06-24-2021, 13:03 | #66991 (permalink) |
Freak Poster Join Date: Jul 2008 Location: Pakistan
Member: 826534 Status: Offline Sonork: 100.1660561 Thanks Meter: 44 | HUAWEI Y600-U20 READ INFO & FLASH CM2 v1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 18 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040502A150303127 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040502A150303127 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0x84189363089C672CD10012691451254E INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : HUAWEI ProdName : Y600-U20 ProdModel : HUAWEI Y600-U20 Device : HWY600-U AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : Y600-U20V100R001C435B018 Done! Elapsed: 00:00:05 Scatter Load Ok , BaseBand : MT6572 , Project : huaqin72_we_b2b_jb3 , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Start at : [24/06/2021 / 1:07:12 pm] Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 18 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040502A150303127 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040502A150303127 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0x84189363089C672CD10012691451254E INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : huaqin72_we_b2b_jb3 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3908 mV BL : BatteryLevel Ok Backup enabled! Backup saved : Backup\Flash\90014A4834473164040502A150303127\ BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x0000000094840000 Flash Pre-Erase Done, time used : 00:00:06 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_huaqin72_we_b2b_jb3.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0013 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:02:30 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:08 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:22 Reconnect Power/Cable! Finish at : [24/06/2021 / 1:10:33 pm] |
The Following User Says Thank You to jddj For This Useful Post: |
06-24-2021, 14:58 | #66992 (permalink) |
Crazy Poster Join Date: Jun 2021 Location: ATTOCK Pakistan Age: 39
Member: 2990669 Status: Offline Sonork: 100.1660561 Thanks Meter: 61 | QMobile Black Two READ INFO & Format File System / Reset Settings [CENTER Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 16 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : Black_Two Model Brand : QMobile Model Device: Black_Two AndrVersion : 6.0 BaseBand CPU: SP7731CEA CompileDate : 07/05/2018 5:01:27 am Project Ver : QMobile BlackTwo_MP_07_05 Model Ext : QMobile Black Two ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:49 Reconnect Power/Cable!] Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 15 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x0000000133CF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:01:06 Reconnect Power/Cable! Finish at : [24/06/2021 / 11:24:23 am][/CENTER] |
The Following User Says Thank You to geo/mobile For This Useful Post: |
06-25-2021, 11:22 | #66993 (permalink) |
No Life Poster Join Date: Feb 2012 Location: Pakistan
Member: 1726229 Status: Offline Thanks Meter: 223 | VIVO Y30 1940 screenlock FRP remove done Smart Reset Code: Operation : Reset Settings/Format FS [ v2.21 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM43) MODE : BOOTROM PORT : 43 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 52427340E5ACA496A237B2F3B7745722 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 8C9E290C40B832FE3855937D7F53A11C83173015A1792E626903D9342A962C7A BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: 150100444836444142028993681A178B EMMC: VEN : SAMSUNG | OEM : 01 | DEV : DH6DAB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 8A3D05B814C9C55C1B82ED33EDB98D7E DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x825757 Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:02:41 Reconnect Power/Cable! |
06-25-2021, 12:29 | #66994 (permalink) |
Member: 2990669 Status: Offline Sonork: 100.1660561 Thanks Meter: 61 | Itel a25 l5002 Operation : Identify [ v2.13 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : itel L5002 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Device info : Patch Level : PPR1.180610.011 Display ID : L5002-F3210-9.0-OP-V052-20210105 Ver. Incmt : OP-V052-20210105 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2021-01-05 Build Time : 05.01.2021 Product Model : itel L5002 Product Brand : Itel Product Name : F3210 Product Device : itel-L5002 Product Manfct : itel Product Info : L5002 Product Board : L5002 Board Platform : sp9832e Product Name : L5002 Product Device : L5002 Platform Version: MOCORTM_18A_ITEL_RLS1_W19.36.4_P6_Debug Project Version: sharkle_Smart_Phone BASE Version: FM_BASE_18A_ITEL_RLS1_W19.36.4_P6 HW Version: sc9832e_modem CMP_Time : 02-27-2020 20:34:00 MODEM TAG : MOCORTM_18A_ITEL_RLS1_W19.36.4_P6_Debug_FM_BASE_18 A_ITEL_RLS1_W19.36.4_P6_sc9832e_modem_sharkle_Smar t_Phone USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:01:25 |
The Following 2 Users Say Thank You to geo/mobile For This Useful Post: |
06-25-2021, 12:29 | #66995 (permalink) |
Member: 2990669 Status: Offline Sonork: 100.1660561 Thanks Meter: 61 | Itel a25 l5002 Identify [ v2.13 ] Operation : Identify [ v2.13 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : itel L5002 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Device info : Patch Level : PPR1.180610.011 Display ID : L5002-F3210-9.0-OP-V052-20210105 Ver. Incmt : OP-V052-20210105 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2021-01-05 Build Time : 05.01.2021 Product Model : itel L5002 Product Brand : Itel Product Name : F3210 Product Device : itel-L5002 Product Manfct : itel Product Info : L5002 Product Board : L5002 Board Platform : sp9832e Product Name : L5002 Product Device : L5002 Platform Version: MOCORTM_18A_ITEL_RLS1_W19.36.4_P6_Debug Project Version: sharkle_Smart_Phone BASE Version: FM_BASE_18A_ITEL_RLS1_W19.36.4_P6 HW Version: sc9832e_modem CMP_Time : 02-27-2020 20:34:00 MODEM TAG : MOCORTM_18A_ITEL_RLS1_W19.36.4_P6_Debug_FM_BASE_18 A_ITEL_RLS1_W19.36.4_P6_sc9832e_modem_sharkle_Smar t_Phone USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:01:25 |
06-25-2021, 14:25 | #66996 (permalink) |
Freak Poster Join Date: Apr 2012 Location: 9ja
Member: 1745682 Status: Offline Thanks Meter: 49 | TECNO CAMON 17 CG6 ANDROID 11 FRP REMOVED ONE CLICK WITH CM2MT2 V2.24 Operation : Reset Settings/Format FS [ v2.24 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM11) MODE : BOOTROM PORT : 11 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN RAPHAEL BROM : MEID : BB24E088EBC9AD3E3FDD96C71422A0ED BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : TECNO : SEC_MIXED | Manual : Disabled BROM : SOCID : DFDFED062F5511219EEDCEDC28730FDC8EF64237CE076E977C EE8B24BE9F7D5B BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Look for cookies BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : CHANGE : v2112 AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_cg6_h696.bin EMI : CNT : 000D EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: 150100445636444142026F81E828C7D3 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : DV6DAB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x1D1EC00000 [ 116.48 GB ] CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 5E3A065092AF91BC2EE99787BC178F7D DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:43 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to mrnice2 For This Useful Post: |
06-25-2021, 15:05 | #66997 (permalink) |
No Life Poster Join Date: Mar 2011 Location: PAKISTAN
Member: 1537135 Status: Offline Thanks Meter: 1,021 | Infinix-X5515F Read Flash File Done Infinity-Box Card found : C1B4DF65 , v0149 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.25 Load IDBase v616218 Ok! UserName and/or Password not set! Can't continue! Update failed! Check settings and/or internet connection! Operation : Identify [ v2.25 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM14) MODE : PRELOADER PORT PORT : 14 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : INFINIX : SEC_NEW | Manual : Disabled BROM : SOCID : 6A4B1DD513A58D125A5EFF0813645929DA9240B56D29797C50 B1E0A0CF6F658C AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 150100514536334D42031F34A806A55F EMMC: VEN : SAMSUNG : OEM : 0 : ID : 514536334D42 EMMC: VEN : SAMSUNG : QE63MB EMMC: SNN : 523544582 ( 0x1F34A806) , MF : 10/2018 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 6E6ECF62A50DCB4936C8AA8D54700863 DA : USB : HIGH-SPEED Boot done! Patch Level : O11019 Display ID : X5515F-H398F-O-180918V174 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2018-09-05 Build Time : 18.09.2018 Product Brand : Infinix Product Name : H398 Product Device : Infinix-X5515F Product Model : Infinix X5515F Product Manfct : INFINIX MOBILITY LIMITED Product Board : x5515c_h398 Board Platform : mt6739 USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption *) NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] Backup sensetive data [ 14 ] Backup path : Backup\MT6739__6E6ECF62A50DCB4936C8AA8D54700863\ Backup done! STORAGE : LifeStatus : eMMC : NOT implemented in selected DA! Done! Elapsed: 00:00:14 Operation : Read Firmware [ v2.25 ] ExtSparse : Enabled ForceRead : Disabled 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM14) MODE : PRELOADER PORT PORT : 14 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : INFINIX : SEC_NEW | Manual : Disabled BROM : SOCID : 6A4B1DD513A58D125A5EFF0813645929DA9240B56D29797C50 B1E0A0CF6F658C AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 150100514536334D42031F34A806A55F EMMC: VEN : SAMSUNG : OEM : 0 : ID : 514536334D42 EMMC: VEN : SAMSUNG : QE63MB EMMC: SNN : 523544582 ( 0x1F34A806) , MF : 10/2018 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 6E6ECF62A50DCB4936C8AA8D54700863 DA : USB : HIGH-SPEED Boot done! Patch Level : O11019 Display ID : X5515F-H398F-O-180918V174 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2018-09-05 Build Time : 18.09.2018 Product Brand : Infinix Product Name : H398 Product Device : Infinix-X5515F Product Model : Infinix X5515F Product Manfct : INFINIX MOBILITY LIMITED Product Board : x5515c_h398 Board Platform : mt6739 MT6739__INFINIX_MOBILITY_LIMITED__Infinix_X5515F__ 8.1.0__X5515F-H398F-O-180918V174__O11019 Read : preloader.bin Read : recovery.img Read : persist.img ExtSparse : Compression ratio : 92% Read : proinfo.img Read : md1rom.img Read : md1dsp.img Read : spmfw.img Read : mcupmfw.img Read : nvram.bin Read : lk.bin Read : loader_ext.img Read : boot.img Read : logo.bin Read : odmdtbo.img Read : tz.img Read : vendor.img ExtSparse : Compression ratio : 14% Read : system.img ExtSparse : Compression ratio : 40% Read : cache.img Read : userdata.img FW Size : 2.29 GB Android Info saved : _Android_info.txt Scatter : MT6739_Android_scatter.txt Saved to : C:\Users\MY PC\Desktop\New folder\infinix x5515f\MT6739__INFINIX_MOBILITY_LIMITED__Infinix_X 5515F__8.1.0__X5515F-H398F-O-180918V174__O11019\ Done! Elapsed: 00:06:59 |
The Following 5 Users Say Thank You to naveedullah0044 For This Useful Post: |
06-26-2021, 11:20 | #66998 (permalink) |
Freak Poster Join Date: Jun 2016 Location: INDIA (BIHAR,MOTIHARI)
Member: 2589490 Status: Offline Sonork: live:.cid.32a2af136177ed3 Thanks Meter: 232 | Redmi 6A (REDMI)PATTERN FRP REMOVE BY CM2 |
The Following 2 Users Say Thank You to HASIM MOBILE For This Useful Post: |
06-26-2021, 11:22 | #66999 (permalink) |
The Following User Says Thank You to HASIM MOBILE For This Useful Post: |
06-26-2021, 11:25 | #67000 (permalink) |
Member: 2589490 Status: Offline Sonork: live:.cid.32a2af136177ed3 Thanks Meter: 232 | OPPO A5S (CPH1909) PATTERN REMOVED successfully by CM2 |
06-26-2021, 11:26 | #67001 (permalink) |
06-26-2021, 12:49 | #67002 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | QMobile Q Infinity C Frp Code: Model Name : Q_Infinity_C Model Brand : Qmobile Model Device: Q_Infinity_C AndrVersion : 7.0 BaseBand CPU: SP7731CEA CompileDate : 2/9/2018 2:28:02 AM Project Ver : QMobile_Q Infinity C_MP_26_01 Model Ext : QMobile Q Infinity C ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:52 Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 77 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x eMMC Loader v7 InfinityBox Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x00000002CA5F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:31 Reconnect Power/Cable! |
06-26-2021, 12:50 | #67003 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | QMobile X30 Flash Code: Brand : TINNO ProdName : QMobile X30 ProdModel : QMobile X30 Device : QMobile X30 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1 Done! Elapsed: 00:00:09 Reconnect Power/Cable! Scatter Load Ok , BaseBand : MT6572 , Project : s4050ap , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A48344732611101938811B362F3 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A48344732611101938811B362F3 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD5229C2578CA739DE4721BD5EE5B0628 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : s4050ap , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Disabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3910 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000000E5E00000 Flash Pre-Erase Done, time used : 00:00:05 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_s4050ap.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:02:56 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:19 Reconnect Power/Cable! |
06-26-2021, 12:51 | #67004 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | vivo 1915 Format Code: AP_CHIP : MT6768 AP_SWTM : Thu Jan 21 14:40:06 CST 2021 AP_SWVR : alps-mp-p0.mp3.tc19sp.sp2-V1.0.1_bbk.p0mp3.k68v1.64_P220 MD_CHIP : MT6768 MD_SWTM : 2000.00.00 MD_DSPV : 1.0 MD_DSPP : MOLY.LR12A.R3.MP.V57.P112 MD_SWVR : BBK_P0MP3_K68V1_64_BSP_HW MD_HWVR : Unknown Patch Level : PPR1.180610.011 Display ID : PPR1.180610.011 release-keys Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2021-01-01 Build Time : 21.01.2021 Product Model : vivo 1915 Product Brand : vivo Product Name : PD1934F_EX Product Device : PD1934F_EX Product Manfct : vivo Product Info : k68v1_64 IMEI[1] : IMEI[2] : Done! Elapsed: 00:00:46 Operation : Reset Settings/Format FS [ v2.24 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB VCOM (Android) (COM101) MODE : MTK USB PORT PORT : 101 Boot done! AP_CHIP : MT6768 AP_SWTM : Thu Jan 21 14:40:06 CST 2021 AP_SWVR : alps-mp-p0.mp3.tc19sp.sp2-V1.0.1_bbk.p0mp3.k68v1.64_P220 Format Ok : UserData - > Format in META will NOT reset FRP! Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
06-26-2021, 12:51 | #67005 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | vivo V2026 Format Frp Code: Product Brand : vivo Product Device : k65v1_64_bsp Product Model : vivo 2026 Product Name : full_k65v1_64_bsp Patch Level : QP1A.190711.020 Display ID : QP1A.190711.020 release-keys Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2020-11-01 Build Time : 26.11.2020 Product Info : k65v1_64_bsp Product Board : k65v1_64_bsp Board Platform : mt6765 Product Manfct : vivo USERDATA : FILESYSTEM : EXT4 with FBE ( File-Base Encryption ) NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] STORAGE : LifeStatus : eMMC : OK! Done! Elapsed: 00:00:53 Operation : Reset Settings/Format FS [ v2.24 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM33) MODE : BOOTROM PORT : 33 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 103591E6F2B828F6AD0F2C4971AD8231 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2112 | Manual : Disabled BROM : SOCID : 3EC077DCCE299C129488504AAA4F200C8F4AC77DE247DC26D48052215CB8C243 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_k65v1_64_bsp.bin EMI : CNT : 0007 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: 90014A68433961503301103E7651B7F3 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : hC9aP3 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 9B7448C0A392E5282B8C9DAE4B8DDD08 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x825757 Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:45 Reconnect Power/Cable! |
The Following User Says Thank You to Tanha0321 For This Useful Post: |
