04-27-2006, 21:31 | #32 (permalink) | |
I can't beleive that after flashing X300 with files from support area your phone lost network. 1. check this link: http://forum.gsmhosting.com/vbb/show...71&postcount=8 2. check imei 3. check "Documentation" folder for instruction | |
04-28-2006, 05:49 | #35 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Just look in folder with software. You will see folder with name "Documentation". In this folder you will see the next instruction: HOW TO repair "No network" and "Bad Imei" for A100/A101/A102 after bad unlock/flashing. 1. Make sure you have checked "Backup" options in "Settings" page. 2. Flash phone with latest firmware 027 (all parts: MAIN+MAP+LP) 3. Go to "Flash" page and select area "EEPROM". 4. Select first "A100_Repair_EEP" file from "EEPROM_REPAIR" folder. 5. Flash it into phone 6. If phone become locked after flashing, use ordinary "Unlock" procedure to rebuild security area. 7. Test phone (Network, Imei, charging). 8. If phone works not good, then repeat from step 4 with other "A100_Repair_EEP" file. X300 repair procedure is the same. Just select X300 repair files. |
02-08-2007, 17:59 | #36 (permalink) |
No Life Poster Join Date: Nov 2005 Location: USA
Member: 197538 Status: Offline Thanks Meter: 97 | Hi infinity team I saw your pic ..regarding correct com ports ... Mine does not say Infinity USB to serial COM5 instead it says USb to Serial Com 5 I am just worried wether this is correct or not ,, becuase todate i have not managed to use infinity since December ,,, Ofcourse i got a few Panasonics and each time i tried witht the supplied cable it didnt work .. now i wonder wether it is this problem or stg else Is USb to Serial ok or it needs to say Infinity USB to serial and if so where r the USB to serial drivers ,? Thanks Mike |
02-08-2007, 20:09 | #37 (permalink) | |
"USB to Serial" port is Ok. If you see this port in DeviceManager this means that drivers installed Ok. anyway, drivers here: http://www.infinity-box.com/download/index.php | |
03-23-2007, 00:58 | #38 (permalink) |
Member: 197538 Status: Offline Thanks Meter: 97 | hi I have X300 when program says ,, press power switch phone turns on instead of booting and if i remove out a lil bit ,,phone doesnt turn on but both blue light comer\s on and green light flickering fast ,,,, what cud be the problem ,,,, i have X300 saying phone locked ,,, user code entered i think too many times ,,,not sure though ,,, have always had problem with this phones using G50 cable ,,,, please help me here ..have read the forum but wierd thngs keep happening sometimes when cable inserted phone starts vibrating or not booting or phone turns on at power key press ,.,, thnx mike |
03-23-2007, 01:16 | #39 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! some old panasonic models really acts strange with inserted cable. sometimes light goes on, sometimes vibrate. This is not infinity fault. This is reaction of phone hardware to cable Tx. Rx idle state levels. if you cant boot it by Holding power button then try to remove and put back battery. Sometimes this works like pressing button. Or try insert battery while holding pressed Power botton Last edited by InfinityHelp; 03-23-2007 at 02:00. |
03-30-2007, 12:03 | #40 (permalink) |
Freak Poster Join Date: Apr 2003 Location: PORTUGAL Age: 73
Member: 27323 Status: Offline Thanks Meter: 8 | Hello, Problem solved whith 1 X300 by this way: In the back of infinitybox I put the switch "off" and connected to com port, and in front, I coonected the G50 cable (I cuted rubber around metal pin to allow connector fit in X300 completely), on RJ45 right side and the switch, on FBUS! UNLOCKED!!!!! I hope that can help somebody! |
10-25-2007, 14:07 | #42 (permalink) | |
yes, my congratulations, it's exactly the thread about box com port problems ! Please, read here about fast solution for your problem: http:///vbb/showthread.php?t=342807 | |
12-04-2007, 15:50 | #43 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 237256 Status: Offline Thanks Meter: 91 | My infinity box is still not detecting connected phone. I have followed all installation instructions as given by IHelper but all to no avail. What is the next step. My email address is [email protected] |
12-04-2007, 16:06 | #44 (permalink) | |
Anyway, what to do next (first): run infinity-Box Shell, select mopdel Pana X300 and see correct cable information, also you will see PICTURES how to modify cable to make it completely good for Pana-X300. | |
01-03-2008, 20:13 | #45 (permalink) | |
No Life Poster Join Date: Sep 2006
Member: 343326 Status: Offline Thanks Meter: 1,463 | Quote:
I too same problem . . . . . . . . I just unlock KG 110 phone and this time i can't unlock the Moto C139 I try to unlock this phone last 4 day's but i can't do that........... WHY....?? Wrere r u infinity team why can't box detect C139 phone. | |
"X300 Phone lock Code" PLZ HELP | meisam | JAF Xtras | 10 | 05-18-2007 22:38 |
Mw30260 display "Parameter problem"??? | colin42100 | Infineon C16X M51 & ARM7 M52 BASED | 15 | 07-14-2004 18:51 |
"ufs dct3 problem" | farry | UFS2 + UFS3-Tornadoflasher | 3 | 02-02-2004 18:41 |
a200 "lcd problem" | Moosani | Samsung Hardware Repair | 0 | 04-06-2003 00:00 |
"another sl45 problem" | farry | x1x to x45/x50 | 6 | 08-16-2002 08:56 |
