04-27-2005, 19:54 | #20 (permalink) | |
No Life Poster Join Date: Nov 2004
Member: 91102 Status: Offline Thanks Meter: 34 | Quote:
ihave installed the drivers before i plugged in due to the instructions then i plugg infinity box in this is all i get in device manager 1. e-gate Virtual Reader Enumerators -> e-gate Virtual Reader Enumerator 2. Smart card readers -> e-gate USB Smart card reader 3. e-gate USB Smart Cards -> e-gate USB Smart Card but i can't see anywhere INFINITY USB SERIAL PORT THEN I DON'T UNDERSTAND THIS PART 3. Insert Cable and select drivers from folder: Program Files\InfinityBox\Drivers\Cable WHAT CABLE DO I NEED TO PLUGG IN? BR | |
04-27-2005, 19:58 | #21 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello ! Please, contact to [email protected] B.R. InfinitySupport Quote:
04-27-2005, 20:20 | #22 (permalink) | |
AND NOW FROM HERE BACK TO THERE I DON'T UNDERSTAND WHAT IS GOING ON ALL DAY I COULDN'T UNLOCK ONE X300 I HAVE DONE EVERYTHING DUE TO INSTALATION GUIDE EXTRACTED ALL THE LATEST UPDATES IN C/PROGRAMFILES/INFINTYBOX/PAN I CAN OPEN THE SOFT USING COM 1 DEVICE READY BUT WHEN IT COMES TO UNLOCK IT DOESN'T DETECT PHONE USING A COM CABLE WITH FOUR METAL PINS AS SHOWN IN THIS THREAD BUT KEEP PRESSING POWER BUTTON NOTHING HAPPENS BR | |
04-27-2005, 22:16 | #23 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello ! Please, follow the next steps to check what is wrong: 1. Double check, what COM-port you use. If you use ordinary COM-port cable and if you connected it to PC back side then it can be that you connected cable to COM-2. Please, try to select COM-1 or COM-2 and try to make unlock again. 2. Pls, check attached pictures (connector modifications) in this thread. It can be that connector not so good fit into phone. 3. If you have any other phone (f.e. A100/G50/G70), try to make unlock for any of these models. If you CAN work with any of these phones, but can't work with X300 then double check item 2. If you CAN'T work with any of these models, then check item 1. 4. If you can start software and you can see dongle serial number, this means that you have installed all drivers Ok, so don't need to uninstall/install anything again. 5. If you still have problems, then send file: Log_GD55_G5x_G70_A100_X300.txt to this mail: InfinityHelp at yahoo.com.hk You can find this file in the same folder where software located. Then we can try to check what is wrong. B.R. InfinitySupport Quote:
12-10-2005, 12:30 | #24 (permalink) | |
No Life Poster Join Date: Sep 2004 Age: 46
Member: 82155 Status: Offline Thanks Meter: 33 | Quote:
12-10-2005, 13:49 | #25 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, You can flash dead x300 w/o problems. Procedure is the same as ordinary. Just connect cable, press software "Flash" button and press phone power button. |
03-18-2006, 13:52 | #27 (permalink) | |
you can see all pinouts in support area "Cables/Pinouts" section | |
04-02-2006, 18:10 | #28 (permalink) |
No Life Poster Join Date: Oct 2003 Age: 43
Member: 40602 Status: Offline Thanks Meter: 118 | @InfinitySupport I have problems connecting my X300 with infinity, can i know what is the best baud rate setting is it 115200, 230400, 460800, or slowest and what is the best setting for communication speed calibration bar is it in the beginning, middle or last. Also if i tick Auto my Comport will change to Com x VCPO, can i know what this means? Its very hard to communicte. I plug the G50 connector in and leave some space so that when i press and hold Power button its RX and TX LED will on. I just try to reset setting on this X300. Any help is really appreciated. Thanks br, s1emens |
04-02-2006, 19:19 | #29 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, Baudrate: 115200 Com port selection: when you tick on "auto" box you will see com ports that really exist in your system - software show only available ports and internal system port names (like "VCP0"). As about connection problem: pls, check "FAQ" thread. you will see inf about X300 communication problem at 1st page (with picture how to adjust connector to make it more good for X300). in most cases need to cut rubber around metal pin to allow connector fit in X300 completely. |
"X300 Phone lock Code" PLZ HELP | meisam | JAF Xtras | 10 | 05-18-2007 22:38 |
Mw30260 display "Parameter problem"??? | colin42100 | Infineon C16X M51 & ARM7 M52 BASED | 15 | 07-14-2004 18:51 |
"ufs dct3 problem" | farry | UFS2 + UFS3-Tornadoflasher | 3 | 02-02-2004 18:41 |
a200 "lcd problem" | Moosani | Samsung Hardware Repair | 0 | 04-06-2003 00:00 |
"another sl45 problem" | farry | x1x to x45/x50 | 6 | 08-16-2002 08:56 |
