09-14-2023, 15:25 | #74971 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,806 | clone Nokia 6310 TA-1400 user lock and reset and firmware reading done connect powered off phone to computer Code: Finish at : [14/09/2023 / 04:58:31 ï؟½] Start at : [14/09/2023 / 04:58:35 ï؟½] Operation : Read UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 49 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : A4EC9F2CA9BE3AC2A989650585D8C928 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 6000 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 INT_RAM : 0x0000D000 EXT_RAM : 0x00800000 Read ExtData Sorting ExtData Reading UserCode Active : Yes , Code : 12345 PLock|MobTrack : Not active Done! Elapsed: 00:00:29 Reconnect Power/Cable! Finish at : [14/09/2023 / 04:59:05 ï؟½] Start at : [14/09/2023 / 04:59:35 ï؟½] Operation : Reset UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 49 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : A4EC9F2CA9BE3AC2A989650585D8C928 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 6000 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 INT_RAM : 0x0000D000 EXT_RAM : 0x00800000 Backup done Read ExtData Sorting ExtData Sort Ok, Rebuild Ok Restore ExtData All done UserCode request removed UserCode set to default ( 0000 or 1122 ) Done! Elapsed: 00:00:58 Reconnect Power/Cable! Finish at : [14/09/2023 / 05:00:34 ï؟½] Start at : [14/09/2023 / 05:01:53 ï؟½] Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 49 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : A4EC9F2CA9BE3AC2A989650585D8C928 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 6000 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 INT_RAM : 0x0000D000 EXT_RAM : 0x00800000 Reading Flash Content now ... Read Flash now Read Ok , 16777216 bytes read Check and collect compile info File_Info : MOBA60A_12864_11B_PCB01_gprs_MT6260_S00.N650_S631_V1.5.bin FileVersion : GOTECH_N650_S631_V1.5 [ScatCFG] : MT6260 / GOTECH_N650_S631_V1.5 / NOR , SF Firmware saved to : D:\BST\infinty\InfinityBox_install_CM2MTK_v1.58\Read_out\MOBA60A_12864_11B_PCB01_gprs_MT6260_S00\ Done! Elapsed: 00:01:00 Reconnect Power/Cable! Finish at : [14/09/2023 / 05:02:53 ï؟½] https://www.4shared.com/rar/t4dZak2x...1_gprs_M.html? |
The Following User Says Thank You to profkefah For This Useful Post: |
09-15-2023, 03:15 | #74972 (permalink) |
Freak Poster Join Date: Sep 2016 Location: GSMPIONEER PHP
Member: 2623988 Status: Offline Sonork: 100.1678253 Thanks Meter: 301 | Oppo A16 CPH2269 August Patch 2023 Smart Reset Oppo A16 CPH2269 August Patch 2023 Smart Reset Both Key : Vol + & Vol - Identify Code: Operation: Identify Device [ v2.49a7 (beta) ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Mode: FLASH Port: Both [ B + P ] [+] Read deep info: PRL, HW, DEBUG [+] Auto-EMI [+] FireFly-Over-DA extended protocol [+] Vendor-Specific Analyzer [-] Local SLA [-] Force BROM Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM_V1633 (Android) (COM16) MODE [0]: PRELOADER PORT; PORT: 16 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... Reset Interface PTFN: MediaTek USB Port_V1633 (COM3) MODE [0]: BOOTROM; PORT: 3 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: F3B157ADB53BEB5B70A9E820F6E2790E BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 4095302DCAD18F8218D356D33613403D0E4C1D259A144458F097A42B29BBF0D6 SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok FF: Looking for EMI Found SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: F3B157ADB53BEB5B70A9E820F6E2790E AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 150100445036444242020751D05DB81D crc Ok Ven: Samsung OEM: 256 ID: 445036444242 [DP6DBB] PRV: 0x02 SNN: 122802269 [0x0751D05D] MM/YY: 11/2021 EMI: Init Ok EMI: FireFly preloader_oppo6765.bin with 9 memory type(s) 1. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 2. eMMC LP_DDR4X ID: 13014E47314A395238 Micron G1J9R8 RAM: 4.00 Gb 3. eMMC LP_DDR4X ID: 150100445836384D42 Samsung DX68MB RAM: 3.00 Gb 4. eMMC LP_DDR4X ID: 13014E47314A395339 Micron G1J9S9 RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 150100445636444142 Samsung DV6DAB RAM: 4.00 Gb 6. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 8. eMMC LP_DDR4X ID: 150100445036444242 Samsung DP6DBB RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 150100445636444242 Samsung DV6DBB RAM: 4.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 150100445036444242020751D05DB81D crc Ok Ven: Samsung OEM: 256 ID: 445036444242 [DP6DBB] PRV: 0x02 SNN: 122802269 [0x0751D05D] MM/YY: 11/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 82158C8A1CB13A2477534B26B31CA7BA MEID: F3B157ADB53BEB5B70A9E820F6E2790E USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 48 Select info source... Analyze userdata... userData: fileSystem : [f2fs] with FBE [file based encryption] Analyze modem... OPPO6765_20375_MDBIN_PCB01_MT6765_S00.MOLY_LR12A_R3_TC16_SP_V1_P45 Analyze nvram... NVRAM: Items: 0xA6 Size: 0x08C47E State: Ok WiFi MAC: AA0036004400 BlTh MAC: AC7352B833BA Verify device config... Finished Backup to C:\InfinityBox\CM2MT2\backup\MT6765__F3B157ADB53BEB5B70A9E820F6E2790E\ Items to check: 20 Read [35] NVRAM Read [14] NVDATA Read [22] PROINFO Read [36] LK Read [13] NVCFG Read [17] PROTECT1 Read [1] PGPT Read [20] PERSIST Read [0] PRELOADER Read [7] OPPORESERVE3 ZERO CONTENT file [64.00 Mb] deleted: C:\InfinityBox\CM2MT2\backup\MT6765__F3B157ADB53BEB5B70A9E820F6E2790E\opporeserve3.bin Read [8] OPPO_CUSTOM Read [23] OCDT Read [26] CDT_ENGINEERING Done 12 files Compress: C:\InfinityBox\CM2MT2\backup\MT6765__F3B157ADB53BEB5B70A9E820F6E2790E\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__F3B157ADB53BEB5B70A9E820F6E2790E.7z Finished STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Analyze preloader... EMI: MT6765 preloader_oppo6765.bin with 9 memory type(s) 1. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 2. eMMC LP_DDR4X ID: 13014E47314A395238 Micron G1J9R8 RAM: 4.00 Gb 3. eMMC LP_DDR4X ID: 150100445836384D42 Samsung DX68MB RAM: 3.00 Gb 4. eMMC LP_DDR4X ID: 13014E47314A395339 Micron G1J9S9 RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 150100445636444142 Samsung DV6DAB RAM: 4.00 Gb 6. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 8. eMMC LP_DDR4X ID: 150100445036444242 Samsung DP6DBB RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 150100445636444242 Samsung DV6DBB RAM: 4.00 Gb Preloader exist: C:\InfinityBox\CM2MT2\backup\preloader\preloader_oppo6765.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_oppo6765.bin [32bb7f00]... Finished Analyze FS layout... Found 13 item(s) Get MDM state... may be enabled Analyze FS layout... Found 13 item(s) Get network config state... Ok Done: 00:02:59 Reconnect Power/Cable now Code: Operation: Reset Settings/Format FS [ v2.49a7 (beta) ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: SMART RESET Wait... WARNING: Reset may clear ALL USER DATA! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM_V1633 (Android) (COM16) MODE [0]: PRELOADER PORT; PORT: 16 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... Reset Interface PTFN: MediaTek USB Port_V1633 (COM3) MODE [0]: BOOTROM; PORT: 3 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: F3B157ADB53BEB5B70A9E820F6E2790E BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 4095302DCAD18F8218D356D33613403D0E4C1D259A144458F097A42B29BBF0D6 SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok EMI known SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: F3B157ADB53BEB5B70A9E820F6E2790E AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 150100445036444242020751D05DB81D crc Ok Ven: Samsung OEM: 256 ID: 445036444242 [DP6DBB] PRV: 0x02 SNN: 122802269 [0x0751D05D] MM/YY: 11/2021 EMI: Init Ok EMI: FireFly preloader_oppo6765.bin with 9 memory type(s) 1. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 2. eMMC LP_DDR4X ID: 13014E47314A395238 Micron G1J9R8 RAM: 4.00 Gb 3. eMMC LP_DDR4X ID: 150100445836384D42 Samsung DX68MB RAM: 3.00 Gb 4. eMMC LP_DDR4X ID: 13014E47314A395339 Micron G1J9S9 RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 150100445636444142 Samsung DV6DAB RAM: 4.00 Gb 6. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 8. eMMC LP_DDR4X ID: 150100445036444242 Samsung DP6DBB RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 150100445636444242 Samsung DV6DBB RAM: 4.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 150100445036444242020751D05DB81D crc Ok Ven: Samsung OEM: 256 ID: 445036444242 [DP6DBB] PRV: 0x02 SNN: 122802269 [0x0751D05D] MM/YY: 11/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 82158C8A1CB13A2477534B26B31CA7BA MEID: F3B157ADB53BEB5B70A9E820F6E2790E USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 48 Select info source... Strategy: [none|generic] SmartInfo: Android Ver: 11 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] Verify device config... Finished Backup exist: C:\InfinityBox\CM2MT2\backup\MT6765__F3B157ADB53BEB5B70A9E820F6E2790E Stage: ANDROID OS [1] Process USERDATA... Ok [2] Process CACHE... Ok [3] Verified [4] Process USERDATA... Ok [5] Process RESET PROTECTION... Ok [6] Verified [7] Process USERDATA... Ok Stage: FRP Stage: SMART Done: 00:01:08 Reconnect Power/Cable now |
The Following 2 Users Say Thank You to homer3706 For This Useful Post: |
09-15-2023, 14:18 | #74973 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Realme C3 Frp Reset Done Operation: Reset Settings/Format FS [ v2.49a4 (beta) ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: FRP [ RESET PROTECTION ] Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM6) MODE [0]: BOOTROM; PORT: 6 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] MEID: 860D412F0E6DAC8185F712AAFC185B2C BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 892B4A6DF7BF85C3313E5B1605838FA2056D390D3936E871B6 04369E8BF3F16A SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok FF: Looking for EMI Found SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 860D412F0E6DAC8185F712AAFC185B2C AGENT: AUTO: Infinix: 2023-05 [caf6df7e] C:\InfinityBox\CM2MT2\boot\Infinix\2023-05\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6768 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 150100444436384D4202C5D9CAEA27E1 crc Ok Ven: Samsung OEM: 256 ID: 444436384D42 [DD68MB] PRV: 0x02 SNN: 3319384810 [0xC5D9CAEA] MM/YY: 2/2020 EMI: Init Ok EMI: FireFly preloader_oppo6769.bin with 13 memory type(s) 1. eMMC LP_DDR4X ID: 150100445636444D42 Samsung DV6DMB RAM: 4.00 Gb 2. eMMC LP_DDR4X ID: 13014E53304A394B39 Micron S0J9K9 RAM: 4.00 Gb 3. eMMC LP_DDR4X ID: 150100444436384D42 Samsung DD68MB RAM: 3.00 Gb 4. eMMC LP_DDR4X ID: 150100444836444142 Samsung DH6DAB RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 3.00 Gb 6. eMMC LP_DDR4X ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 150100445036384D42 Samsung DP68MB RAM: 3.00 Gb 8. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 9. eMMC LP_DDR4X ID: 1501003458364B4D42 Samsung 4X6KMB RAM: 2.00 Gb 10. eMMC LP_DDR4X ID: 450100444134313238 Sandisk DA4128 RAM: 4.00 Gb 11. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 2.00 Gb 12. eMMC LP_DDR4X ID: 150100334836434142 Samsung 3H6CAB RAM: 6.00 Gb 13. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 6.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x00070000 [ 448.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 150100444436384D4202C5D9CAEA27E1 crc Ok Ven: Samsung OEM: 256 ID: 444436384D42 [DD68MB] PRV: 0x02 SNN: 3319384810 [0xC5D9CAEA] MM/YY: 2/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] RNID: 717DCFCEF48E8A01E6749F46538A0327 MEID: 860D412F0E6DAC8185F712AAFC185B2C USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 48 Strategy: [none|generic] Verify device config... Ok Loaders Ok Stage: ANDROID OS [1] Process RESET PROTECTION... Ok [2] Verified Stage: FRP Done: 00:00:42 Reconnect Power/Cable now |
09-15-2023, 14:21 | #74974 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Oppo F19 Pro Frp Reset Done Operation: Reset Settings/Format FS [ v2.49a4 (beta) ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: FRP [ RESET PROTECTION ] Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM4) MODE [0]: BOOTROM; PORT: 4 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6779 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0725 CODE: Lafite TYPE: MODERN [RAPHAEL] MEID: B319D8DD90859F865AC7D33B8647A876 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 35121984BDE3235821A4463D7123B3EABCD3D205F5C97CB468 6958E4206BDE21 SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth libusb exec warn ctrl_msg1 v1.2.6.0 0x0A Ok FF: Looking for EMI Found SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: B319D8DD90859F865AC7D33B8647A876 AGENT: AUTO: Vivo: SEC_2023 [ecb438fd] C:\InfinityBox\CM2MT2\boot\Vivo\SEC_2023\MTK_AllIn One_DA_v3.fdaaf7f6.bin Looking for suitable BootChain in DA... Switch to v2216 Found MT6779 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized UFS CID: CE014B4D3856383030314A4D2D423831 Ven: 0x01CE VID: KM8V8001JM-B81 IFW: 1900 EMI: Init Ok EMI: FireFly preloader_k79v1_64.bin with 16 memory type(s) 1. eUFS LP_DDR4X Dev: KM2V7001CM-B706 RAM: 6.00 Gb 2. eUFS LP_DDR4X Dev: KM8V7001JA-B813 RAM: 8.00 Gb 3. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 13014E53304A394B39 Micron S0J9K9 RAM: 4.00 Gb 5. eUFS LP_DDR4X Dev: KM8V7001JM-B810 RAM: 8.00 Gb 6. eUFS LP_DDR4X Dev: H9HQ16AECMMDAR RAM: 6.00 Gb 7. eUFS LP_DDR4X Dev: H9HQ16AFAMMDAR RAM: 8.00 Gb 8. eUFS LP_DDR4X Dev: KM2V8001CM-B707 RAM: 6.00 Gb 9. eUFS LP_DDR4X Dev: KM5V7001DM-B621 RAM: 4.00 Gb 10. eUFS LP_DDR4X Dev: KM2B8001CM-BB01 RAM: 6.00 Gb 11. eUFS LP_DDR4X Dev: KM8B8001JM-BC01 RAM: 8.00 Gb 12. eUFS LP_DDR4X Dev: KM8V8001JM-B813 RAM: 8.00 Gb 13. eUFS LP_DDR4X Dev: H9HQ15AFAMBDAR RAM: 8.00 Gb 14. eUFS LP_DDR4X Dev: H9HQ15AECMBDAR RAM: 6.00 Gb 15. eUFS LP_DDR4X Dev: H9HQ21AFAMADAR RAM: 8.00 Gb 16. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 6.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x00080000 [ 512.00 Kb ] RAM: DRAM: 0x200000000 [ 8.00 Gb ] UFS CID: CE014B4D3856383030314A4D2D423831 Ven: 0x01CE VID: KM8V8001JM-B81 IFW: 1900 LU0: 0x00400000 [ 4.00 Mb ] LU1: 0x00400000 [ 4.00 Mb ] LU2: 0x1DCB000000 [ 119.17 Gb ] FSN: 51a1a41c020d REG: 0x101010000 CHIP: MT6779 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0725 CODE: Lafite TYPE: MODERN [RAPHAEL] RNID: 4AB25E8979F64A7365347CE8C15291DC MEID: B319D8DD90859F865AC7D33B8647A876 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 51 Strategy: [none|generic] Verify device config... Ok Loaders Ok Stage: ANDROID OS [1] Process RESET PROTECTION... Ok [2] Verified Stage: FRP Done: 00:00:54 Reconnect Power/Cable now |
09-15-2023, 14:22 | #74975 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Inifnix X6835 Smart Reset Done Operation: Reset Settings/Format FS [ v2.49a4 (beta) ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: FRP [ RESET PROTECTION ] Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM6) MODE [0]: BOOTROM; PORT: 6 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] MEID: 860D412F0E6DAC8185F712AAFC185B2C BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 892B4A6DF7BF85C3313E5B1605838FA2056D390D3936E871B6 04369E8BF3F16A SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok FF: Looking for EMI Found SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 860D412F0E6DAC8185F712AAFC185B2C AGENT: AUTO: Infinix: 2023-05 [caf6df7e] C:\InfinityBox\CM2MT2\boot\Infinix\2023-05\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6768 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 150100444436384D4202C5D9CAEA27E1 crc Ok Ven: Samsung OEM: 256 ID: 444436384D42 [DD68MB] PRV: 0x02 SNN: 3319384810 [0xC5D9CAEA] MM/YY: 2/2020 EMI: Init Ok EMI: FireFly preloader_oppo6769.bin with 13 memory type(s) 1. eMMC LP_DDR4X ID: 150100445636444D42 Samsung DV6DMB RAM: 4.00 Gb 2. eMMC LP_DDR4X ID: 13014E53304A394B39 Micron S0J9K9 RAM: 4.00 Gb 3. eMMC LP_DDR4X ID: 150100444436384D42 Samsung DD68MB RAM: 3.00 Gb 4. eMMC LP_DDR4X ID: 150100444836444142 Samsung DH6DAB RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 3.00 Gb 6. eMMC LP_DDR4X ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 150100445036384D42 Samsung DP68MB RAM: 3.00 Gb 8. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 9. eMMC LP_DDR4X ID: 1501003458364B4D42 Samsung 4X6KMB RAM: 2.00 Gb 10. eMMC LP_DDR4X ID: 450100444134313238 Sandisk DA4128 RAM: 4.00 Gb 11. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 2.00 Gb 12. eMMC LP_DDR4X ID: 150100334836434142 Samsung 3H6CAB RAM: 6.00 Gb 13. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 6.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x00070000 [ 448.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 150100444436384D4202C5D9CAEA27E1 crc Ok Ven: Samsung OEM: 256 ID: 444436384D42 [DD68MB] PRV: 0x02 SNN: 3319384810 [0xC5D9CAEA] MM/YY: 2/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] RNID: 717DCFCEF48E8A01E6749F46538A0327 MEID: 860D412F0E6DAC8185F712AAFC185B2C USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 48 Strategy: [none|generic] Verify device config... Ok Loaders Ok Stage: ANDROID OS [1] Process RESET PROTECTION... Ok [2] Verified Stage: FRP Done: 00:00:42 Reconnect Power/Cable now |
09-15-2023, 14:25 | #74976 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | infinix Hot10i pr652b Smart Resert Done Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Infinix : infinix-pr652b.f94d6017.f89a4840 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:20 |
09-15-2023, 15:37 | #74977 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Infinix Hot 10i FullFlash Done Operation : Flash Firmware [ v2.14 ] Setting : Update NVRAM : False Setting : Force NVRAM : False Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : PR652B-F6317-11.0-OP-V76-20221102.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x4A PMTMng : Update PMT Ok! Prepare target ... Prepare Ok! CODE : sharkl3_pubcp_LTEA_DSP.bin CODE : PM_sharkl3_cm4_v2.bin ERASE : MISC CODE : prodnv.img CODE : boot.img FSIMG : socko.img ERASE : METADATA CODE : dtbo.img CODE : SC9600_sharkl3_pubcp_modem.dat ERASE : L_RUNTIMENV1 CODE : logo.bin CODE : sharkl3_cm4.bin ERASE : UBOOT_LOG CODE : vbmeta_system_ext.img FSIMG : super.img CODE : sharkl3_pubcp_customer_deltanv.bin CODE : vbmeta_system.img FSIMG : cache.img CODE : sharkl3_pubcp_DM_DSP.bin CODE : gnssbdmodem.bin FSIMG : userdata.img CODE : gnssmodem.bin CODE : vbmeta_product.img CODE : vbmeta-sign.img CODE : Infinix_fastboot_720_1600_24bit.bmp ERASE : TRANFS CODE : cover.img CODE : tos-sign.bin CODE : teecfg-sign.bin CODE : vbmeta_vendor.img ERASE : SYSDUMPDB FSIMG : persist.img UBOOT : u-boot-spl-16k-sign.bin CODE : sml-sign.bin UBOOT : u-boot-sign.bin FSIMG : odmko.img Flashing finished! Reconnect Power/Cable! Done! Elapsed: 00:02:59 |
09-16-2023, 12:53 | #74978 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Tecno : KG5k Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Tecno : KG5k Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:09:07 |
09-16-2023, 13:06 | #74979 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | ViVo Y15 Operation: Memory Tool Init [ v2.49 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM6) MODE [0]: BOOTROM; PORT: 6 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: C9871E0B0CE7E1E4788914FCE9A4003B BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 41873F85328D416949BC988228F527CCECB457BDE493763E0D EE90E081DFFC86 SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok FF: Looking for EMI Found SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: C9871E0B0CE7E1E4788914FCE9A4003B AGENT: AUTO: Vivo: SEC_2023 [ecb438fd] C:\InfinityBox\CM2MT2\boot\Vivo\SEC_2023\MTK_AllIn One_DA_v3.fdaaf7f6.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 150100525036344D42012C77E4CB967D crc Ok Ven: Samsung OEM: 256 ID: 525036344D42 [RP64MB] PRV: 0x01 SNN: 746054859 [0x2C77E4CB] MM/YY: 9/2019 EMI: Init Ok EMI: FireFly preloader_k65v1_64_bsp.bin with 14 memory type(s) 1. eMMC LP_DDR4X ID: 150100445636444D42 Samsung DV6DMB RAM: 4.00 Gb 2. eMMC LP_DDR4X ID: 13014E53304A394B39 Micron S0J9K9 RAM: 4.00 Gb 3. eMMC LP_DDR4X ID: 150100444836444142 Samsung DH6DAB RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 150100444836444D42 Samsung DH6DMB RAM: 4.00 Gb 6. eMMC DDR3 ID: 150100525036344D42 Samsung RP64MB RAM: 4.00 Gb 7. eMMC DDR3 ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 8. eMMC DDR3 ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 10. eMMC LP_DDR4X ID: 150100335636434D42 Samsung 3V6CMB RAM: 6.00 Gb 11. eMMC LP_DDR4X ID: 13014E47314A395238 Micron G1J9R8 RAM: 4.00 Gb 12. eMMC LP_DDR4X ID: 13014E47314A395339 Micron G1J9S9 RAM: 4.00 Gb 13. eMMC LP_DDR4X ID: 150100445636444142 Samsung DV6DAB RAM: 4.00 Gb 14. eMMC LP_DDR4X ID: 150100445036444142 Samsung DP6DAB RAM: 4.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 150100525036344D42012C77E4CB967D crc Ok Ven: Samsung OEM: 256 ID: 525036344D42 [RP64MB] PRV: 0x01 SNN: 746054859 [0x2C77E4CB] MM/YY: 9/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 882AB18E808544D69545ED32A236519D MEID: C9871E0B0CE7E1E4788914FCE9A4003B USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 42 Verify device config... Ok Loaders Ok Reading... MemTool storage: C:\InfinityBox\CM2MT2\phdata\ Ready MemoryTool Operation: Erase Memory Wait... WARNING: Write or Erase operation may brick device! Make sure you select correct partitions and data! Continue? Yes Erase 3 partition(s) Erase [1] partition: FRP Ok Erase [2] partition: CACHE Ok Erase [3] partition: USERDATA Ok Finished Close MemoryTool session Done: 00:00:39 Reconnect Power/Cable now |
09-16-2023, 14:10 | #74980 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | vivo 2026 Frp Code: SW: vivo/2026/2026:10/QP1A.190711.020/compiler03232317:user/release-keys Product Brand: vivo Product Device: k65v1_64_bsp Product Model: vivo 2026 Product Name: full_k65v1_64_bsp Patch Level: QP1A.190711.020 Display ID: QP1A.190711.020 release-keys SW Version: compiler03232317 Ver. CodeName: REL Ver. Release: 10 Sec. Patch: 2021-02-01 Build Time: 23/03/2021 3:48:53 pm CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: k65v1_64_bsp SW: full_k65v1_64_bsp-user 10 QP1A.190711.020 compiler03232317 release-keys Product Board: k65v1_64_bsp Board Platform: mt6765 Product Manfct: vivo Strategy: [vivo] Firmware ID: MT6765_vivo_vivo_2026_OSv10_QP1A.190711.020_k65v1_64_bsp Verify firmware [MT6765_vivo_vivo_2026_OSv10_QP1A.190711.020_k65v1_64_bsp]... Exist Analyze userdata... userData: fileSystem [ext4] with FBE [file based encryption] Analyze modem... BBK_Q0MP1_K65V1_64_BSP_MDBIN_PCB01_MT6765_S00.MOLY_LR12A_R2_MP_V102_7_P69 Analyze nvram... NVRAM: Items: 0xB6 Size: 0x1250C6 State: Ok WiFi MAC: 9C8281073361 BlTh MAC: 9C8281073360 IMEI[1]: IMEI[2]: Verify device config... Ok Loaders Ok STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Analyze preloader... EMI: MT6765 preloader_k65v1_64_bsp.bin with 9 memory type(s) 1. eMMC LP_DDR4X ID: 150100445836384D42 Samsung DX68MB RAM: 3.00 Gb 2. eMMC LP_DDR4X ID: 13014E47314A395339 Micron G1J9S9 RAM: 4.00 Gb 3. eMMC LP_DDR4X ID: 150100445636444D42 Samsung DV6DMB RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 150100444436384D42 Samsung DD68MB RAM: 3.00 Gb 5. eMMC LP_DDR4X ID: 150100444836444142 Samsung DH6DAB RAM: 4.00 Gb 6. eMMC LP_DDR4X ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 150100445636444142 Samsung DV6DAB RAM: 4.00 Gb 8. eMMC LP_DDR4X ID: 150100445036444142 Samsung DP6DAB RAM: 4.00 Gb 9. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb Preloader exist: C:\InfinityBox\CM2MT2\backup\preloader\preloader_k65v1_64_bsp.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_k65v1_64_bsp.bin [1fe20459]... Exist Done: 00:00:37 Reconnect Power/Cable now Reset Mode: Reset FRP only Operation: Reset Settings/Format FS [ v2.47 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: FRP [ RESET PROTECTION ] Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM5) MODE [0]: BOOTROM; PORT: 5 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 1473ECC885142EDF7637CD1A6B057BE0 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 1BA426A54467BAFA61B508322D408FB788CCF62CBAEBB63A7A5BB86379BE9FA7 SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok EMI known SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 1473ECC885142EDF7637CD1A6B057BE0 AGENT: AUTO: Vivo: SEC_2022 [ae9c7ba6] C:\InfinityBox\CM2MT2\boot\Vivo\SEC_2022\MTK_AllInOne_DA.6677b6ce.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 1501004448364441420293CFD0981895 Ven: Samsung OEM: 256 ID: 444836444142 [DH6DAB] PRV: 0x02 SNN: 2479870104 [0x93CFD098] MM/YY: 1/2021 EMI: Init Ok EMI: FireFly preloader_k65v1_64_bsp.bin with 9 memory type(s) 1. eMMC LP_DDR4X ID: 150100445836384D42 Samsung DX68MB RAM: 3.00 Gb 2. eMMC LP_DDR4X ID: 13014E47314A395339 Micron G1J9S9 RAM: 4.00 Gb 3. eMMC LP_DDR4X ID: 150100445636444D42 Samsung DV6DMB RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 150100444436384D42 Samsung DD68MB RAM: 3.00 Gb 5. eMMC LP_DDR4X ID: 150100444836444142 Samsung DH6DAB RAM: 4.00 Gb 6. eMMC LP_DDR4X ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 150100445636444142 Samsung DV6DAB RAM: 4.00 Gb 8. eMMC LP_DDR4X ID: 150100445036444142 Samsung DP6DAB RAM: 4.00 Gb 9. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x00070000 [ 448.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 1501004448364441420293CFD0981895 Ven: Samsung OEM: 256 ID: 444836444142 [DH6DAB] PRV: 0x02 SNN: 2479870104 [0x93CFD098] MM/YY: 1/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 16255E255B848B78091DB79A5CFA12C5 MEID: 1473ECC885142EDF7637CD1A6B057BE0 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 47 Strategy: [none|generic] Verify device config... Ok Loaders Ok Stage: ANDROID OS [1] Process RESET PROTECTION... Ok [2] Verified Stage: FRP Done: 00:00:23 Reconnect Power/Cable now |
09-16-2023, 15:18 | #74981 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | motorola XT1700 Frp Code: Patch Level: MRA58K Display ID: XT1700_S503_161114_IRE SW Version: XT1700_S503_161114_IRE Ver. CodeName: REL Ver. Release: 6.0 Sec. Patch: 2016-10-05 Build Time: 14/11/2016 8:05:57 am Product Model: XT1700 Product Brand: motorola Product Name: taidos_row Product Device: taidos_row CPU: armeabi-v7a,armeabi Product Manfct: motorola Board Platform: mt6735m Product Info: taidos_row SW: taidos_row-user 6.0 MRA58K XT1700_S503_161114_IRE release-keys Strategy: [none|generic] Firmware ID: MT6735M_motorola_XT1700_OSv6.0_XT1700_S503_161114_IRE_MRA58K_taidos_row Verify firmware [MT6735M_motorola_XT1700_OSv6.0_XT1700_S503_161114_IRE_MRA58K_taidos_row]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Analyze userdata... userData: fileSystem [ext4] with FDE [encryptable] Analyze modem... Nothing Analyze nvram... NVRAM: Items: 0x12F Size: 0x067812 State: Ok WiFi MAC: 64DB43221B3C BlTh MAC: 64DB431E1B3C IMEI[1]: IMEI[2]: Verify device config... Ok Loaders Ok Analyze preloader... EMI: MT6752 preloader_taidos_row.bin with 6 memory type(s) 1. eMMC DDR3 ID: 150100464531324D42 Samsung FE12MB RAM: 1.00 Gb 2. eMMC DDR3 ID: 150100514531334D42 Samsung QE13MB RAM: 2.00 Gb 3. eMMC DDR3 ID: 150100464E58324D42 Samsung FNX2MB RAM: 1.00 Gb 4. eMMC DDR3 ID: 90014A483847346192 Hynix H8G4a RAM: 1.00 Gb 5. eMMC DDR3 ID: 90014A484147346132 Hynix HAG4a2 RAM: 2.00 Gb 6. eMMC DDR3 ID: 13014E51324A393652 Micron Q2J96R RAM: 2.00 Gb Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_taidos_row.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_taidos_row.bin [555b7434]... Exist Done: 00:00:40 Reconnect Power/Cable now Operation: Reset Settings/Format FS [ v2.47 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: FRP [ RESET PROTECTION ] Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (Android) (COM8) MODE [0]: PRELOADER PORT; PORT: 8 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6735 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0335 TYPE: LEGACY [MTK] BROM: Sec Level: 0x00000001 Mode: SBC VER: 0xFF BL: 0x01 [PRELOADER PORT] AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_AllInOne_DA.2022-04-10.3365c4d2.bin Looking for suitable BootChain in DA... Found MT6735 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started NAND: DEVICE NOT FOUND EMMC: OK CID: 150100464E58324D4201C51CAA6098B1 DA v4.2.155 DA: DRAM ready Boot to 2nd DA... Ok Load HW info... EMMC CID: 150100464E58324D4201C51CAA60A3B1 Ven: Samsung OEM: 256 ID: 464E58324D42 [FNX2MB] PRV: 0x01 SNN: 3306990176 [0xC51CAA60] MM/YY: 10/2016 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00080000 [ 512.00 Kb ] USER: 0x1D2000000 [ 7.28 Gb ] RAM: SRAM: 0x00020000 [ 128.00 Kb ] RAM: DRAM: 0x40000000 [ 1.00 Gb ] CHIP: MT6735 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0335 TYPE: LEGACY [MTK] RNID: 4510FE5B406F711D3A864B93ED9ACF2E DA: Status: BLANK FLASH; Boot Style: EMMC FLASH BOOT USB: HIGH-SPEED Boot done LEGACY [MTK] Analyze PMT... Ok PMT: LGPT [0x06] Records: 30 Strategy: [none|generic] Verify device config... Ok Loaders Ok Stage: ANDROID OS [1] Process RESET PROTECTION... Ok [2] Verified Done: 00:00:23 Reconnect Power/Cable now |
09-16-2023, 15:19 | #74982 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | TECNO-BD2p Format & Frp Code: Product Brand : TECNO Product Name : BD2p-OP Product Device : TECNO-BD2p Product Model : TECNO BD2p Product Board : BD2p Patch Level : RP1A.201005.001 Display ID : BD2p-SP613DEF-RGo-OP-230419V18 Ver. Incmt : 230419V18 Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2023-04-05 Build Time : 20.04.2023 Product Info : sp7731e_1h10 Product Board : sp7731e_1h10 Board Platform : sp7731e Product Manfct : TECNO MOBILE LIMITED NVMng : SecurityInfo IMEI[1] : IMEI[2] : IMEI[3] : WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC : SLS:0, SKS:0, SKV:4 USERDATA : FILESYSTEM : F2FS with FBE ( File-Base Encryption ) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:01:54 Operation : Format FS / Reset Settings [ v2.14 ] Mode : Reset Settings [ Format FS ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : TECNO : BD2-OP Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Reconnect Power/Cable! Done! Elapsed: 00:00:24 |
09-16-2023, 15:20 | #74983 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | TECNO KG8 Frp Code: SW: TECNO/KG8-GL/TECNO-KG8:11/RP1A.200720.011/230607V594:user/release-keys Product Brand: TECNO Product Device: TECNO-KG8 Product Model: TECNO KG8 Product Name: KG8-GL Patch Level: RP1A.200720.011 Display ID: KG8-H698CDEFGH-R-GL-230607V594 SW Version: 230607V594 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2023-06-05 Build Time: 06/06/2023 7:19:44 pm CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: kg8_h698 SW: vnd_kg8_h698-user 11 RP1A.200720.011 346883 release-keys Product Board: TECNO-KG8 Board Platform: mt6768 Product Manfct: TECNO MOBILE LIMITED Strategy: [none|generic] Firmware ID: MT6768_TECNO_MOBILE_LIMITED_TECNO_KG8_OSv11_KG8-H698CDEFGH-R-GL-230607V594_RP1A.200720.011_kg8_h698 Verify firmware [MT6768_TECNO_MOBILE_LIMITED_TECNO_KG8_OSv11_KG8-H698CDEFGH-R-GL-230607V594_RP1A.200720.011_kg8_h698]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Analyze userdata... userData: fileSystem : [f2fs] with FBE [file based encryption] Analyze modem... Nothing Analyze nvram... NVRAM: Items: 0xB8 Size: 0x122373 State: Ok WiFi MAC: 2C4DDEF15E21 BlTh MAC: 2C4DDEF15E20 IMEI[1]: IMEI[2]: Verify device config... Ok Loaders Ok STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY NOT PROGRAMMED [USABLE] Analyze preloader... EMI: MT6752 preloader_kg8_h698.bin with 16 memory type(s) 1. eMMC LP_DDR4X ID: 90014A684445615033 Hynix hDEaP3 RAM: 6.00 Gb 2. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 13014E53304A394B39 Micron S0J9K9 RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 150100445036384D42 Samsung DP68MB RAM: 3.00 Gb 6. eMMC LP_DDR4X ID: 150100444836444142 Samsung DH6DAB RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 150100334836434142 Samsung 3H6CAB RAM: 6.00 Gb 8. eMMC LP_DDR4X ID: 150100445636444142 Samsung DV6DAB RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 150100445036444142 Samsung DP6DAB RAM: 4.00 Gb 10. eMMC LP_DDR4X ID: 13014E47314A395339 Micron G1J9S9 RAM: 4.00 Gb 11. eMMC LP_DDR4X ID: 150100335636434D42 Samsung 3V6CMB RAM: 6.00 Gb 12. eMMC LP_DDR4X ID: 150100335636434142 Samsung 3V6CAB RAM: 6.00 Gb 13. eMMC LP_DDR4X ID: 150100335036434D42 Samsung 3P6CMB RAM: 6.00 Gb 14. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 4.00 Gb 15. eMMC LP_DDR4X ID: 150100445036444242 Samsung DP6DBB RAM: 4.00 Gb 16. eMMC LP_DDR4X ID: 150100445636444242 Samsung DV6DBB RAM: 4.00 Gb Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_kg8_h698.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_kg8_h698.bin [d4349359]... Exist Done: 00:00:30 Reconnect Power/Cable now Operation: Reset Settings/Format FS [ v2.47 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: FRP [ RESET PROTECTION ] Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM5) MODE [0]: BOOTROM; PORT: 5 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] MEID: 76DD3B61360FBF1C272B75B4608E156F BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: B3B845E6CC1617B62A8AB9ED4E0DC9F67E5A16804C07171F05113A17DBAD1F8E SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok EMI known SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 76DD3B61360FBF1C272B75B4608E156F AGENT: AUTO: Tecno: 2023-05 [caf6df7e] C:\InfinityBox\CM2MT2\boot\Infinix\2023-05\MTK_AllInOne_DA.2023-05-10.fa7ac554.bin Looking for suitable BootChain in DA... Found MT6768 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 15010044503644414202378DFAB3B879 Ven: Samsung OEM: 256 ID: 445036444142 [DP6DAB] PRV: 0x02 SNN: 932051635 [0x378DFAB3] MM/YY: 11/2021 EMI: Init Ok EMI: FireFly preloader_kg8_h698.bin with 16 memory type(s) 1. eMMC LP_DDR4X ID: 90014A684445615033 Hynix hDEaP3 RAM: 6.00 Gb 2. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 13014E53304A394B39 Micron S0J9K9 RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 150100445036384D42 Samsung DP68MB RAM: 3.00 Gb 6. eMMC LP_DDR4X ID: 150100444836444142 Samsung DH6DAB RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 150100334836434142 Samsung 3H6CAB RAM: 6.00 Gb 8. eMMC LP_DDR4X ID: 150100445636444142 Samsung DV6DAB RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 150100445036444142 Samsung DP6DAB RAM: 4.00 Gb 10. eMMC LP_DDR4X ID: 13014E47314A395339 Micron G1J9S9 RAM: 4.00 Gb 11. eMMC LP_DDR4X ID: 150100335636434D42 Samsung 3V6CMB RAM: 6.00 Gb 12. eMMC LP_DDR4X ID: 150100335636434142 Samsung 3V6CAB RAM: 6.00 Gb 13. eMMC LP_DDR4X ID: 150100335036434D42 Samsung 3P6CMB RAM: 6.00 Gb 14. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 4.00 Gb 15. eMMC LP_DDR4X ID: 150100445036444242 Samsung DP6DBB RAM: 4.00 Gb 16. eMMC LP_DDR4X ID: 150100445636444242 Samsung DV6DBB RAM: 4.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x00070000 [ 448.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 15010044503644414202378DFAB3B879 Ven: Samsung OEM: 256 ID: 445036444142 [DP6DAB] PRV: 0x02 SNN: 932051635 [0x378DFAB3] MM/YY: 11/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] RNID: CC534B4C90B934020F38087BE3217515 MEID: 76DD3B61360FBF1C272B75B4608E156F USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 49 Strategy: [none|generic] Verify device config... Ok Loaders Ok Stage: ANDROID OS [1] Process RESET PROTECTION... Ok [2] Verified Stage: FRP Done: 00:00:21 Reconnect Power/Cable now |
09-16-2023, 15:21 | #74984 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Infinix-X688B Frp Code: SW: Infinix/X688B-GL/Infinix-X688B:11/RP1A.200720.011/230324V619:user/release-keys Product Brand: Infinix Product Device: Infinix-X688B Product Model: Infinix X688B Product Name: X688B-GL Patch Level: RP1A.200720.011 Display ID: X688B-H659ABCDEFGHIJKLMNO-R-GL-230324V619 SW Version: 230324V619 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2023-03-05 Build Time: 24/03/2023 10:02:24 am CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: x688b_h659 SW: vnd_x688b_h659-user 11 RP1A.200720.011 282777 release-keys Product Board: Infinix-X688B Board Platform: mt6765 Product Manfct: INFINIX MOBILITY LIMITED Strategy: [none|generic] Firmware ID: MT6765_INFINIX_MOBILITY_LIMITED_Infinix_X688B_OSv11_X688B-H659ABCDEFGHIJKLMNO-R-GL-230324V619_RP1A.200720.011_x688b_h659 Verify firmware [MT6765_INFINIX_MOBILITY_LIMITED_Infinix_X688B_OSv11_X688B-H659ABCDEFGHIJKLMNO-R-GL-230324V619_RP1A.200720.011_x688b_h659]... Exist Analyze userdata... userData: fileSystem : [f2fs] with FBE [file based encryption] Analyze modem... TK_MD_BASIC_MDBIN_PCB01_MT6765_S00.MOLY_LR12A_R3_MP_V149_4_P65 Analyze nvram... NVRAM: Items: 0xA2 Size: 0x08C02F State: Ok WiFi MAC: 5810B7B9CA63 BlTh MAC: 5810B7B9CA62 IMEI[1]: IMEI[2]: Verify device config... Ok Loaders Ok STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY NOT PROGRAMMED [USABLE] Analyze preloader... EMI: MT6765 preloader_x688b_h659.bin with 20 memory type(s) 1. eMMC LP_DDR4X ID: 90014A684445615033 Hynix hDEaP3 RAM: 6.00 Gb 2. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 150100444836444142 Samsung DH6DAB RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 150100445636444242 Samsung DV6DBB RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 13014E47314A395339 Micron G1J9S9 RAM: 4.00 Gb 6. eMMC LP_DDR4X ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 90014A484347386134 Hynix HCG8a4 RAM: 6.00 Gb 8. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 6.00 Gb 10. eMMC LP_DDR4X ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 11. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 3.00 Gb 12. eMMC LP_DDR4X ID: 150100445036384D42 Samsung DP68MB RAM: 3.00 Gb 13. eMMC LP_DDR4X ID: 13014E53304A394B39 Micron S0J9K9 RAM: 4.00 Gb 14. eMMC LP_DDR4X ID: 150100445636444142 Samsung DV6DAB RAM: 4.00 Gb 15. eMMC LP_DDR4X ID: 150100445036444142 Samsung DP6DAB RAM: 4.00 Gb 16. eMMC LP_DDR4X ID: 150100445636444D42 Samsung DV6DMB RAM: 4.00 Gb 17. eMMC LP_DDR4X ID: 150100444436384D42 Samsung DD68MB RAM: 3.00 Gb 18. eMMC LP_DDR4X ID: 150100445036444242 Samsung DP6DBB RAM: 4.00 Gb 19. eMMC LP_DDR4X ID: 150100445836384D42 Samsung DX68MB RAM: 3.00 Gb 20. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_x688b_h659.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_x688b_h659.bin [3a6b50ea]... Exist Done: 00:00:28 Reconnect Power/Cable now Operation: Reset Settings/Format FS [ v2.47 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: FRP [ RESET PROTECTION ] Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM9) MODE [0]: BOOTROM; PORT: 9 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 5A8FBDC9324D55EBD656408A8D8E4402 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: B44F010D12E0B934F208F2290C5E170D6C4E6E8BA2621C0D36B6121B973445BB SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok EMI known SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 5A8FBDC9324D55EBD656408A8D8E4402 AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_AllInOne_DA.2022-04-10.3365c4d2.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 15010044503644414202E8BCCA6F5889 Ven: Samsung OEM: 256 ID: 445036444142 [DP6DAB] PRV: 0x02 SNN: 3904686703 [0xE8BCCA6F] MM/YY: 5/2021 EMI: Init Ok EMI: FireFly preloader_x688b_h659.bin with 20 memory type(s) 1. eMMC LP_DDR4X ID: 90014A684445615033 Hynix hDEaP3 RAM: 6.00 Gb 2. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 150100444836444142 Samsung DH6DAB RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 150100445636444242 Samsung DV6DBB RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 13014E47314A395339 Micron G1J9S9 RAM: 4.00 Gb 6. eMMC LP_DDR4X ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 90014A484347386134 Hynix HCG8a4 RAM: 6.00 Gb 8. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 6.00 Gb 10. eMMC LP_DDR4X ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 11. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 3.00 Gb 12. eMMC LP_DDR4X ID: 150100445036384D42 Samsung DP68MB RAM: 3.00 Gb 13. eMMC LP_DDR4X ID: 13014E53304A394B39 Micron S0J9K9 RAM: 4.00 Gb 14. eMMC LP_DDR4X ID: 150100445636444142 Samsung DV6DAB RAM: 4.00 Gb 15. eMMC LP_DDR4X ID: 150100445036444142 Samsung DP6DAB RAM: 4.00 Gb 16. eMMC LP_DDR4X ID: 150100445636444D42 Samsung DV6DMB RAM: 4.00 Gb 17. eMMC LP_DDR4X ID: 150100444436384D42 Samsung DD68MB RAM: 3.00 Gb 18. eMMC LP_DDR4X ID: 150100445036444242 Samsung DP6DBB RAM: 4.00 Gb 19. eMMC LP_DDR4X ID: 150100445836384D42 Samsung DX68MB RAM: 3.00 Gb 20. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 15010044503644414202E8BCCA6F5889 Ven: Samsung OEM: 256 ID: 445036444142 [DP6DAB] PRV: 0x02 SNN: 3904686703 [0xE8BCCA6F] MM/YY: 5/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: B1938E7B0C91C7C33BBF902D9F2B0326 MEID: 5A8FBDC9324D55EBD656408A8D8E4402 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 41 Strategy: [none|generic] Verify device config... Ok Loaders Ok Stage: ANDROID OS [1] Process RESET PROTECTION... Ok [2] Verified Stage: FRP Done: 00:00:20 Reconnect Power/Cable now |
