03-08-2006, 21:44 | #1 (permalink) |
Product Supporter Join Date: Sep 2004 Age: 39
Member: 81703 Status: Offline Thanks Meter: 1,332 | Problem with 6230i... Boot... ASIC ID: 1052 TIKU BT2 te_2nd.fia te_amd.fia Configuration Info (9F): Number of Flashes: 4 00000000: Samsung, 00EC 22F8 0000 0011, 10 02000000: Samsung, 00EC 0035 0000 0000, 9 04000000: NotUsed, 0000 0100 0000 0000, 0 06000000: NotUsed, 0000 0100 0000 0000, 0 ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5 Erase[15.56 MB]... erasing region [00000000 to 0000FFFF] erasing region [00010000 to 009FFFFF] erasing region [00A00000 to 00B3FFFF] erasing region [00B60000 to 00FAFFFF] in 114.73s Flash[10.15 MB]...in 37.64s * * Processed file in 160.95 seconds Processing File: rm72_73_110E_03.70.ucp_CTV_ES Boot... ASIC ID: 1052 TIKU BT2 te_2nd.fia te_essr.fia Configuration Info (9F): Number of Flashes: 4 00000000: Samsung, 00EC 22F8 0000 0011, 10 02000000: Samsung, 00EC 0035 0000 0000, 9 04000000: NotUsed, 0000 0100 0000 0000, 0 06000000: NotUsed, 0000 0100 0000 0000, 0 ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5 Erase[0.00 MB]... in 5.97s Flash[3.97 MB]...in 19.67s * * Processed file in 35.42 seconds Extract content...fail Processing File: rm72_73_110E_03.70C Boot... ASIC ID: 1052 TIKU BT2 te_2nd.fia te_essr.fia Configuration Info (9F): Number of Flashes: 4 00000000: Samsung, 00EC 22F8 0000 0011, 10 02000000: Samsung, 00EC 0035 0000 0000, 9 04000000: NotUsed, 0000 0100 0000 0000, 0 06000000: NotUsed, 0000 0100 0000 0000, 0 ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5 Erase[0.00 MB]... in 1.31s Flash[4.48 MB]...in 23.73s * * Processed file in 34.84 seconds * * * Phone flashing done in 4:10 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... Factory Default Settings...Fail I think that this could happen if the flash it's not well solder and it should be applied some hot there?Or this error is because of new hardware in 6230i? Thanks in advance Griffin Team |
03-09-2006, 08:23 | #3 (permalink) | |
Freak Poster Join Date: Apr 2003 Location: LT
Member: 27078 Status: Offline Thanks Meter: 1 | Quote:
SW version 3.70, with which you flashed your phone supports both hardware types - the old one and the new one, in your case it's ok, so you must seek another ways, maybe try to Disable VPP. | |
03-09-2006, 16:30 | #4 (permalink) |
Member: 81703 Status: Offline Thanks Meter: 1,332 | I tried Garick and was impossible. Tamer_Elhosary, I tried changing PPM and CNT to M instead of E and got the same... Should I change the MCU too? I tried reading info but MTBox becomes a bit crazy and couldn't load it by using ini file. Thanks to both of you for your help BR Luskao |
03-10-2006, 22:05 | #5 (permalink) |
Insane Poster Join Date: Jan 2006 Location: PALESTINE
Member: 225184 Status: Offline Thanks Meter: 0 | the same problems as to me but my phone is made by Germany use this file (RM-72_dp_v_102[1].0_mcuswM_03.62) which phone is made by germany or other europe country. mcu rm72_73_11003.620 ppm rm72_73_110M_03.62c cnt rm72_73_110M_03.62.ucp_c and use this file(RM-72_dp_v_102[1].0_mcuswE_03.62) which phone is made by nokia or hunghira. best regards br |
Problem with 6230i noise and scratch | maciekmm | Nokia Hardware & Hardware Repair | 24 | 07-16-2010 12:17 |
Problem with 6230i, need advice | Trier | Nokia Digital Core Technology 4 ( DCT-4 ) | 7 | 07-09-2006 13:42 |
Connect Problem with 6230i | Xonic | UFS2 + UFS3-Tornadoflasher | 5 | 04-03-2006 05:56 |
Problem with 6230i Flashing useing UFS3 1.3L | alianu | UFS2 + UFS3-Tornadoflasher | 0 | 09-09-2005 19:31 |
