK_L : BD3B3190277610CE8910B1B4C33BE7DA Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HAG4a2 Boot Ok! MIAccount reset passed! Device may relock back on WiFi/Network enable! Code: Operation : Read Flash [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 425 [MSM8917] ID_BLOCK_S : 95F3FFDF ID_BLOCK_L : 7F38AB87353CE4B7DE923E69FD6991A6 ID_BLOCK_L : BD3B3190277610CE8910B1B4C33BE7DA Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HAG4a2 Boot Ok! Brand : Xiaomi ProdName : rolex ProdModel : Redmi 4A Device : rolex AndroidVer: 6.0.1 Manufact. : Xiaomi QLMxCPU : MSM8937 DevInfo : MSM8937__Xiaomi__Xiaomi__ANDR_v6.0.1__Redmi_4A__rolex__rolex Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sbl1.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : devcfg.mbn [Read Ok] : adspso.bin [Read Ok] : ddr.bin [Read Ok] : fs_gc.img [Read Ok] : sec.dat [Read Ok] : splash.img [Read Ok] : emmc_appsboot.mbn [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : persist.img [Read Ok] : misc.img [Read Ok] : lksecapp.mbn [Read Ok] : cmnlib.mbn [Read Ok] : cmnlib64.mbn [Read Ok] : keymaster.mbn [Read Ok] : cust.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8917 / eMMC Firmware Size : 3669 MiB Done! Elapsed: 00:06:44 |
12-21-2017, 03:06 | #47076 (permalink) |
Member: 2550141 Status: Offline Thanks Meter: 1,115 | Prestigio MultiPhone Wize NV3 3537 DUO [SC7731] [Android 6] Read Info/NV Read Info Code: Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 7 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : PSP3537DUO Model Brand : Prestigio Model Device: GF50B2G AndrVersion : 6.0 BaseBand CPU: SC7731C CompileDate : 01.12.2016 2:35:41 Project Ver : PSP3537DUO.20161201.1.0.09 Model Ext : PSP3537DUO ExtraInfo : HWInfo not exists, normal phone Code: Operation : Read NV [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 7 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Detected eMMC Flash , Structure detect Ok! Read GSM NV Read WCN NV Read Ok , 0xCA53 Saved to : C:\InfinityBox\CM2SPD\phdata\backup\CX77xx_SPDNV.spdnv Code: NVM File looks Ok Operation : Write NV [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 7 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected eMMC Flash , Structure detect Ok! Write NVM Part #1 Ok! Write NVM Part #2 Ok! Clean DYNV |
12-21-2017, 03:30 | #47077 (permalink) |
Member: 2550141 Status: Offline Thanks Meter: 1,115 | Xiaomi Redmi 4A Read QCN Done with Infinity CM2 Read QCN Code: Operation : Read QCN (NVM) [ v1.16 ] 1. Enable DiagInterface on device [ by Code, Root or other way ] 2. Make sure DiagDrivers installed and work correct Wait for phone... Device Found! Initialize ... DiagMode initialized! MSMHW : 00000560 MODHW : 0000100C BUILD : MPSS.JO.1.2.c2-00092-8937_GENNS_PACK-1.103461.1.110954.1_V046 RTIME : Sep 26 201704:34:55 BTIME : Jul 27 201602:00:00 DEVST : 8937.gen Reading NVRAM data in XQCN format ... Reading NV Items... Reading NV Items SIM1... Reading NV Items SIM2... Reading RFNV... Reading Provisioning Item Files... Reading Feature_Mask... Saved as : C:\InfinityBox\CM2QLM\Backup\QCN\00000560__MPSS.JO.1.2.c2-00092-8937_GENNS_PACK-1.103461.1.110954.1_V046.xqcn Read Done! |
12-21-2017, 06:49 | #47078 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Gfive Z15 SPD6531 Logo Stuck Recover DOne By Formate With Infinity CM2 Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 101 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:08 Reconnect Power/Cable! |
12-21-2017, 07:43 | #47079 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile X30 MT6572 Dead Set Recover Done With Flashing With Infinity CM2 Card found : S/N : A19EC787 , v0136 Chinese Miracle II [MTK module] v 1.58 Scatter Load Ok , BaseBand : MT6572 , Project : s4050ap , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473261110143B6989F421D Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A4834473261110143B6989F421D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F395D55E5E70A0DA74AD5DE66A5B INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : s4050ap , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : Unknown (not supported or without battery) BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000000E5E00000 Flash Pre-Erase Done, time used : 00:00:00 SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:02:57 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:40 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:55 Reconnect Power/Cable! |
12-21-2017, 08:35 | #47080 (permalink) |
No Life Poster Join Date: Nov 2016 Location: GUJARAT
Member: 2643730 Status: Offline Thanks Meter: 1,115 | Micromax Bharat 3 (Q437) frp unlock by cm2 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 460001154D32584EFAF706427D238FDC Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM2XN [eMMC] : FLASH_CID : 150100464E58324D4206F7FADC8F447D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x10681B281E5705EF1E424FAA081D9358 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
12-21-2017, 08:51 | #47081 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Lenovo A319 MT6572 Dead set Recover Done By Flashing With Infinity CM2 Card found : S/N : A19EC787 , v0136 Chinese Miracle II [MTK module] v 1.58 Scatter Load Ok , BaseBand : MT6572 , Project : huaqin72_cwet_1a_kk , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A48344732611101E0C0952D7255 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A48344732611101E0C0952D7255 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F395F17B9A953EAB51332B3AD7F9 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : huaqin72_cwet_1a_kk , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3673 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x0000000094840000 Flash Pre-Erase Done, time used : 00:00:02 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_huaqin72_cwet_1a_kk.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:04:33 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:01:10 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:06:02 Reconnect Power/Cable! |
12-21-2017, 10:26 | #47082 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Ideoid BalrX7 MT6580 FRP/Pravices Lock Remove Done By Infinity CM2 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A48414732650507A9C0A08F5253 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e2GA [eMMC] : FLASH_CID : 90014A48414732650507A9C0A08F5253 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB800000 [eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB] DEV RID : 0xD9C8F395638072F0B6D2B102F6A561BB INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:49 Reconnect Power/Cable! Operation : Reset Privacy Lock [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A48414732650507A9C0A08F5253 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e2GA [eMMC] : FLASH_CID : 90014A48414732650507A9C0A08F5253 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB800000 [eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB] DEV RID : 0xD9C8F395638072F0B6D2B102F6A561BB INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Checking data ... Process block #1 Process block #2 Privacy Lock reset Ok! Done! Elapsed: 00:00:39 Reconnect Power/Cable! |
12-21-2017, 10:30 | #47083 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Samsung Clone J700f MT6572 FRP Teset Done With Infinity CM2 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 7001004D4D43303447020BB97E447057 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , G40CM [eMMC] : FLASH_CID : 7001004D4D43303447020BB97E447057 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E2C00000 [eMMC] : FLASH_UCP : 3628 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F39508ACF63C868FEFD1AED061CE INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:32 Reconnect Power/Cable! |
12-21-2017, 10:32 | #47084 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile M90 MT6580 Hanging Probelam Solve Only Formate With Infinity CM2 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 1501004B3758564D42017888D09EA1C1 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D42017888D09EA1C1 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xD9C8F3957B66AF1996EF6558AE297C46 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:21 Reconnect Power/Cable! |
12-21-2017, 12:15 | #47085 (permalink) |
Member: 1677653 Status: Offline Thanks Meter: 2,769 | TECNO T528 FORMAT & READ FLASH DONE Card found : S/N : A6XXXXX5 , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 13 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : C4659858CBAED58DC50D76F67BEFF04E BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C800 6000 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F4 , [GigaDevice] GD25LQ128 [0] : FLASH_DIE : 00C8 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 INT_RAM : 0x0000D000 EXT_RAM : 0x00800000 File_Info : UL281_T528_TECNO_PCB01_gprs_MT6260_S00.T528UL281A1-AF-161202V9.bin FileVersion : T528UL281A1-AF-161202V9 Done! Elapsed: 00:00:11 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 13 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : C4659858CBAED58DC50D76F67BEFF04E BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C800 6000 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F4 , [GigaDevice] GD25LQ128 [0] : FLASH_DIE : 00C8 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 INT_RAM : 0x0000D000 EXT_RAM : 0x00800000 Backup done Executing FFS FORMAT now... FAT_RANGE : 0x00DC0000-0x00FFFFFF , LEN : 0x00240000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:27 Reconnect Power/Cable! Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 13 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : C4659858CBAED58DC50D76F67BEFF04E BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C800 6000 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F4 , [GigaDevice] GD25LQ128 [0] : FLASH_DIE : 00C8 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 INT_RAM : 0x0000D000 EXT_RAM : 0x00800000 Reading Flash Content now ... Read Flash now Read Ok , 16777216 bytes read Check and collect compile info File_Info : UL281_T528_TECNO_PCB01_gprs_MT6260_S00.T528UL281A1-AF-161202V9.bin FileVersion : T528UL281A1-AF-161202V9 Saved to : C:\InfinityBox\CM2MTK\Read_out\UL281_T528_TECNO_PC B01_gprs_MT6260_S00.T528UL281A1-AF-161202V9.bin Done! Elapsed: 00:00:56 Reconnect Power/Cable! |
