10-22-2007, 14:29 | #1 (permalink) |
Major Poster Join Date: Sep 2006
Member: 341849 Status: Offline Thanks Meter: 3 | After unlock 8600 no 3,6,9 button |
10-22-2007, 14:43 | #3 (permalink) |
Member: 341849 Status: Offline Thanks Meter: 3 | Yes, it was ok becauwse # not working either and this was used to check software version b4 unlocking!! Have check ribbon and connector and all seem to be ok with no damage! Regards |
10-22-2007, 14:44 | #4 (permalink) |
Member: 341849 Status: Offline Thanks Meter: 3 | Yes, it was ok because # not working either and this was used to check software version b4 unlocking!! Have check ribbon and connector and all seem to be ok with no damage! Regards |
10-22-2007, 21:59 | #9 (permalink) |
Freak Poster Join Date: Jul 2002 Location: Manchester, UK
Member: 13975 Status: Offline Thanks Meter: 7 | Open th ephone back up, check you didnt leave any fingerprints on the ics, intenral shieldings/flex connectors, and rebuild it. Send too the nearest repair centre and hopefully they will fix it. |
Nokia E71 keypad problem.. Buttons 3,6,9 and menu is not working | desi0067 | Nokia Hardware & Hardware Repair | 8 | 10-20-2013 14:39 |
Water damage W200 where the button 3,6,9 have other function then it should solution. | reactos | Sony Ericsson Hardware Repair | 1 | 04-16-2008 22:16 |
8310 Key 3,6,9,# not work | NuengEve | Nokia Hardware & Hardware Repair | 7 | 04-27-2005 10:05 |
a52-3,6,9 keys problem | TELE-MEDIA | E-Gold Based Phones | 3 | 01-16-2005 22:14 |
sagem 3026 keys 3,6,9,# blocked soft? | george gsm | Infineon C16X M51 & ARM7 M52 BASED | 0 | 08-14-2002 21:22 |
