10-06-2009, 11:49 | #1036 (permalink) |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | Code: ==== log: [10/6/2009 3:21:02 PM] ==== COM23 [VCP0] selected module v1.66 Device: Zong-A136 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... sw version: PAK-P108A2V1.0.0B01 CMPAK-P108A2B07-En-PK01 g3dBV2.0 Apr 24 2008 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20091006-152328.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20091006-152329.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20091006-152335.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20091006-152348.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 178 sec Remove/Install battery now ! |
The Following User Says Thank You to Shakeel_pattoki For This Useful Post: |
10-06-2009, 11:54 | #1037 (permalink) |
No Life Poster Join Date: Jun 2007 Location: Talk to *** and He Will Listen
Member: 532761 Status: Offline Sonork: 100-1592994 Thanks Meter: 1,104 | T280i easy unlock using great infinity done COM5 [VCP0] selected module v1.37 Device: Sony-Ericsson-T280i "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 89890400040089:89890400000000 flash: Intel ST [def 0080x040000] 32Mb Check hardware done Read data ... reading Sony-Ericsson-T280i_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\t280i Read data done Check data ... Check data done Write ... ........................ flash: 89890400040089:89890400000000 Write: simlock Write done Finished, time used: 214 sec Remove/Install battery now ! |
The Following User Says Thank You to venuno For This Useful Post: |
10-06-2009, 11:57 | #1038 (permalink) |
Member: 437195 Status: Offline Thanks Meter: 1,734 | Code: COM21 [VCP0] selected module v1.66 Device: LG-KG270 Checking data, wait... Action: reset Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .00 ULC2GL ORANGE FR KG275 P16 FL 33 V10b 208-01 JUN 08 2007 +1 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-static_20090820-173231.B1E.bin loading data... data loaded imei: 35558801098831400 reading eeprom-security_35558801098831400... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-security_35558801098831400_20090820-173232.B1E.bin reading eeprom-complete_35558801098831400... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-complete_35558801098831400_20090820-173238.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Write Done Finished, time used: 30 sec Remove/Install battery now ! |
10-06-2009, 13:13 | #1039 (permalink) |
No Life Poster Join Date: Aug 2005 Location: Ena Neray Na Ho Dildar Ve Age: 37
Member: 171512 Status: Offline Thanks Meter: 1,034 | nktel a200 repair ok ==== log: [10/6/2009 3:28:36 PM] ==== COM4 [VCP0] selected module v2.91 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:A403:000A status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #02 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #03 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [enhanced] generation startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.4A3488A7.[N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_ S5LCD_V1_7_1.BIN_3FC2FBBD].rpl ==================== New firmware detected (v.2.91, database date: unknown): N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_ S5LCD_V1_7_1.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished device-id: 4A3488A7 rom info protocol ver: 04 ver. sw 1: N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_ S5LCD_V1_7_1.BIN ver. sw 2: N66_ABROAD_5CDGB_S5LCD_V1.7.1, 42043DC0 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 98000300000001:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detect device sec info... detection phase #1... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 98000300000001:18E59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... ffs formatting... flash: 98000300000001:18E59F00000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\N 66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_S 5LCD_V1_7_1__system_log_4A3488A7_3FC2FBBD_20091006-152925.B0X.bin Finished, time used: 44 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to ehsas_ghum For This Useful Post: |
10-06-2009, 17:56 | #1040 (permalink) |
No Life Poster Join Date: Dec 2005 Location: IN_BATTLE_FIELD.
Member: 214340 Status: Offline Thanks Meter: 906 | N81i_BLUETOOTH_CALIBRATION_DONE_SUCCESSFULLY LOGS COM5 [VCP0] selected module v2.91 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... TYM072720_702_PCB01_GPRS_MT6226_S01.072720_702_V11 25__fullflash_20090927-194039.B0M.bin loaded detected record size adjusted detected record size adjusted detected record size adjusted Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:5441:14D0 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: 072720_702_V1125 Version: Tianyu26_06B_HW 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok 512 byte(s) read 160 byte(s) read reading data #2... 512 byte(s) read writing data... verification... verification Ok Finished, time used: 29 sec Remove/Install battery now ! BR |
The Following User Says Thank You to mobile_hotman For This Useful Post: |
10-07-2009, 06:58 | #1041 (permalink) |
Temporary banned !! Join Date: Jun 2009
Member: 1048290 Status: Offline Thanks Meter: 49 | |^^^^^^^^^^^^^^^^^^^^\ ||\ |__INFINTY IS BEST_| ||´""|""\___ | ...___smart_____! | |___|___|___|) (@!)!(@)**""""""**|(@) (@)******|(@) _-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_ |
The Following User Says Thank You to GSMAAS For This Useful Post: |
10-07-2009, 07:44 | #1042 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Pakistan..
Member: 301242 Status: Offline Thanks Meter: 201 | COM9 [VCP0] selected module v1.70 Device: LG-KP100 Checking data, wait... Action: unlock direct unlock method #2 (Airtel etc.) Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .01 ULC2GL 2008-03-06 1.0 TMO_UK KP100 01 FL 44 V10a 234-30 M Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-static_20091007-114218.B1E.bin loading data... data loaded imei: 35847902899608400 reading eeprom-security_35847902899608400... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-security_35847902899608400_20091007-114218.B1E.bin reading eeprom-complete_35847902xx608400... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_3584790xxx608400_20091007-114220.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-security Writing: eeprom-security probably you need to restore original imei after unlock process Write Done Finished, time used: 20 sec Remove/Install battery now ! |
The Following User Says Thank You to fawad85 For This Useful Post: |
10-07-2009, 09:15 | #1043 (permalink) |
Member: 171512 Status: Offline Thanks Meter: 1,034 | 6300 repair ok COM4 [VCP0] selected module v2.91 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:FD12:FA16 status: FF high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #02 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #03 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [enhanced] generation startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.CFCD0E14.[TEMP26_05C_CARD_PCB01_GPRS_MT6226_S01.MAUI_05C_W06 _16_F2.BIN_895C8C23].rpl rom info detection finished device-id: CFCD0E14 rom info protocol ver: 04 ver. sw 1: TEMP26_05C_CARD_PCB01_GPRS_MT6226_S01.MAUI_05C_W06 _16_F2.BIN ver. sw 2: MAUI.05C.W06.16.F2, DC73A376 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 01227E22202200:29EA0000000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detect device sec info... detection phase #1... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 01227E22202200:29EA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... ffs formatting... flash: 01227E22202200:29EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\T EMP26_05C_CARD_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_ 16_F2__system_log_CFCD0E14_895C8C23_20091007-130229.B0X.bin Finished, time used: 145 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
10-07-2009, 10:21 | #1044 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Quote:
Please, if you still have phone on hands, read full flash from this phone and send full flash backup file to [email protected] | |
10-07-2009, 11:52 | #1045 (permalink) |
No Life Poster Join Date: Jul 2007 Location: In my body
Member: 544160 Status: Offline Sonork: 100.1603100 Thanks Meter: 178 | T33i Repair Done COM4 [VCP0] selected module v2.93 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:A903:0002 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 89881500010001:89881500000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 89881500010001:89881500000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb detecting chip #02 in region #00... flash: 89881500010001:89881500000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb detecting chip #03 in region #00... flash: 89881500010001:89881500000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 89881500010001:89881500000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 89881500010001:89881500000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [standard] generation rom info detection finished rom info protocol ver: 04 ver. sw 1: T1C2O9N_0427_ML_B06.BIN ver. sw 2: T1C2O9N_0427_ML_B06, 00000000 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 89881500010001:89881500000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detect device sec info... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: T1C2O9N_0427_ML_B06__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\T1C2O9N_0427_ML_B 06__ffs_20091006-170406.B0E.bin flash: 89881500010001:89881500000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... ffs formatting... flash: 89881500010001:89881500000000 Finalization Done Finished, time used: 125 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to thushdt For This Useful Post: |
10-07-2009, 11:58 | #1046 (permalink) |
Member: 544160 Status: Offline Sonork: 100.1603100 Thanks Meter: 178 | K915 MP3 MP4 PLAYER Repair Done COM4 [VCP1] selected module v2.93 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read NOR flash Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:05FB:55EF status: FF high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [enhanced] generation startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.085280EB.[U4_PCB01_GPRS_MT6226_S01.UP6226V23B29.BIN_ACECB183].rpl ==================== New firmware detected (v.2.90, database date: unknown): U4_PCB01_GPRS_MT6226_S01.UP6226V23B29.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished device-id: 085280EB rom info protocol ver: 04 ver. sw 1: U4_PCB01_GPRS_MT6226_S01.UP6226V23B29.BIN ver. sw 2: UP6226V23B29, 7C4E1353 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC257E25082501:29EA0000000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detect device sec info... detection phase #1... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: U4_PCB01_GPRS_MT6226_S01.UP6226V23B29__fullflash.. . file saved: D:\PHONE\FLASH\CHINA\K915 MP3 MP4 PLAYER\BACKUP\U4_PCB01_GPRS_MT6226_S01.UP6226V23B2 9__fullflash_20091002-092350.B0M.bin file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\U 4_PCB01_GPRS_MT6226_S01.UP6226V23B29__system_log_0 85280EB_ACECB183_20091002-092454.B0X.bin Finished, time used: 709 sec Remove/Install battery now ! |
10-07-2009, 12:08 | #1047 (permalink) |
Member: 171512 Status: Offline Thanks Meter: 1,034 | imei change china Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6225, E03 Hardware version: 25_GEMINI_HW Software version: BB17N_BLE_CLUB_L8EN_ Software date: 2006.06.14 Barcode: MT012345678901234567 imei: 359986265906682 imei: 135790246811220 imei write method: mode-1 imei write channel: imei #2 for dual sim/mono CPU new imei: 359986265906682 verification Ok Finished, time used: 10 sec Power off phone now ! |
10-07-2009, 12:09 | #1048 (permalink) |
Member: 171512 Status: Offline Thanks Meter: 1,034 | n95 repair ok module v2.91 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:1003:0004 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: M684_SET_NS5_AR7_V3.0RMNNZ Version: HX695_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok building list... done items to clear: 160 warning: wrong packet cs items cleared: 160 of 160 building list... done items remains: 0 Finished, time used: 32 sec Remove/Install battery now ! |
10-07-2009, 12:10 | #1049 (permalink) |
Member: 171512 Status: Offline Thanks Meter: 1,034 | imei change again Action: imei Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6225, E03 Hardware version: 25_GEMINI_HW Software version: BB17N_BLE_CLUB_L8EN_ Software date: 2006.06.14 Barcode: MT012345678901234567 imei: 359986265906682 imei: 135790246811220 imei write method: mode-1 imei write channel: imei #2 for dual sim/mono CPU new imei: 359986265906682 verification Ok Finished, time used: 10 sec Power off phone now ! |
10-07-2009, 12:13 | #1050 (permalink) |
Member: 171512 Status: Offline Thanks Meter: 1,034 | xintel repair imei is ok Action: imei Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6226, E02 Hardware version: M500Z_05C_HW Software version: E506_B15.00.1_26S01" Software date: 2005.04.12 Barcode: MT012345678901234567 imei: 135790246811220 imei write method: mode-1 imei write channel: imei #1 for dual sim/mono CPU new imei: 354580236895457 verification Ok Finished, time used: 5 sec Power off phone now ! |
