06-11-2020, 06:34 | #63376 (permalink) |
Freak Poster Join Date: Aug 2018 Location: bagbari bogra dhaka bangladesh
Member: 2856614 Status: Offline Sonork: 100.650600 Thanks Meter: 252 | itel p11 formate by cm2 1 click Chinese Miracle II [SPD module] v 1.27 Set mode to : SP [SC773x] eMMC [Android 6.x] Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 5 ] Port Opened Sync... Initial Boot Failed! Boot not done, reason : Wrong BootKeys Hint : Reset power and use ANOTHER BootKey ( VOL up or VOL down ) Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 5 ] Port Opened Sync... Initial Boot Failed! Boot not done, reason : Wrong BootKeys Hint : Reset power and use ANOTHER BootKey ( VOL up or VOL down ) Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 5 ] Port Opened Sync... Initial Boot Failed! Boot not done, reason : Wrong BootKeys Hint : Reset power and use ANOTHER BootKey ( VOL up or VOL down ) Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 5 ] Port Opened Sync... Initial Boot Failed! Boot not done, reason : Wrong BootKeys Hint : Reset power and use ANOTHER BootKey ( VOL up or VOL down ) Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 5 ] Port Opened Sync... Initial Boot Failed! Boot not done, reason : Wrong BootKeys Hint : Reset power and use ANOTHER BootKey ( VOL up or VOL down ) Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 5 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x000000011B0F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:23 Reconnect Power/Cable! |
The Following User Says Thank You to limonbogra For This Useful Post: |
06-11-2020, 10:04 | #63377 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Maxx t110 reset password done by cm2 Card found : 73CA70CC , v0143 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.06 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] SPRD mode : SC6531 : REV : E000 : NOR : [ 4MB ] Operation : Format FileSystem [ v1.06 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531 Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_015 CC177A22A_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
The Following User Says Thank You to A.G.Shahid For This Useful Post: |
06-11-2020, 10:05 | #63378 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Maxx g2 reset password done by cm2 Card found : 73CA70CC , v0143 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.06 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] SPRD mode : SC6531 : REV : E000 : NOR : [ 4MB ] Operation : Format FileSystem [ v1.06 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531E Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_035 B940CF947_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
06-11-2020, 10:06 | #63379 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile b65 reset password done by cm2 Card found : 73CA70CC , v0143 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.06 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] SPRD mode : SC6531 : REV : E000 : NOR : [ 4MB ] Operation : Format FileSystem [ v1.06 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531E Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_078 6FAFA9D5F_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
06-11-2020, 10:08 | #63380 (permalink) |
Freak Poster Join Date: Sep 2011 Location: Joined Infinity(dec2018)
Member: 1647864 Status: Offline Thanks Meter: 80 | Tecno CF8 SC7731C pattern and frp lock done with cm2sp2 Here is complete guide Code: Operation : Identify [ v2.04 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device … Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731x_BASE : SC7731C_eMMC_1GB_NS Sending Init Boot … Boot sent! Kick FDL … BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup … Port speed : 921600 Sending Flash Boot … Boot sent! Kick FLASH FDL … ProtoEx : : TRCC not supported! FDL : Control transfered! Boot Done! Device info : Patch Level : MRA58K Display ID : S22_HB_X5A_ZX_432_V01_20191230 Ver. Incmt : S22_HB_X5A_ZX_432_V01_20191230 Ver. CodeName : REL Ver. Release : 6.0 Sec. Patch : 2018-05-05 Build Time : 1577678448 Product Model : X5A Product Brand : HB Product Name : S22_X5A Product Device : S22_X5A Product Board : S22_X5A Product Manfct : HB Board Platform : sc8830 Product Info : S22_X5A Product Model : TECNO CF7 Product Model : TECNO CF8 Update DataBase … Platform Version: MOCORTM_14B_7731C_W16.xx.x_Debug Project Version: sc7731C_CP0_modem BASE Version: TM_BASE_W16.xx.x MMI Version: sc7731C_modem HW Version: sc7731C_CP0_modem CMP_Time : 07-04-2016 13:42:20 MODEM TAG : MOCORTM_14B_7731C_W16.xx.x_Debug_TM_BASE_W16.xx.x_sc7731C_CP0_modem_sc7731C_CP0_modem_sc7731C_modem UserData : STATE : PLAIN Code: Operation : Format FS / Reset Settings [ v2.04 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device … Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731x_BASE : SC7731C_eMMC_1GB_NS Sending Init Boot … Boot sent! Kick FDL … BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup … Port speed : 921600 Sending Flash Boot … Boot sent! Kick FLASH FDL … ProtoEx : : TRCC not supported! FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:58 |
The Following User Says Thank You to bhalaygilani For This Useful Post: |
06-11-2020, 11:35 | #63381 (permalink) |
Freak Poster Join Date: Oct 2015 Location: eArTh
Member: 2470191 Status: Offline Sonork: 100.1652036 Thanks Meter: 308 | 2 Pieces Nokia 1 Plus FRP Unlock Successfully Done Code:
06-11-2020, 13:06 | #63382 (permalink) |
No Life Poster Join Date: May 2011 Location: KPK Mardan Age: 36
Member: 1582572 Status: Offline Sonork: 100.1609641 Thanks Meter: 573 | Qmobile phantom p2 max , FRP and ETC done Boot done! Patch Level : MRA58K Display ID : MRA58K test-keys Ver. CodeName : REL Ver. Release : 6.0 Sec. Patch : 2017-03-05 Build Time : 1567591638 Product Model : PHANTOM P2 MAX Product Brand : welcome Product Name : PHANTOM_P2_MAX Product Device : PHANTOM_P2_MAX Product Manfct : welcome Board Platform : mt6570 Product Info : PHANTOM_P2_MAX MT6570__welcome__PHANTOM_P2_MAX__6.0__MRA58K__PHAN TOM_P2_MAX Read : preloader.bin Read : proinfo.img Read : nvram.bin Read : lk.bin Read : boot.img Read : recovery.img Read : logo.bin Read : md1rom.img Read : secro.img Read : system.img ExtSparse : Compression ratio : 6% Read : cache.img Read : userdata.img FW Size : 1.67 GB Android Info saved : _Android_info.txt Scatter : MT6570_Android_scatter.txt Saved to : C:\Users\shani\Desktop\206\MT6570__welcome__PHANTO M_P2_MAX__6.0__MRA58K__PHANTOM_P2_MAX\ Done! Elapsed: 00:05:41 MT6570__welcome__PHANTOM_P2_MAX__6.0__MRA58K__PHAN TOM_P2_MAX |
The Following 2 Users Say Thank You to Shani3 For This Useful Post: |
06-11-2020, 13:22 | #63383 (permalink) |
Major Poster Join Date: Sep 2019 Location: Côte d'Ivoire
Member: 2930238 Status: Offline Thanks Meter: 18 | ITEL A56 Pro (W6004P) FRP removed with CM2 SPD/UniSOC module Card found : FCxxxxx , v0143 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.05 Load IDBase v42913 Ok! Operation : Identify [ v2.05 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device not found! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.05 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Patch Level : PPR1.180610.011 Display ID : W6004P-SP591-9.0-OP-V004-20200305 Ver. Incmt : OP-V004-20200305 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2020-02-05 Build Time : 1583389673 Product Model : itel W6004P Product Brand : Itel Product Name : SP591 Product Device : itel-W6004P Product Manfct : ITEL MOBILE LIMITED Product Info : W6004P Product Board : W6004P Board Platform : sp7731e Display ID : W6004P-SP591-9.0-OP-V004-20200305 Platform Version: MOCORTM_17C_ITEL_RLS2_W19.28.5_P4_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_ITEL_RLS2_W19.28.5_P4 HW Version: sc7731e_modem CMP_Time : 10-15-2019 12:10:52 MODEM TAG : MOCORTM_17C_ITEL_RLS2_W19.28.5_P4_Debug_FM_BASE_17 C_ITEL_RLS2_W19.28.5_P4_sc7731e_modem_pike2_pub UserData : STATE : PLAIN [EXTFS] Done! Elapsed: 00:02:27 Operation : Format FS / Reset Settings [ v2.05 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:47 |
The Following 3 Users Say Thank You to m_expert For This Useful Post: |
06-12-2020, 05:42 | #63384 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Oppo r831 hang on logo done by cm2 Card found : S/N : 73CA70CC , v0143 Chinese Miracle II [MTK module] v 1.58 Scatter Load Ok , BaseBand : MT6572 , Project : OPPO72_14079 , Storage : EMMC Files found : 13 , Set to Flash : 12 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040502A24340C125 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040502A24340C125 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F3956F8062F570FD637300D7442F INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : OPPO72_14079 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled Switching to HSUSB HSUSB Init Ok BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 4033 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 4 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x0000000001A80000 Erase : 0x0000000004480000-0x0000000002000000 Erase : 0x0000000007480000-0x0000000080900000 Flash Pre-Erase Done, time used : 00:00:01 SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : FFFFFFFF PartErr : Not initialized , will update PMT now ... Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : EBR2 Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash now : FAT Image Flash Ok Flash Write Done, time used : 00:02:27 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : EBR2 Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Verify Passed : FAT Data Verify Done, time used : 00:00:15 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:05 Reconnect Power/Cable! |
06-12-2020, 05:48 | #63385 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Huawei p11 hang on logo done by cm2 Card found : S/N : 73CA70CC , v0143 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164048614001082927F Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048614001082927F [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0x9ADF21D41D43DCA9D69DC40D279AD05D INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:25 Reconnect Power/Cable! |
06-12-2020, 05:54 | #63386 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Lava grand2c hang on logo done by cm2 Card found : S/N : 73CA70CC , v0143 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 484A019065324741C5230705B10B2DC0 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e2GA [eMMC] : FLASH_CID : 90014A4841473265050723C5C02D23B1 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB800000 [eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB] DEV RID : 0x0B9C44DE4882EA7B0D2A9B9697C763ED INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Lava ProdName : Grand2c ProdModel : Grand2c Device : Grand2c AndroidVer: 6.0 MTKxCPU : MT6735 MTKxPRJ : alps-mp-m0.mp1-V2.39.1_lava6735.35u.m_P6 MODEM : BaseBand : MT6735_S00_MOLY_LR9_W1444_MD_LWTG_MP_V79_P1_1_lwg_ n EXTRA : LCD : Not info available LCD Res : 1280x720 TOUCH [0] : GT9XX CAM [0] : s5k3h7y_darling_mipi_raw CAM [1] : s5k3h7y_qtech_mipi_raw CAM [2] : s5k4h5yc_darling_mipi_raw CAM [3] : s5k4h5yc_qt_mipi_raw MODEM : lava35_sp601_65t_m_lwg LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES Done! Elapsed: 00:00:09 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 484A019065324741C5230705B10B2DC0 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e2GA [eMMC] : FLASH_CID : 90014A4841473265050723C5C02D23B1 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB800000 [eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB] DEV RID : 0x0B9C44DE4882EA7B0D2A9B9697C763ED INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:46 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to A.G.Shahid For This Useful Post: |
06-12-2020, 05:57 | #63387 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Moto xt 1609 reset frp done by cm2 Card found : 73CA70CC , v0143 Infinity-Box Android Service Tool [AST] v1.03 Operation : Moto ADB Enable [ v1.03 ] Mode : Enable ADB Waiting for NetInterface arrival ... 1. Power off device. Press and hold 'VOL DOWN' and 'POWER ON' buttons 2. Select by 'VOL DOWN' or 'VOL UP' FACTORY MODE , press 'POWER ON' 3. Connect USB cable, when device boot complete! Connect Ok! Waiting ... Trying link with : 192.168.137.2 Connected to device! Device : XT1609 Switching to FACTORY ... Setting Unsecure mode Waiting device ... Connect Ok! Trying link with : 192.168.137.2 Connected to device! Device : XT1609 Setting ADB ... Waiting device ... Connect Ok! Trying link with : 192.168.137.2 Connected to device! Device : XT1609 Setting ADB ... 1. Disconnect cable from device, wait device reboot 2. Make "Reset FRP" 3. Disable "FACTORY MODE" after operations done! Done! Elapsed: 00:00:37 Operation : Reset FRP (ADB) [ v1.03 ] Waiting for device in ADB mode ... 1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need! 2. Insert USB cable, accept AUTH on PhoneScreen, if software ask! Connect Ok! Device : harpia_vzw Model : XT1609 FRP reset passed! Make FACTORY RESET from menu! -- > MOTO FRP : Don't forget to DISABLE FACTORY MODE! Done! Elapsed: 00:00:12 Operation : Moto ADB Enable [ v1.03 ] Mode : Disable Factory Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! Operation done! Done! Elapsed: 00:00:05 |
06-12-2020, 06:11 | #63388 (permalink) |
No Life Poster Join Date: Apr 2011 Location: Pakistan
Member: 1555233 Status: Offline Thanks Meter: 2,192 | KING CM2 QMobile i7i PRO Reset FRP DONE Card found : A9EC786B , v0143 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.05 Load IDBase v42913 Ok! Operation : Identify [ v2.05 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731x_BASE : SC7731C_eMMC_1GB_NS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Patch Level : MRA58K Display ID : QMobile i7i PRO_MP_20_03 Ver. Incmt : 52 Ver. CodeName : REL Ver. Release : 6.0 Sec. Patch : 2016-10-05 Build Time : 1490005069 Product Model : QMobile i7i PRO Product Brand : QMobile Product Name : i7i_PRO Product Device : i7i_PRO Product Board : sp7731cea Product Manfct : QMobile Board Platform : sc8830 Product Info : i7i_PRO Platform Version: MOCORTM_W16.28.2_P2_Debug Project Version: sc7731C_CP0_modem BASE Version: TM_BASE_W16.28.2_P2 MMI Version: sc7731C_modem HW Version: sc7731C_CP0_modem CMP_Time : 10-12-2016 11:16:57 MODEM TAG : MOCORTM_W16.28.2_P2_Debug_TM_BASE_W16.28.2_P2_sc77 31C_CP0_modem_sc7731C_CP0_modem_sc7731C_modem UserData : STATE : PLAIN [EXTFS] Done! Elapsed: 00:01:25 Reconnect Power/Cable! Operation : Format FS / Reset Settings [ v2.05 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731x_BASE : SC7731C_eMMC_1GB_NS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:01:08 |
The Following 5 Users Say Thank You to amjadnona For This Useful Post: |
06-12-2020, 06:12 | #63389 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile l2 reset password & read flash file done by cm2 Card found : 73CA70CC , v0143 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.06 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] SPRD mode : SC6531 : REV : 0000 : NOR : [ 8MB-16MB] Operation : Identify [ v1.06 ] BootMode : FLASH 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 653x NOR v1.3(c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] IMEI[1] : IMEI[2] : Done! Elapsed: 00:00:22 Reconnect Power/Cable! Operation : Format FileSystem [ v1.06 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 653x NOR v1.3(c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_016 859629F37_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:27 Reconnect Power/Cable! Operation : Read Flash [ v1.06 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 653x NOR v1.3(c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] Read Flash Ok, Size : 4.00 MiB Project Version: SC6531_BAR MMI Version: SC6531_BAR HW Version: SC6531_BAR Saved to : G:\Mix Flash File\SC6531_BAR.bin Done! Elapsed: 00:00:46 Reconnect Power/Cable! Boot Key 2 |
The Following 3 Users Say Thank You to A.G.Shahid For This Useful Post: |
06-12-2020, 06:20 | #63390 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Vgotel s100 reset password done by cm2 Card found : 73CA70CC , v0143 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.06 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] SPRD mode : SC6531 : REV : E000 : NOR : [ 4MB ] Operation : Format FileSystem [ v1.06 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531 Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_198 C894723F1_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
