07-30-2023, 09:56 | #74611 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Nokia 1 MTK6735 One Click FRP/Pattren Reset Done With King Infinity CM2 Code: S/N: A19EC787 v0155 Chinese Miracle II - MT2 Service Tool v2.46 Init log engine... Ok Build directories tree... Ok Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 35 dirs: 0 Verify device database... BuiltIn: 28 Custom: 0 Build device list... Ok Scan 76 profiles... Ok Init environment... Ok Load IDBase v418494 Ok Check for updates... You have latest version [2.46] installed Telegram Channel: @InfinityBox Telegram Chat: @InfinityBoxTalks Account: https://infinity-box.com/service/ Wrong Username or Password - set it at [Settings|Account] to get server access Operation: Reset Settings/Format FS [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: SMART RESET Wait... WARNING: Reset may clear ALL USER DATA! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM293) MODE [0]: BOOTROM; PORT: 293 Waiting for BOOT ACK... BROM: Skip ACK verication BROM: Init... Ok CHIP: MT6735 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0335 TYPE: LEGACY [MTK] MEID: 147902361B2C677F41A31649BBBEAD0C BROM: Sec Level: 0x00000001 Mode: SBC VER: 0x05 BL: 0xFE [BOOTROM] BROM: EMI: Search libusb exec warn conn enum v1.2.7.3 0x28 EMI: Not found AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6735 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started NAND: DEVICE NOT FOUND EMMC: OK CID: 90014A483847346132A5C6D005B66D5F DA v4.2.155 EXT_RAM NOT initialized EMMC: OK CID: 484A019061344738D0C6A5325F6DB605 NAND: DEVICE NOT FOUND DRAM: 0x00BC EMI: Init EMI [0] via Internal database INIT: 0x00BC eMMC [ 0x40000000 [ 1.00 Gb ] ] RAM: DRAM: 0x40000000 [ 1.00 Gb ] DA: DRAM ready Boot to 2nd DA... Ok Load HW info... EMMC CID: 90014A483847346132A5C6D005B6155F VEN: Hynix OEM: 330 ID: 483847346132 [H8G4a2] PRV: 0xA5 SNN: 3335521718 [0xC6D005B6] MM/YY: 1/2018 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x1D2000000 [ 7.28 Gb ] RAM: SRAM: 0x00020000 [ 128.00 Kb ] RAM: DRAM: 0x40000000 [ 1.00 Gb ] CHIP: MT6735 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0335 TYPE: LEGACY [MTK] RNID: 647697D1A2F1709D488C47064367F167 MEID: 147902361B2C677F41A31649BBBEAD0C DA: Status: BLANK FLASH; Boot Style: EMMC FLASH BOOT USB: FULL-SPEED Change Port Speed PTFN: MediaTek DA USB VCOM (Android) (COM294) MODE: PRELOADER PORT; PORT: 294 Boot done LEGACY [MTK] Analyze PMT... Ok PMT: LGPT [0x06] Records: 34 Select info source... Ok SW: Nokia/Frontier_00WW/FRT:10/QP1A.190711.020/00WW_3_110:user/release-keys Product Brand: alps Product Device: FRT Product Model: Nokia 1 Product Name: FRT_00WW_FIH Patch Level: QP1A.190711.020 Display ID: 00WW_3_110 SW Version: 00WW_3_110 Ver. CodeName: REL Ver. Release: 10 Sec. Patch: 2020-09-05 Build Time: 26/08/2020 3:24:13 pm CPU: armeabi-v7a,armeabi Product Info: FRT SW: Frontier_00WW-user 10 QP1A.190711.020 00WW_3_110 release-keys Product Board: FRT Board Platform: mt6737m Product Brand: Nokia Product Manfct: HMD Global Product Name: Frontier_00WW Strategy: [nokia] SmartInfo: Android Ver: 10 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] Verify device config... Ok Loaders Ok Backup to C:\InfinityBox\CM2MT2\backup\MT6735__147902361B2C677F41A31649BBBEAD0C\ Items to check: 20 Read [3] NVRAM Read [19] NVDATA Read [2] PROINFO Read [6] LK Read [4] PROTECT1 lda-pt: pgpt Read [0] PRELOADER Done 6 files Compress: C:\InfinityBox\CM2MT2\backup\MT6735__147902361B2C677F41A31649BBBEAD0C\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6735__147902361B2C677F41A31649BBBEAD0C.7z Verified Stage : ANDROID OS [1] Process RESET PROTECTION... Ok [2] Process USERDATA... Ok [3] Process CACHE... Ok [4] Verified [5] Verified [6] Process USERDATA... Ok [7] Verified Stage : SMART Done: 00:00:48 Reconnect Power/Cable now |
07-30-2023, 12:05 | #74612 (permalink) |
Freak Poster Join Date: Nov 2013 Location: Infinity Team
Member: 2072265 Status: Offline Thanks Meter: 47 | nokia ta1464 format done Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 96 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 52EFA31B67DED26CD728F0AEF1B47FD0 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Executing FFS FORMAT now... FAT_RANGE : 0x00300000-0x003FDFFF , LEN : 0x000FE000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
07-30-2023, 12:11 | #74613 (permalink) |
Member: 2072265 Status: Offline Thanks Meter: 47 | jazz digit format done with cm2 Operation: Reset Settings/Format FS [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: FACTORY RESET : WIPE + FRP Wait... WARNING: Reset may clear ALL USER DATA! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM96) MODE [0]: BOOTROM; PORT: 96 Waiting for BOOT ACK... BROM: Skip ACK verication BROM: Init... Ok CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0002 EVOL: 0x0000 HWC: 0x0699 CODE: Zion TYPE: MODERN [RAPHAEL] MEID: CB6800ABB0BFCE4CEB7C7D1DAAF28ACD BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: F9056B7FF6EF9067D69F4BE2AC642270D37D0EF760620F91CD C17883AD8DC1F9 SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok FF: Looking for EMI Found SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: CB6800ABB0BFCE4CEB7C7D1DAAF28ACD AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.bin Looking for suitable BootChain in DA... Found MT6739 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMI: Init Ok EMI: FireFly preloader_fise6731_kaio_m.bin with 6 memory type(s) 1. eMMC DDR3 ID: 700100454534454434 Ven: Kingston | Dev: EE4ED4 RAM: 512.00 Mb 2. eMMC DDR3 ID: F40122426977696E20 Ven: Biwin | Dev: Biwin RAM: 512.00 Mb 3. eMMC DDR3 ID: 150100463558354342 Ven: Samsung | Dev: F5X5CB RAM: 512.00 Mb 4. eMMC DDR3 ID: 150100464A32354142 Ven: Samsung | Dev: FJ25AB RAM: 512.00 Mb 5. eMMC DDR3 ID: FE014E50314A39344D Ven: Micron | Dev: P1J94M RAM: 512.00 Mb 6. eMMC DDR3 ID: 90014A483447326111 Ven: Hynix | Dev: H4G2a RAM: 512.00 Mb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x00020000 [ 128.00 Kb ] RAM: DRAM: 0x20000000 [ 512.00 Mb ] EMMC CID: 90014A483447326111020706F0AE250D VEN: Hynix OEM: 330 ID: 483447326111 [H4G2a] PRV: 0x02 SNN: 117895342 [0x0706F0AE] MM/YY: 2/2018 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0xE9000000 [ 3.64 Gb ] CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0699 CODE: Zion TYPE: MODERN [RAPHAEL] RNID: FDE8C12F5877BFB847C5E5B3A89CA3DD MEID: CB6800ABB0BFCE4CEB7C7D1DAAF28ACD USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 34 Select info source... Ok Patch Level: MRA58K Display ID: Digit_M42445P_DG_SW02_20210128_1035 SW Version: Digit_M42445P_DG_SW02_20210128_1035 Ver. CodeName: REL Ver. Release: 6.0 Sec. Patch: 2015-10-01 Build Time: 1/28/2021 2:37:45 AM Product Model: Digit4G-Bold Product Brand: Digit Product Name: Digit4G-Bold Product Device: Digit4G-Bold Product Manfct: alps CPU: armeabi-v7a,armeabi Board Platform: mt6739 Product Info: Digit4G-Bold SW: full_fise6731_kaio_m-user 6.0 MRA58K 1611801406 dev-keys Product Model: mt6731 Strategy: [none|generic] Verify device config... Ok Loaders Ok Backup to C:\InfinityBox\CM2MT2\backup\MT6739__CB6800ABB0BFC E4CEB7C7D1DAAF28ACD\ Items to check: 20 Read [21] NVRAM Read [8] NVDATA Read [14] PROINFO ZERO CONTENT file [3.00 Mb] deleted: C:\InfinityBox\CM2MT2\backup\MT6739__CB6800ABB0BFC E4CEB7C7D1DAAF28ACD\proinfo.bin Read [22] LK Read [7] NVCFG Read [10] PROTECT1 Read [1] PGPT Read [0] PRELOADER Done 7 files Compress: C:\InfinityBox\CM2MT2\backup\MT6739__CB6800ABB0BFC E4CEB7C7D1DAAF28ACD\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6739__CB6800ABB0BFC E4CEB7C7D1DAAF28ACD.7z Verified Stage : ANDROID OS [1] Verified [2] Process USERDATA... Ok Stage : FRP Done: 00:00:55 Reconnect Power/Cable now |
07-31-2023, 05:09 | #74614 (permalink) |
Member: 2072265 Status: Offline Thanks Meter: 47 | itel vision 3 frp remove done Operation : Format FS / Reset Settings [ v2.14 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : iTel : S661L_Vision-3 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:23 |
07-31-2023, 08:41 | #74615 (permalink) |
Member: 2072265 Status: Offline Thanks Meter: 47 | oppo A15 smart reset done with cm2 Operation: Reset Settings/Format FS [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: SMART RESET Wait... WARNING: Reset may clear ALL USER DATA! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM96) MODE [0]: BOOTROM; PORT: 96 Waiting for BOOT ACK... BROM: Skip ACK verication BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: FBBF8218AB7B34B05286AE5A6ECE8A32 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 6E1893128C5E4F04ACDA47AFDECC8E13C1C949473A1CB61475 6AFC378E128AD2 SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok EMI known SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: FBBF8218AB7B34B05286AE5A6ECE8A32 AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 90014A68423861503E030035D9B1C7A5 VEN: Hynix OEM: 330 ID: 68423861503E [hB8aP>] PRV: 0x03 SNN: 3529137 [0x0035D9B1] MM/YY: 12/2020 EMI: Init Ok EMI: FireFly preloader_oppo6765.bin with 12 memory type(s) 1. eMMC LP_DDR4X ID: 1501003458364B4D42 Ven: Samsung | Dev: 4X6KMB RAM: 2.00 Gb 2. eMMC LP_DDR4X ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 2.00 Gb 4. eMMC LP_DDR4X ID: 13014E47314A395238 Ven: Micron | Dev: G1J9R8 RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 150100445836384D42 Ven: Samsung | Dev: DX68MB RAM: 3.00 Gb 6. eMMC LP_DDR4X ID: 150100444836444142 Ven: Samsung | Dev: DH6DAB RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 13014E47314A395339 Ven: Micron | Dev: G1J9S9 RAM: 4.00 Gb 8. eMMC LP_DDR4X ID: 150100445636444D42 Ven: Samsung | Dev: DV6DMB RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 90014A684339615033 Ven: Hynix | Dev: hC9aP3 RAM: 4.00 Gb 10. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 4.00 Gb 11. eMMC LP_DDR4X ID: 150100445636444142 Ven: Samsung | Dev: DV6DAB RAM: 4.00 Gb 12. eMMC LP_DDR4X ID: 150100445636444242 Ven: Samsung | Dev: DV6DBB RAM: 4.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x80000000 [ 2.00 Gb ] EMMC CID: 90014A68423861503E030035D9B1C7A5 VEN: Hynix OEM: 330 ID: 68423861503E [hB8aP>] PRV: 0x03 SNN: 3529137 [0x0035D9B1] MM/YY: 12/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 521EE7A30E96C3CC46C8DF4ADBBD2EAA MEID: FBBF8218AB7B34B05286AE5A6ECE8A32 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 47 Select info source... Ok Patch Level: QP1A.190711.020 Display ID: QP1A.190711.020 release-keys Ver. CodeName: REL Ver. Release: 10 Sec. Patch: 2022-04-05 Build Time: 4/12/2022 12:27:05 PM CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: oppo6765 SW: full_oppo6765-user 10 QP1A.190711.020 bedd37e98646d3a1 release-keys Strategy: [oppo] SmartInfo: Android Ver: 10 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] Verify device config... Ok Loaders Ok Backup exist: C:\InfinityBox\CM2MT2\backup\MT6765__FBBF8218AB7B3 4B05286AE5A6ECE8A32 Stage : ANDROID OS [1] Process RESET PROTECTION... Ok [2] Process USERDATA... Ok [3] Process CACHE... Ok [4] Verified [5] Verified [6] Process USERDATA... Ok [7] Process USERDATA... Ok Stage : FRP Stage : SMART Done: 00:01:12 Reconnect Power/Cable now |
07-31-2023, 08:50 | #74616 (permalink) |
Member: 2072265 Status: Offline Thanks Meter: 47 | tecno bf7 frp remove done Operation: Reset Settings/Format FS [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: FRP [ RESET PROTECTION ] Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (Android) (COM23) MODE [0]: PRELOADER PORT; PORT: 23 Waiting for BOOT ACK... PRELOADER ACK Ok BROM: Init... Ok CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] AGENT: AUTO: Tecno: 2023-05 [caf6df7e] C:\InfinityBox\CM2MT2\boot\Infinix\2023-05\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6761 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x0003A600 [ 233.50 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: D6010341334135363112CD87B0D119FF VEN: Foresee OEM: 259 ID: 413341353631 [A3A561] PRV: 0x12 SNN: 3448221905 [0xCD87B0D1] MM/YY: 1/2022 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE67800000 [ 57.62 Gb ] CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] RNID: 340F1641404AD3514382B3DF30D53524 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 50 Select info source... Ok Product Brand: TECNO Product Device: TECNO-BF7 Product Model: TECNO BF7 Product Name: BF7-GL SW: TECNO/BF7-GL/TECNO-BF7:12/SP1A.210812.016/230315V839:user/release-keys Patch Level: SP1A.210812.016 Display ID: BF7-H6127ABCDSTUAdAeAfArAs-S-GL-230315V839 SW Version: 230315V839 Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2023-03-05 Build Time: 3/14/2023 10:52:08 PM Product Info: bf7_h6127 SW: vnd_bf7_h6127-user 12 SP1A.210812.016 274334 release-keys Product Manfct: TECNO Product Board: TECNO-BF7 Board Platform: mt6761 Strategy: [none|generic] Verify device config... Ok Loaders Ok Backup to C:\InfinityBox\CM2MT2\backup\MT6761__340F1641404AD 3514382B3DF30D53524\ Items to check: 20 Read [16] NVRAM Read [8] NVDATA Read [3] PROINFO Read [7] NVCFG Read [11] PROTECT1 Read [1] PGPT Read [14] PERSIST Read [0] PRELOADER Done 8 files Compress: C:\InfinityBox\CM2MT2\backup\MT6761__340F1641404AD 3514382B3DF30D53524\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6761__340F1641404AD 3514382B3DF30D53524.7z Verified Stage : ANDROID OS [1] Process RESET PROTECTION... Ok [2] Verified Stage : FRP Done: 00:00:51 Reconnect Power/Cable now |
07-31-2023, 11:43 | #74617 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,776 | Realme c21y reset pattern & frp done by cm2 Card found : 73CA70CC , v0155 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Identify [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Realme : C21Y_C25Y_RMX3261_RMX3262_RMX3263 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Device info : Product Brand : realme Product Device : RMX3261 Product Model : RMX3261 Product Name : RMX3261 Patch Level : RP1A.201005.001 Display ID : RMX3261_11_A.53 Ver. Incmt : 1633442216000 Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2021-09-05 Build Time : 05.10.2021 SW OTA Version : RMX3261_11_A.53_20211005204136 Product Info : S19610AA1 Product Board : RMX3261 Board Platform : ums512 Product Manfct : realme Platform Version: MOCORTM_20A_W21.35.3_P2_Debug Project Version: sharkl5pro_pub BASE Version: 4G_MODEM_20A_W21.35.3_P2 HW Version: sharkl5pro_modem CMP_Time : 09-24-2021 18:35:55 MODEM TAG : MOCORTM_20A_W21.35.3_P2_Debug_4G_MODEM_20A_W21.35. 3_P2_sharkl5pro_modem_sharkl5pro_pub USERDATA : FILESYSTEM : F2FS with FBE ( File-Base Encryption ) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:00:49 Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Realme : C21Y_C25Y_RMX3261_RMX3262_RMX3263 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:20 |
07-31-2023, 12:02 | #74618 (permalink) |
No Life Poster Join Date: Dec 2012 Location: Khushab Punjab Pakistan
Member: 1857951 Status: Offline Sonork: 100.1638512 Thanks Meter: 261 | infinix Hot 9 Play Read Flash File Done With Cm2 By .::Mustafa::. Operation: Read Firmware [ v2.38c9 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Destination: E:\infinex hot 9 play\ Free space: 12.47 Gb Wait... [+] Pack FW [Sparse] [-] Forced Read 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (Android) (COM6) MODE: PRELOADER PORT; PORT: 6 Waiting BOOT ack... PRELOADER: ACK confirmed BROM: Init BROM BROM: Init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA BROM: BROM|BL : 0xFF|0x03 [PRELOADER PORT] AGENT: Infinix: SEC_NEW | Manual: Off [c7992f8b] K:\Box setup\CM2\CM2\CM2MT2\boot\Infinix\SEC_NEW\MTK_AllI nOne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started DA: SYNC DA: MODE: PRELOADER DA: EXT_RAM initialized DA: BOOT to 2nd DA... DA: 2ND stage confirmed DA: SYNC with DA passed DA: Receiving HW info SRAM 0x00080000 [ 512.00 KB ] DRAM 0xC0000000 [ 3.00 GB ] EMMC: CID: 90014A68433861503E0300056F967707 VEN: Hynix OEM: 74 ID: 68433861503E [hC8aP>] PRV: 0x03 SNN: 356246 [0x00056F96] MF: 7/2020 BOOT1: 0x00400000 [ 4.00 MB ] BOOT2: 0x00400000 [ 4.00 MB ] RPMB: 0x01000000 [ 16.00 MB ] USER: 0xE8F800000 [ 58.24 GB ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 6AF0099F090F7B222430C1E757FE9396 DA: USB: HIGH-SPEED Boot done [1] Reading... Ok Reading... Scan memory... Found region: 27380 [12|27380|0] Scan filesystem... SW : Infinix/X680B-OP/Infinix-X680B:10/QP1A.190711.020/EFIJ-OP-220505V281:user/release-keys Product Brand: Infinix Product Device: Infinix-X680B Product Model: Infinix X680B Product Name: X680B-OP Patch Level: QP1A.190711.020 Display ID: X680B-H6215EFIJ-Q-OP-220505V281 SW Version: EFIJ-OP-220505V281 Ver. CodeName: REL Ver. Release: 10 Sec. Patch: 2022-04-05 Build Time: 05.05.2022 CPU : arm64-v8a,armeabi-v7a,armeabi CPU : armeabi-v7a,armeabi CPU : arm64-v8a Product Info: x680b_h6215 SW : full_x680b_h6215-user 10 QP1A.190711.020 292143 release-keys Product Board: Infinix-X680B Board Platform: mt6765 Product Manfct: INFINIX MOBILITY LIMITED Startegy: 7 Firmware ID: MT6765_INFINIX_MOBILITY_LIMITED_Infinix_X680B_10_X 680B-H6215EFIJ-Q-OP-220505V281_QP1A.190711.020_x680b_h6215 Read: preloader.bin Read: cm2pit.bin Read: boot_para.img Read: proinfo.img Read: para.img Read: expdb.img Read: frp.img Read: metadata.img Read: md_udc.img Read: nvcfg.img Read: nvdata.img Read: persist.img ExtSparse: Compression ratio: 98% Read: protect.img Read: protect.img Read: tkv.img Read: recovery.img Read: seccfg.img Read: sec.img Read: md1rom.img Read: spmfw.img Read: tinysys-scp.bin Read: tinysys-scp.bin Exist Read: sspm.img Read: sspm.img Exist Read: gz.img Read: gz.img Read: nvram.bin Read: lk.bin Read: lk.bin Exist Read: boot.img Read: logo.bin Read: dtbo.img Read: tz.img Read: tz.img Exist Read: vbmeta.img Read: vbmeta_system.img Read: vbmeta_vendor.img Read: super.img ExtSparse: Compression ratio: 4% Read: cache.img Read: tranfs.img Read: userdata.img Read: otp.img Read: flashinfo.img Read: sgpt.img FW Size: 4.31 GB Android Info saved: _Android_info.txt Scatter: MT6765_Android_scatter.txt Saved: E:\infinex hot 9 play\MT6765_INFINIX_MOBILITY_LIMITED_Infinix_X680B _10_X680B-H6215EFIJ-Q-OP-220505V281_QP1A.190711.020_x680b_h6215\ Verify device config... Ok Loaders Ok Verify firmware [MT6765_INFINIX_MOBILITY_LIMITED_Infinix_X680B_10_X 680B-H6215EFIJ-Q-OP-220505V281_QP1A.190711.020_x680b_h6215]... Exist Done: 00:06:27 |
07-31-2023, 12:39 | #74619 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | TECNO-LE6 Flash Code: SW: TECNO/LE6-GL/TECNO-LE6:11/RP1A.200720.011/230504V564:user/release-keys Product Brand: TECNO Product Device: TECNO-LE6 Product Model: TECNO LE6 Product Name: LE6-GL Patch Level: RP1A.200720.011 Display ID: LE6-H6222CDEFG-R-GL-230504V564 SW Version: 230504V564 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2023-05-05 Build Time: 5/4/2023 11:10:28 AM CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: le6_h6222 SW: vnd_le6_h6222-user 11 RP1A.200720.011 317285 release-keys Product Board: TECNO-LE6 Board Platform: mt6765 Product Manfct: TECNO MOBILE LIMITED Strategy: [none|generic] Firmware ID: MT6765_TECNO_MOBILE_LIMITED_TECNO_LE6_OSv11_LE6-H6222CDEFG-R-GL-230504V564_RP1A.200720.011_le6_h6222 Analyze userdata... userData: fileSystem : [f2fs] with FBE [file based encryption] Analyze modem... Nothing Analyze nvram... NVRAM: Items: 0xA2 Size: 0x08C177 State: Ok WiFi MAC: 8077A482D43F BlTh MAC: 8077A482D43E IMEI[1]: IMEI[2]: STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Analyze preloader... EMI: MT6765 preloader_le6_h6222.bin with 9 memory type(s) 1. eMMC LP_DDR4X ID: 150100445036444142 Ven: Samsung | Dev: DP6DAB RAM: 4.00 Gb 2. eMMC LP_DDR4X ID: 150100445836384D42 Ven: Samsung | Dev: DX68MB RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 3.00 Gb 5. eMMC LP_DDR4X ID: 150100335636434D42 Ven: Samsung | Dev: 3V6CMB RAM: 6.00 Gb 6. eMMC LP_DDR4X ID: 150100335636434242 Ven: Samsung | Dev: 3V6CBB RAM: 6.00 Gb 7. eMMC LP_DDR4X ID: 150100445036444242 Ven: Samsung | Dev: DP6DBB RAM: 4.00 Gb 8. eMMC LP_DDR4X ID: 90014A684445615033 Ven: Hynix | Dev: hDEaP3 RAM: 6.00 Gb 9. eMMC LP_DDR4X ID: 150100335636434142 Ven: Samsung | Dev: 3V6CAB RAM: 6.00 Gb Preloader exist: C:\InfinityBox\CM2MT2\backup\preloader\preloader_le6_h6222.bin Done: 00:00:23 Reconnect Power/Cable now Load: D:\China File\Inifinix\LE6-H6222CDEFG-R-GL-221028V747(MobiFirmware.com)\LE6-H6222CDEFG-R-GL-221028V747(MobiFirmware.com)\(MobiFirmware.com)\MT6765_Android_scatter.txt Preloader [HW DEV]: EMI: MT6765 preloader_le6_h6222.bin with 9 memory type(s) 1. eMMC LP_DDR4X ID: 150100445036444142 Ven: Samsung | Dev: DP6DAB RAM: 4.00 Gb 2. eMMC LP_DDR4X ID: 150100445836384D42 Ven: Samsung | Dev: DX68MB RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 3.00 Gb 5. eMMC LP_DDR4X ID: 150100335636434D42 Ven: Samsung | Dev: 3V6CMB RAM: 6.00 Gb 6. eMMC LP_DDR4X ID: 150100335636434242 Ven: Samsung | Dev: 3V6CBB RAM: 6.00 Gb 7. eMMC LP_DDR4X ID: 150100445036444242 Ven: Samsung | Dev: DP6DBB RAM: 4.00 Gb 8. eMMC LP_DDR4X ID: 90014A684445615033 Ven: Hynix | Dev: hDEaP3 RAM: 6.00 Gb 9. eMMC LP_DDR4X ID: 150100335636434142 Ven: Samsung | Dev: 3V6CAB RAM: 6.00 Gb Operation: Write Flash [ v2.45 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Wait... [+] Update PMT [re-Part] [-] Checksum Verify [+] Safe Erase [Upgrade] [+] Check compatibility [-] Backup [-] UserData Safe [-] FLASH ERASE Files: 17 [FL]: D:\China File\Inifinix\LE6-H6222CDEFG-R-GL-221028V747(MobiFirmware.com)\LE6-H6222CDEFG-R-GL-221028V747(MobiFirmware.com)\(MobiFirmware.com)\ preloader_le6_h6222.bin [ 242.34 Kb ] md1img.img [ 48.10 Mb ] spmfw.img [ 62.58 Kb ] scp.img [ 554.77 Kb ] sspm.img [ 424.56 Kb ] gz.img [ 1.00 Mb ] lk.img [ 913.97 Kb ] logo.bin [ 1.49 Mb ] boot.img [ 32.00 Mb ] dtbo.img [ 8.00 Mb ] tee.img [ 872.22 Kb ] vbmeta.img [ 4.00 Kb ] vbmeta_system.img [ 4.00 Kb ] vbmeta_vendor.img [ 4.00 Kb ] super.img [ 6.12 Gb ] tranfs.img [ 60.14 Kb ] userdata.img [ 2.23 Mb ] Total size: 0x18DBECE68 [ 6.21 Gb ] 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (Android) (COM3) MODE [0]: PRELOADER PORT; PORT: 3 Waiting for BOOT ACK... PRELOADER ACK Ok BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] AGENT: AUTO: Infinix: 2023-05 [caf6df7e] C:\InfinityBox\CM2MT2\boot\Infinix\2023-05\MTK_AllInOne_DA.bin [6d318e00] D:\China File\Inifinix\LE6-H6222CDEFG-R-GL-221028V747(MobiFirmware.com)\LE6-H6222CDEFG-R-GL-221028V747(MobiFirmware.com)\(MobiFirmware.com)\preloader_le6_h6222.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... SRAM: 0x0003A000 [ 232.00 Kb ] DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 150100445036444142024D0EFEAFC8D7 VEN: Samsung OEM: 256 ID: 445036444142 [DP6DAB] PRV: 0x02 SNN: 1292828335 [0x4D0EFEAF] MM/YY: 12/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: D74CB5CE23E3C9B98D258FB3A8B79B5F USB: HIGH-SPEED Boot done MODERN [RAPHAEL] HW verification... HW verification Pass Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 48 Verify PMT... Ok Verify SEC DL... Pre-Erase... Erase: 0x0000000000000000 0x0000000000108000 Erase: 0x0000000000408000 0x0000000001580000 Erase: 0x0000000003988000 0x000000000769A000 Erase: 0x000000000C800000 0x0000000000800000 Erase: 0x0000000010000000 0x0000000000200000 Erase: 0x0000000014800000 0x00000002A9800000 RePartition... RePartition: Ok Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 48 Flash write... Write: PRELOADER [ 242.34 Kb ] Update bootloader backup copy... Ok Write: MD1IMG_A [ 48.10 Mb ] Write: SPMFW_A [ 62.58 Kb ] Ok Write: SCP_A [ 554.77 Kb ] Ok Write: SSPM_A [ 424.56 Kb ] Ok Write: GZ_A [ 1.00 Mb ] Ok Write: LK_A [ 913.97 Kb ] Ok Write: LOGO_A [ 1.49 Mb ] Ok Write: BOOT_A [ 32.00 Mb ] Ok Write: DTBO_A [ 8.00 Mb ] Ok Write: TEE_A [ 872.22 Kb ] Ok Write: VBMETA_A [ 4.00 Kb ] Ok Write: VBMETA_SYSTEM_A [ 4.00 Kb ] Ok Write: VBMETA_VENDOR_A [ 4.00 Kb ] Ok Write: SUPER [ 6.12 Gb ] Ok Write: TRANFS [ 60.14 Kb ] Ok Write: USERDATA [ 2.23 Mb ] Ok RePartition... RePartition: Ok Flashing finished Done: 00:07:19 Reconnect Power/Cable now |
07-31-2023, 12:40 | #74620 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | GFIVE Stark Format Code: Patch Level: P00610 Display ID: GFIVE_StarK_20200522 SW Version: 1590138721 Ver. CodeName: REL Ver. Release: 9 Sec. Patch: 2020-04-05 Build Time: 5/22/2020 9:11:03 AM Product Model: Stark Product Brand: GFIVE Product Name: Stark Product Device: Stark CPU: armeabi-v7a,armeabi Product Manfct: GFIVE Product Info: Stark SW: Stark-user 9 P00610 1590138721 release-keys Product Board: mt6580 Board Platform: mt6580 Strategy: [none|generic] Firmware ID: MT6580_GFIVE_Stark_OSv9_GFIVE_StarK_20200522_P00610_Stark Analyze userdata... userData: fileSystem : [f2fs] with FDE [encryptable] Analyze modem... Nothing Analyze nvram... NVRAM: Items: 0x77 Size: 0x029778 State: Ok WiFi MAC: AA0036004400 BlTh MAC: 000047AA31A5 IMEI[1]: IMEI[2]: Analyze preloader... EMI: MT6752 preloader_k80_bsp.bin with 1 memory type(s) Preloader exist: C:\InfinityBox\CM2MT2\backup\preloader\preloader_k80_bsp.bin Done: 00:00:22 Reconnect Power/Cable now Reset Mode: Safe Factory Reset via WIPE Operation: Reset Settings/Format FS [ v2.45 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: FACTORY RESET: WIPE Wait... WARNING: Format FS WILL RESET ALL USER DATA! Make sure about correct format mode selection! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (Android) (COM3) MODE [0]: PRELOADER PORT; PORT: 3 Waiting for BOOT ACK... PRELOADER ACK Ok BROM: Init... Ok CHIP: MT6580 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x6580 TYPE: LEGACY [MTK] BROM: Sec Level: 0x00000000 Mode: PLAIN VER: 0xFF BL: 0x01 [PRELOADER PORT] AGENT: AUTO: 0_base: base_v1712 [e600c7d1] C:\InfinityBox\CM2MT2\boot\0_base\base_v1712\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6580 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started NAND: DEVICE NOT FOUND EMMC: OK CID: 4D0101043030443016E7113187B62999 DA v4.2.156 DA: DRAM ready Boot to 2nd DA... Ok Load HW info... EMMC CID: 0401014D304430303111E7169929B687 VEN: Unknown 0x0004 OEM: 257 ID: 4D3044303031 [M0D001] PRV: 0x11 SNN: 3877017897 [0xE7169929] MM/YY: 11/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x39D000000 [ 14.45 Gb ] SRAM: 0x00020000 [ 128.00 Kb ] DRAM: 0x40000000 [ 1.00 Gb ] CHIP: MT6580 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x6580 TYPE: LEGACY [MTK] RNID: 6A32A7497D59E05E286FD2EF8D965044 DA: Status: BLANK FLASH; Boot Style: EMMC FLASH BOOT USB: HIGH-SPEED Boot done LEGACY [MTK] Analyze PMT... Ok PMT: LGPT [0x06] Records: 32 Strategy: [none|generic] Stage a: FACTORY RESET: WIPE [1] Verified [2] Process USERDATA... Ok In case of "DL IMAGE FAIL" message after reset use Service -> [Fix DL] button Done: 00:00:19 Reconnect Power/Cable now |
07-31-2023, 12:41 | #74621 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | TECNO-KE5k Frp Code: SW: TECNO/KE5k-OP/TECNO-KE5k:10/QP1A.190711.020/CD-OP-220822V236:user/release-keys Product Brand: TECNO Product Device: TECNO-KE5k Product Model: TECNO KE5k Product Name: KE5k-OP Patch Level: QP1A.190711.020 Display ID: KE5k-H6122CD-Q-OP-220822V236 SW Version: CD-OP-220822V236 Ver. CodeName: REL Ver. Release: 10 Sec. Patch: 2022-08-01 Build Time: 8/22/2022 11:27:23 AM CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: ke5k_h6122 SW: full_ke5k_h6122-user 10 QP1A.190711.020 63429 release-keys Product Board: TECNO-KE5k Board Platform: mt6765 Product Manfct: TECNO MOBILE LIMITED Strategy: [none|generic] Firmware ID: MT6765_TECNO_MOBILE_LIMITED_TECNO_KE5k_OSv10_KE5k-H6122CD-Q-OP-220822V236_QP1A.190711.020_ke5k_h6122 Analyze userdata... userData: fileSystem : [f2fs] with FBE [file based encryption] Analyze modem... TK_MD_BASIC_MDBIN_PCB01_MT6765_S00.MOLY_LR12A_R3_MP_V118_11_P53 Analyze nvram... NVRAM: Items: 0xA3 Size: 0x101A86 State: Ok WiFi MAC: AA0036004400 BlTh MAC: C4BF6049C7CE IMEI[1]: IMEI[2]: STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY NOT PROGRAMMED [USABLE] Analyze preloader... EMI: MT6765 preloader_ke5k_h6122.bin with 20 memory type(s) 1. eMMC LP_DDR4X ID: 90014A684445615033 Ven: Hynix | Dev: hDEaP3 RAM: 6.00 Gb 2. eMMC LP_DDR4X ID: 150100444836444D42 Ven: Samsung | Dev: DH6DMB RAM: 4.00 Gb 3. eMMC LP_DDR4X ID: 150100444836444142 Ven: Samsung | Dev: DH6DAB RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 150100334836434142 Ven: Samsung | Dev: 3H6CAB RAM: 6.00 Gb 5. eMMC LP_DDR4X ID: 150100335636434D42 Ven: Samsung | Dev: 3V6CMB RAM: 6.00 Gb 6. eMMC LP_DDR4X ID: 90014A484347386134 Ven: Hynix | Dev: HCG8a4 RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 90014A484347386134 Ven: Hynix | Dev: HCG8a4 RAM: 6.00 Gb 8. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 6.00 Gb 10. eMMC LP_DDR4X ID: 90014A684339615033 Ven: Hynix | Dev: hC9aP3 RAM: 4.00 Gb 11. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 3.00 Gb 12. eMMC LP_DDR4X ID: 150100445036384D42 Ven: Samsung | Dev: DP68MB RAM: 3.00 Gb 13. eMMC LP_DDR4X ID: 13014E53304A394B39 Ven: Micron | Dev: S0J9K9 RAM: 4.00 Gb 14. eMMC LP_DDR4X ID: 150100445636444142 Ven: Samsung | Dev: DV6DAB RAM: 4.00 Gb 15. eMMC LP_DDR4X ID: 150100445036444142 Ven: Samsung | Dev: DP6DAB RAM: 4.00 Gb 16. eMMC LP_DDR4X ID: 150100445636444D42 Ven: Samsung | Dev: DV6DMB RAM: 4.00 Gb 17. eMMC LP_DDR4X ID: 150100444436384D42 Ven: Samsung | Dev: DD68MB RAM: 3.00 Gb 18. eMMC LP_DDR4X ID: 13014E47314A395238 Ven: Micron | Dev: G1J9R8 RAM: 4.00 Gb 19. eMMC LP_DDR4X ID: 13014E53304A333741 Ven: Micron | Dev: S0J37A RAM: 3.00 Gb 20. eMMC LP_DDR4X ID: 150100445036444242 Ven: Samsung | Dev: DP6DBB RAM: 4.00 Gb Preloader exist: C:\InfinityBox\CM2MT2\backup\preloader\preloader_ke5k_h6122.bin Done: 00:00:28 Reconnect Power/Cable now Reset Mode: Reset FRP only Operation: Reset Settings/Format FS [ v2.45 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: FRP [ RESET PROTECTION ] Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MTK USB Port (COM6) MODE [0]: BOOTROM; PORT: 6 Waiting for BOOT ACK... BROM: Skip ACK verication BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 5783F0D9626876D7AE33CE6FE45DC688 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 26379C441B40B95A1467AA8D16A17DF3465A32612FD07E492842931DF254758E SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok EMI known SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 5783F0D9626876D7AE33CE6FE45DC688 AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 15010044503644414203DE04CAF897D5 VEN: Samsung OEM: 256 ID: 445036444142 [DP6DAB] PRV: 0x03 SNN: 3724856056 [0xDE04CAF8] MM/YY: 9/2020 EMI: Init Ok EMI: FireFly preloader_ke5k_h6122.bin with 20 memory type(s) 1. eMMC LP_DDR4X ID: 90014A684445615033 Ven: Hynix | Dev: hDEaP3 RAM: 6.00 Gb 2. eMMC LP_DDR4X ID: 150100444836444D42 Ven: Samsung | Dev: DH6DMB RAM: 4.00 Gb 3. eMMC LP_DDR4X ID: 150100444836444142 Ven: Samsung | Dev: DH6DAB RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 150100334836434142 Ven: Samsung | Dev: 3H6CAB RAM: 6.00 Gb 5. eMMC LP_DDR4X ID: 150100335636434D42 Ven: Samsung | Dev: 3V6CMB RAM: 6.00 Gb 6. eMMC LP_DDR4X ID: 90014A484347386134 Ven: Hynix | Dev: HCG8a4 RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 90014A484347386134 Ven: Hynix | Dev: HCG8a4 RAM: 6.00 Gb 8. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 6.00 Gb 10. eMMC LP_DDR4X ID: 90014A684339615033 Ven: Hynix | Dev: hC9aP3 RAM: 4.00 Gb 11. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 3.00 Gb 12. eMMC LP_DDR4X ID: 150100445036384D42 Ven: Samsung | Dev: DP68MB RAM: 3.00 Gb 13. eMMC LP_DDR4X ID: 13014E53304A394B39 Ven: Micron | Dev: S0J9K9 RAM: 4.00 Gb 14. eMMC LP_DDR4X ID: 150100445636444142 Ven: Samsung | Dev: DV6DAB RAM: 4.00 Gb 15. eMMC LP_DDR4X ID: 150100445036444142 Ven: Samsung | Dev: DP6DAB RAM: 4.00 Gb 16. eMMC LP_DDR4X ID: 150100445636444D42 Ven: Samsung | Dev: DV6DMB RAM: 4.00 Gb 17. eMMC LP_DDR4X ID: 150100444436384D42 Ven: Samsung | Dev: DD68MB RAM: 3.00 Gb 18. eMMC LP_DDR4X ID: 13014E47314A395238 Ven: Micron | Dev: G1J9R8 RAM: 4.00 Gb 19. eMMC LP_DDR4X ID: 13014E53304A333741 Ven: Micron | Dev: S0J37A RAM: 3.00 Gb 20. eMMC LP_DDR4X ID: 150100445036444242 Ven: Samsung | Dev: DP6DBB RAM: 4.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... SRAM: 0x0003A000 [ 232.00 Kb ] DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 15010044503644414203DE04CAF897D5 VEN: Samsung OEM: 256 ID: 445036444142 [DP6DAB] PRV: 0x03 SNN: 3724856056 [0xDE04CAF8] MM/YY: 9/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: D42C9C451D6E5A126AB9F3CA8E4557E8 MEID: 5783F0D9626876D7AE33CE6FE45DC688 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 41 Strategy: [none|generic] Stage a: FRP [ RESET PROTECTION ] [1] Process RESET PROTECTION... Ok [2] Verified Stage b: FRP [ RESET PROTECTION ] [1] Verified [2] Verified Done: 00:01:25 Reconnect Power/Cable now |
07-31-2023, 12:42 | #74622 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | Infinix-X665E Format & Frp Code: Operation: Reset Settings/Format FS [ v2.45 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: SMART RESET Wait... WARNING: Format FS WILL RESET ALL USER DATA! Make sure about correct format mode selection! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (Android) (COM3) MODE [0]: PRELOADER PORT; PORT: 3 Waiting for BOOT ACK... PRELOADER ACK Ok BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] AGENT: AUTO: Infinix: 2023-05 [caf6df7e] C:\InfinityBox\CM2MT2\boot\Infinix\2023-05\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... SRAM: 0x0003A000 [ 232.00 Kb ] DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: F40122415256313158134DC9A55AC9F5 VEN: Biwin OEM: 290 ID: 415256313158 [ARV11X] PRV: 0x13 SNN: 1305060698 [0x4DC9A55A] MM/YY: 12/2022 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0xE90000000 [ 58.25 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 86AC692821FC64F7ED7C71B5B7FA0683 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 50 Select info source... Ok Product Brand: Infinix Product Device: Infinix-X665E Product Model: Infinix X665E Product Name: X665E-GL SW: Infinix/X665E-GL/Infinix-X665E:12/SP1A.210812.016/230215V969:user/release-keys Patch Level: SP1A.210812.016 Display ID: X665E-H6126YZAaAbAcAdAeAfAgAhAi-S-GL-230215V969 SW Version: 230215V969 Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2023-02-01 Build Time: 2/15/2023 6:39:04 AM Product Info: x665e_h6126 SW: vnd_x665e_h6126-user 12 SP1A.210812.016 245708 release-keys Product Manfct: INFINIX Product Board: Infinix-X665E Board Platform: mt6765 Strategy: [none|generic] SmartInfo: Android Ver: 12 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] Stage a: SMART RESET [1] Process RESET PROTECTION... Ok [2] Process USERDATA... Ok [3] Verified [4] Verified [5] Verified [6] Process USERDATA... Ok [7] Process USERDATA... Ok Stage b: SMART RESET [1] Verified [2] Verified Stage c: SMART RESET Stage d: SMART RESET Done: 00:01:12 Reconnect Power/Cable now |
07-31-2023, 12:44 | #74623 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | TECNO-KC2 Format & Frp Code: Operation: Reset Settings/Format FS [ v2.45 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: SMART RESET Wait... WARNING: Format FS WILL RESET ALL USER DATA! Make sure about correct format mode selection! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (Android) (COM7) MODE [0]: PRELOADER PORT; PORT: 7 Waiting for BOOT ACK... PRELOADER ACK Ok BROM: Init... Ok CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6761 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... Reset Interface PTFN: MTK USB Port (COM9) MODE [0]: BOOTROM; PORT: 9 Waiting for BOOT ACK... BROM: Skip ACK verication BROM: Init... Ok CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] MEID: A7BE90BDFA6D3D0C85B862F52E502A0B BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 027042F0DE1A3CA78FA3A3A24CA1AD6384A31119A5A98B7AB5E59D6D3E13D273 SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok EMI known SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: A7BE90BDFA6D3D0C85B862F52E502A0B AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6761 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 150100474436424D4201F4DB977317ED VEN: Samsung OEM: 256 ID: 474436424D42 [GD6BMB] PRV: 0x01 SNN: 4108031859 [0xF4DB9773] MM/YY: 1/2020 EMI: Init Ok EMI: FireFly preloader_kc2_h6113.bin with 13 memory type(s) 1. eMMC DDR3 ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 3.00 Gb 2. eMMC DDR3 ID: FE014A333232344433 Ven: Micron | Dev: 3224D3 RAM: 3.00 Gb 3. eMMC DDR3 ID: 90014A484347386134 Ven: Hynix | Dev: HCG8a4 RAM: 4.00 Gb 4. eMMC DDR3 ID: 150100514536334D42 Ven: Samsung | Dev: QE63MB RAM: 2.00 Gb 5. eMMC DDR3 ID: 150100464536324D42 Ven: Samsung | Dev: FE62MB RAM: 1.00 Gb 6. eMMC DDR3 ID: 90014A484147346132 Ven: Hynix | Dev: HAG4a2 RAM: 2.00 Gb 7. eMMC DDR3 ID: 150100514436334D42 Ven: Samsung | Dev: QD63MB RAM: 2.00 Gb 8. eMMC DDR3 ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 2.00 Gb 9. eMMC DDR3 ID: 700100464D42434541 Ven: Kingston | Dev: FMBCEA RAM: 2.00 Gb 10. eMMC DDR3 ID: 150100524836344142 Ven: Samsung | Dev: RH64AB RAM: 4.00 Gb 11. eMMC DDR3 ID: 90014A684339615033 Ven: Hynix | Dev: hC9aP3 RAM: 4.00 Gb 12. eMMC DDR3 ID: 150100474436424D42 Ven: Samsung | Dev: GD6BMB RAM: 3.00 Gb 13. eMMC DDR3 ID: 90014A484147346132 Ven: Hynix | Dev: HAG4a2 RAM: 3.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... SRAM: 0x0003A500 [ 233.25 Kb ] DRAM: 0xC0000000 [ 3.00 Gb ] EMMC CID: 150100474436424D4201F4DB977317ED VEN: Samsung OEM: 256 ID: 474436424D42 [GD6BMB] PRV: 0x01 SNN: 4108031859 [0xF4DB9773] MM/YY: 1/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] RNID: 108A2B8F81FC817FE65E992E4754A1D1 MEID: A7BE90BDFA6D3D0C85B862F52E502A0B USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 39 Select info source... Ok Patch Level: PPR1.180610.011 Display ID: KC2-H6113AI-P-210705V320 SW Version: AI-210705V320 Ver. CodeName: REL Ver. Release: 9 Sec. Patch: 2021-07-05 Build Time: 7/5/2021 9:54:12 AM Product Model: TECNO KC2 Product Brand: TECNO Product Name: H6113 Product Device: TECNO-KC2 CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: TECNO MOBILE LIMITED Product Info: kc2_h6113 SW: full_kc2_h6113-user 9 PPR1.180610.011 126295 release-keys Product Board: TECNO-KC2 Board Platform: mt6761 Strategy: [none|generic] SmartInfo: Android Ver: 9 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] Stage a: SMART RESET [1] Process RESET PROTECTION... Ok [2] Process USERDATA... Ok [3] Process CACHE... Ok [4] Verified [5] Verified [6] Process USERDATA... Ok [7] Verified Stage b: SMART RESET [1] Verified [2] Verified Stage c: SMART RESET Stage d: SMART RESET Done: 00:00:36 Reconnect Power/Cable now |
07-31-2023, 12:57 | #74624 (permalink) |
Member: 2072265 Status: Offline Thanks Meter: 47 | infinix x680 format done Operation: Reset Settings/Format FS [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: FACTORY RESET : WIPE + FRP Wait... WARNING: Reset may clear ALL USER DATA! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM4) MODE [0]: BOOTROM; PORT: 4 Waiting for BOOT ACK... BROM: Skip ACK verication BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 0E15CE5C63E85965CCD87F304CEB4B38 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: A0806CB877C3FCD151E749F0D69233CF6D43847BAA9FDC9D5A A86A5EAD2EEAF3 SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok FF: Looking for EMI Found SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 0E15CE5C63E85965CCD87F304CEB4B38 AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 1501004450364441420320679A9A87BF VEN: Samsung OEM: 256 ID: 445036444142 [DP6DAB] PRV: 0x03 SNN: 543660698 [0x20679A9A] MM/YY: 8/2020 EMI: Init Ok EMI: FireFly preloader_x680b_h6215.bin with 17 memory type(s) 1. eMMC LP_DDR4X ID: 90014A684445615033 Ven: Hynix | Dev: hDEaP3 RAM: 6.00 Gb 2. eMMC LP_DDR4X ID: 150100444836444D42 Ven: Samsung | Dev: DH6DMB RAM: 4.00 Gb 3. eMMC LP_DDR4X ID: 150100444836444142 Ven: Samsung | Dev: DH6DAB RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 150100334836434142 Ven: Samsung | Dev: 3H6CAB RAM: 6.00 Gb 5. eMMC LP_DDR4X ID: 150100335636434D42 Ven: Samsung | Dev: 3V6CMB RAM: 6.00 Gb 6. eMMC LP_DDR4X ID: 90014A484347386134 Ven: Hynix | Dev: HCG8a4 RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 90014A484347386134 Ven: Hynix | Dev: HCG8a4 RAM: 6.00 Gb 8. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 6.00 Gb 10. eMMC LP_DDR4X ID: 90014A684339615033 Ven: Hynix | Dev: hC9aP3 RAM: 4.00 Gb 11. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 3.00 Gb 12. eMMC LP_DDR4X ID: 150100445036384D42 Ven: Samsung | Dev: DP68MB RAM: 3.00 Gb 13. eMMC LP_DDR4X ID: 13014E53304A394B39 Ven: Micron | Dev: S0J9K9 RAM: 4.00 Gb 14. eMMC LP_DDR4X ID: 150100445636444142 Ven: Samsung | Dev: DV6DAB RAM: 4.00 Gb 15. eMMC LP_DDR4X ID: 150100445036444142 Ven: Samsung | Dev: DP6DAB RAM: 4.00 Gb 16. eMMC LP_DDR4X ID: 150100445636444D42 Ven: Samsung | Dev: DV6DMB RAM: 4.00 Gb 17. eMMC LP_DDR4X ID: 150100444436384D42 Ven: Samsung | Dev: DD68MB RAM: 3.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 1501004450364441420320679A9A87BF VEN: Samsung OEM: 256 ID: 445036444142 [DP6DAB] PRV: 0x03 SNN: 543660698 [0x20679A9A] MM/YY: 8/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 9C5FB49BC4CAAF03C8ACC47A7BE27E85 MEID: 0E15CE5C63E85965CCD87F304CEB4B38 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 41 Select info source... Ok SW: Infinix/X680B-OP/Infinix-X680B:10/QP1A.190711.020/EFIJ-OP-210804V255:user/release-keys Product Brand: Infinix Product Device: Infinix-X680B Product Model: Infinix X680B Product Name: X680B-OP Patch Level: QP1A.190711.020 Display ID: X680B-H6215EFIJ-Q-OP-210804V255 SW Version: EFIJ-OP-210804V255 Ver. CodeName: REL Ver. Release: 10 Sec. Patch: 2021-08-05 Build Time: 8/4/2021 10:51:45 AM CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: x680b_h6215 SW: full_x680b_h6215-user 10 QP1A.190711.020 140253 release-keys Product Board: Infinix-X680B Board Platform: mt6765 Product Manfct: INFINIX MOBILITY LIMITED Strategy: [none|generic] Verify device config... Ok Loaders Ok Backup to C:\InfinityBox\CM2MT2\backup\MT6765__0E15CE5C63E85 965CCD87F304CEB4B38\ Items to check: 20 Read [26] NVRAM Read [10] NVDATA Read [3] PROINFO Read [27] LK Read [9] NVCFG Read [12] PROTECT1 Read [1] PGPT Read [11] PERSIST Read [0] PRELOADER Done 9 files Compress: C:\InfinityBox\CM2MT2\backup\MT6765__0E15CE5C63E85 965CCD87F304CEB4B38\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__0E15CE5C63E85 965CCD87F304CEB4B38.7z Verified Stage : ANDROID OS [1] Verified [2] Process USERDATA... Ok Stage : FRP [1] Process... Done: 00:00:50 Reconnect Power/Cable now |
07-31-2023, 15:54 | #74625 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,776 | Qmobile power 3 reset password done by cm2 Card found : S/N : 73CA70CC , v0155 Chinese Miracle II [MTK module] v 1.58 Operation : Reset UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 3 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : ACDF61F94DA9E4FC6DFE7D7AC14F3924 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EC , [GigaDevice] GD25LQ32 [0] : FLASH_DIE : 00C8 0060 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Read ExtData Sorting ExtData Sort Ok, Rebuild Ok Restore ExtData All done UserCode request removed UserCode set to default ( 0000 or 1122 ) Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
