09-23-2009, 13:11 | #976 (permalink) |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | COM22 [Serial2] selected module v2.82 Action: touchscreen calibration mode: 4 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:0D03:000B status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: M2800_Abroad_S71PL1_ILI_V1.0.5 Version: LONGYU25_GEMINI_HW detecting structure #2... 4 5 11 done 67 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-4)... done 210 byte(s) read reading data #2... writing data... verification... verification Ok Power-On and test phone now If calibration is not completed yet: 1. make "Reverse calibration order" Checked and try again 2. try another calibration mode Finished, time used: 21 sec Remove/Install battery now ! |
The Following User Says Thank You to Shakeel_pattoki For This Useful Post: |
09-24-2009, 07:24 | #977 (permalink) |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM6 [VCP0] selected module v2.75 Action: touchscreen calibration mode: 3 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:B703:000B Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: M2800_Abroad_TV0057_V1.0.10 Version: LONGYU25_GEMINI_HW detecting structure #2... 4 5 11 done 67 byte(s) read imei: 35850901002701 connection Ok detecting structure #5 (mode-4)... done 210 byte(s) read writing data... verification... verification Ok Finished, time used: 9 sec Remove/Install battery now ! |
09-24-2009, 07:28 | #978 (permalink) |
No Life Poster Join Date: Nov 2005 Location: TIRUPUR
Member: 202500 Status: Offline Thanks Meter: 234 | s259 unlock done infinity qcmodule 1.8 ver cable ustpro or infinty e250 rj45 COM2 [VCP2] selected module v1.08 Device: Samsung-SCH-S259 Checking data, wait... Action: unlock Phone should be Switched ON ! Connecting, wait... Phone detected, wait... step-1 done step-2 done step-3 done operation finished Finished, time used: 24 sec Remove/Install battery now ! no need rebuild option. |
The Following 2 Users Say Thank You to ashok_kumar459 For This Useful Post: |
09-24-2009, 08:15 | #979 (permalink) |
No Life Poster Join Date: Oct 2006 Location: pakistan
Member: 373786 Status: Offline Sonork: 100.1601935 Thanks Meter: 130 | KG200 successfully repair COM5 [VCP0] selected module v2.79 Device: LG-KG200 Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active "format ffs" active write: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6219:8B02:8B01]... CPU: MT6219 detected CPU: MT6226MA chip: 0031:14C1:CDCA status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: ARIMA26_05C_PCB01_GPRS_MT6226M_S01.7S7330SA00-001-R1D.BIN ver. sw 2: 7S7330SA00-001-R1D, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: LG-KG200_ARIMA26_05C_PCB01_GPRS_MT6226M_S01.7S7330SA0 0-001-R1D__ffs... file saved: C:\Program Files\InfinityBox\MModule\LG-KG200_ARIMA26_05C_PCB01_GPRS_MT6226M_S01.7S7330SA0 0-001-R1D__ffs_20090924-115846.A3E.bin Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Area: Firmware flash: 98004900000002:29EA0000000000 Write: Firmware Area: Eeprom/ffs flash: 98004900000002:29EA0000000000 Write: Eeprom/ffs detect device identification#2... detection phase #1... . detect device identification#2 finished Write Done Finalization ... formatting... flash: 98004900000002:29EA0000000000 Finalization Done Finished, time used: 492 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following 2 Users Say Thank You to ..::proudcracker::.. For This Useful Post: |
09-24-2009, 08:40 | #980 (permalink) |
No Life Poster Join Date: Aug 2005 Location: Ena Neray Na Ho Dildar Ve Age: 37
Member: 171512 Status: Offline Thanks Meter: 1,034 | NK TEL A200 REPAIR OK COM4 [VCP0] selected module v2.82 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:8C03:0005 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 89881200010001:89881200000000 flash: Intel Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 89881200010001:89881200000000 flash: Intel Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #02 in region #00... flash: 89881200010001:89881200000000 flash: Intel Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #03 in region #00... flash: 89881200010001:89881200000000 flash: Intel Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 89881200010001:89881200000000 flash: Intel Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 89881200010001:89881200000000 flash: Intel Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation ==================== New firmware detected (v.2.82, database date: 15.05.2009): KCM25_GEMINI_PCB01_GPRS_MT6225_S00.K7_PBLCD_PBCAME RA_T3_V3_0.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: KCM25_GEMINI_PCB01_GPRS_MT6225_S00.K7_PBLCD_PBCAME RA_T3_V3_0.BIN ver. sw 2: k7_PbLCD_PbCamera_T3_V3.0, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 89881200010001:89881200000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 89881200010001:89881200000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 89881200010001:89881200000000 Finalization Done Finished, time used: 50 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following 2 Users Say Thank You to ehsas_ghum For This Useful Post: |
09-24-2009, 10:47 | #981 (permalink) |
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM6 [VCP0] selected module v2.91 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check detailed information Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:EC03:000A status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [enhanced] generation startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.95E537E4.[V490_PCB01_GPRS_MT6226_S01.L3P4T02_7_12_1_0T02M071 4_M510A.BIN_F7A6AFBA].rpl rom info detection finished device-id: 95E537E4 rom info protocol ver: 04 ver. sw 1: V490_PCB01_GPRS_MT6226_S01.L3P4T02_7_12_1_0T02M071 4_M510A.BIN ver. sw 2: L3P4T02.7.12.1.0T02M0714_M510A, 45505908 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC257E25082501:2AEA0000000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation operation terminated by user file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\_ system_log_95E537E4_F7A6AFBA_20090924-023645.B0X.bin Finished, time used: 36 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to cel_phon For This Useful Post: |
09-24-2009, 11:05 | #982 (permalink) |
No Life Poster Join Date: Mar 2008 Location: China/USA
Member: 718425 Status: Offline Thanks Meter: 5,873 | Alcatel-S210 unlock COM3 [VCP1] selectedmodule v1.32 Device: Alcatel-S210 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 812500 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-S210_eeprom_calibration-1... file saved: D:\Program Files\InfinityBox\HModule\Alcatel-S210_eeprom_calibration-1_20090517-213722.80E.bin Read data done Check data ... Check data done Write ... ......... ......... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Write done Finished, time used: 74 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to R@ZIB-BD For This Useful Post: |
09-24-2009, 17:32 | #983 (permalink) |
Freak Poster Join Date: Mar 2008 Location: Akay Institute of mobile tech.
Member: 732084 Status: Offline Thanks Meter: 122 | INFINITY TEAM Successfully unlock new samsung B189 Successfully unlock samsung B189 simple way open QC MODULE2 choose samsung s189 first rebuild software says errer dont warry. secend SP unlock your set successfuly unlocked. INFINITY TEAM PLZ ADD SAMSUNG GURU B189 IN LIST |
The Following 3 Users Say Thank You to gunjan1 For This Useful Post: |
09-25-2009, 06:31 | #984 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Heart of Islam Age: 41
Member: 762034 Status: Offline Sonork: 100.1585274 Thanks Meter: 1,448 | KE770 telestra unlock COM4 [VCP0] selected module v1.69 Device: LG-KE770 Checking data, wait... Action: unlock direct unlock Boot ... Press and HOLD Power button now ! s-gold2: C0 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 0089:88B0 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE770_eeprom-static_20090925-101802.B1E.bin reading eeprom-static2... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE770_eeprom-static2_20090925-101802.B1E.bin loading data... data loaded imei: 35030526000000100 reading eeprom-security_35030526000000100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE770_eeprom-security_35030526000000100_20090925-101803.B1E.bin reading eeprom-complete_35030526000000100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE770_eeprom-complete_35030526000000100_20090925-101804.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-complete Writing: eeprom-complete Verifying... Verify result: 01E6 Done probably you need to restore original imei after unlock process Write Done Finished, time used: 22 sec Remove/Install battery now ! |
The Following 3 Users Say Thank You to guljee786 For This Useful Post: |
09-25-2009, 06:48 | #985 (permalink) |
Member: 171512 Status: Offline Thanks Meter: 1,034 | COM4 [VCP0] selected module v2.82 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:F29C:7748 status: FF high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.B325F664.[A8_PCB01_GPRS_MT6226_S01.A909B_YY01_00_1_0T06_0711 .BIN_1C9D8A37].rpl identification#1 detection finished device-id: B325F664 identification#1 protocol ver: 04 ver. sw 1: A8_PCB01_GPRS_MT6226_S01.A909B_YY01_00_1_0T06_0711 .BIN ver. sw 2: A909B_YY01_00_1.0T06_0711, C87562E3 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC257E25082501:2BEA0000000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: EC257E25082501:2BEA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: EC257E25082501:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\A 8_PCB01_GPRS_MT6226_S01.A909B_YY01_00_1_0T06_0711_ _system_log_B325F664_1C9D8A37_20090924-160706.B0X.bin Finished, time used: 151 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following 3 Users Say Thank You to ehsas_ghum For This Useful Post: |
09-26-2009, 09:55 | #986 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Al-Madina Communication Age: 46
Member: 206532 Status: Offline Sonork: 100.1622270 Thanks Meter: 875 | module v1.68 Device: Huawei-T161L Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... sw version: 0 R_T161L_01 A_T161L_09 25 5 H5 5 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-static_20090926-135052.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-security_20090926-135052.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-complete_20090926-135054.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_lock-area_20090926-135101.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 41 sec Remove/Install battery now ! |
The Following 3 Users Say Thank You to alis For This Useful Post: |
09-26-2009, 13:58 | #987 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | @alis Thank you very much for your tries to post so many test reports as possible, but, please, stop to copy/paste old logs again and again. Thank you for your kind support and understanding ! |
09-26-2009, 14:13 | #988 (permalink) |
Member: 171512 Status: Offline Thanks Meter: 1,034 | HK.SUOAL S9+ REPAIR OK ==== log: [9/26/2009 12:45:04 PM] ==== COM4 [VCP0] selected module v2.82 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:C003:0006 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: BOWAY25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W 08_12.BIN ver. sw 2: MAUI.GEMINI.W08.12, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: EC257E25082501:18E59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: EC257E25082501:18E59F00000000 Finalization Done Finished, time used: 39 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
09-26-2009, 16:44 | #989 (permalink) |
No Life Poster Join Date: May 2007 Location: InsidE AndroiD Age: 37
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 474 | k200i successfully done restarting with sim card COM3 [VCP0] selected module v1.35 Device: Sony-Ericsson-K200i "advanced chip detection" active Action: reset settings Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection ... Check connection done Set baud ... 812500 Set baud done Check hardware ... flash: 01227E22212200:92EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb software version: R1AA008 software version: CXC1250827 version flex: CDA102772/1 imei: 35617701164657 Check hardware done Read data ... reading Sony-Ericsson-K200i_35617701164657_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K200i_35617701164657_eeprom_calibration-1_20090926-032133.80E.bin reading Sony-Ericsson-K200i_35617701164657_eeprom_calibration-2... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K200i_35617701164657_eeprom_calibration-2_20090926-032139.80E.bin reading Sony-Ericsson-K200i_35617701164657_ffs... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K200i_35617701164657_ffs_20090926-032300.80E.bin Read data done Check data ... Check data done Write ... flash: 01227E22212200:46237300000000 Erase: ffs Write done Finished, time used: 162 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to azeem781986 For This Useful Post: |
09-26-2009, 16:46 | #990 (permalink) |
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 474 | chinese phone userlock done------ COM3 [VCP0] selected module v2.89 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "user code" unlock method: standard fast Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:BD03:0001 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #02 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #03 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... slowest Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [standard] generation ==================== New firmware detected (v.2.89, database date: 10.08.2009): CT61A_PCB01_GPRS_MT6225_S00.CT61A_V4_5_70NM.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info protocol ver: 04 ver. sw 1: CT61A_PCB01_GPRS_MT6225_S00.CT61A_V4_5_70NM.BIN ver. sw 2: CT61A_V4.5_70nm, 00000000 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 98000300000001:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent detecting psn code area... .................................................. .................................................. .................................................. .................................................. .................................................. ...... psn code area is absent detect device sec info... detection phase #1... . detect device sec info finished detecting ffs/eeprom structure pass 1... ....................... detect standard fat location pass #1... .................................................. .... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs/eeprom detected ok: element #1 Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 98000300000001:18E59F00000000 Backup required data Done Patch required data ... .................................................. .... lock area found Patch required data Done Special operation ... Special operation Done Write ... flash: 98000300000001:18E59F00000000 flash: 98000300000001:18E59F00000000 Write: lock-area-1 Write Done Finalization ... Finalization Done Finished, time used: 243 sec Remove/Install battery now ! |
