01-03-2011, 04:11 | #7681 (permalink) |
Banned Join Date: Sep 2007
Member: 583468 Status: Offline Sonork: 100.1592004 Thanks Meter: 106 | ZTC V800 SUCESSFULLY FLASH READ AND touchscreen calibration COM4 [VCP0] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6223:8A04:8A00]... CPU: MT6223 high speed boot Off chip: 0011:A8CA:000C status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent ==================== New firmware found (v.3.25, database date: 23.12.2010): H686Y_HV1_QCIF_PCB01_GPRS_MT6223P_S00.H686Y_HV1_QC IF_V1_0_2.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 04 sw version: H686Y_HV1_QCIF_PCB01_GPRS_MT6223P_S00.H686Y_HV1_QC IF_V1_0_2.BIN project-id: H686Y_HV1_QCIF_V1.0.2, 00000000 code offset: 00000000 ffs offset/size [01]: 00E80000/00180000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E80000 standard ffs/eeprom offset confirmed: 00E80000 detecting ffs/eeprom size... ffs/eeprom size: 00180000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E80000-00FFFFFF firmware area: 00000000-00E7FFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: H686Y_HV1_QCIF_PCB01_GPRS_MT6223P_S00.H686Y_HV1_QC IF_V1_0_2__fullflash... file saved: C:\Documents and Settings\JMZ\Desktop\H686Y_HV1_QCIF_PCB01_GPRS_MT6 223P_S00.H686Y_HV1_QCIF_V1_0_2__fullflash_20110103-082233.B0M.bin Finished, time used: 12 min 56 sec Remove/Install battery now ! |
The Following User Says Thank You to jmzboudh For This Useful Post: |
01-03-2011, 04:12 | #7682 (permalink) |
Member: 583468 Status: Offline Sonork: 100.1592004 Thanks Meter: 106 | ztc v800 touchscreen calibration ==== [1/3/2011 8:24:20 AM] ==== COM4 [VCP0] selected module v3.25 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... H686Y_HV1_QCIF_PCB01_GPRS_MT6223P_S00.H686Y_HV1_QC IF_V1_0_2__fullflash_20110103-082233.B0M.bin loaded ffs/eeprom record offset detected ffs/eeprom record size detected ffs/eeprom record offset detected ffs/eeprom record size detected Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A04:8A00]... CPU: MT6223 high speed boot Off chip: 0011:A8CA:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E04 Date: 2000.00.00 Version: 1.0 Version: H686Y_HV1_QCIF_V1.0.2 Version: H686_V1 44 byte(s) read imei: 35548650008963 connection Ok 512 byte(s) read 180 byte(s) read 512 byte(s) read calibration value: 0 writing data... verification... verification Ok Finished, time used: 12 sec Remove/Install battery now ! |
01-03-2011, 08:04 | #7683 (permalink) |
No Life Poster Join Date: Dec 2006 Location: P A K I S T A N
Member: 416286 Status: Offline Sonork: 100.1622339 Thanks Meter: 759 | COM6 [VCP7] selected module v1.78 Device: LG-KP105 Checking data, wait... Action: reset settings ("format ffs") Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: .01 ULC2GL KP105 KP100 P16 00 ARB V10f ARB-XX MAY-27-2008 Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP105_eeprom-static_20110103-112539.B1E.bin loading data... data loaded imei: 35996001268343100 reading eeprom-security_35996001268343100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP105_eeprom-security_35996001268343100_20110103-112540.B1E.bin reading eeprom-complete_35996001268343100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP105_eeprom-complete_35996001268343100_20110103-112541.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Write Done Finished, time used: 21 sec Remove/Install battery now ! |
The Following User Says Thank You to gsmpointhrp For This Useful Post: |
01-03-2011, 08:09 | #7684 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | N70, BEST v1.13 Code: Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Selected FlashSettings : Manual Files Set for Flashing : MCU : RM84_51003301.C0 PPM : RM84_51003301.V25 Check FlashFiles, Please, wait... -> SWversion check skipped : Manual mode selected Setting FlashMode FlashMode set Ok 1st boot Ok, C0 APE part info : APE ASICID : 17100701 APE MODE ID : 00 APE PUB ID : 0582F61769BBB43C8A24602AB504C64F4C2934BF APE R_HASH : 2C05369F57CC3C4CF9E783E83D9B512B APE ROM ID : AB5E4ADB27A06946 CMT part info : CMT ASICID : 000000010000022600010006000C192101002200 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 03B00002AB996351DD0A5E8C014984B2EEAFEFD5 CMT MODE ID : 00 CMT R_HASH : E9EFF4BFAA5393217CA6B17755FC3E14 CMT ROM ID : F28A211FCEA7B19D CMT : Sending 2nd loader... Use : RAP3Gv2_2nd.fg CMT Loader sent, Boot Ok MCU Configuration FLASHID : 225000EC , CMT , NOR CMT Flash ID : 225000EC < SAMSUNG [SEC] => K8S6415ETB FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg CMT Algo sent CMT PAPUB : 72BF9DE5D6711B3B1133EBCAB5914FA419C78DC100 Transmission mode : Dual (Ddr, TX2) APE : Sending 2nd loader... Use : helen3_2nd.fg APE Loader sent, Boot Ok FLASHID : 00360098 , APE , NAND APE Flash ID : 00360098 < UNKNOW [NOT IN BASE] ALGO : OMAP1610 GBBM-1.8.1 AL FLMCID : 000002000000060000000000000000 Sending ALGO.... Use : h3_sam_nand_gbbm.fg APE Algo sent APE PAPUB : 72BF9DE5D6711B3B1133EBCAB5914FA419C78DC000 Boot Done! Partitioning.... Partitioning Ok... Transmission mode : Dual (Ddr, TX2) Erase : Processing RM84_51003301.C0 Found 4 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x0052B60D CMT , NOR , Area : 0x006A0000 - 0x006BFFFF CMT , NOR , Area : 0x006DF000 - 0x006EFFFF CMT , NOR , Area : 0x00700000 - 0x007EFFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok Found 4 areas to erase, erase group Asic : APE , Sub : NAND APE , NAND , Area : 0x00000000 - 0x0000FFFF APE , NAND , Area : 0x00010000 - 0x0001FFFF APE , NAND , Area : 0x00020000 - 0x000203FF APE , NAND , Area : 0x00050000 - 0x03ECFFFF Erasing, wait..... APE : Group erase Ok TIME : Erase time : 00:00:51 Transmission mode : Dual (Ddr, TX2) Write : Processing RM84_51003301.C0 CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] APE: Writing Hash CERT [KEYS] APE: Writing Hash CERT [X-LOADER] APE: Writing Hash CERT [PRIMAPP] APE: Writing Hash CERT [SOS+LOADER] APE: Writing Hash CERT [SOS+XZIP] APE: Writing Hash CERT [PASUBTOC] APE: Writing Hash CERT [PAPUBKEYS] APE: Writing Hash CERT [SOS*CORE] Total writen 1122 blocks TIME : Write time : 00:03:28 Partitioning.... Partitioning Ok... Transmission mode : Dual (Ddr, TX2) Erase : Processing RM84_51003301.V25 Found 2 areas to erase, erase group Asic : APE , Sub : NAND APE , NAND , Area : 0x01AE0000 - 0x02AFFFFF APE , NAND , Area : 0x02B00000 - 0x03ECFFFF Erasing, wait..... APE : Group erase Ok TIME : Erase time : 00:00:00 Transmission mode : Dual (Ddr, TX2) Write : Processing RM84_51003301.V25 Total writen 1583 blocks TIME : Write time : 00:01:51 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia N70 Software Info: V 05wk07v48.6 19-01-10 RM-84 (c) Nokia. IMEI: 359566010169685 Product code: 0533691 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! AfterFlash operations done... Reconnect, wait... Connect phone on selected interface... |
The Following User Says Thank You to Dzirt For This Useful Post: |
01-03-2011, 08:11 | #7685 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | 6131 fix ST_SECURITY error Code: Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Local SX4 procedure started... Phone Imei: 359390008279327 Key file exists, no need to read... Step 1... Step 2... Step 3... SX4 Auth - Ok Done! Uploading RF/Battery tune to phone... Using : RM-115.pm Operating mode is OK, no need change... Field 1 Record 0 write - Ok Record 2 write - Ok Record 4 write - Ok Record 6 write - Ok Record 8 write - Ok Record 13 write - Ok Record 16 write - Ok Record 18 write - Ok Record 20 write - Ok Record 25 write - Ok Record 26 write - Ok Record 28 write - Ok Record 29 write - Ok Record 31 write - Ok Record 34 write - Ok Field 309 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 4 write - Ok Record 5 write - Ok Record 7 write - Ok Record 8 write - Ok Record 17 write - Ok Check ST_SECURITY now... Security status : ST_SECURITY => OK Done! Elapsed: 00:00:01 |
The Following 3 Users Say Thank You to Dzirt For This Useful Post: |
01-03-2011, 08:50 | #7686 (permalink) |
No Life Poster Join Date: May 2007 Location: uk
Member: 508072 Status: Offline Thanks Meter: 1,621 | Action: "repair imei" Model: Spice-S415-2008-03-19 Checking data, wait... Phone should be Switched ON ! Connecting, wait... baud set to: 115200 Phone detected, wait... imei-1: 135790246811220 imei write method: mode-1 new imei-1: 353923038966418 verification Ok Finished, time used: 3 sec Remove/Install battery now ! |
The Following User Says Thank You to joni_rajpura For This Useful Post: |
01-03-2011, 08:59 | #7687 (permalink) |
Member: 508072 Status: Offline Thanks Meter: 1,621 | COM2 [VCP3] selected module v3.70 Device: Spice-S415-2008-03-19 Checking data, wait... advanced flash detection disabled Action: "sp-unlock" unlock method: standard fast Unlock procedure can be faster if you skip ffs/eeprom area backup procedure. Do you want to disable ffs/eeprom backup ? ffs/eeprom backup disabled ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6205:8B00]... CPU: MT6205 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 7F22C400000000:18E59F00000000 flash: T 2Mb otp offset: 001F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < ffs/eeprom address can not be detected, value from database assigned: 001B0000/00050000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 7F22C400000000:18E59F00000000 Backup required data Done ====> Patch required data ... ...... lock area found Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... ..... required data found flash: 7F22C400000000:18E59F00000000 flash: 7F22C400000000:18E59F00000000 Write: area 1 (pass 1) ... area 1 patch applied Ok Special operation Done ====> Write ... flash: 7F22C400000000:18E59F00000000 flash: 7F22C400000000:18E59F00000000 Write: lock-area-1 Write Done ====> Finalization ... Finalization Done Finished, time used: 24 sec Remove/Install battery now ! |
01-03-2011, 09:30 | #7688 (permalink) |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM3 [VCP0] selected module v3.70 Device: LG-KG195 Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 chip: 0031:15FE6EE status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S7332SA00-001-R1C.BIN project-id: 7S7332SA00-001-R1C, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent ffs/eeprom address assigned: 00E00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 98004900000002:29EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98004900000002:29EA0000000000 Finalization Done Finished, time used: 35 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to cel_phon For This Useful Post: |
01-03-2011, 09:47 | #7689 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Gujrat (India) Age: 38
Member: 253882 Status: Offline Sonork: 100.1585698 Thanks Meter: 242 | CJF.10.IOct 09 2010 MICROMAX C111 09 Oct 2010 selected.. Offline.. Downloading mode.. prepare for patching... try conecting..1 Sending Boot.. patching in progress... patching in progress 50%... patching in progress 100%... done... Finished, time used: 41 sec |
The Following 3 Users Say Thank You to msmobile For This Useful Post: |
01-03-2011, 09:50 | #7690 (permalink) |
Member: 253882 Status: Offline Sonork: 100.1585698 Thanks Meter: 242 | unlocked --------------------------------------------------------- HARDWARE : MTS_S100 COMPILE : Jul 06 2010 (21:17:17) REALEASE : Oct 24 2006 (13:00:00) SW Version : QSC6010 SCNRZ MTS_S100_RBTL4 --------------------------------------------------------- Phonce code : 0000 Finished, time used: 3 sec ==== [1/3/2011 1:54:02 PM] ==== COM30 [QCUSB_COM30_1] selected module v1.41 Device: ZTE-S100 operation: SP-unlock mode #2 Phone should be Switched ON ! connecting... ESN(hex) : 80543233 disabling minlock... Done... Phones should be restarting now... Finished, time used: 3 sec Loading data, wait... [Infinity Box] CDMA-Tool v1.41 smart-card: connected S/N: 237B:0118 Wait... Device: ZTE-S100 Done COM30 ready ==== [1/3/2011 1:59:56 PM] ==== COM30 [QCUSB_COM30_1] selected module v1.41 Device: ZTE-S100 operation: SP-unlock mode #2 Phone should be Switched ON ! connecting... ESN(hex) : 80ECB2C7 disabling minlock... Done... Phones should be restarting now... Finished, time used: 3 sec Loading data, wait... [Infinity Box] CDMA-Tool v1.41 smart-card: connected S/N: 237B:0118 Wait... Device: ZTE-S100 Done COM30 ready ==== [1/3/2011 2:07:47 PM] ==== COM30 [QCUSB_COM30_1] selected module v1.41 Device: ZTE-S100 operation: SP-unlock mode #2 Phone should be Switched ON ! connecting... ESN(hex) : 80F62939 disabling minlock... Done... Phones should be restarting now... Finished, time used: 3 sec ==== [1/3/2011 2:10:37 PM] ==== COM30 [QCUSB_COM30_1] selected module v1.41 Device: ZTE-S100 operation: SP-unlock mode #2 Phone should be Switched ON ! connecting... ESN(hex) : 80A6B1B5 disabling minlock... Done... Phones should be restarting now... Finished, time used: 3 sec ==== [1/3/2011 2:11:24 PM] ==== COM30 [QCUSB_COM30_1] selected module v1.41 Device: ZTE-S100 operation: SP-unlock mode #2 Phone should be Switched ON ! connecting... ESN(hex) : 800AA12E disabling minlock... Done... Phones should be restarting now... Finished, time used: 3 sec Loading data, wait... [Infinity Box] CDMA-Tool v1.41 smart-card: connected S/N: 237B:0118 Wait... Device: Micromax-C111 Done COM24 ready ==== [1/3/2011 2:16:21 PM] ==== COM24 [QCUSB_COM24_1] selected module v1.41 Device: Micromax-C111 operation: SP-unlock Phone should be Switched ON ! connecting... CJF.10.IOct 09 2010 MICROMAX C111 09 Oct 2010 selected.. Offline.. Downloading mode.. prepare for patching... try conecting..1 Sending Boot.. patching in progress... patching in progress 50%... patching in progress 100%... done... Finished, time used: 41 sec Thx infinity Team.......... |
01-03-2011, 09:56 | #7691 (permalink) |
Member: 253882 Status: Offline Sonork: 100.1585698 Thanks Meter: 242 | COM30 [QCUSB_COM30_1] selected module v1.41 Device: ZTE-S100 operation: SP-unlock mode #2 Phone should be Switched ON ! connecting... ESN(hex) : 80ECB2C7 disabling minlock... Done... Phones should be restarting now... Finished, time used: 3 sec |
01-03-2011, 09:57 | #7692 (permalink) |
Member: 253882 Status: Offline Sonork: 100.1585698 Thanks Meter: 242 | ==== [1/3/2011 2:25:43 PM] ==== COM24 [QCUSB_COM24_3] selected module v1.41 Device: Micromax-C111 operation: SP-unlock Phone should be Switched ON ! connecting... CJF.10.IOct 09 2010 MICROMAX C111 09 Oct 2010 selected.. Offline.. Downloading mode.. prepare for patching... try conecting..1 Sending Boot.. patching in progress... patching in progress 50%... patching in progress 100%... done... Finished, time used: 41 sec |
01-03-2011, 10:28 | #7693 (permalink) |
Member: 508072 Status: Offline Thanks Meter: 1,621 | COM2 [VCP1] selected module v3.70 Device: Spice-S415-2008-03-19 Checking data, wait... advanced flash detection disabled Action: "sp-unlock" unlock method: standard fast Unlock procedure can be faster if you skip ffs/eeprom area backup procedure. Do you want to disable ffs/eeprom backup ? ffs/eeprom backup disabled ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6205:8B00]... CPU: MT6205 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 7F22C400000000:18E59F00000000 flash: T 2Mb otp offset: 001F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < ffs/eeprom address can not be detected, value from database assigned: 001B0000/00050000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 7F22C400000000:18E59F00000000 Backup required data Done ====> Patch required data ... ...... lock area found Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... ..... required data found flash: 7F22C400000000:18E59F00000000 flash: 7F22C400000000:18E59F00000000 Write: area 1 (pass 1) ... area 1 patch applied Ok Special operation Done ====> Write ... flash: 7F22C400000000:18E59F00000000 flash: 7F22C400000000:18E59F00000000 Write: lock-area-1 Write Done ====> Finalization ... Finalization Done Finished, time used: 24 sec Remove/Install battery now ! |
01-03-2011, 10:55 | #7694 (permalink) |
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM6 [VCP0] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:8003:000E status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: K320MLT_PCB01_GPRS_MT6225_S00.M_RK3230401_M28202_V 1_0_0_0M0918.BIN project-id: M.RK3230401.M28202.V1.0.0.0M0918, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: K320MLT_PCB01_GPRS_MT6225_S00.M_RK3230401_M28202_V 1_0_0_0M0918__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\K320MLT_PCB01_GPR S_MT6225_S00.M_RK3230401_M28202_V1_0_0_0M0918__ffs _20110103-145513.B0E.bin flash: 98000300000001:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:18E59F00000000 Finalization Done Finished, time used: 2 min 7 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
01-03-2011, 11:22 | #7695 (permalink) |
No Life Poster Join Date: Jul 2008 Location: pakistan hafizabad
Member: 811013 Status: Offline Sonork: 03468717163 Thanks Meter: 744 | zong 231 unlocking don COM4 [VCP0] selected module v3.62 Action: "sp-unlock" unlock method: smart fast Model: ZTE-R231 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: E-PK-ZONG9-P107A1V1.0.0B02 Version: 08BZTENJ35_OG_08B 80 byte(s) read imei: 35424903277553 connection Ok 186 byte(s) read reading data... reading data #2... building new data... writing data... 174 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 15 sec Remove/Install battery now ! Last edited by javedsf; 01-03-2011 at 11:28. |
The Following 3 Users Say Thank You to javedsf For This Useful Post: |
