02-08-2021, 16:19 | #65851 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:27 Reconnect Power/Cable! Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483847316505073013AC1E245F Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A483847316505073013AC1E245F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x768AE2F94E55332FA7110B1FDDF6888F INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Symphony ProdName : V75 ProdModel : V75 Device : V75 AndroidVer: 6.0 MTKxCPU : MT6580 MTKxPRJ : ALPS.W10.24.p0 SECURITY : IMEI_SW [1] : 358377084427228 IMEI_SW [2] : 358377084577220 BTMAC Addr : B4C0F522B507 WiFi MAC : B4C0F5227A6F MODEM : BaseBand : MT6580_S00_MOLY_WR8_W1449_MD_WG_MP_V41_P8_1_wg_n EXTRA : LCD : Not info available LCD Res : 854x480 TOUCH [0] : ektf2k TOUCH [1] : ft6336 CAM [0] : STOM_HAL_IMGSENSOR CAM [1] : =gc0310_mipi_yuv CAM [2] : ov5670_mipi_raw_sunwin CAM [3] : ov5670_mipi_raw_cmk CAM [4] : ov5675_mipi_raw CAM [5] : gc2355_mipi_raw CAM [6] : sp2508_mipi_raw CAM [7] : hi553_mipi_raw_sunwin MODEM : STOM_MODEM =mt6580_v2800an_hspa_modem_B1_P7_sym_bd LOCALE : en_US zh_CN bn_BD ur_PK hdpi Done! Elapsed: 00:00:17 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483847316505073013AC1E245F Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A483847316505073013AC1E245F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x768AE2F94E55332FA7110B1FDDF6888F INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:33 Reconnect Power/Cable! |
02-09-2021, 05:43 | #65852 (permalink) |
Freak Poster Join Date: Aug 2004 Location: WORLDWIDE
Member: 78516 Status: Offline Thanks Meter: 62 | Oppo reno2 z cph1951 reset Code: Card found : 1E479E79 , v0147 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.21 Load IDBase v21168 Ok! Operation : Reset Settings/Format FS [ v2.21 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM88) MODE : BOOTROM PORT : 88 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 CODE : Lafite TYPE : MODERN RAPHAEL BROM : MEID : 54F9874760A59B4430C2FEE10272A222 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 1D0509C3FE4B43092B03BB156B44B8F4E63F2551141C9C41F9B4F9CC0506B955 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6779 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512,00 KB ] DRAM: 0x200000000 [ 8,00 GB ] UFS: CE014B4D3856373030314A4D2D423831 UFS: VEN : 0x01CE VID : KM8V7001JM-B81 IFW : 0900 LU0 : 0x00400000 [ 4,00 MB ] LU1 : 0x00400000 [ 4,00 MB ] LU2 : 0x1DCB000000 [ 119,17 GB ] FSN : 00330061003000390061003800370031 REG : 0x101010000 CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 2DEC48D7DCF308D376F90ACCDD7A40D5 DA : USB : HIGH-SPEED Boot done! Done! Elapsed: 00:01:58 Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.21 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM88) MODE : BOOTROM PORT : 88 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 CODE : Lafite TYPE : MODERN RAPHAEL BROM : MEID : 54F9874760A59B4430C2FEE10272A222 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 1D0509C3FE4B43092B03BB156B44B8F4E63F2551141C9C41F9B4F9CC0506B955 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6779 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512,00 KB ] DRAM: 0x200000000 [ 8,00 GB ] UFS: CE014B4D3856373030314A4D2D423831 UFS: VEN : 0x01CE VID : KM8V7001JM-B81 IFW : 0900 LU0 : 0x00400000 [ 4,00 MB ] LU1 : 0x00400000 [ 4,00 MB ] LU2 : 0x1DCB000000 [ 119,17 GB ] FSN : 00330061003000390061003800370031 REG : 0x101010000 CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 2DEC48D7DCF308D376F90ACCDD7A40D5 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x825757 Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:49 Reconnect Power/Cable! |
The Following User Says Thank You to tooko For This Useful Post: |
02-09-2021, 06:06 | #65853 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile Gli Lite SPD77xx FRP/Patrren Reset Done With King Infinity CM2 Code: Card found : A19EC787 , v0147 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.10 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.10 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_2GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0004 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:36 |
The Following User Says Thank You to azhergoga007 For This Useful Post: |
02-09-2021, 08:24 | #65854 (permalink) |
No Life Poster Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Infinix X650C Frp Remove Done With King Cm2 Operation : Reset Settings/Format FS [ v2.21 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1633 (Android) (COM4) MODE : PRELOADER PORT PORT : 4 Waiting BOOT ack ... PRELOADER : ACK confirm FAIL! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : TECNO : SECURE_v2 | Manual : Disabled BROM : SOCID : 7AAAA3EFC2076FDBF670479680B62D13E4F99DD7B358436CCC C9CB66C13A8671 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SWSEC.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 150100444436384D42026DCECAA98597 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : DD68MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : E30D5E21904D285FFF5B6AC07D958E70 DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
02-09-2021, 08:55 | #65855 (permalink) |
Junior Member Join Date: Oct 2011 Location: tongi, gazipur, bangladesh
Member: 1676530 Status: Offline Thanks Meter: 12 | meizu m3s da error...... help me please Operation : Reset Settings/Format FS [ v2.20 ] Mode : FULL FACTORY ( WIPE + FRP ) 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM43) MODE : BOOTROM PORT : 43 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : MEID : 123902DC4DAC771FCC2A86AE30D16724 BROM : SecLevel : 0x00000007 BROM : SecMode : SBC+SLA+SDA BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Meizu : M3s_M5n_U10 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00000001 : DA SEND ERROR! ERROR : BROM : DL MODE ERROR INFO : BROM Level : SLA AUTH or AUTH required! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
02-09-2021, 12:40 | #65856 (permalink) |
Freak Poster Join Date: Aug 2016 Location: pakistan
Member: 2607653 Status: Offline Sonork: family members Thanks Meter: 177 | Jazz Digit 4G Format Done Operation : Reset Settings/Format FS [ v2.21 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM21) MODE : BOOTROM PORT : 21 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN RAPHAEL BROM : MEID : C2C7FD5918D2C8E81825CAFE6A126705 BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Jazz : Digit 4G | Manual : Disabled BROM : SOCID : 5267D5292DE60EF65DDF0AAAC39E159A1DE2A9A3D9AD1AA33E 1B184883ED5382 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0002 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x20000000 [ 512.00 MB ] EMMC: 15010046355835434201E2D454C462D3 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : F5X5CB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0xE9000000 [ 3.64 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 8D49A4A2952F184D4DC98F66264EA2F DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x8C5454 Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:30 Reconnect Power/Cable! |
02-09-2021, 14:40 | #65857 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Infinix X572 Remove FRP Lock Done :) Code: Operation : Identify [ v2.21 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM7) MODE : PRELOADER PORT PORT : 7 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6753 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x02 BROM : PRELOADER PORT MODE : 0_base : BASE_v2044 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6753 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 150100475836424D420308C3CEF2BC17 DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100475836424D420308C3CEF2A417 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : GX6BMB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] CHIP : MT6753 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 9F554E5596205D11EB08D2A6B42660E3 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Patch Level : O11019 Display ID : X572-H5312CE-O-180531V117 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2018-05-05 Build Time : 30.05.2018 Product Model : Infinix X572[/LIST]Product Brand : Infinix Product Name : H5312 Product Device : Infinix-X572 Product Manfct : Infinix Product Info : Infinix-X572 Board Platform : mt6753 USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption *) IMEI[0] : 35333xx9177xxxx IMEI[1] : 35333xx9177xxxx NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] Backup sensetive data [ 15 ] Backup path : Backup\MT6753__9F554E5596205D11EB08D2A6B42660E3\ [3] Read : NVRAM [19] Read : NVDATA [2] Read : PROINFO [6] Read : LK [4] Read : PROTECT1 [5] Read : PROTECT2 [0] Read : PRELOADER [12] Read : SECCFG Backup done! Done! Elapsed: 00:00:27 Code: Operation : Reset Settings/Format FS [ v2.21 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM7) MODE : PRELOADER PORT PORT : 7 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6753 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x02 BROM : PRELOADER PORT MODE : 0_base : BASE_v2044 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6753 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 150100475836424D420308C3CEF2BC17 DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100475836424D420308C3CEF2A417 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : GX6BMB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] CHIP : MT6753 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 9F554E5596205D11EB08D2A6B42660E3 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:36 Reconnect Power/Cable! |
The Following User Says Thank You to syed tuqeer For This Useful Post: |
02-09-2021, 17:55 | #65858 (permalink) |
No Life Poster Join Date: Sep 2004 Location: South Mrorocco Age: 49
Member: 80599 Status: Offline Sonork: 1621236 Thanks Meter: 280 | A1k sucssefully unnlock pin password Hi . Here is log sucss unlock pattern or password after format Card found : xxxxxxxx , v0147 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.21 Load IDBase v21168 Ok! Operation : HW Report [ v2.21 ] HWreport : Mode : eMMC 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM8) MODE : BOOTROM PORT : 8 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : F1C1D577AF41E0EE2E5CE15EF7A35FEE BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2028 | Manual : Disabled BROM : SOCID : E009DC021D60CB722FA9DF2F331AB7DA151BE3BD033D54F5D9 6EECF7F09F5BDD BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0003 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232,00 KB ] DRAM: 0x80000000 [ 2,00 GB ] EMMC: 150100514436334D42036C359BB7464F EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QD63MB EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x01000000 [ 16,00 MB ] USER : 0x747C00000 [ 29,12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : F203FD8C9919FB448B290E65252618C7 DA : USB : HIGH-SPEED Boot done! Memory Info : CID : 150100514436334D42036C359BB7464F MEM : VEN : SAMSUNG | OEM : 01 | DEV : QD63MB DAT : Size: 29820 MB, Max.Speed: 52000 kHz, blklen(512), nblks(61071360), ro(0) EXT_CSD Info : EXT_CSD rev. : v1.8 ( MMC v5.1 ) CSD struct rev. : v1.2 Supported command sets : 1h HPI features : 1h BG operations support : 1h BG operations status : 0h Correct prg. sectors : 0h 1st init time after part. : 3000 ms Min. write perf.(DDR,52MH,8b): 0h Min. read perf. (DDR,52MH,8b): 0h TRIM timeout: 0 ms Secure feature support: 55h Secure erase timeout : 8100 ms Secure trim timeout : 5100 ms Access size : 3584 bytes HC erase unit size : 512 kbytes HC erase timeout : 300 ms HC write prot grp size: 8192 kbytes HC erase grp def. : 0h Reliable write sect count: 1h Sleep current (VCC) : 7h Sleep current (VCCQ): 7h Sleep/awake timeout : 26214400 ns Sector count : 3a3e000h Min. WR Perf. (52MH,8b): 0h Min. Read Perf.(52MH,8b): 0h Min. WR Perf. (26MH,8b,52MH,4b): 0h Min. Read Perf.(26MH,8b,52MH,4b): 0h Min. WR Perf. (26MH,4b): 0h Min. Read Perf.(26MH,4b): 0h Power class: 0 Power class(DDR,52MH,3.6V): 0h Power class(DDR,52MH,1.9V): 0h Power class(26MH,3.6V) : 0h Power class(52MH,3.6V) : 0h Power class(26MH,1.9V) : 0h Power class(52MH,1.9V) : 0h Part. switch timing : 2h Out-of-INTR busy timing: ah Card type : 57h Command set : 0h Command set rev.: 0h HS timing : 0h Bus width : 0h Erase memory content : 0h Partition config : 48h Boot partition size : 4096 kbytes Boot information : 7h Boot config protection: 0h Boot bus width : 2h Boot area write prot : 0h User area write prot : 0h FW configuration : 0h RPMB size : 16384 kbytes Write rel. setting : 1fh Write rel. parameter: 14h Start background ops : 0h Enable background ops: 2h H/W reset function : 1h HPI management : 0h Max. enhanced area size : 747h (15261696 kbytes) Part. support : 7h Part. attribute: 0h Part. setting : 0h General purpose 1 size : 0h (0 kbytes) General purpose 2 size : 0h (0 kbytes) General purpose 3 size : 0h (0 kbytes) General purpose 4 size : 0h (0 kbytes) Enh. user area size : 0h (0 kbytes) Enh. user area start: 0h Bad block mgmt mode: 0h Overall status : MLC status : 20% - 30% used SLC status : 20% - 30% used EOL status : Normal ( Less than 80% reserved blocks used ) RPMB : RPMB KEY EXISTS! [State : NOT CLEAN : UNUSABLE] Done! Elapsed: 00:00:45 Operation : Reset Settings/Format FS [ v2.21 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM8) MODE : BOOTROM PORT : 8 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : F1C1D577AF41E0EE2E5CE15EF7A35FEE BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2028 | Manual : Disabled BROM : SOCID : E009DC021D60CB722FA9DF2F331AB7DA151BE3BD033D54F5D9 6EECF7F09F5BDD BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0003 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232,00 KB ] DRAM: 0x80000000 [ 2,00 GB ] EMMC: 150100514436334D42036C359BB7464F EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QD63MB EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x01000000 [ 16,00 MB ] USER : 0x747C00000 [ 29,12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : F203FD8C9919FB448B290E65252618C7 DA : USB : HIGH-SPEED Boot done! Done! Elapsed: 00:00:36 Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.21 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM8) MODE : BOOTROM PORT : 8 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : F1C1D577AF41E0EE2E5CE15EF7A35FEE BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2028 | Manual : Disabled BROM : SOCID : E009DC021D60CB722FA9DF2F331AB7DA151BE3BD033D54F5D9 6EECF7F09F5BDD BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0003 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232,00 KB ] DRAM: 0x80000000 [ 2,00 GB ] EMMC: 150100514436334D42036C359BB7464F EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QD63MB EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x01000000 [ 16,00 MB ] USER : 0x747C00000 [ 29,12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : F203FD8C9919FB448B290E65252618C7 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x815757 Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:01:08 Reconnect Power/Cable! |
The Following User Says Thank You to ramoon20 For This Useful Post: |
02-10-2021, 04:52 | #65859 (permalink) |
Freak Poster Join Date: Jul 2004 Location: Khakassia,MobileService Age: 48
Member: 72306 Status: Offline Thanks Meter: 193 | honor 8s smart reset done with TP Operation : Reset Settings/Format FS [ v2.21 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM5) MODE : BOOTROM PORT : 5 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN RAPHAEL BROM : MEID : EF1DB94657BEC859DABAC3CAAACE35E9 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 09AD217C4E66A513750BCE6221D4CF789E6210D5BFB2C7760A 8C057F6A1917D5 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232,00 KB ] DRAM: 0x80000000 [ 2,00 GB ] EMMC: 150100514436334D4201B812D3B83681 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QD63MB EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x01000000 [ 16,00 MB ] USER : 0x747C00000 [ 29,12 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 8DB78231AF843704FEE034702461681B DA : USB : HIGH-SPEED Boot done! Done! Elapsed: 00:00:36 Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.21 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM5) MODE : BOOTROM PORT : 5 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN RAPHAEL BROM : MEID : EF1DB94657BEC859DABAC3CAAACE35E9 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 09AD217C4E66A513750BCE6221D4CF789E6210D5BFB2C7760A 8C057F6A1917D5 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232,00 KB ] DRAM: 0x80000000 [ 2,00 GB ] EMMC: 150100514436334D4201B812D3B83681 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QD63MB EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x01000000 [ 16,00 MB ] USER : 0x747C00000 [ 29,12 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 8DB78231AF843704FEE034702461681B DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x815657 Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Done! Elapsed: 00:01:23 Reconnect Power/Cable! |
The Following 4 Users Say Thank You to Igorbublik For This Useful Post: |
02-10-2021, 08:29 | #65860 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | QMobile i8i 2019 Operation : Format FS / Reset Settings [ v2.11 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Qmobile : QMobile i8i 2019 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:42 |
02-10-2021, 09:36 | #65861 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Sharja UAE
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | oppo F17 pro done by CM2 Read Firmware Code: 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM45) MODE : BOOTROM PORT : 45 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 CODE : Lafite TYPE : MODERN RAPHAEL BROM : MEID : 3F5FDC027E244771D0B923F675B57BFB BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : EB3947CAC28141511432CF197BF0E7C8ABBC8A04B7D964737E8144A4B82D9D90 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6779 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x200000000 [ 8.00 GB ] UFS: CE014B4D3856373030314A4D2D423831 UFS: VEN : 0x01CE VID : KM8V7001JM-B81 IFW : 1200 LU0 : 0x00400000 [ 4.00 MB ] LU1 : 0x00400000 [ 4.00 MB ] LU2 : 0x1DCB000000 [ 119.17 GB ] FSN : 00330063003100390034006600630035 REG : 0x101010000 CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 2EF18E817925CE35DF648176A707E8C2 DA : USB : HIGH-SPEED Boot done! Patch Level : QP1A.190711.020 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2020-10-05 Build Time : 29.09.2020 MT6779__10__QP1A.190711.020 Read : preloader.bin Read : recovery.img Read : opporeserve.img Read : oppo_custom.img Read : vbmeta.img Read : persist.img ExtSparse : Compression ratio : 92% Read : proinfo.img Read : nvram.bin Read : ocdt.img Read : cdt_engineering.img Read : md1rom.img Read : spmfw.img Read : audio_dsp.img Read : tinysys-scp.bin Read : tinysys-sspm.bin Read : cam_vpu1.img Read : cam_vpu2.img Read : cam_vpu3.img Read : gz.img Read : lk.bin Read : boot.img Read : logo.bin Read : dtbo.img Read : tz.img Read : special_preload.img ExtSparse : Compression ratio : 99% Read : my_custom.img ExtSparse : Compression ratio : 99% Read : vbmeta_system.img Read : vbmeta_vendor.img Read : super.img ExtSparse : Compression ratio : 20% Read : cache.img Read : userdata.img FW Size : 6.70 GB Android Info saved : _Android_info.txt Scatter : MT6779_Android_scatter.txt Saved to : F:\Oppo\New folder\MT6779__10__QP1A.190711.020\ Done! Elapsed: 00:10:00 Code: Operation : Reset Settings/Format FS [ v2.21 ] Mode : FULL FACTORY ( FORCED + FRP ) 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM45) MODE : BOOTROM PORT : 45 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 CODE : Lafite TYPE : MODERN RAPHAEL BROM : MEID : 3F5FDC027E244771D0B923F675B57BFB BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : EB3947CAC28141511432CF197BF0E7C8ABBC8A04B7D964737E8144A4B82D9D90 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6779 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x200000000 [ 8.00 GB ] UFS: CE014B4D3856373030314A4D2D423831 UFS: VEN : 0x01CE VID : KM8V7001JM-B81 IFW : 1200 LU0 : 0x00400000 [ 4.00 MB ] LU1 : 0x00400000 [ 4.00 MB ] LU2 : 0x1DCB000000 [ 119.17 GB ] FSN : 00330063003100390034006600630035 REG : 0x101010000 CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 2EF18E817925CE35DF648176A707E8C2 DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:31 Reconnect Power/Cable! |
The Following 4 Users Say Thank You to Hafiz ArslanAli For This Useful Post: |
02-10-2021, 11:23 | #65862 (permalink) | |
Freak Poster Join Date: Nov 2016 Location: GB
Member: 2647569 Status: Offline Sonork: micaw Thanks Meter: 118 | Mobicel Pulse Network successfully unlocked code: Quote:
02-10-2021, 11:33 | #65863 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Infinix-X650 Frp Code: Patch Level : O11019 Display ID : X650-H8029AB-OGo-190928V241 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2019-09-05 Build Time : 28.09.2019 Product Brand : Infinix Product Name : H8029 Product Device : Infinix-X650 Product Info : Infinix-X650 Product Model : Infinix X650 Product Manfct : INFINIX MOBILITY LIMITED Product Board : Infinix-X650 Board Platform : mt6580 USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) IMEI[0] : 358288100317964 IMEI[1] : 358288100317972 NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] Done! Elapsed: 00:00:33 Operation : Reset Settings/Format FS [ v2.21 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM3) MODE : PRELOADER PORT PORT : 3 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT MODE : TECNO : LB6 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_SWSEC.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 460001704543424D65262041DF963C87 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 700100464D42434541202665873C96DF EMMC: VEN : KINGSTON | OEM : 01 | DEV : FMBCEA EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x74A000000 [ 29.16 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 87CF662C71A4413C208B44A5A73E1A73 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:34 Reconnect Power/Cable! |
02-10-2021, 11:33 | #65864 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | OPPO A5S Format Code: AP_CHIP : MT6765,S01 AP_SWTM : Tue Oct 20 21:35:32 CST 2020 AP_SWVR : CPH1909_11_A.42_201020_34570289 AP_HWVR : S01 MD_CHIP : MT6765 MD_SWTM : 2000.00.00 MD_DSPV : 1.0 MD_DSPP : MOLY.LR12A.R2.TC16.SP.V50.5.P96 MD_SWVR : OPPO_O1MP6_K65V1_64_BSP_HW MD_HWVR : Unknown Patch Level : O11019 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2020-10-05 Product Manfct : OPPO IMEI[1] : IMEI[2] : Done! Elapsed: 00:00:43 Operation : Reset Settings/Format FS [ v2.16 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM4) MODE : BOOTROM PORT : 4 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BOOTROM BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 [0200] V0: 0000 0000 [0001] BROM : SOCID : C377094A5E4C5EBE0974F09A485B81E658C3CC63E0985C20C53FAA9725AE37FA BROM : Configuring target for META BROM : META configured! INIT : META confirmed! Boot done! AP_CHIP : MT6765,S01 AP_SWTM : Tue Oct 20 21:35:32 CST 2020 AP_SWVR : CPH1909_11_A.42_201020_34570289 AP_HWVR : S01 Format Ok : UserData - > Format in META will NOT reset FRP! Done! Elapsed: 00:00:35 Reconnect Power/Cable! |
The Following User Says Thank You to Tanha0321 For This Useful Post: |
02-10-2021, 11:34 | #65865 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | TECNO BB4k Frp Code: Patch Level : PPR1.180610.011 Display ID : BB4k-H6114UVW-PGo-200617V92 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2020-06-05 Build Time : 17.06.2020 Product Model : TECNO BB4k Product Brand : TECNO Product Name : H6114 Product Device : TECNO-BB4k Product Manfct : TECNO MOBILE LIMITED Product Info : bb4k_h6114 Product Board : TECNO-BB4k Board Platform : mt6761 USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption **) NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] STORAGE : LifeStatus : eMMC : NOT implemented in selected DA! Done! Elapsed: 00:00:51 Operation : Reset Settings/Format FS [ v2.16 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM3) MODE : PRELOADER PORT PORT : 3 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : TECNO : SECURE_v2 | Manual : Disabled BROM : SOCID : 895E87AC41FA2EC25B0EB48D7A91AE5992C8AB7840AF92455C8B4DD55541AF72 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SWSEC.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 150100514436334D4201331AD35467F1 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QD63MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : D9CA996A80BDB6D229BE1E6FAB0E337B DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
