Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
06-08-2021, 22:53 | #2 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | Post original device PID, model, number, etc. (HH40, HH41, HH41V ... etc.) p.s. You dont have active profile. Try to make one, with correct APN, user/password, etc. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
06-10-2021, 15:29 | #3 (permalink) | |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | For info Quote:
06-16-2021, 18:11 | #4 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | I already sent you tool, instructions few days ago, Have you even tried it ? There is service manual in archive, Inside you can read how to do fw update. Dont repeat useless posts, just open your eyes. B r Alex
The Following 4 Users Say Thank You to Brka For This Useful Post: |
06-16-2021, 18:27 | #5 (permalink) | |
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | thanks for support Quote:
06-16-2021, 18:45 | #6 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | If the update tool cant detect it, probably not. There are no l3 or l4 documents, and no mention of dead devices. However, try holding reset button when insert power cable, maybe tool will detect it. B r Alex
06-16-2021, 18:52 | #8 (permalink) | |
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | Quote:
the problem: wifi not appear only cable Lan can connect to internet, when i try to flash he says that the ip change and after flash tool cannot connect Last edited by Brka; 11-12-2021 at 18:11. Reason: merged posts | |
The Following User Says Thank You to ghacks For This Useful Post: |
06-22-2021, 15:12 | #9 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | Quote:
there is no L3 or L4 documents, as i already told you. If device can not connect (go to flash mode), then is either Hardware Issue or Hard-bricked. So far there is not known method for repair. (except visiting authorized service center and board swap) b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
06-23-2021, 14:59 | #10 (permalink) |
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | thanks for help yes thanks for help you i think no solution for that i already try to look at mainboard and Heat some IC same problem nothing result |
09-17-2021, 18:02 | #12 (permalink) | |
b.r. Alex
11-12-2021, 17:01 | #14 (permalink) | |
Junior Member Join Date: Oct 2015
Member: 2469220 Status: Offline Thanks Meter: 0 | Quote:
Hello sir, I have the same problem, can you send me the tools so I can solve the problem, i need to flash the firmware.. my model router is HH41nh Hi sir This is The information. Nombre del dispositivo: HUB41 IMEI: 014993002291698 IMSI: 370012007127868 Mi número: 18091163476 Versión de software: HH41_NK_02.00_16 Versión de módem: HH41_NK_02.00_16 Dirección MAC: 88:9e:33:82:45:78 PID HH41NH-2BAVO2-1 Last edited by Brka; 11-12-2021 at 18:09. Reason: added info | |
11-12-2021, 18:12 | #15 (permalink) | |
b.r. Alex
The Following User Says Thank You to Brka For This Useful Post: |
