01-09-2010, 16:04 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: india
Member: 368923 Status: Offline Thanks Meter: 85 | zte x-761 dead with other box ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_ BFFA108_En_Fr_Es.B0M ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z3_PT_ BFFA104_Vodafone-Indie_En_Pt.B0M ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_ BFFA108_En_Fr_Es_Vodafone-Indie.B0M ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_ BFFA107_Vodafone-Indie_En_Fr_Es.B0M |
01-09-2010, 16:41 | #2 (permalink) |
Member: 368923 Status: Offline Thanks Meter: 85 | i also flashed the set again with this file , but set is still dead. pls help me infinity team . ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_ BFFA105_En_Fr_Es.B0M COM5 selected module v3.00 Device: ZTE-X761 Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active "format ffs" active write: Firmware ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_ BFFA105_En_Fr_Es.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:F303:0002 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.340D7 535.[ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_BFFA1 08.BIN_D3155415].rpl rom info detection finished device-id: 340D7535 rom info ver: 04 sw version: ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_BFFA1 08.BIN project-id: X761_Z2_SF_BFFA108, 155415D3 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [enhanced] generation TCL-ID is absent ffs/eeprom address assigned: 00E00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent rom info relocation detected startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_ BFFA108__system_log_340D7535_D3155415_20100109-205813.B0X.bin Area: Firmware flash: EC257E25082501:18E59F00000000 Write: Firmware sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... ffs formatting... flash: EC257E25082501:18E59F00000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_ BFFA108__system_log_340D7535_D3155415_20100109-210757.B0X.bin Finished, time used: 10 min 16 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
01-09-2010, 19:47 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, What do you mean "dead" ? This phone can not be killed permanently. If you have flashed it with file from support area and phone can not power-on you have to check phone hardware. |
01-10-2010, 07:10 | #4 (permalink) |
Member: 368923 Status: Offline Thanks Meter: 85 | sir , its a brand new phone .nothing hardware is damaged to the set . i have tried almost every flash file on the support , but set is still dead. pls help me . br , sunnny |
01-10-2010, 08:12 | #5 (permalink) |
No Life Poster Join Date: Jul 2009 Location: philippines now here in U.A.E Age: 38
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | try with latest firmware by the way if the phone complete but not power i mean we need latest firmware you flash den pos here logs |
zte gx 761 dead while flashing | neeraj1st | Infinity-Box | 24 | 02-25-2012 11:19 |
zte gx 761 dead after complete formate | neeraj1st | Infinity-Box | 5 | 08-20-2010 16:11 |
X760 dead by other box repaired with Infinity!!! | jepetu | Infinity-Box | 1 | 08-05-2009 22:21 |
How does PadFinder work with other boxes like Infinity, Furious, ET-box etc.? | Multi-box TEAM | PadFinder box | 49 | 11-21-2008 10:39 |
Philips 855 dead after flash with other box | vladimik | Multi-Box | 13 | 02-19-2008 03:01 |
