03-29-2021, 10:57 | #66316 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | Zong Z2 Frp Code: Patch Level : PPR1.180610.011 Display ID : A5701_ZONG_B06_20190912 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-08-05 Build Time : 16.03.2020 Product Model : Z2 Product Brand : Zong Product Name : Z2 Product Device : Z2 Product Manfct : Zong Product Info : Z2 Product Board : Zong Board Platform : mt6739 USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption **) NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] STORAGE : LifeStatus : eMMC : NOT implemented in selected DA! Done! Elapsed: 00:00:27 Operation : Reset Settings/Format FS [ v2.21 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM3) MODE : PRELOADER PORT PORT : 3 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : 0_base : BASE_v1812 | Manual : Disabled BROM : SOCID : 9A1B14483E0BF6DFCA84F2FFF25B5F07999542C12D210D65F463A65691B960EF AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 7001004548414345410109EE59744449 EMMC: VEN : KINGSTON | OEM : 01 | DEV : EHACEA EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A5000000 [ 14.58 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 7571BCE347A48628D7A831AA3365618B DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
03-29-2021, 10:59 | #66317 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | HUAWEI Hol-U19 Pinlock Reset Code: Brand : HUAWEI ProdName : Hol-U19 ProdModel : Hol-U19 Device : HWHol-U AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : Holly-U19V100R001C328B107_A Done! Elapsed: 00:00:07 Reconnect Power/Cable! Operation : Clear UserLocks [Pin/Pwd/Pattern/FVLock/GoogleAcc] [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 1501004B3858564D4206E93ECE9512CF Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMVX8 [eMMC] : FLASH_CID : 1501004B3858564D4206E93ECE9512CF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xD5229C25EEA46BD524819DB5B272702F INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! LSSDB Ok! LSSKY Ok! LSSWL Ok! LSSSH Ok! LSSGS Ok! Security Settings : Clear Ok! [Info] : That feature NOT RESET "PRIVACY PASSWORD LOCK"! Use separate button! [Info] : That feature NOT RESET "FRP/GoogleLOCK"! Use separate "FRP" reset! [Info] : If phone stuck on "Logo" : 1. Wait 2-3 minutes. Power Off phone by long press "Power" button 2. Power On phone again 3. Or wait up to 3-7 minutes, until phone start by itself 4. Also recommended reboot phone twice before start use it Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
03-29-2021, 11:01 | #66318 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | Infinix-X655C Frp Code: Product Brand : Infinix Product Device : Infinix-X655C Product Model : Infinix X655C Product Name : X655C-OP Patch Level : QP1A.190711.020 Display ID : X655C-H6211ABKG-Q-OP-201210V274 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2020-12-05 Build Time : 10.12.2020 Product Info : x655c_h6211 Product Board : Infinix-X655C Board Platform : mt6765 Product Manfct : INFINIX MOBILITY LIMITED USERDATA : FILESYSTEM : F2FS with FBE ( File-Base Encryption ) NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] STORAGE : LifeStatus : eMMC : NOT implemented in selected DA! Done! Elapsed: 00:00:31 Operation : Reset Settings/Format FS [ v2.21 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM3) MODE : PRELOADER PORT PORT : 3 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : TECNO : SECURE_v2 | Manual : Disabled BROM : SOCID : 586BEDF2293A622B7E752A310761FFB7F42BE55064C7442220A91009AC254CC4 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SWSEC.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: 15010044503644414203C98FCC7F3797 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : DP6DAB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : D84A726B9D4C4CD97853696EF128C7DB DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
03-29-2021, 11:03 | #66319 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | VGOTEL Smart_5 Frp Code: Patch Level : PPR1.180610.011 Display ID : Smart_5_V07_20190520_1114 Display ID : Smart_5_V10_20190918_1603 Ver. Incmt : 20190520 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-09-05 Build Time : 18.09.2019 Product Model : Smart 5 Product Brand : VGOTEL Product Name : Smart_5 Product Device : Smart_5 Product Manfct : VGOTEL Product Info : Smart_5 Product Board : sp9863a_1h10 Board Platform : sp9863a Platform Version: MOCORTM_18B_W19.10.2_P20.01_Debug Project Version: sharkl3_pub BASE Version: FM_BASE_18B_W19.10.2_P20.01 HW Version: sc9863A_modem CMP_Time : 08-30-2019 19:10:47 MODEM TAG : MOCORTM_18B_W19.10.2_P20.01_Debug_FM_BASE_18B_W19.10.2_P20.01_sc9863A_modem_sharkl3_pub USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:01:57 Operation : Format FS / Reset Settings [ v2.11 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9863x_BASE : SC9863A_eMMC_3GB_0S Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:39 |
03-29-2021, 11:04 | #66320 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | Panasonic P55_Novo_4G Privacy Reset Code: Brand : Panasonic ProdName : P55_Novo_4G ProdModel : P55 Novo 4G Device : P55_Novo_4G AndroidVer: 6.0 MTKxCPU : MT6735 MTKxPRJ : Y3569_DY35691_PANASONIC-P55-NOVO_L108 Done! Elapsed: 00:00:14 Reconnect Power/Cable! Operation : Reset Privacy Lock [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 42 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 484A019061344741A034A43269196404 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , 2a4GA [eMMC] : FLASH_CID : 90014A484147346132A434A004646369 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0xD5229C2517AE53BB67FA1F5164779966 INT RAM : 0x00020000 EXT RAM : 0xC0000000 [3 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Checking data ... Process block #1 Process block #2 Privacy Lock reset Ok! Done! Elapsed: 00:00:23 Reconnect Power/Cable! |
03-29-2021, 11:07 | #66321 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | VNUS Moon M24 Flash Code: Patch Level : MRA58K Display ID : J106G_VNUS_Moon M24 _B15_V1.2_20200520 Ver. Incmt : root-103233 Ver. CodeName : REL Ver. Release : 6.0 Sec. Patch : 2016-07-01 Build Time : 20.05.2020 Product Brand : VNUS Product Name : sp7731g_1h10_hd_oversea Product Device : sp7731g_1h10 Product Board : sp7731gea_hdr Product Manfct : VNUS Board Platform : sc8830 Product Info : sp7731g_1h10 Product Model : Moon M24 Platform Version: MOCORTM_14B_MP_7731G_W17.22.4_Debug Project Version: sc7731g_CP0_modem BASE Version: TM_BASE_W17.22.4 MMI Version: sc7731g_modem HW Version: sc7731g_CP0_modem CMP_Time : 05-31-2017 21:23:59 MODEM TAG : MOCORTM_14B_MP_7731G_W17.22.4_Debug_TM_BASE_W17.22.4_sc7731g_CP0_modem_sc7731g_CP0_modem_sc7731g_modem UserData : STATE : PLAIN [EXTFS] - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:01:32 Open : SPD_PROG.xml Reading package ... Read package finished! Created by Infinity-Box (c) 2020 Chinese Miracle II : Spreadtrum / UniSoc Service Module Device Info file : _Android_info.txt Patch Level : MRA58K Display ID : J106G_VNUS_Moon M24 _B15_V1.2_20200520 Ver. Incmt : root-103233 Ver. CodeName : REL Ver. Release : 6.0 Sec. Patch : 2016-07-01 Build Time : 20.05.2020 Product Brand : VNUS Product Name : sp7731g_1h10_hd_oversea Product Device : sp7731g_1h10 Product Board : sp7731gea_hdr Product Manfct : VNUS Board Platform : sc8830 Product Info : sp7731g_1h10 Product Model : Moon M24 SECSolution : LEGACY [SS] Operation : Flash Firmware [ v2.11 ] Setting : Update NVRAM : False Setting : Force NVRAM : False Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : INFINITY FW PACKAGE Sending Init Boot ... Boot sent! Kick FDL ... Kick FDL again ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x20 PMTMng : Update PMT Ok! FSIMG : prodnv.img CODE : wmodem.bin CODE : wdsp.bin CODE : modem_wcn.img CODE : boot_logo.bmp CODE : fastboot_logo.bmp CODE : logo2.bin CODE : logo3.bin CODE : logo4.bin CODE : logo5.bin CODE : boot.img FSIMG : system.img FSIMG : persist.img FSIMG : sysinfo.bin FSIMG : cache.img CODE : recovery.img FSIMG : userdata.img UBOOT : u-boot.bin UBOOT : u-boot-spl.bin ERASE : WFLASH ERASE : WCNFLASH ERASE : MISC Flashing finished! Reconnect Power/Cable! Done! Elapsed: 00:04:59 |
03-29-2021, 11:11 | #66322 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | Qmobile L106 Format Code: Operation : Format FileSystem [ v1.07 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v2.0 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_026511504F17_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
03-29-2021, 11:11 | #66323 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | TECNO-KD7 Frp Code: Product Brand : TECNO Product Device : TECNO-KD7 Product Model : TECNO KD7 Product Name : KD7-GL Patch Level : QP1A.190711.020 Display ID : KD7-H6211FQRSTU-Q-GL-200923V332 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2020-09-05 Build Time : 23.09.2020 Product Info : kd7_h6211 Product Board : TECNO-KD7 Board Platform : mt6765 Product Manfct : TECNO MOBILE LIMITED USERDATA : FILESYSTEM : F2FS with FBE ( File-Base Encryption ) STORAGE : LifeStatus : eMMC : NOT implemented in selected DA! Done! Elapsed: 00:00:29 Operation : Reset Settings/Format FS [ v2.21 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM42) MODE : PRELOADER PORT PORT : 42 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : TECNO : SEC_MIXED | Manual : Disabled BROM : SOCID : 9F4E5C3E4624D478033E1E9BBB853F4367CFE1C258F60E3249BC0723522B5FB3 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: 15010044503644414203B4077197789 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : DP6DAB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : E14F6577CBA49B1A2E772946190E8702 DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:25 Reconnect Power/Cable! |
03-29-2021, 11:12 | #66324 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | coolpad 1825-E0 Frp Code: Patch Level : PPR1.180610.011 Display ID : R09_20190711 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-06-05 Build Time : 14.12.2019 Product Model : 1825-E0 Product Brand : coolpad Product Name : 1825-E0 Product Device : 1825-E0 Product Manfct : coolpad Product Info : 1825-E0 Product Board : k61v1_64_bsp Board Platform : mt6761 USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption **) STORAGE : LifeStatus : eMMC : OK! Done! Elapsed: 00:00:38 Operation : Reset Settings/Format FS [ v2.21 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM3) MODE : PRELOADER PORT PORT : 3 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : TECNO : RAPHAEL_V2 | Manual : Disabled BROM : SOCID : BB49B49DCD35B94EEEBDD0B182FA5D7FF4871767DEC1E27B0B4E913FE0F6DB49 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_V2.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 90014A484147346132A41CA5382F14B9 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HAG4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : CC79AB30100F234D834A17A41DCDBDD5 DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:31 Reconnect Power/Cable! |
03-29-2021, 19:31 | #66325 (permalink) |
Junior Member Join Date: Mar 2021 Location: malawi,mangochi Age: 26
Member: 2984791 Status: Offline Thanks Meter: 0 | Plz team i have a problem with my cm2 dongle Is giving this errors Dongle identification data damaged SerialNo 27071AD6 PLEASE PLEASE HELP ME |
03-30-2021, 04:58 | #66326 (permalink) |
No Life Poster Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Vgotel new7 Frp Remove Done With King Cm2 Operation : Reset Settings/Format FS [ v2.20 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1633 (Android) (COM4) MODE : PRELOADER PORT PORT : 4 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT MODE : 0_base : BASE_v2044 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 440001453130344687CD013665B64047 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 45010044463430313601CD874740B665 EMMC: VEN : SANDISK | OEM : 01 | DEV : DF4016 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : A594A6925EBE702DB7BAF224D66C28E7 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:21 Reconnect Power/Cable! |
03-30-2021, 07:11 | #66327 (permalink) |
Banned Join Date: May 2013 Location: Hacked by Hackflax on tiktok
Member: 1941705 Status: Offline Thanks Meter: 1,248 | 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM6) MODE : BOOTROM PORT : 6 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : MEID : CD848E8020766DBFFE8A2C201C24F834 BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 150100525831424D42075072DE779DA5 DAInf: 4 : 2 : 155 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 520001154D42315872500742A59D77DE NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 DRAM : 0x0178 EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0 INIT : 0xBC : eMMC [ 0xC0000000 : [ 3,00 GB ] ] DRAM : DRAM: 0xC0000000 [ 3,00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100525831424D42075072DE77A3A5 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : RX1BMB EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x747C00000 [ 29,12 GB ] SRAM: 0x00020000 [ 128,00 KB ] DRAM: 0xC0000000 [ 3,00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : E919D59D4FACC03329C6D8065A193773 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM9) MODE : PRELOADER PORT PORT : 9 Boot done! Patch Level : MRA58K Display ID : M6HPro_OINOM_CH_PURE_V1.04_20171016 Ver. CodeName : REL Ver. Release : 6.0 Sec. Patch : 2017-01-05 Build Time : 16.10.2017 Product Model : M6H Pro Product Brand : OINOM Product Name : M6H Pro Product Device : Q5C Product Manfct : M6H Pro Board Platform : mt6737t Product Info : q5c23q_xwp_m6hpro_dz MT6737T__M6H_Pro__M6H_Pro__6.0__M6HPro_OINOM_CH_PU RE_V1.04_20171016__MRA58K__q5c23q_xwp_m6hpro_dz Read : preloader.bin Read : proinfo.img Read : nvram.bin Read : lk.bin Read : boot.img Read : recovery.img Read : logo.bin Read : secro.img Read : tz.img Read : system.img ExtSparse : Compression ratio : 59% Read : cache.img Read : userdata.img FW Size : 1,29 GB Android Info saved : _Android_info.txt Scatter : MT6737T_Android_scatter.txt Saved to : F:\Server\Nomu\Nomu M6H Pro\MT6737T__M6H_Pro__M6H_Pro__6.0__M6HPro_OINOM_C H_PURE_V1.04_20171016__MRA58K__q5c23q_xwp_m6hpro_d z\ Done! Elapsed: 00:09:20 |
03-30-2021, 09:37 | #66328 (permalink) |
No Life Poster Join Date: Mar 2011 Location: Faisalabad
Member: 1527968 Status: Offline Sonork: 100.1651182 Thanks Meter: 483 | PD2036F_EX_A_1.11.3_vivo_mtk free on sport site 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM74) MODE : BOOTROM PORT : 74 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 5F03F540805BFC498EEEDFD1081DB8FB BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 5610CC22D6D3860BD18DCD338B697AB90934C687D862ECA9D3 84129E07A8CD91 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0003 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: 90014A684339615033011014FA791867 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : hC9aP3 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 8106074013C77F727E40B53F3756A5A7 DA : USB : HIGH-SPEED Boot done! Product Brand : vivo Product Device : k65v1_64_bsp Product Model : vivo 2026 Product Name : full_k65v1_64_bsp Patch Level : QP1A.190711.020 Display ID : QP1A.190711.020 release-keys Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2021-01-01 Build Time : 04.02.2021 Product Info : k65v1_64_bsp Product Board : k65v1_64_bsp Board Platform : mt6765 Product Manfct : vivo MT6765__10__QP1A.190711.020__k65v1_64_bsp Read : preloader.bin Read : recovery.img Read : vbmeta_system.img Read : vbmeta_vendor.img Read : backup.img Read : survival.img Read : reserved.img Read : cust.img ExtSparse : Compression ratio : 96% Read : vgc.img ExtSparse : Compression ratio : 99% Read : persist.img ExtSparse : Compression ratio : 89% Read : proinfo.img Read : efuse.img Read : md1rom.img Read : spmfw.img Read : tinysys-scp.bin Read : tinysys-sspm.bin Read : nvram.bin Read : lk.bin Read : boot.img Read : logo.bin Read : dtbo.img Read : tz.img Read : super.img ExtSparse : Compression ratio : 21% Read : vbmeta.img Read : cache.img Read : userdata.img FW Size : 5.23 GB Android Info saved : _Android_info.txt Scatter : MT6765_Android_scatter.txt Saved to : C:\Users\alimobile\Desktop\MT6765__10__QP1A.190711 .020__k65v1_64_bsp\ Done! Operation: Upload File: C:\Users\alimobile\Desktop\MT6765__10__QP1A.190711 .020__k65v1_64_bsp vivo Y20 2021.rar Authentication... Initialization... 3/30/2021: 13:35:18: Upload file 2347.46 Mb 3/30/2021: 13:35:21: Uploading 2347.46 Mb... |
The Following 2 Users Say Thank You to alimobile279 For This Useful Post: |
03-30-2021, 13:46 | #66329 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: French 13 Age: 38
Member: 94762 Status: Offline Thanks Meter: 115 | Quote:
thx in advance | |
03-30-2021, 13:50 | #66330 (permalink) |
No Life Poster Join Date: Oct 2015 Location: Pakistan
Member: 2478233 Status: Offline Thanks Meter: 596 | Infinix x680f dm varity error fix done by flashing Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.21 Load IDBase v210169 Ok! Update configuration ... Update Ok! Load IDBase v210169 Ok! Preloader [HW DEV] Info : EMI : DEV : MT6765 EMI : SRC : preloader_x680f_h6116.bin EMI : CNT : 0004 EMI : [00] : eMMC : DDR3 : ID : 150100475836424142 : VEN : SAMSUNG | DEV : GX6BAB : RAM : [ 3.00 GB ] EMI : [01] : eMMC : DDR3 : ID : 150100514436334D42 : VEN : SAMSUNG | DEV : QD63MB : RAM : [ 2.00 GB ] EMI : [02] : eMMC : DDR3 : ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ] EMI : [03] : eMMC : DDR3 : ID : 90014A484347386134 : VEN : HYNIX | DEV : HCG8a4 : RAM : [ 4.00 GB ] Operation : Write Flash [ v2.21 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :22 [FL] : Set : tkv.img [FL] : Set : recovery.img [FL] : Set : md1img-verified.img [FL] : Set : spmfw-verified.img [FL] : Set : scp-verified.img [FL] : Set : scp-verified.img [FL] : Set : sspm-verified.img [FL] : Set : sspm-verified.img [FL] : Set : lk-verified.img [FL] : Set : lk-verified.img [FL] : Set : boot.img [FL] : Set : logo-verified.bin [FL] : Set : dtbo-verified.img [FL] : Set : tee-verified.img [FL] : Set : tee-verified.img [FL] : Set : vbmeta.img [FL] : Set : vbmeta_system.img [FL] : Set : vbmeta_vendor.img [FL] : Set : super.img [FL] : Set : cache.img [FL] : Set : tranfs.img [FL] : Set : userdata.img [FL] : Total size : 0x1044045DC [ 4.07 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM11) MODE : BOOTROM PORT : 11 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 011B471E336BC9DA63EF478CEF375C8B BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : FAA8F6A2663FB4497FAB256258970D46E253E0FCB2BB7D5AB0 A9DAE10ED5BD36 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6765 EMI : SRC : preloader_x680f_h6116.bin EMI : CNT : 0004 EMI : [00] : eMMC : DDR3 : ID : 150100475836424142 : VEN : SAMSUNG | DEV : GX6BAB : RAM : [ 3.00 GB ] EMI : [01] : eMMC : DDR3 : ID : 150100514436334D42 : VEN : SAMSUNG | DEV : QD63MB : RAM : [ 2.00 GB ] EMI : [02] : eMMC : DDR3 : ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ] EMI : [03] : eMMC : DDR3 : ID : 90014A484347386134 : VEN : HYNIX | DEV : HCG8a4 : RAM : [ 4.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: 90014A484347386134A210629572570B EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HCG8a4 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : D4CF3D81C3153AD6C60BFB61AF8E3903 DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000000108000 Erase : 0x0000000000408000 : 0x0000000004C1A000 Erase : 0x0000000007022000 : 0x00000000047DE000 Erase : 0x000000000F800000 : 0x000000000BB00000 Erase : 0x000000001F300000 : 0x0000000204D00000 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : TKV FAIL : SEC : IMG TYPE MISMATCH Write : RECOVERY Write : MD1IMG Write : SPMFW Write : SCP1 Write : SCP2 Write : SSPM_1 Write : SSPM_2 Write : LK Write : LK2 Write : BOOT Write : LOGO Write : DTBO Write : TEE1 Write : TEE2 Write : VBMETA Write : VBMETA_SYSTEM Write : VBMETA_VENDOR Write : SUPER Write : CACHE Write : TRANFS FAIL : SEC : IMG TYPE MISMATCH Write : USERDATA Ultra : Ok! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:03:24 Reconnect Power/Cable! |
The Following User Says Thank You to Arslanmayo For This Useful Post: |
