04-14-2021, 08:06 | #66466 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | QMobile XLi Frp Code: Patch Level : OPM2.171019.012 Display ID : OPM2.171019.012 release-keys Ver. Incmt : 1554788373 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2019-04-01 Build Time : 16.04.2019 Product Info : k101 Product Model : QMobile XLi Product Brand : QMobile Product Name : QMobile_XLi Product Device : QMobile_XLi Product Manfct : QMobile Product Model : XLi Product Board : k101 Board Platform : sp7731e Platform Version: MOCORTM_17C_W18.23.4_P2_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W18.23.4_P2 HW Version: sc7731e_modem MODEM TAG : MOCORTM_17C_W18.23.4_P2_Debug_FM_BASE_17C_W18.23.4_P2_sc7731e_modem_pike2_pub USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:01:32 Operation : Format FS / Reset Settings [ v2.11 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Mobicel : ASTRO Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:43 |
04-14-2021, 08:07 | #66467 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | OPPO A5S Format Code: AP_CHIP : MT6765,S01 AP_SWTM : Tue Dec 15 20:50:33 CST 2020 AP_SWVR : CPH1909_11_A.44_201215_3c30b5de AP_HWVR : S01 MD_CHIP : MT6765 MD_SWTM : 2000.00.00 MD_DSPV : 1.0 MD_DSPP : MOLY.LR12A.R2.TC16.SP.V50.5.P97 MD_SWVR : OPPO_O1MP6_K65V1_64_BSP_HW MD_HWVR : Unknown Patch Level : O11019 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2020-12-05 Product Manfct : OPPO IMEI[1] : IMEI[2] : Done! Elapsed: 00:00:55 Operation : Reset Settings/Format FS [ v2.21 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM4) MODE : BOOTROM PORT : 4 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : MEID : D2018FA262C064496224DCD088A01D88 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BOOTROM BROM : LOG : F0: 102B 0000 F3: 0000 0000 [0200] V0: 0000 0000 [0001] BROM : SOCID : FED4B91772EDFAC67B73407BAD4897A805AF5D4C9192C3E3142ADD2A65D28007 BROM : Configuring target for META BROM : META configured! INIT : META confirmed! Boot done! AP_CHIP : MT6765,S01 AP_SWTM : Tue Dec 15 20:50:33 CST 2020 AP_SWVR : CPH1909_11_A.44_201215_3c30b5de AP_HWVR : S01 Format Ok : UserData - > Format in META will NOT reset FRP! Done! Elapsed: 00:01:06 Reconnect Power/Cable! |
04-14-2021, 08:08 | #66468 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | QMobile LT700_PRO Flash Code: Brand : QMobile ProdName : LT700_PRO ProdModel : LT700 PRO Device : LT700_PRO AndroidVer: 6.0 MTKxCPU : MT6735 MTKxPRJ : GBL7360QM_0302_T5572 Done! Elapsed: 00:00:14 Reconnect Power/Cable! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 520001154D4231452B1F0742990C30C8 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMB1E [eMMC] : FLASH_CID : 150100524531424D42071F2BC8307399 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xD5229C25934AB2BE6B9E6D98FFE04D8B INT RAM : 0x00020000 EXT RAM : 0xC0000000 [3 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6735 , Project : gionee6735_65u_m0 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Disabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 3597 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000001C80000-0x0000000004D80000 Erase : 0x0000000006B00000-0x000000039C280000 Flash Pre-Erase Done, time used : 00:00:02 SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 0016 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : LK Image Flash Ok Flash now : BOOT Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : SECRO Image Flash Ok Flash now : TEE1 Image Flash Ok Flash now : TEE2 Image Flash Ok Flash now : SYSTEM Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USERDATA Image Flash Ok Flash Write Done, time used : 00:07:26 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:07:48 Reconnect Power/Cable! |
04-14-2021, 08:10 | #66469 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Jazz Digit Flash Code: Patch Level : KOT49H Display ID : Digit_M42421DG_SW19 Ver. CodeName : REL Ver. Release : 4.4.2 Build Time : 25.11.2020 Product Model : Digit4G Product Brand : Digit Product Name : Digit4G Product Device : Digit4G Product Manfct : alps Board Platform : mt6739 Product Info : Digit4G USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption ***) NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] STORAGE : LifeStatus : eMMC : NOT implemented in selected DA! Done! Elapsed: 00:00:22 Created by Infinity-Box (c) 2020 Chinese Miracle II : MediaTek Service Module Device Info file : _Android_info.txt Patch Level : KOT49H Display ID : Digit_M42421DG_SW15 Ver. CodeName : REL Ver. Release : 4.4.2 Build Time : 22.08.2020 Product Model : Digit4G Product Brand : Digit Product Name : Digit4G Product Device : Digit4G Product Manfct : alps Board Platform : mt6739 Product Info : Digit4G Preloader [HW DEV] Info : EMI : DEV : MT6739 EMI : SRC : preloader_fise6731_kaie_s_e_k.bin EMI : CNT : 0006 EMI : [00] : eMMC : DDR3 : ID : 700100454534454434 : VEN : KINGSTON | DEV : EE4ED4 : RAM : [ 512.00 MB ] EMI : [01] : eMMC : DDR3 : ID : F40122426977696E20 : VEN : BIWIN | DEV : Biwin : RAM : [ 512.00 MB ] EMI : [02] : eMMC : DDR3 : ID : 150100463558354342 : VEN : SAMSUNG | DEV : F5X5CB : RAM : [ 512.00 MB ] EMI : [03] : eMMC : DDR3 : ID : 150100464A32354142 : VEN : SAMSUNG | DEV : FJ25AB : RAM : [ 512.00 MB ] EMI : [04] : eMMC : DDR3 : ID : FE014E50314A39344D : VEN : MICRON | DEV : P1J94M : RAM : [ 512.00 MB ] EMI : [05] : eMMC : DDR3 : ID : 90014A483447326111 : VEN : HYNIX | DEV : H4G2a : RAM : [ 512.00 MB ] Operation : Write Flash [ v2.21 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :17 [FL] : Set : preloader_fise6731_kaie_s_e_k.bin [FL] : Set : recovery.img [FL] : Set : md1rom.img [FL] : Set : md1dsp.img [FL] : Set : spmfw.img [FL] : Set : mcupmfw.img [FL] : Set : lk.bin [FL] : Set : lk.bin [FL] : Set : loader_ext.img [FL] : Set : loader_ext.img [FL] : Set : boot.img [FL] : Set : logo.bin [FL] : Set : tz.img [FL] : Set : tz.img [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0x20E87698 [ 526.53 MB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM26) MODE : BOOTROM PORT : 26 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN RAPHAEL BROM : MEID : 94CBEA37B040686ED9178A94D36E655D BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v1844 | Manual : Enabled BROM : SOCID : 77714611CF5B25FD084AAAB778E47A25AA296C9465B9DA496C1904C0E2029D09 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6739 EMI : SRC : preloader_fise6731_kaie_s_e_k.bin EMI : CNT : 0006 EMI : [00] : eMMC : DDR3 : ID : 700100454534454434 : VEN : KINGSTON | DEV : EE4ED4 : RAM : [ 512.00 MB ] EMI : [01] : eMMC : DDR3 : ID : F40122426977696E20 : VEN : BIWIN | DEV : Biwin : RAM : [ 512.00 MB ] EMI : [02] : eMMC : DDR3 : ID : 150100463558354342 : VEN : SAMSUNG | DEV : F5X5CB : RAM : [ 512.00 MB ] EMI : [03] : eMMC : DDR3 : ID : 150100464A32354142 : VEN : SAMSUNG | DEV : FJ25AB : RAM : [ 512.00 MB ] EMI : [04] : eMMC : DDR3 : ID : FE014E50314A39344D : VEN : MICRON | DEV : P1J94M : RAM : [ 512.00 MB ] EMI : [05] : eMMC : DDR3 : ID : 90014A483447326111 : VEN : HYNIX | DEV : H4G2a : RAM : [ 512.00 MB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x20000000 [ 512.00 MB ] EMMC: 150100463558354342013FA5DE48322B EMMC: VEN : SAMSUNG | OEM : 01 | DEV : F5X5CB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0xE9000000 [ 3.64 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : DB4DCEC440CC106F5F25D72C629A504 DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000002E88000 Erase : 0x0000000003688000 : 0x0000000004000000 Erase : 0x0000000008800000 : 0x0000000000A00000 Erase : 0x0000000009500000 : 0x0000000007200000 Erase : 0x0000000010C00000 : 0x0000000000200000 Erase : 0x0000000010E20000 : 0x00000000D71DBE00 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Update bootloader backup copy ... Update bootloader backup copy Ok! Write : RECOVERY Write : MD1IMG Write : MD1DSP Write : SPMFW Write : MCUPMFW Write : LK Write : LK2 Write : LOADER_EXT1 Write : LOADER_EXT2 Write : BOOT Write : LOGO Write : TEE1 Write : TEE2 Write : SYSTEM Write : CACHE Write : USERDATA [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:01:56 Reconnect Power/Cable! |
04-14-2021, 08:11 | #66470 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Motorola Moto E (4) Frp Code: Brand : motorola ProdName : woods_retail ProdModel : Moto E (4) Device : woods AndroidVer: 7.1.1 MTKxCPU : MT6737M MTKxPRJ : alps-mp-n1.mp1-V1_lenovo6737m.35.n1_P69 Done! Elapsed: 00:00:05 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D3331456A230D429DC413D3 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM31E [eMMC] : FLASH_CID : 150100514531334D420D236AD313849D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xD5229C25F8F53906EC9DA20F8CEDE6EE INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
04-14-2021, 08:12 | #66471 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | QMobile E1 Frp Code: Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 21 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 52000115414231331BCE0642D1071FC4 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BAB13 [eMMC] : FLASH_CID : 15010052333142414206CE1BC41F83D1 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xD5229C2531BCE75E38198376C3EFC2E5 INT RAM : 0x00020000 EXT RAM : 0xC0000000 [3 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:13 Reconnect Power/Cable! |
04-14-2021, 08:13 | #66472 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | OPPO A1601 Format Code: AP_CHIP : MT6750,S01 AP_SWTM : Tue Sep 6 04:42:51 CST 2016 AP_SWVR : A59_11_A.12_180302 AP_HWVR : S01 MD_CHIP : MT6750 MD_SWTM : 2000.00.00 MD_DSPV : 1.0 MD_DSPP : MOLY.LR11.W1539.MD.MP.V20.3.P6 MD_SWVR : OPPO6755_66_L_HW MD_HWVR : Unknown Product Model : A1601 Product Brand : OPPO Product Name : A1601 Product Device : A1601 Product Board : full_oppo6750_15131 Product Info : oppo6750_15131 SW Version : A.20 SW OTA Version : A1601EX_311.A.20_0200_201707151435 SW OTA Name : A1601EX_311_A.20_170715 Display ID : A1601EX_11_A.20_170715 Kernel Info : 3.10.72-G201707151435 Product Board : full_oppo6750_15331 Product Info : oppo6750_15331 SW Version : A.14 SW OTA Version : A1601EX_11.A.14_INT_014_201609060407 SW OTA Name : A1601EX_11_A.14_160906 Display ID : A1601EX_11_A.14_160906 Kernel Info : 3.10.72-G201609060407 Patch Level : LMY47I Ver. CodeName : REL Ver. Release : 5.1 Sec. Patch : 2016-08-05 Build Time : 05.09.2016 Product Manfct : OPPO Board Platform : mt6750 IMEI[1] : [ ERASED ] IMEI[2] : [ ERASED ] Done! Elapsed: 00:00:58 Operation : Reset Settings/Format FS [ v2.21 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM108) MODE : PRELOADER PORT PORT : 108 Waiting BOOT ack ... PRELOADER : ACK confirmed! INIT : META confirmed! Boot done! AP_CHIP : MT6750,S01 AP_SWTM : Tue Sep 6 04:42:51 CST 2016 AP_SWVR : A59_11_A.12_180302 AP_HWVR : S01 Format Ok : UserData - > Format in META will NOT reset FRP! Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
04-14-2021, 08:14 | #66473 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | TECNO-KC2 Frp Code: Patch Level : PPR1.180610.011 Display ID : KC2-H6113AI-P-200414V265 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2020-04-05 Build Time : 14.04.2020 Product Model : TECNO KC2 Product Brand : TECNO Product Name : H6113 Product Device : TECNO-KC2 Product Manfct : TECNO MOBILE LIMITED Product Info : kc2_h6113 Product Board : TECNO-KC2 Board Platform : mt6761 USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption **) NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] STORAGE : LifeStatus : eMMC : NOT implemented in selected DA! Done! Elapsed: 00:00:27 Operation : Reset Settings/Format FS [ v2.21 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM3) MODE : PRELOADER PORT PORT : 3 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : TECNO : SEC_BASE | Manual : Disabled BROM : SOCID : 151EF46A9B3757486B2B4A1BA848E6299C193930A162FC319D710224C1D61517 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 150100474436424D4201A328D362C665 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : GD6BMB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 910627696653B71EC07DA0EFB85D4C03 DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
04-14-2021, 08:50 | #66474 (permalink) |
Freak Poster Join Date: Nov 2016 Location: Vietnam
Member: 2643704 Status: Offline Sonork: Zalo:0932606079 Thanks Meter: 135 | Itel IT1508 Plus hang logo flash done Code: Card found : 9A3E079A , v0147 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.11 Load IDBase v8331 Ok! Operation : Identify [ v2.11 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731x_BASE : SC7731C_eMMC_1GB_NS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Patch Level : LMY47D Display ID : LMY47D release-keys Ver. Incmt : eng.root.20170322.103347 Ver. CodeName : REL Ver. Release : 5.1 Sec. Patch : 2017-01-05 Build Time : 22.03.2017 Product Model : itel it1508 Plus Product Brand : Itel Product Name : itel_it1508Plus Product Device : itel_it1508Plus Product Manfct : itel Board Platform : sc8830 Product Info : c160_tsl_263 Platform Version: MOCORTM_Pike_W15.18_Debug Project Version: sc7731g_CP0_modem BASE Version: TM_BASE_15B_W16.04.3_P13 MMI Version: sc7731g_modem HW Version: sc7731g_CP0_modem CMP_Time : 03-14-2017 17:31:53 MODEM TAG : MOCORTM_Pike_W15.18_Debug_TM_BASE_15B_W16.04.3_P13_sc7731g_CP0_modem_sc7731g_CP0_modem_sc7731g_modem UserData : STATE : PLAIN [EXTFS] - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:00:45 Open : itel_it1508Plus_sc7731x_VietNam.pac VER : BP_R1.0.0 LEN : 2,22 GiB CPU : SC77xx VER : SC7731_eMMC_IT1508PLUS_SC7731X_VIETNA_INFINITY-BOX Reading package ... Read package finished! Patch Level : LMY47D Display ID : LMY47D release-keys Ver. Incmt : eng.root.20170322.103347 Ver. CodeName : REL Ver. Release : 5.1 Sec. Patch : 2017-01-05 Build Time : 22.03.2017 Product Model : itel it1508 Plus Product Brand : Itel Product Name : itel_it1508Plus Product Device : itel_it1508Plus Product Manfct : itel Board Platform : sc8830 Product Info : c160_tsl_263 Operation : Flash Firmware [ v2.11 ] Setting : Update NVRAM : False Setting : Force NVRAM : False Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! >>> ERROR : Protocol HandShake failed! >>> Error : Fail to init protocol! >>> Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Flash Firmware [ v2.11 ] Setting : Update NVRAM : False Setting : Force NVRAM : False Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : itel_it1508Plus_sc7731x_VietNam.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x1A PMTMng : Update PMT Ok! CODE : prodnv.img ERASE : UBOOT ERASE : WRUNTIMENV1 ERASE : WCNRUNTIMENV1 ERASE : MISC UBOOT : u-boot-spl-16k.bin CODE : sc7731g_CP0_modem.bin CODE : DSP_DM_Gx.bin CODE : sc8830g_modem_CP2_WCN_Trunk_W16.28.5_Release.bin CODE : logo_480x854.bin CODE : fblogo_480x854.bin CODE : boot.img FSIMG : system.img FSIMG : oem.img CODE : sysinfo.img FSIMG : cache.img CODE : recovery.img FSIMG : userdata.img UBOOT : u-boot.bin Flashing finished! Reconnect Power/Cable! Done! Elapsed: 00:03:53 |
04-14-2021, 17:52 | #66475 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,806 | Samsung e1200r flash done ORIGINAL POSTER MS-GSM DZGSM [IMG]****************************/convkey/2a52/f25h3ixtlqjzu1azg.jpg[/IMG] |
The Following User Says Thank You to profkefah For This Useful Post: |
04-14-2021, 17:54 | #66476 (permalink) |
Member: 2371500 Status: Offline Thanks Meter: 5,806 | Condor t8 frp remove done ORIGINAL POSTER MS-GSM DZGSM [IMG]****************************/convkey/403e/d3p06lal0qai004zg.jpg[/IMG] |
04-14-2021, 20:40 | #66477 (permalink) |
Freak Poster Join Date: May 2016 Location: BRAZIL
Member: 2578528 Status: Offline Thanks Meter: 139 | Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Device info : Patch Level : OPM2.171019.012 Display ID : HOW_20191010 Ver. Incmt : 27119 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2018-06-05 Build Time : 06.11.2019 Product Model : 705-G Go Product Brand : HOW Product Name : 705-G_Go Product Device : 705-G_Go Product Manfct : HOW Product Info : 7705-G_Go Product Board : sp7731e_1h10 Board Platform : sp7731e Platform Version: MOCORTM_17C_W18.22.1_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W18.22.1 HW Version: sc7731e_modem CMP_Time : 05-28-2018 13:35:31 MODEM TAG : MOCORTM_17C_W18.22.1_Debug_FM_BASE_17C_W18.22.1_sc 7731e_modem_pike2_pub USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption *) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:29:40 Operation : Format FS / Reset Settings [ v2.11 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... >>> Device not found! >>> Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Format FS / Reset Settings [ v2.11 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:01:06 |
04-14-2021, 20:42 | #66478 (permalink) |
Member: 2578528 Status: Offline Thanks Meter: 139 | TABLET HOW HT-705-G Go - FRP DONE Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Device info : Patch Level : OPM2.171019.012 Display ID : HOW_20191010 Ver. Incmt : 27119 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2018-06-05 Build Time : 06.11.2019 Product Model : 705-G Go Product Brand : HOW Product Name : 705-G_Go Product Device : 705-G_Go Product Manfct : HOW Product Info : 7705-G_Go Product Board : sp7731e_1h10 Board Platform : sp7731e Platform Version: MOCORTM_17C_W18.22.1_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W18.22.1 HW Version: sc7731e_modem CMP_Time : 05-28-2018 13:35:31 MODEM TAG : MOCORTM_17C_W18.22.1_Debug_FM_BASE_17C_W18.22.1_sc 7731e_modem_pike2_pub USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption *) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:29:40 Operation : Format FS / Reset Settings [ v2.11 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... >>> Device not found! >>> Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Format FS / Reset Settings [ v2.11 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:01:06 |
04-15-2021, 11:58 | #66479 (permalink) |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Offline Thanks Meter: 1,640 | itel A23S SC9832E DUMP, SP UNLOCK done Code: Operation : Identify [ v2.11 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9832E_BASE : SC9832E_eMMC_1GB_0S Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Device info : Patch Level : OPM2.171019.012 Display ID : A23S-SU335-8.1-MZ-Voda-L-V019-20210324 Ver. Incmt : MZ-Voda-L-V019-20210324 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2021-04-05 Build Time : 24.03.2021 Product Model : itel A23S Product Brand : Itel Product Name : SU335 Product Device : itel-A23S Product Manfct : ITEL MOBILE LIMITED Product Info : itel A23S Product Board : sp9832e_1h10_32b Board Platform : sp9832e NVMng : SecurityInfo IMEI[1] : 3551831 IMEI[2] : 354648020000004 IMEI[3] : 8674000 WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC : SLS:0, SKS:0, SKV:3 Platform Version: MOCORTM_17B_Release_W18.26.1_P25_Debug Project Version: sharkle_Smart_Phone BASE Version: FM_BASE_17B_Release_W18.26.1_P25 HW Version: sc9832e_modem CMP_Time : 08-27-2020 14:37:04 MODEM TAG : MOCORTM_17B_Release_W18.26.1_P25_Debug_FM_BASE_17B_Release_W18.26.1_P25_sc9832e_modem_sharkle_Smart_Phone USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:01:04 Code: Operation : Read FW [ v2.11 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9832E_BASE : SC9832E_eMMC_1GB_0S Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Device info : Patch Level : OPM2.171019.012 Display ID : A23S-SU335-8.1-MZ-Voda-L-V019-20210324 Ver. Incmt : MZ-Voda-L-V019-20210324 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2021-04-05 Build Time : 24.03.2021 Product Model : itel A23S Product Brand : Itel Product Name : SU335 Product Device : itel-A23S Product Manfct : ITEL MOBILE LIMITED Product Info : itel A23S Product Board : sp9832e_1h10_32b Board Platform : sp9832e AndroidVer : 8 VlnrLevel : 0x02 SP9832E__ITEL_MOBILE_LIMITED__itel_A23S__8.1.0__A23S-SU335-8.1-MZ-Voda-L-V019-20210324__OPM2.171019.012__itel_A23S Read : u-boot.bin Read : sml.bin Read : tos.bin Read : vbmeta.img Read : ldsp_l.bin Read : gdsp_l.bin Read : modem_l.bin Read : deltanv_l.bin Read : nvitem_l.bin Read : modem_wcn.img Read : gnssmodem.bin Read : gnssbdmodem.bin Read : pm_sys.bin Read : boot.img Read : recovery.img Make : persist.img Read : boot_logo.bmp Read : fastboot_logo.bmp Read : system.img ExtSparse : Compression ratio : 90% Read : vendor.img ExtSparse : Compression ratio : 87% Make : userdata.img Make : cache.img Read : prodnv.img ExtSparse : Compression ratio : 46% Read : phase.cfg Read : u-boot-spl.bin Waiting for device ... ADB : Device found! ADB : Connected! ADB : Prepare Ok! Winter is coming! Winter is coming! Just some noise around. Wait ... Firmware size : 0x5E56EFF4 ( 1,47 GiB ) Android Info saved : _Android_info.txt Reconnect Power/Cable! Done! Elapsed: 00:09:16 Code: Operation : SP Unlock [ v2.11 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : A23S-SU335-8.1-MZ-Voda-L-V019-20210324 Platform Version: MOCORTM_17B_Release_W18.26.1_P25_Debug Project Version: sharkle_Smart_Phone BASE Version: FM_BASE_17B_Release_W18.26.1_P25 HW Version: sc9832e_modem CMP_Time : 08-27-2020 14:37:04 MODEM TAG : MOCORTM_17B_Release_W18.26.1_P25_Debug_FM_BASE_17B_Release_W18.26.1_P25_sc9832e_modem_sharkle_Smart_Phone NVMng : SecurityInfo IMEI[1] : 355183 IMEI[2] : 3546480 WIFIMAC : 40D25FE67A89 BT_MAC : 40D25FE67A88 SEC : SLS:0, SKS:0, SKV:3 SLStatus : 11 Unlocking device ... Sync data ... Device unlocked! Done! Elapsed: 00:00:27 |
The Following 2 Users Say Thank You to yuranc8 For This Useful Post: |
04-17-2021, 06:53 | #66480 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Infinix x625c read factory firmware done by cm2 Card found : 73CA70CC , v0147 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.21 Load IDBase v210169 Ok! Update configuration ... Update Ok! Load IDBase v210169 Ok! Operation : Identify [ v2.21 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM13) MODE : PRELOADER PORT PORT : 13 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6757 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 CODE : Kibo TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x02 BROM : PRELOADER PORT MODE : Tecno : SEC_BASE | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_SWSEC.bin AGENT : Found MT6757 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: 90014A484347386134A2CA8829C8A5A3 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HCG8a4 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6757 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 259044C088C9EA1DA7FEEE5853218B0D DA : USB : HIGH-SPEED Boot done! Patch Level : PPR1.180610.011 Display ID : X625C-H576CD-P-190807V70 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-08-05 Build Time : 07.08.2019 Product Model : Infinix X625C Product Brand : Infinix Product Name : H576CD Product Device : Infinix-X625C Product Manfct : alps Product Info : x625c64_h576 Product Board : Infinix-X625C Board Platform : mt6757 Product Manfct : INFINIX MOBILITY LIMITED USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption **) IMEI[0] : 355184104118743 IMEI[1] : 355184104118750 NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] Backup sensetive data [ 15 ] Backup path : Backup\MT6757__259044C088C9EA1DA7FEEE5853218B0D\ [8] Read : NVRAM [32] Read : NVDATA [24] Read : PROINFO [9] Read : LK [31] Read : NVCFG [19] Read : PROTECT1 [20] Read : PROTECT2 [18] Read : PERSIST [0] Read : PRELOADER [2] Read : SECCFG Backup done! STORAGE : LifeStatus : eMMC : NOT implemented in selected DA! Done! Elapsed: 00:00:28 Operation : Read Firmware [ v2.21 ] ExtSparse : Enabled ForceRead : Enabled 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM13) MODE : PRELOADER PORT PORT : 13 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6757 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 CODE : Kibo TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x02 BROM : PRELOADER PORT MODE : Tecno : SEC_BASE | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_SWSEC.bin AGENT : Found MT6757 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: 90014A484347386134A2CA8829C8A5A3 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HCG8a4 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6757 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 259044C088C9EA1DA7FEEE5853218B0D DA : USB : HIGH-SPEED Boot done! Patch Level : PPR1.180610.011 Display ID : X625C-H576CD-P-190807V70 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-08-05 Build Time : 07.08.2019 Product Model : Infinix X625C Product Brand : Infinix Product Name : H576CD Product Device : Infinix-X625C Product Manfct : alps Product Info : x625c64_h576 Product Board : Infinix-X625C Board Platform : mt6757 Product Manfct : INFINIX MOBILITY LIMITED MT6757__alps__Infinix_X625C__9__X625C-H576CD-P-190807V70__PPR1.180610.011__x625c64_h576 Read : preloader.bin Read : md1rom.img Read : md1dsp.img Read : md1arm7.img Read : md3rom.img Read : nvram.bin Read : lk.bin Read : boot.img Read : logo.bin Read : dtbo.img Read : tz.img Read : vendor.img ExtSparse : Compression ratio : 41% Read : system.img ExtSparse : Compression ratio : 21% Read : persist.img ExtSparse : Compression ratio : 92% Read : cache.img Read : recovery.img Read : tkv.img Read : proinfo.img Read : tranfs.img Read : userdata.img FW Size : 3.75 GB Android Info saved : _Android_info.txt Scatter : MT6757_Android_scatter.txt Saved to : C:\InfinityBox\CM2MT2\Backup\MT6757__alps__Infinix _X625C__9__X625C-H576CD-P-190807V70__PPR1.180610.011__x625c64_h576\ Done! Elapsed: 00:06:49 |
