04-18-2011, 09:33 | #11071 (permalink) |
Junior Member Join Date: Oct 2007
Member: 612181 Status: Offline Thanks Meter: 1 | Siemens cl75 successfully unlocked by infinity box Device: Siemens-CL75 Checking data, wait... Action: Unlock Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22202200:98E59F00000000 flash: Amd PL127J D 16Mb id: 0000527A Boot Done Set baud... 115200 Set baud Done Check Flash... Check Flash Done Check space... file saved: C:\Program Files\InfinityBox\QModule\backup_eeprom_unlock-1_20110329-174904.21E.bin file saved: C:\Program Files\InfinityBox\QModule\backup_eeprom_unlock-2_20110329-174907.21E.bin Check space Done Check parameters... Check parameters Done Format file system... area-01... area requested/selected: 02/03 Format file system Done Write... Preparing... area requested/selected: 02/03 Finalizing... area requested/selected: 02/03 Write Done Finished Remove/Install battery now ! Time used: 48 sec |
The Following User Says Thank You to Eduman For This Useful Post: |
04-18-2011, 10:14 | #11072 (permalink) | |
No Life Poster Join Date: Aug 2005 Location: Ena Neray Na Ho Dildar Ve Age: 37
Member: 171512 Status: Offline Thanks Meter: 1,034 | nokia n96 flash done thanks Quote:
The Following 3 Users Say Thank You to ehsas_ghum For This Useful Post: |
04-18-2011, 10:51 | #11073 (permalink) |
Product Manager Join Date: Sep 2009 Location: Pakistan Age: 36
Member: 1118710 Status: Offline Sonork: 100.1604414 Thanks Meter: 4,970 | 5130C Dead USB Flashing Done. 5130C Dead USB Flashing Done. Here is The Log registered to: Danish Shafiq Connect phone on selected interface... Core version : 1.18 , Rev : 3.0 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm495__07.95.mcusw PPM : rm495__07.95.ppm_mena_b CNT : rm495__07.95.image_mena_b_red Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! RAP_PUB: 0E20000D2FC789568FFAAFC34AF48C6A87055D44 CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm495__07.95.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT Result: 0000 Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:34 Write : Processing rm495__07.95.mcusw Total 1178 [1178/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:00:57 MCU Write done ===Flashing [PPM]=== Erase : Processing rm495__07.95.ppm_mena_b Found 1 areas to erase Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:01 Write : Processing rm495__07.95.ppm_mena_b Total 404 [404/0/0] blocks to write, writing... TIME : Write time : 00:00:20 PPM Write done ===Flashing [CNT]=== Erase : Processing rm495__07.95.image_mena_b_red Found 2 areas to erase Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT Result: 0000 Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:06:06 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm495__07.95.image_mena_b_red Total 528 [528/0/0] blocks to write, writing... TIME : Write time : 00:00:28 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:11:28 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5130c-2 Software Info: V 07.95 03-02-10 RM-495 (c) Nokia IMEI: 35************* PPM version : V 07.95 03-02-10 RM-495 (c) Nokia MEN Product code: 0586824 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:12:49 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following 2 Users Say Thank You to Danish Shafiq For This Useful Post: |
04-18-2011, 10:59 | #11074 (permalink) |
Member: 1118710 Status: Offline Sonork: 100.1604414 Thanks Meter: 4,970 | 1616 Flashing Done With BESt... 1616 Flashing Done With BESt... Here Is The LOG registered to: Danish Shafiq Connect phone on selected interface... UFS S/N ***** boot - Ok Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Core version : 1.18 , Rev : 3.0 Selected FlashSettings : Manual Files Set for Flashing : MCU : rh125_005.800 PPM : rh125_005.80ia CNT : rh1250_nai05.80ia Infineon flashing... Booting phone now.... Sync Ok , A2 CPU ID : XGOLD , A200341100 Boot Ok , 01 PBL : SE0_091125 F11 Algo Ok , 01 SBL mode Ok SBL : Default_RAM_Bootloader EPP CFG [Bering]... FLASH ID : 0020000000C08800 FLASH ID : ST, M58WR064 Boot Done! ===Flashing [MCU]=== File : rh125_005.800 Image : hw_f11_rh125_r05.800.fls Cert block found, sending.... Cert sent Found 3 region(s) Processing Region 1/3 Erase , Start : 0x00800000 , Len : 0x00210000 Erasing, wait ... Erase done Write , Start : 0x00800000 , Len : 0x00210000 Flashing , wait ... Region flash done Processing Region 2/3 Erase , Start : 0x00C60000 , Len : 0x00208440 Erasing, wait ... Erase done Write , Start : 0x00C60000 , Len : 0x00208440 Flashing , wait ... Region flash done Processing Region 3/3 Erase , Start : 0x00FFC000 , Len : 0x00000040 Erasing, wait ... Erase done Write , Start : 0x00FFC000 , Len : 0x00000040 Flashing , wait ... Region flash done Check : EB6C ===Flashing [PPM]=== File : rh125_005.80ia Image : hw_f11_rh125_005.80ia.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00210000 , Len : 0x001FAB00 Erasing, wait ... Erase done Write , Start : 0x00210000 , Len : 0x001FAB00 Flashing , wait ... Region flash done Check : 2238 ===Flashing [CNT]=== File : rh1250_nai05.80ia Image : hw_f11_rh1250_nai05.80ia.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00EB0000 , Len : 0x0005CC40 Erasing, wait ... Erase done Write , Start : 0x00EB0000 , Len : 0x0005CC40 Flashing , wait ... Region flash done Check : AE98 Flashing done, rebooting... -> Infineon info : Do FullFactory Sets after flashing Flashing Done! Init Service mode... Wait... Afterflash settings... SW ver : V 05.80 06-08-10 RH-125 (c) Nokia IMEI : 35************* PCode : 0588625 Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! All done! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following 3 Users Say Thank You to Danish Shafiq For This Useful Post: |
04-18-2011, 12:14 | #11075 (permalink) |
Junior Member Join Date: Jun 2010
Member: 1333676 Status: Offline Thanks Meter: 0 | Phone Type: RM-561 (Nokia 2700 classic) SW Version: V 09.97 18-06-10 RM-561 (c) Nokia Imei plain: 35691203001766-5 Product Code: 0588457 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! |
04-18-2011, 12:35 | #11076 (permalink) |
Freak Poster Join Date: Mar 2011 Location: m + koti hyd 95
Member: 1532828 Status: Offline Thanks Meter: 77 | Device: Sony-Ericsson-J121i restart problem solved COM105 [VCP0] selected module v1.38 Device: Sony-Ericsson-J121i "advanced chip detection" active Action: reset settings Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection ... Check connection done Set baud ... 406250 Set baud done Check hardware ... flash: 89886200010001:89886200000000 flash: Intel Intel std [def 003Fx010000 0008x002000] 4Mb software version: 1030-000 software version: MLD-5- Check hardware done Read data ... reading Sony-Ericsson-J121i_eeprom_calibration-1... file saved: C:\InfinityBox\HModule\Sony-Ericsson-J121i_eeprom_calibration-1_20110418-170102.6AE.bin reading Sony-Ericsson-J121i_ffs... file saved: C:\InfinityBox\HModule\Sony-Ericsson-J121i_ffs_20110418-170116.6AE.bin Read data done Check data ... Check data done Write ... flash: 89886200010001:89886200000000 Erase: ffs Write done Finished, time used: 32 sec Remove/Install battery now ! |
The Following User Says Thank You to mobile+plus For This Useful Post: |
04-18-2011, 12:45 | #11077 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Nokia C1 01 Flashing OK ( Fail on other Tools ) Nokia C1 01 Flashing OK ( Fail on other Tools ) Quote:
The Following 2 Users Say Thank You to srinibas For This Useful Post: |
04-18-2011, 12:54 | #11078 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Green Forest
Member: 1316000 Status: Offline Sonork: 100.1624093 Thanks Meter: 348 | COM1 [VCP0] selected module v3.26 Action: reset settings ("format ffs") Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:4903:0007 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: MAUI.GEMINI.W08.12.52 Version: HEXING25_GEMINI_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok building list... done items to clear: 131 warning: wrong packet cs items cleared: 119 of 131 building list... done items remains: 0 Finished, time used: 35 sec Remove/Install battery now ! |
The Following User Says Thank You to net.tarik For This Useful Post: |
04-18-2011, 12:54 | #11079 (permalink) |
Member: 1316000 Status: Offline Sonork: 100.1624093 Thanks Meter: 348 | COM1 [VCP0] selected module v3.26 Action: reset settings ("format ffs") Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:4903:0007 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: MAUI.GEMINI.W08.12.45 Version: HEXING25_GEMINI_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok building list... done items to clear: 136 warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs items cleared: 136 of 136 building list... done items remains: 0 Finished, time used: 21 sec Remove/Install battery now ! |
04-18-2011, 12:54 | #11080 (permalink) |
Member: 1316000 Status: Offline Sonork: 100.1624093 Thanks Meter: 348 | COM1 [VCP1] selected module v3.26 Action: reset settings ("format ffs") Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:4903:0007 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: MAUI.GEMINI.W08.12.01 Version: HEXING25_GEMINI_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 35578503006070 connection Ok building list... done items to clear: 136 warning: wrong packet cs items cleared: 136 of 136 building list... done items remains: 0 Finished, time used: 21 sec Remove/Install battery now ! |
04-18-2011, 12:55 | #11081 (permalink) |
Member: 1316000 Status: Offline Sonork: 100.1624093 Thanks Meter: 348 | COM4 selected module v3.29 Action: reset settings ("format ffs") Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:F003:0008 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: M9A_9328_V3.0_0112_1 Version: UNISTAR25_GEMINI_HW ==================== New firmware found (v.3.29, database date: 04.04.2011): M9A_9328_V3.0_0112_1 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== detecting structure #2... 5 11 done 67 byte(s) read imei: 35875303434968 connection Ok building list... done items to clear: 158 warning: wrong packet cs warning: wrong packet cs items cleared: 158 of 158 items remains: 0 Finished, time used: 43 sec Remove/Install battery now ! |
04-18-2011, 12:55 | #11082 (permalink) |
04-18-2011, 12:56 | #11083 (permalink) |
Member: 1316000 Status: Offline Sonork: 100.1624093 Thanks Meter: 348 | COM4 selected module v3.29 Action: reset settings ("format ffs") Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:BB03:0007 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: MWKS_V002.C15.C Version: S825BT.25.SM.BTM detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok building list... done items to clear: 128 items cleared: 128 of 128 building list... done items remains: 0 Finished, time used: 27 sec Remove/Install battery now ! |
04-18-2011, 12:56 | #11084 (permalink) |
Member: 1316000 Status: Offline Sonork: 100.1624093 Thanks Meter: 348 | COM4 selected module v3.29 Action: reset settings ("format ffs") Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:BB03:0007 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: MWKS_V002.C15.C Version: S825BT.25.SM.BTM detecting structure #2... 0 done 44 byte(s) read imei: 35755600005785 connection Ok building list... done items to clear: 140 items cleared: 81 of 140 building list... done items remains: 0 Finished, time used: 1 min 0 sec Remove/Install battery now ! |
04-18-2011, 12:57 | #11085 (permalink) |
Member: 1316000 Status: Offline Sonork: 100.1624093 Thanks Meter: 348 | COM1 [VCP0] selected module v3.26 Action: reset settings ("format ffs") Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:4903:0007 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: A008_4_V248 Version: HEXING25_GEMINI_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 35195503045816 connection Ok building list... done items to clear: 139 warning: wrong packet cs items cleared: 139 of 139 warning: wrong packet cs building list... done items remains: 0 Finished, time used: 20 sec Remove/Install battery now ! |
