09-14-2008, 22:16 | #62 (permalink) |
Freak Poster Join Date: Jul 2008
Member: 814085 Status: Offline Sonork: cangens Thanks Meter: 27 | Motorola w370 tracfone unlock w375_0.0.80_Main_H80S_K2_1175254689.34M.bin = MAIN w375_0.0.80_LP_A06_Cn.34P.bin = Language Pack W375_Flex_A4_002_retail.34F.bin = FLEX I could help with these FLASH because I do not let A bracket ME or if someone's got to help me grace.- THANKS CANGENS GUATEMALA |
12-13-2008, 12:32 | #63 (permalink) | |
Freak Poster Join Date: Mar 2006 Location: 03218554185 Age: 43
Member: 243881 Status: Offline Thanks Meter: 68 | Quote:
03-11-2009, 08:47 | #68 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Philippines
Member: 243127 Status: Offline Thanks Meter: 35 | sir kasamiko where could i find that firmware? coz when I enter in support site it is only w370_6.9.75_FLEX_A0_00I_TracFone.34F w370_6.9.75_LP_NA1_En_Es_Pt.34P w370_6.9.75_Main_H80S_1172910612_ver2.34M is in there... thanks! |
03-11-2009, 09:01 | #69 (permalink) |
Registered User Join Date: Aug 2007 Location: bohol philippines Age: 42
Member: 572549 Status: Offline Thanks Meter: 175 | @rhyks just flash with this firmware W375 w375_0.0.80_Main_H80S_K2_1175254689.34M.bin = MAIN w375_0.0.80_LP_A06_Cn.34P.bin = Language Pack W375_Flex_A4_002_retail.34F.bin = FLEX |
03-13-2009, 04:57 | #70 (permalink) | |
No Life Poster Join Date: Oct 2003 Location: Philippines
Member: 42604 Status: Offline Thanks Meter: 187 | Quote:
Because you're on W370 folder....it is located on W375 folder.. looks like this ------>Motorola / W375 / 0.0.80 / Flex file can be found here ------> Motorola / W375 / flex_original / the one i used is first on the list... goodluck... | |
The Following User Says Thank You to kasamiko For This Useful Post: |
03-14-2009, 23:57 | #71 (permalink) |
Freak Poster Join Date: Dec 2007
Member: 642071 Status: Offline Thanks Meter: 54 | COM3 [VCP0] selected "smart write" active Action: flash Write: Firmware Write: Language Pack Write: Flex Skip: Eeprom Device: W370 Checking data, wait... Connect... Press and HOLD Power button... rom version: 0411 Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 921600 Set Baud Done Check Flash-1... SW version: 6.9.75 HW version: MOTOROLA_H80S LP ver: 6975_NA1 Flex ver: FLEX_A0_00I cpu id: 08B6 imei eeprom: 3545130126782017 required SW version: 6.9.75 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _35451301267820_20090314-173849.34E.bin Check Flash-2 Done Write... Writing: Firmware Writing: Language Pack Writing: Flex Write Done Finished, time used: 316 sec Remove/Install battery now ! Done without any problem |
The Following User Says Thank You to Dwight07 For This Useful Post: |
03-20-2009, 21:51 | #74 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
04-14-2009, 06:11 | #75 (permalink) |
Freak Poster Join Date: Sep 2007 Location: GSMPHILIPPINES
Member: 580978 Status: Offline Thanks Meter: 35 | badly needed W375_Flex_A4_002_retail.34F.bin = FLEX w375_0.0.80_Main_H80S_K2_1175254689.34M.bin w375_0.0.80_LP_A06_Cn.34P.bin w375_0.0.80_LP_001_Fr_De_It.34P.bin this is what i download to suport instead of this w375_0.0.80_Main_H80S_K2_1175254689.34M.bin = MAIN w375_0.0.80_LP_A06_Cn.34P.bin = Language Pack W375_Flex_A4_002_retail.34F.bin = FLEX i reealy need this flex version W375_Flex_A4_002_retail.34F.bin = FLEX its missing in support i have w370 flash to w375 but ive got no signal |
W370 Tracfone Unlock / Flash | bigmac1204 | Scout | 9 | 07-14-2010 07:47 |
>> T349 successfully unlock << | jhepoy_org | UST Pro II | 7 | 09-02-2009 08:14 |
W370 tracfone unlock succes using smart-clip | maxieboy | Smart-Clip | 10 | 09-05-2008 07:10 |
W370 TracFone Unlock Success | Orange_Dominica | Smart-Clip | 12 | 08-12-2008 12:34 |
problem unlocking w370 tracfone | wakuwaku | Smart-Clip | 7 | 08-04-2008 10:06 |
