06-03-2020, 12:00 | #63271 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Samsuug clone a888 hang on logo done by cm2 Card found : S/N : 73CA70CC , v0143 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 1101003030344745300128D9F93F7277 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 0EG40 [eMMC] : FLASH_CID : 1101003030344745300128D9F93F7277 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0x0B9C44DE803A7EC4A1496C018A8B6DAB INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : alps ProdName : full_boway6580_weg_gm_l Device : boway6580_weg_gm_l AndroidVer: 5.1 MTKxCPU : MT6580 MTKxPRJ : ALPS.L1.MP6.V2.19_BOWAY6580.WEG.GM.L_P8 MODEM : BaseBand : MT6580_S00_MOLY_WR8_W1449_MD_WG_MP_V23_P2_1_wg_n EXTRA : LCD : Not info available LCD Res : 960x480 TOUCH [0] : gslx680 CAM [0] : ov5670_mipi_raw CAM [1] : gc2235mipi_raw CAM [2] : gc2235submipi_raw CAM [3] : sp2609_mipi_raw CAM [4] : sp2609sub_mipi_raw MODEM : a886_band1_band2_band5_co_gps_sim_hot_switch LOCALE : K_PRODUCT_LOCALES=en_US en_GB cs_CZ da_DK de_DE de_AT hr_HR lv_LV lt_LT hu_HU nl_NL nb_NO pl_PL sk_SK fi_FI sv_SE bg_BG uk_UA ar_IL ar_EG ko_KR km_KH es_US es_ES ca_ES ru_RU pt_BR fr_FR tr_TR in_ID ms_MY vi_VN th_TH pt_PT el_GR tl_PH my_MM my_ZG fa_IR iw_IL Done! Elapsed: 00:00:07 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 1101003030344745300128D9F93F7277 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 0EG40 [eMMC] : FLASH_CID : 1101003030344745300128D9F93F7277 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0x0B9C44DE803A7EC4A1496C018A8B6DAB INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:33 Reconnect Power/Cable! |
06-03-2020, 12:02 | #63272 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile l3 selfie v2 reset password done by cm2 Card found : S/N : 73CA70CC , v0143 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 4 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 252EBCFDBA21C4D9C8C457910F29482D BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00300000 SDS_INFO : 0x002FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 File_Info : FISE61M_11C_PCB01_gsm_MT6261_S00.QMOBILE_L3_SELFIE _V2_V10_28_12_18.bin FileVersion : QMobile_L3_Selfie_V2_V10_28_12_18 Done! Elapsed: 00:00:09 Reconnect Power/Cable! Operation : Reset UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 4 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 252EBCFDBA21C4D9C8C457910F29482D BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00300000 SDS_INFO : 0x002FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Read ExtData Sorting ExtData Sort Ok, Rebuild Ok Restore ExtData All done UserCode request removed UserCode set to default ( 0000 or 1122 ) Done! Elapsed: 00:00:11 Reconnect Power/Cable! |
06-03-2020, 12:09 | #63273 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | X bo v8 hang on logo done by cm2 Card found : S/N : 73CA70CC , v0143 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A2058494E594816A19F4E83308F Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , HYNIX [eMMC] : FLASH_CID : 90014A2058494E594816A19F4E83308F [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0x0B9C44DE4F9BBE4AEE446F8665B275F0 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : X-BO ProdName : V8 ProdModel : V8 Device : V8 AndroidVer: 5.1 CU_SWVer : V1.0.5 MTKxCPU : MT6580 MTKxPRJ : ALPS.L1.MP6.V2.19_HCT6580.WEG.A.L_P55 MODEM : BaseBand : MT6580_S00_MOLY_WR8_W1449_MD_WG_MP_V23_P8_1_wg_n EXTRA : LCD : Not info available LCD Res : M_HEIGHT=960xM_WIDTH=480 TOUCH [0] : STOM_KERNEL_TOUCHPANEL=gsl915 CAM [0] : STOM_HAL_IMGSENSOR=gc2385smipi_raw CAM [1] : gc2365mipi_raw CAM [2] : gc2355s_mipi_raw CAM [3] : imx190_mipi_raw CAM [4] : gc2365mmipi_raw CAM [5] : ov8825_mipi_raw CAM [6] : ov9760m_mipi_raw CAM [7] : ov9762m_mipi_raw MODEM : STOM_MODEM=hct6580_we_a_l_hspa_b1b5_coclk_RTM7289_ 2sim_hotplug_v130_NOT_CO_DECK LOCALE : K_PRODUCT_LOCALES=en_US ar_AE ar_EG fa_IR pt_BR pt_PT fr_FR ru_RU tr_TR el_GR vi_VN my_MM es_ES es_US tl_PH th_TH de_DE de_AT in_ID ms_MY zh_CN hi_IN bn_IN Done! Elapsed: 00:00:11 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A2058494E594816A19F4E83308F Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , HYNIX [eMMC] : FLASH_CID : 90014A2058494E594816A19F4E83308F [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0x0B9C44DE4F9BBE4AEE446F8665B275F0 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:31 Reconnect Power/Cable! |
06-03-2020, 12:11 | #63274 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile a300 hang on logo done by cm2 Card found : S/N : 73CA70CC , v0143 Chinese Miracle II [MTK module] v 1.58 Scatter Load Ok , BaseBand : MT6572 , Project : s7810bp , Storage : EMMC Files found : 11 , Set to Flash : 10 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : QMobile Device Model : QMobile A300 Device CPU : MT6572 Device IntName : A300 Device Version : 4.2.2 Device Compile : 12/12/2013 6:05:11 AM Device Project : ALPS.JB3.MP.V1.P65 Device ExtInfo : QMobile A300 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8C00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164048601A3602341EB Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048601A3602341EB [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F395316D3B8D816E46719C07E398 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : s7810bp , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3751 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000600000-0x0000000000100000 Erase : 0x0000000002300000-0x00000000E3E00000 Flash Pre-Erase Done, time used : 00:00:00 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_s7810bp.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0013 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:03:18 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:05 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:42 Reconnect Power/Cable! |
06-03-2020, 12:13 | #63275 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile mobile l5 classic reset password done by cm2 Card found : 73CA70CC , v0143 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.06 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] Operation : Identify [ v1.06 ] ----- > Powered On : 1. Power On device 2. Connect USB cable 3. When device show StorageMode : Press '0' button for a 5 second! ----- > Powered Off : 1. Insert USB cable 2. Wait when device show Charge icon 3. When device show StorageMode : Press '0' button for a 5 second! Wait for device ... Device Connected! BOOT_PWR0 : 0x00600000 BOOT_INIT : 0x81C0024C BOOT_MODE : DOWNLOAD Setting BOOTROM mode BOOT_MODE : BOOTROM Boot_CPU : 0x88094009 : [RDA] : RDA8851CL MEMD for flsh_spi32m Branch: none Boot_CS0 : 0x161660C8 : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] Performing MemoryInit Selecting RL Sending RL Config : MemoryInit Config : Loader BOOT_MODE : RLOADER Boot IV : 0xFBA2A2E0 Boot done! Identify : Code Integrity Check pass! Device Info Details : [0] : X9B [1] : 8809 [2] : CT8851B [3] : pasw_rda6625 [4] : flsh_spi32m [5] : gc9106/st7735r/gc9102/NV3021/gc9108/gc9104 [6] : byd3A01/gc6123/gc6113/gc6133/byd3a02serial/sp0821/pas6175/sp0829/gc6153_x [7] : rdabt_8809 [8] : rdafm_8809 [9] : 20190831Sat1634 [10] : OT_L5_Classic_HSD7735XL91049106BOE9108_BYDGDSP_EnF rArPeUd_190831 Security Info : IMEI[1] : IMEI[2] : IMEI[3] : IMEI[4] : BT_ADDR : 680058350182 inf_usb-dll:err [_usb_read_async] timeout error Done! Elapsed: 00:02:58 Reconnect Power/Cable! Operation : Reset Settings [ v1.06 ] ----- > Powered On : 1. Power On device 2. Connect USB cable 3. When device show StorageMode : Press '0' button for a 5 second! ----- > Powered Off : 1. Insert USB cable 2. Wait when device show Charge icon 3. When device show StorageMode : Press '0' button for a 5 second! Wait for device ... Device Connected! BOOT_PWR0 : 0x00600000 BOOT_INIT : 0x81C0024C BOOT_MODE : DOWNLOAD Setting BOOTROM mode BOOT_MODE : BOOTROM Boot_CPU : 0x88094009 : [RDA] : RDA8851CL MEMD for flsh_spi32m Branch: none Boot_CS0 : 0x161660C8 : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] Performing MemoryInit Selecting RL Sending RL Config : MemoryInit Config : Loader BOOT_MODE : RLOADER Boot IV : 0xFBA2A2E0 Boot done! Preparing PMT Verifying PMT Erasing 1097728 bytes FileSystem format done! Done! Elapsed: 00:01:02 Reconnect Power/Cable! |
06-03-2020, 12:33 | #63276 (permalink) |
No Life Poster Join Date: Dec 2012 Location: Khushab Punjab Pakistan
Member: 1857951 Status: Offline Sonork: 100.1638512 Thanks Meter: 261 | Ufone biometric device TPS350 Hang On Logo Done By .::Mustafa::. With infinity Cm2 Ufone biometric device TPS350 Hang On Logo Done By .::Mustafa::. With infinity Cm2 Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473165050711255D0994CD Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A4838473165050711255D0994CD [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xC3555188DC01B21D3B3D13BFA95E5D1E INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : alps ProdName : TPS350 ProdModel : TPS350 Device : simwi8321_tb_l AndroidVer: 5.1 MTKxCPU : MT6580 MTKxPRJ : ALPS.L1.MP6.V2.48.1_SIMWI8321.TB.L [Read Ok] : preloader_simwi8321_tb_l.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6580 / V1.1.2 / simwi8321_tb_l / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 1262 MiB Scatter saved to : C:\Users\Mustafakhb\Desktop\MT6580__alps__TPS350__ simwi8321_tb_l__5.1__ALPS.L1.MP6.V2.48.1_SIMWI8321 .TB.L\ All done! Done! Elapsed: 00:06:39 Reconnect Power/Cable! |
The Following User Says Thank You to .::Mustafa::. For This Useful Post: |
06-03-2020, 12:44 | #63277 (permalink) |
No Life Poster Join Date: Feb 2019 Location: Madagascar
Member: 2897012 Status: Offline Thanks Meter: 400 | WIKO WIM(i9051) frp lock reset done Code: ard found : F9XXXXXD , v0143 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 625 [MSM8953] ID_BLOCK_S : EC71C039 ID_BLOCK_E : 00007705 ID_BLOCK_L : 2F4C0389EFE4BAC79B62A6B44E6BF6FD ID_BLOCK_L : A97D83F2852B83C166AC58E85855EDF3 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8953 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000E8F800000 [ eMMC 64 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RC14MB Boot Ok! Brand : WIKO ProdName : I9051 ProdModel : WIM Device : I9051 AndroidVer: 7.1.1 Manufact. : WIM SysPatch : NMF26F DevComTime: 20/09/2017 07:08:06 QLMxCPU : MSM8953 USERData : NORMAL GCSec : NORMAL Done! Elapsed: 00:00:16 Reconnect Power/Cable! Code: Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 625 [MSM8953] ID_BLOCK_S : EC71C039 ID_BLOCK_E : 00007705 ID_BLOCK_L : 2F4C0389EFE4BAC79B62A6B44E6BF6FD ID_BLOCK_L : A97D83F2852B83C166AC58E85855EDF3 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8953 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000E8F800000 [ eMMC 64 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RC14MB Boot Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to Manikanika81 For This Useful Post: |
06-03-2020, 18:51 | #63278 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Gione m6 full format done Code: Operation : Identify [ v2.11 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM18) MODE : PRELOADER PORT PORT : 18 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT MODE : Gionee : M7 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL_CRYPTO.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 150100524836344D4205A2FCD3EC3493 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : RH64MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 457DFCC18DCBD4DB269D239FCBCD7267 DA : USB : HIGH-SPEED Boot done! Board Platform : mt6755 Build Time : 1491384559 Display ID : amigo3.5.0 Patch Level : MRA58K Product Info : gnbj6755_66_m Ver. CodeName : REL Ver. Release : 6.0 Sec. Patch : 2017-01-05 Product Board : M6 Product Brand : GIONEE Product Device : GiONEE_BBL7515A Product Manfct : GIONEE Product Model : M6 Product Name : M6 USERDATA : ENCRYPTED IMEI[0] : XXXXXXXXXXXXXXX IMEI[1] : XXXXXXXXXXXXXXX NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] STORAGE : LifeStatus : Verify NOT supported by DA/HW! Done! Elapsed: 00:00:16 Code: Operation : Reset Settings/Format FS [ v2.11 ] Mode : FULL FACTORY ( FORCED + FRP ) 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM18) MODE : PRELOADER PORT PORT : 18 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT MODE : Gionee : M7 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL_CRYPTO.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 150100524836344D4205A2FCD3EC3493 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : RH64MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 457DFCC18DCBD4DB269D239FCBCD7267 DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : PRIVACY Format Ok : USERDATA Done! Elapsed: 00:00:37 Reconnect Power/Cable! |
06-04-2020, 05:53 | #63279 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Motorolla XT1609 QLM FRP Reset Done With King Infinity CM2 Code: Card found : A19EC787 , v0143 Infinity-Box Android Service Tool [AST] v1.03 Operation : Moto ADB Enable [ v1.03 ] Mode : Enable ADB Waiting for NetInterface arrival ... 1. Power off device. Press and hold 'VOL DOWN' and 'POWER ON' buttons 2. Select by 'VOL DOWN' or 'VOL UP' FACTORY MODE , press 'POWER ON' 3. Connect USB cable, when device boot complete! Connect Ok! Waiting ... Trying link with : 192.168.137.2 Connected to device! Device : XT1609 Switching to FACTORY ... Setting Unsecure mode Waiting device ... Connect Ok! Trying link with : 192.168.137.2 Connected to device! Device : XT1609 Setting ADB ... Waiting device ... Connect Ok! Trying link with : 192.168.137.2 Connected to device! Device : XT1609 Setting ADB ... 1. Disconnect cable from device, wait device reboot 2. Make "Reset FRP" 3. Disable "FACTORY MODE" after operations done! Done! Elapsed: 00:00:37 Operation : Reset FRP (ADB) [ v1.03 ] Waiting for device in ADB mode ... 1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need! 2. Insert USB cable, accept AUTH on PhoneScreen, if software ask! Connect Ok! Device : harpia_vzw Model : XT1609 FRP reset passed! Make FACTORY RESET from menu! -- > MOTO FRP : Don't forget to DISABLE FACTORY MODE! Done! Elapsed: 00:00:13 |
06-04-2020, 08:29 | #63280 (permalink) |
No Life Poster Join Date: Apr 2011 Location: Pakistan
Member: 1555233 Status: Offline Thanks Meter: 2,192 | KING CM2 KING Nokia 105 Ta 1174 Reset Security Code Done SVC MODE without boot key Card found : A9EC786B , v0143 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.06 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] Operation : Identify [ v1.06 ] BootMode : SVC 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : SPRD ( Legacy ) ModemInfo : Platform Version: MOCOR_16A.KING_W19.40.7_Release BASE Version: BASE_SVN HW Version: SC6531EFM_BAR CMP_Time : 07-10-2019 15:56:03 SecInfo : IMEI[1] : 357XXXXXXXXXXXXX IMEI[2] : 357XXXXXXXXXXXXX IMEI[3] : 000000000000000 WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC_ID : 7FBFFFFF71F864B9 Done! Elapsed: 00:00:39 Reconnect Power/Cable! Operation : Format FileSystem [ v1.06 ] 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! Format FFS Done! Done! Elapsed: 00:00:30 Reconnect Power/Cable |
The Following 2 Users Say Thank You to amjadnona For This Useful Post: |
06-04-2020, 09:26 | #63281 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Lg ls755 hang on logo done by cm2 Card found : 73CA70CC , v0143 Infinity-Box LG Service Tool [ LGS ] v1.03 Operation : Identify [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD VOLUME UP KEY! 3. Insert USB cable, wait until Download mode screen will appear Wait for phone... Connection opened successfully! Waiting for loader ... Handshake passed! Collect info... Running : MiniOS 3.0 , ver.1.1 , with proto ver.01000004 HWInfo : BaseBand : MT6755 HWInfo : ChargeLv : 50% HWInfo : MEM_INFO : QE13MB , MEM_LEN : 0x01D1F000 [eMMC 16 GiB] DevInfo : Model : LGLS755 , Type : LS755ZVF DevInfo : ANDROID 6.0.1 DevInfo : PSN : CT01S160922004165 , PID : LGLS755WOSW5H6LD DevInfo : IMEI : 359328046833762 DevInfo : SecMode : S , Build : U , RCT : 000F4240 SWInfo : SWver : ZVF , SW : LS755ZVF_02 SWInfo : FacSW : LS755ZVF_02 RegInfo : Region : US , Provider : SPR Prepare passed, mode 0x01 Boot done! Brand : lge ProdName : mk6p55_spr_us ProdModel : LGLS755 Device : mk6p55 AndroidVer: 6.0.1 SWVersion : LGLS755AT-00-ZVF-SPR-US-AUG-06-2018+02 Manufact. : LGE LGMxCPU : MT6755 Done! Elapsed: 00:00:11 Operation : Reset Settings/Format FS [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD VOLUME UP KEY! 3. Insert USB cable, wait until Download mode screen will appear Wait for phone... Connection opened successfully! Waiting for loader ... Handshake passed! Collect info... Prepare passed, mode 0x01 Boot done! Format UserData Format Cache Format done Erase FRP#0 block Ok! Reconnect Power/Cable! Done! Elapsed: 00:00:15 |
The Following User Says Thank You to A.G.Shahid For This Useful Post: |
06-04-2020, 09:29 | #63282 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Lenovo a6000 hang on logo done by cm2 Card found : 73CA70CC , v0143 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Loading firmware ... Load Ok! Operation : Flash [ v1.16 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 1C55C4B7 ID_BLOCK_I : 007050E1 ID_BLOCK_L : CC34AEA80793988B74292B34F34EC606 ID_BLOCK_L : 0C47C96055FC6EE71AD5BE777DB0AEAD Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Files in Chain : 111 Flashing now Flashing : NON-HLOS.bin Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : hyp.mbn Flashing : hyp.mbn Flashing : splash.img Flashing : sec.dat Flashing : boot.img Flashing : system_1.img Flashing : system_2.img Flashing : system_3.img Flashing : system_4.img Flashing : system_5.img Flashing : system_6.img Flashing : system_7.img Flashing : system_8.img Flashing : system_9.img Flashing : system_10.img Flashing : system_11.img Flashing : system_12.img Flashing : system_13.img Flashing : system_14.img Flashing : system_15.img Flashing : system_16.img Flashing : system_17.img Flashing : system_18.img Flashing : system_19.img Flashing : system_20.img Flashing : system_21.img Flashing : system_22.img Flashing : system_23.img Flashing : system_24.img Flashing : system_25.img Flashing : system_26.img Flashing : system_27.img Flashing : system_28.img Flashing : system_29.img Flashing : system_30.img Flashing : persist_1.img Flashing : cache_1.img Flashing : cache_2.img Flashing : cache_3.img Flashing : cache_4.img Flashing : cache_5.img Flashing : recovery.img Flashing : userdata_1.img Flashing : userdata_2.img Flashing : userdata_3.img Flashing : userdata_4.img Flashing : userdata_5.img Flashing : userdata_6.img Flashing : userdata_7.img Flashing : userdata_8.img Flashing : userdata_9.img Flashing : userdata_10.img Flashing : userdata_11.img Flashing : userdata_12.img Flashing : userdata_13.img Flashing : userdata_14.img Flashing : userdata_15.img Flashing : userdata_16.img Flashing : userdata_17.img Flashing : userdata_18.img Flashing : userdata_19.img Flashing : userdata_20.img Flashing : userdata_21.img Flashing : userdata_22.img Flashing : userdata_23.img Flashing : userdata_24.img Flashing : userdata_25.img Flashing : userdata_26.img Flashing : userdata_27.img Flashing : userdata_28.img Flashing : userdata_29.img Flashing : userdata_30.img Flashing : userdata_31.img Flashing : userdata_32.img Flashing : userdata_33.img Flashing : userdata_34.img Flashing : userdata_35.img Flashing : userdata_36.img Flashing : userdata_37.img Flashing : userdata_38.img Flashing : userdata_39.img Flashing : userdata_40.img Flashing : userdata_41.img Flashing : userdata_42.img Flashing : userdata_43.img Flashing : userdata_44.img Flashing : userdata_45.img Flashing : userdata_46.img Flashing : userdata_47.img Flashing : gpt_main0.bin Flashing : gpt_backup0.bin Flash sequence completed! Applying patches for storage # 0 Records : 26 Patch sequence completed! BootConfig set to 0x00 Flashing done! Done! Elapsed: 00:05:16 Reconnect Power/Cable! |
06-04-2020, 11:34 | #63283 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile S8 MT6580 FRP Reset Done With King Infinity CM2 Code: Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100514531334D420DFC899A2D74B9 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM31E [eMMC] : FLASH_CID : 150100514531334D420DFC899A2D74B9 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xD9C8F395D70D38FE108F3E942DF6FB13 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:21 Reconnect Power/Cable! |
06-04-2020, 12:10 | #63284 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile s250 reset password done by cm2 Card found : S/N : 73CA70CC , v0143 Chinese Miracle II [MTK module] v 1.58 Operation : Reset UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : D45A777D2FCB4EB400C94B823DBAA6DD BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EC , [GigaDevice] GD25LQ32 [0] : FLASH_DIE : 00C8 0060 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Read ExtData Sorting ExtData Sort Ok, Rebuild Ok Restore ExtData All done UserCode request removed UserCode set to default ( 0000 or 1122 ) Done! Elapsed: 00:00:09 Reconnect Power/Cable! |
06-04-2020, 13:14 | #63285 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Moto E (4) Frp Code: Brand : motorola ProdName : woods_retail ProdModel : Moto E (4) Device : woods AndroidVer: 7.1.1 MTKxCPU : MT6737M MTKxPRJ : alps-mp-n1.mp1-V1_lenovo6737m.35.n1_P129 Done! Elapsed: 00:00:18 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 46 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 484A019061344741D44DA532DD4821A5 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , 2a4GA [eMMC] : FLASH_CID : 90014A484147346132A54DD4A52134DD [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0xD5229C253F05AB9083913CA192D024CB INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:13 Reconnect Power/Cable! |
