10-30-2010, 08:26 | #6031 (permalink) |
No Life Poster Join Date: Jun 2007 Location: INDIA
Member: 530721 Status: Offline Thanks Meter: 157 | successfully unlocked samsung s259 successfully unlocked samsung s259 thanks to Infinity cdma tool and MEGATRON |
The Following 2 Users Say Thank You to Sandeep Mobiles For This Useful Post: |
10-30-2010, 08:29 | #6032 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Pakistan
Member: 897524 Status: Offline Sonork: 100,1609543 Thanks Meter: 172 | Successfully unlock Huawei T156 COM5 [VCP0] selected module v1.68 Device: Huawei-T156 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-static_20101030-122725.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-security_20101030-122726.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-complete_20101030-122733.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_lock-area_20101030-122752.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 65 sec Remove/Install battery now ! |
The Following User Says Thank You to gsmcrazy1 For This Useful Post: |
10-30-2010, 08:37 | #6033 (permalink) |
No Life Poster Join Date: May 2008 Location: NC, USA Age: 36
Member: 779665 Status: Offline Sonork: 100.1581784 Thanks Meter: 492 | Code: COM5 [VCP1] selected module v3.08 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:AF0F:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished ==================== New firmware detected (v.3.08, database date: 03.02.2010): V840_GEMINI_PCB01_GPRS_MT6225_S00.V940_V02.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info ver: 04 sw version: V840_GEMINI_PCB01_GPRS_MT6225_S00.V940_V02.BIN project-id: V940_V02, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: V840_GEMINI_PCB01_GPRS_MT6225_S00.V940_V02__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\V840_GEMINI_PCB01_GPRS_MT6225_S00.V940_V02__ffs_20101030-123433.B0E.bin flash: EC257E25082501:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC257E25082501:18E59F00000000 Finalization Done Finished, time used: 2 min 29 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On !] |
The Following User Says Thank You to nadirghazi For This Useful Post: |
10-30-2010, 10:10 | #6035 (permalink) |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | 6300 restart done COM6 [VCP0] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:CCD4:0927 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22022201:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E22022201:1C8DB300000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #02 in region #00... flash: 01227E22022201:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #03 in region #00... flash: 01227E22022201:1C8DB300000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #04 in region #00... flash: 01227E22022201:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #05 in region #00... flash: 01227E22022201:1C8DB300000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #06 in region #00... flash: 01227E22022201:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #07 in region #00... flash: 01227E22022201:1C8DB300000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 number of flash chip/regions detected: 08/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01227E22022201:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E22022201:1C8DB300000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #02 in region #00... flash: 01227E22022201:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 02/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.41A41207.[MV188_A_PCB01_GPRS_MT6226_S01.MV188_A_0712_FMBT_V2 0.BIN_5E51AC2D].rpl rom info detection finished device-id: 41A41207 rom info ver: 04 sw version: MV188_A_PCB01_GPRS_MT6226_S01.MV188_A_0712_FMBT_V2 0.BIN project-id: MV188_A_0712_FMBT_V20, 2DAC515E code offset: 00000000 ffs offset/size [01]: 00F00000/00100000 rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent detecting ffs/eeprom area in 2 chip(s)... standard ffs/eeprom offset detected: 00F00000 standard ffs/eeprom offset confirmed: 00F00000 detecting ffs/eeprom size... ffs/eeprom size: 00100000 ffs/eeprom chip: 01 ffs/eeprom area: 00800000:00700000-007FFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: MV188_A_PCB01_GPRS_MT6226_S01.MV188_A_0712_FMBT_V2 0__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\MV188_A_PCB01_GPR S_MT6226_S01.MV188_A_0712_FMBT_V20__ffs_20101030-140905.B0E.bin flash: 01227E22022201:2AEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E22022201:1C8DB300000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\M V188_A_PCB01_GPRS_MT6226_S01.MV188_A_0712_FMBT_V20 __system_log_41A41207_5E51AC2D_20101030-140924.B0X.bin Finished, time used: 3 min 8 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to naveedbutt For This Useful Post: |
10-30-2010, 10:25 | #6036 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Pakistan/UAE/WorldWide
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | 6303 flash done with ufs Code: registered to: mohsin Connect phone on selected interface... UFS S/N 91378 boot - Ok Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Files Set for Flashing : MCU : rm443__10.12.mcusw PPM : rm443__10.12.ppm_a CNT : rm443__10.12.image_a_is_matt_black FlashFile verify disabled Backup enabled, Will read Certificates now... Setting FlashMode 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 07E00008BA337F5622A697AA713C3A347D25B934 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok CMT Flash ID: 89820089 < INTEL => 0046L0Y1GG FLASHID : 89820089 , CMT , NOR FLCNT : 00000000000000000000000000000000 FLMCID : FFFF000000000000 Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg CMT Algo sent CMT PAPUB : E6E2AB6C2D394BC82633D2B4965E7E519E2FB25E00 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 20480 byte(s) IMEI : 353199039372340 CMT : Read CCC certificate... Cert size : 14025 byte(s) CMT : Read HWC certificate... Error while prepare, can't read certificate... :( Cert Read done! NPC Certificate saved... CCC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\infinity bb5 tool\Best\Backup\Cert\3531990393xxxxx.rpl Setting FlashMode 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 07E00008BA337F5622A697AA713C3A347D25B934 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok CMT Flash ID: 89820089 < INTEL => 0046L0Y1GG FLASHID : 89820089 , CMT , NOR FLCNT : 00000000000000000000000000000000 FLMCID : FFFF000000000000 Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg CMT Algo sent CMT PAPUB : E6E2AB6C2D394BC82633D2B4965E7E519E2FB25E00 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT select Ok Erase : Processing rm443__10.12.mcusw CMT select Ok Found 8 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x0001FFFF CMT , NOR , Area : 0x00040000 - 0x0005FFFF CMT , NOR , Area : 0x00060000 - 0x0007FFFF CMT , NOR , Area : 0x00080000 - 0x0015FFFF CMT , NOR , Area : 0x00160000 - 0x0023FFFF CMT , NOR , Area : 0x01740000 - 0x0191FFFF CMT , NOR , Area : 0x00240000 - 0x0173FFFF CMT , NOR , Area : 0x022E0000 - 0x0261FFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:01:55 Write : Processing rm443__10.12.mcusw CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [ISA+DYNSW] Total writen 1587 blocks TIME : Write time : 00:02:52 Setting FlashMode 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 07E00008BA337F5622A697AA713C3A347D25B934 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok CMT Flash ID: 89820089 < INTEL => 0046L0Y1GG FLASHID : 89820089 , CMT , NOR FLCNT : 00000000000000000000000000000000 FLMCID : FFFF000000000000 Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg CMT Algo sent CMT PAPUB : E6E2AB6C2D394BC82633D2B4965E7E519E2FB25E00 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT select Ok Erase : Processing rm443__10.12.ppm_a CMT select Ok Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01920000 - 0x022DFFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:29 Write : Processing rm443__10.12.ppm_a Total writen 399 blocks TIME : Write time : 00:00:41 Setting FlashMode 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 07E00008BA337F5622A697AA713C3A347D25B934 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok CMT Flash ID: 89820089 < INTEL => 0046L0Y1GG FLASHID : 89820089 , CMT , NOR FLCNT : 00000000000000000000000000000000 FLMCID : FFFF000000000000 Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg CMT Algo sent CMT PAPUB : E6E2AB6C2D394BC82633D2B4965E7E519E2FB25E00 Transmission mode : Dual (Ddr, TX2) Boot Done! ConvertImage: Processing rm443__10.12.image_a_is_matt_black ConvertImage: Page Size is 128K, no need convert CMT select Ok Erase : Processing rm443__10.12.image_a_is_matt_black CMT select Ok Found 2 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x02620000 - 0x029BFFFF CMT , NOR , Area : 0x029C0000 - 0x03FBFFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:02:27 Write : Processing rm443__10.12.image_a_is_matt_black Total writen 640 blocks TIME : Write time : 00:01:05 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia 6303 classic Software Info: V 10.12 08-04-10 RM-443 (c) Nokia IMEI: 3531990393xxxxx Product code: 0569445 Checking... SimLock status : SimLock Damaged!!!!! :( Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Reset LifeTimer ... Ok |
The Following 3 Users Say Thank You to Mohsin-* For This Useful Post: |
10-30-2010, 10:39 | #6037 (permalink) |
No Life Poster Join Date: Mar 2007 Location: punjab(india) Age: 45
Member: 467045 Status: Offline Sonork: 100.1603919 Thanks Meter: 1,705 | nokia 5800xm flashing done FlashFile verify disabled Files Set for Flashing : MCU : RM-356_51.0.006_prd.core.C00 PPM : RM-356_51.0.006_prd.rofs2.V22 PPM2 : RM-356_51.0.006_C01_prd.rofs3.fpsx CNT : RM-356_51.0.006_026_000_U01.uda.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006400C192101031103 EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 1230000C2C2B8B52BCF390C0B97B304E8978EF4B ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing UPDAPP... Processing PAPUBKEYS... Processing UPDAPP... Boot Done! TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 Waiting for response: 28 Waiting for response: 27 Waiting for response: 26 Waiting for response: 25 Waiting for response: 24 Waiting for response: 23 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Auth done... ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing RM-356_51.0.006_prd.core.C00 Found 5 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT Result: 0000 Erasing area 0x00400000 - 0x007FFFFF, NAND, CMT Result: 0000 Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT Result: 0000 Erasing area 0x00D60000 - 0x09E5FFFF, NAND, CMT Result: 0000 Erase partition 0x0A Partition erase Ok Partitioning : Ok [5] TIME : Erase time : 00:00:00 Write : Processing RM-356_51.0.006_prd.core.C00 Total 508 [508/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*ENO] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS+CORE] CMT : Writing Hash CERT [SOS+ROFS1] TIME : Write time : 00:00:34 MCU Write done ===Flashing [PPM]=== Erase : Processing RM-356_51.0.006_prd.rofs2.V22 Found 1 areas to erase Erasing area 0x07180000 - 0x0915FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-356_51.0.006_prd.rofs2.V22 Total 134 [134/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS2] TIME : Write time : 00:00:10 PPM Write done ===Flashing [PPM2]=== Erase : Processing RM-356_51.0.006_C01_prd.rofs3.fpsx Found 1 areas to erase Erasing area 0x09160000 - 0x09E5FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-356_51.0.006_C01_prd.rofs3.fpsx Total 11 [11/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS3] TIME : Write time : 00:00:00 PPM Write done ===Flashing [CNT]=== Erase : Processing RM-356_51.0.006_026_000_U01.uda.fpsx Found 1 areas to erase Erasing area 0x09E60000 - 0x0F71FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-356_51.0.006_026_000_U01.uda.fpsx Total 29 [29/0/0] blocks to write, writing... TIME : Write time : 00:00:02 CNT Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:00:48 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5800 XpressMusic Software Info: V ICPR72_10w21.3 23-06-10 RM-356 (c) Nokia IMEI: 357988038188947 Ape Version: V 51.0.006 Product code: 0573797 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:01:18 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
The Following 5 Users Say Thank You to JINDALGSM™ For This Useful Post: |
10-30-2010, 11:01 | #6038 (permalink) |
Member: 467045 Status: Offline Sonork: 100.1603919 Thanks Meter: 1,705 | nokia e63 fbus flashing done Files Set for Flashing : MCU : rm437_410.21.010_prd.c00 PPM : rm437_410.21.010_prd.v27 CNT : rm437_410.21.010.52U APE : RM437_ENO_008.07.45_100.71.920.a01.fpsx CNT3 : sofie_erase_y_drive.fpsx FlashFile verify disabled Backup enabled, Will read Certificates now... Setting FlashMode No answer from phone... 1. Check cable/connection, try again 2. Maybe HW fault or bad cable SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : C:\Documents and Settings\Administrator\Desktop\Best\Best\Backup\Ce rt\30_10_2010_15.rpl Setting FlashMode 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006400C192101031103 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 0AD00019B57B00527F571708F451169CB991B16E CMT MODE ID : 00 CMT R_HASH : 9A28E119033B91D14D22838C86D0D53C CMT ROM ID : 4B9B75103E691FF8 CMT : Sending 2nd loader... Use : RAPIDOv11_2nd.fg CMT Loader sent, Boot Ok CMT Flash ID: 004000EC < SAMSUNG [SEC] => KAT00F00RA [NAND] FLASHID : 004000EC , CMT , NAND FLCNT : 00000000000000000000000000000000 FLMCID : FFFF000000000000 Sending ALGO.... Use : RAPIDOv11_algo.fg CMT Algo sent CMT PAPUB : C25399C696B8549EDCDB1497A950B3A20DDFB6E000 Transmission mode : Dual (Ddr, TX2) Boot Done! Partitioning.... Partitioning Ok... CMT select Ok Erase : Processing rm437_410.21.010_prd.c00 CMT select Ok Found 3 areas to erase, erase group Asic : CMT , Sub : NAND CMT , NAND , Area : 0x00040000 - 0x007FFFFF CMT , NAND , Area : 0x00A00000 - 0x0759FFFF CMT , NAND , Area : 0x0F1C0000 - 0x0F8BFFFF Erasing, wait..... CMT : Group erase Ok Erase Partition 0x0B , CMT , NAND CMT : Partition erase Ok Erase Partition 0x09 , CMT , NAND CMT : Partition erase Ok Erase Partition 0x0A , CMT , NAND CMT : Partition erase Ok TIME : Erase time : 00:00:01 Write : Processing rm437_410.21.010_prd.c00 CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS*CORE] CMT: Writing Hash CERT [SOS+ROFS] Total writen 525 blocks TIME : Write time : 00:05:54 Setting FlashMode 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006400C192101031103 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 0AD00019B57B00527F571708F451169CB991B16E CMT MODE ID : 00 CMT R_HASH : 9A28E119033B91D14D22838C86D0D53C CMT ROM ID : 4B9B75103E691FF8 CMT : Sending 2nd loader... Use : RAPIDOv11_2nd.fg CMT Loader sent, Boot Ok CMT Flash ID: 004000EC < SAMSUNG [SEC] => KAT00F00RA [NAND] FLASHID : 004000EC , CMT , NAND FLCNT : 00000000000000000000000000000000 FLMCID : FFFF000000000000 Sending ALGO.... Use : RAPIDOv11_algo.fg CMT Algo sent CMT PAPUB : C25399C696B8549EDCDB1497A950B3A20DDFB6E000 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT select Ok Erase : Processing rm437_410.21.010_prd.v27 CMT select Ok Found 1 areas to erase, erase group Asic : CMT , Sub : NAND CMT , NAND , Area : 0x05420000 - 0x0759FFFF Erasing, wait..... CMT : Group erase Ok Erase Partition 0x09 , CMT , NAND CMT : Partition erase Ok TIME : Erase time : 00:00:00 Write : Processing rm437_410.21.010_prd.v27 CMT: Writing Hash CERT [SOS+ROFX] Total writen 200 blocks TIME : Write time : 00:02:16 Setting FlashMode 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006400C192101031103 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 0AD00019B57B00527F571708F451169CB991B16E CMT MODE ID : 00 CMT R_HASH : 9A28E119033B91D14D22838C86D0D53C CMT ROM ID : 4B9B75103E691FF8 CMT : Sending 2nd loader... Use : RAPIDOv11_2nd.fg CMT Loader sent, Boot Ok CMT Flash ID: 004000EC < SAMSUNG [SEC] => KAT00F00RA [NAND] FLASHID : 004000EC , CMT , NAND FLCNT : 00000000000000000000000000000000 FLMCID : FFFF000000000000 Sending ALGO.... Use : RAPIDOv11_algo.fg CMT Algo sent CMT PAPUB : C25399C696B8549EDCDB1497A950B3A20DDFB6E000 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT select Ok Erase : Processing rm437_410.21.010.52U CMT select Ok Erase Partition 0x08 , CMT , NAND CMT : Partition erase Ok TIME : Erase time : 00:00:01 Write : Processing rm437_410.21.010.52U Total writen 115 blocks TIME : Write time : 00:01:18 Setting FlashMode 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006400C192101031103 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 0AD00019B57B00527F571708F451169CB991B16E CMT MODE ID : 00 CMT R_HASH : 9A28E119033B91D14D22838C86D0D53C CMT ROM ID : 4B9B75103E691FF8 CMT : Sending 2nd loader... Use : RAPIDOv11_2nd.fg CMT Loader sent, Boot Ok CMT Flash ID: 004000EC < SAMSUNG [SEC] => KAT00F00RA [NAND] FLASHID : 004000EC , CMT , NAND FLCNT : 00000000000000000000000000000000 FLMCID : FFFF000000000000 Sending ALGO.... Use : RAPIDOv11_algo.fg CMT Algo sent CMT PAPUB : C25399C696B8549EDCDB1497A950B3A20DDFB6E000 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT select Ok Erase : Processing RM437_ENO_008.07.45_100.71.920.a01.fpsx CMT select Ok Erase CRTFL : SOS*ENO CMT : CRTFL erase Ok TIME : Erase time : 00:00:00 Write : Processing RM437_ENO_008.07.45_100.71.920.a01.fpsx CMT: Writing Hash CERT [SOS*ENO] Total writen 15 blocks TIME : Write time : 00:00:09 Setting FlashMode 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006400C192101031103 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 0AD00019B57B00527F571708F451169CB991B16E CMT MODE ID : 00 CMT R_HASH : 9A28E119033B91D14D22838C86D0D53C CMT ROM ID : 4B9B75103E691FF8 CMT : Sending 2nd loader... Use : RAPIDOv11_2nd.fg CMT Loader sent, Boot Ok CMT Flash ID: 004000EC < SAMSUNG [SEC] => KAT00F00RA [NAND] FLASHID : 004000EC , CMT , NAND FLCNT : 00000000000000000000000000000000 FLMCID : FFFF000000000000 Sending ALGO.... Use : RAPIDOv11_algo.fg CMT Algo sent CMT PAPUB : C25399C696B8549EDCDB1497A950B3A20DDFB6E000 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT select Ok Erase : Processing sofie_erase_y_drive.fpsx CMT select Ok Found 1 areas to erase, erase group Asic : CMT , Sub : NAND CMT , NAND , Area : 0x0F020000 - 0x0F1BFFFF Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:00 Write : Processing sofie_erase_y_drive.fpsx Total writen 0 blocks TIME : Write time : 00:00:00 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia E63 Software Info: V ICPR71_09w47.3 09-02-10 RM-437 (c) Nokia IMEI: 359319025636060 Product code: 0572527 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! AfterFlash operations done... Reconnect, wait... Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
10-30-2010, 11:04 | #6039 (permalink) |
No Life Poster Join Date: Jul 2009 Location: chandigarh INDIA
Member: 1066865 Status: Offline Thanks Meter: 593 | 5130c successfully flashed via ufs interface 5130C SUCCESSFULLY FLASHED VIA UFS INTERFACE Code: Files Set for Flashing : MCU : rm495__07.91.mcusw PPM : rm495__07.91.ppm_ed CNT : rm495__07.91_ism_003.image_ed_si_red_tmo_hr_red Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- -> Phone not found.. :( -> Error while flashing... :( FlashFile verify disabled Files Set for Flashing : MCU : rm495__07.91.mcusw PPM : rm495__07.91.ppm_ed CNT : rm495__07.91_ism_003.image_ed_si_red_tmo_hr_red Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- -> Phone not found.. :( -> Error while flashing... :( UFS S/N 80167 boot - Ok Connect phone on selected interface... Files Set for Flashing : MCU : rm495__07.91.mcusw PPM : rm495__07.91.ppm_ed CNT : rm495__07.91_ism_003.image_ed_si_red_tmo_hr_red FlashFile verify disabled Setting FlashMode 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 0B800008F7B17D562FC80EC92179AB71A2CB39E5 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok CMT Flash ID: 89820089 < INTEL => 0046L0Y1GG FLASHID : 89820089 , CMT , NOR FLCNT : 00000000000000000000000000000000 FLMCID : FFFF000000000000 Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg CMT Algo sent CMT PAPUB : 917F11196FDB7378C18EF7260698CA4489DCA02700 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT select Ok Erase : Processing rm495__07.91.mcusw CMT select Ok Found 6 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x000006BF CMT , NOR , Area : 0x000006C0 - 0x0001FFFF CMT , NOR , Area : 0x00040000 - 0x000BFFFF CMT , NOR , Area : 0x000C0000 - 0x0013FFFF CMT , NOR , Area : 0x00140000 - 0x0137FFFF CMT , NOR , Area : 0x01380000 - 0x0151FFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:01:40 Write : Processing rm495__07.91.mcusw CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] Total writen 1169 blocks TIME : Write time : 00:01:54 Setting FlashMode 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 0B800008F7B17D562FC80EC92179AB71A2CB39E5 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok CMT Flash ID: 89820089 < INTEL => 0046L0Y1GG FLASHID : 89820089 , CMT , NOR FLCNT : 00000000000000000000000000000000 FLMCID : FFFF000000000000 Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg CMT Algo sent CMT PAPUB : 917F11196FDB7378C18EF7260698CA4489DCA02700 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT select Ok Erase : Processing rm495__07.91.ppm_ed CMT select Ok Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01520000 - 0x01DBFFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:39 Write : Processing rm495__07.91.ppm_ed Total writen 443 blocks TIME : Write time : 00:00:41 Setting FlashMode 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 0B800008F7B17D562FC80EC92179AB71A2CB39E5 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok CMT Flash ID: 89820089 < INTEL => 0046L0Y1GG FLASHID : 89820089 , CMT , NOR FLCNT : 00000000000000000000000000000000 FLMCID : FFFF000000000000 Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg CMT Algo sent CMT PAPUB : 917F11196FDB7378C18EF7260698CA4489DCA02700 Transmission mode : Dual (Ddr, TX2) Boot Done! ConvertImage: Processing rm495__07.91_ism_003.image_ed_si_red_tmo_hr_red ConvertImage: Page Size is 128K, no need convert CMT select Ok Erase : Processing rm495__07.91_ism_003.image_ed_si_red_tmo_hr_red CMT select Ok Found 2 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01DC0000 - 0x0215FFFF CMT , NOR , Area : 0x02160000 - 0x03FBFFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:01:24 Write : Processing rm495__07.91_ism_003.image_ed_si_red_tmo_hr_red Total writen 832 blocks TIME : Write time : 00:01:18 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia 5130c-2 Software Info: V 07.91 29-10-09 RM-495 (c) Nokia IMEI: 355232034474536 Product code: 0573693 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Reset LifeTimer ... Ok Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following 4 Users Say Thank You to sunny_luthras99 For This Useful Post: |
10-30-2010, 11:41 | #6040 (permalink) |
No Life Poster Join Date: Jul 2007 Location: UK Age: 45
Member: 553000 Status: Offline Thanks Meter: 2,302 | Huawei-C5005 unlock done..........! SW : C5005C53B115BOOT: 6000P1B102S--------------------------------------------------------- HARDWARE: SCNRZ...* COMPILE : Jan 08 2009 REALEASE: Jun 29 2006 SW Version : QSC6030-SCNRZ-....--------------------------------------------------------- Phonce code : 0000SPC : SPC2 : 002563Finished, time used: 17 sec ------------------------------------------------------------------ COM82 [QCUSB_COM82_2] selected module v1.33 Device: Huawei-C5005 operation: SP-unlock Phone should be Switched ON ! connecting... checking version... C5005C53B115 Huawei C5005 version B115 selected.. downloading mode... wait conecting... sending command... patching in progres... patching in progres 10%... patching in progres 20%... patching in progres 30%... patching in progres 40%... patching in progres 50%... patching in progres 60%... patching in progres 70%... patching in progres 80%... patching in progres 90%... pls wait... Done... Phones should be restarting now... Finished, time used: 58 sec |
The Following 2 Users Say Thank You to kmaxmax For This Useful Post: |
10-30-2010, 11:44 | #6041 (permalink) | |
Freak Poster Join Date: Oct 2010 Location: Pakistan
Member: 1417911 Status: Offline Sonork: 100.109719 Thanks Meter: 128 | 6700 Flash Sucessfully By BB5 Easy Service Tool Here Is Logs Quote:
The Following 3 Users Say Thank You to .:Gsm_Expert:. For This Useful Post: |
10-30-2010, 11:45 | #6042 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | COM14 [VCP0] selected module v3.25 Action: reset settings ("format ffs") Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:9886:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: A381.SW.V00.03.YIDALONG Version: A381_V01_HW detecting structure #2... 1 2 3 5 7 8 9 11 13 done 80 byte(s) read imei: 35918903089718 connection Ok building list... done items to clear: 163 warning: wrong packet cs items cleared: 156 of 163 building list... done items remains: 1 Finished, time used: 1 min 7 sec Remove/Install battery now ! |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
10-30-2010, 11:46 | #6043 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | COM3 [VCP0] selected module v1.33 Device: LG-3510 operation: Repair "Blink" Phone should be Switched ON ! connecting... QSC6010-RD3510 QSC6010-RD3510 LG RD3510 selected.. erasing... done.... Finished, time used: 29 sec |
10-30-2010, 12:19 | #6044 (permalink) |
No Life Poster Join Date: Nov 2007
Member: 629860 Status: Offline Thanks Meter: 53 | R231 zte unlocked COM12 [VCP0] selected module v3.62 Action: "sp-unlock" unlock method: smart fast Model: ZTE-R231 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: E-PK-ZONG9-P107A1V1.0.0B02 Version: 08BZTENJ35_OG_08B 80 byte(s) read imei: 354xxx7560 connection Ok 186 byte(s) read reading data... reading data #2... building new data... writing data... 174 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... warning: wrong packet cs verification Ok done Finished, time used: 15 sec Remove/Install battery now ! |
The Following User Says Thank You to razisamb For This Useful Post: |
10-30-2010, 12:35 | #6045 (permalink) |
No Life Poster Join Date: Jan 2008 Location: india
Member: 681945 Status: Offline Thanks Meter: 422 | LG RD3000 BLINKING REPAIR SUCCESFULLY DONE IN FIRST ATEMPT COM2 [VCP0] selected module v1.33 Device: LG-3000 operation: Repair "Blink" Phone should be Switched ON ! connecting... Repair blink lg-3500 version 08... sending command.... fixing 1.... fixing 2.... fixing 3.... fixing 4.... fixing 5.... fixing 6.... fixing 7.... fixing 8.... fixing 9.... fixing 10.... fixing 11.... fixing 12.... fixing 13.... fixing 14.... fixing 15.... fixing 16.... fixing 17.... fixing 18.... fixing 19.... fixing 20.... done.... Finished, time used: 23 sec FIRST > USE LG 7050 RJ45 CABLE SELECT CORRECT COM PORT SELECT RD3000 MODEL PRESS REPAIR BLINKING AFTER FINISH REMOVE CABLE AND PRESS ON.. UR SET IS OUT FROM BLINKING THANKS FOR A VERY EASY METHOD FROM INFINITY CDMA TEAM WBR KAPIL GUPTA |
The Following 3 Users Say Thank You to kapilgupta For This Useful Post: |
